Hard drive coolers...
Discussion in 'Overclocking, Cooling & Modding' started by lung, Jul 4, 2003.
  1. goldfries
    goldfries www.goldfries.com
    you can try modifying your case panels to hold 2 small fans. :)
  2. Brian
    Brian Newbie
    if you can arrange it to blow air upon the HD, then i don't think you'll need a HD cooler
  3. lung
    lung Just Started
    So r u guys saying that all 7200rpm hard disks should have a cooler or a fan blowing on it? Mine's a Maxtor and it's running at 7200rpm...
    And how do I find out at how many Celcius degrees my hard disk is currently running at? :roll:
  4. Brian
    Brian Newbie
    no, but we're saying that the hd will last longer only. try MBM5 or speedfan to see whether you hd supports reading temps
  5. lung
    lung Just Started
    Err... Is that hardware or software? :mrgreen:
  6. Brian
    Brian Newbie
    FREE software :p :mrgreen:
    if hardware, i'll say go buy bla bla bla
  7. goldfries
    lung. not all hard disks comes with onboard temp probe.
    another software you can use is ActiveSMART.
  8. Chai
    Especially WD harddisks. No monitoring.
    My bro's Deathstar died. It doesn't have any cooling. That could be the reason why it died.
  9. lung
    lung Just Started
    So do you think my Maxtor will have an onboard temp probe? How do I find out...
  10. goldfries
    erm. depends on which model la
    the ones i used for review, one has and one doesn't. some new HDD don't have, i heard WD don't have.
    http://www.ariolic.com
    go there download ActiveSMART
    if your HDD has temp probe inside, it will state the temperature.
