Hey Guys, I currently have a ATI 9800pro (128) but i have upgraded my desktop....currently it doesnt have any AGP slots so i must upgrade my card... Ive been looking at 6800gs and/or 7600gt Is it wrong for me to assume that the 7600gt is better then the 6800 based on the newer series model? Im looking to get a good card for about 200-220$US Anyone have suggestions on which one is better...if not a totally different card? Also..... Would it be better to buy two cards for 250US and have them run SLI....or wiser to buy 1 card for 250US? Hows the performance differences?
1 high-end card is generally more worthwhile than 2 for the same price. I've got a 6800GS and it's great but for around the same price the 7600GT is slightly better.
chai do you have review for 7600gt with x800 gto2 ? these 2 cards are in the same price range jsut wonder how different those 2 can be.
System Specs: Processor Intel Pentium 4 3 GHz Chipset Intel 915G Express Installed Memory 1000 MB (DDR SDRAM) Motherboard Bus Speed 800 MHz Video Output Interface PCI Express Supported RAM Speeds 400 MHz Installed Cache Memory 1 MB Thats the best i can do while at work.....Its a nice machine.. I was looking at the BFG 7600GT
Realized today that my PSU says 310WAT MAX on it.... 7600GT suggests 350watts... Do i have to upgrade or do you think it will be OK?
Well, I would recommend you upgrading to a better one. What brand is it? Enermax and Fotran Source are good cheap choices.
