help install 64bit OS on foxconn motherboard
Discussion in 'BIOS Optimization Guide (BOG)' started by dohp, Sep 1, 2015.
  1. dohp
    dohp Newbie
    Hi everyone I am hoping you can help me set up a clean install of windows 10 or 8.1 64 bit edition on my 945P7AD motherboard 3.2 intel pentium processor 4gb based system. I have tried several versions of 64 bit OS and all of them fail to start properly after instal but 32 bit versions work without problems. This is a brand new motherboard (bought as a replacement for a failed one). I am hoping that someone on here can talk me through what I need to do in the bios to get this to work - cheers - Dave
  2. zy
    zy zynine.com Staff Member
    Did you check if you have the latest BIOS?
  3. Adrian Wong
    You should also check the BIOS to make sure ACPI and AHCI are enabled.
