how to convert to ntfs
Discussion in 'General Software' started by luqman, Jan 3, 2006.
  1. luqman
    luqman Newbie
    ok i have an xp running file aloction system how do i change it to NTFS. i used to have an 98SE but i upgraded it to xp pro. and now am wondering how to change the file system to NT? :?:
  2. zy
    zy zynine.com Staff Member
    run:
    convert /FS:NTFS
  3. McTavish
    McTavish Newbie
    Open the command prompt in XP and type convert c: /fs:ntfs that’s assuming your XP sees itself as C: if not change it to the appropriate drive letter.
    You will get a message telling you basically it can’t do the conversion with Windows running and would you like to do it on next reboot.
  4. luqman
    luqman Newbie
    no off
    no offense macravish but zy has an easier method :mrgreen:
  5. luqman
    luqman Newbie
    damn
    it needs the volume lable damn!!!! i don't have it!!!!! :cry: :cry: :cry: :cry:
  6. McTavish
    McTavish Newbie
    You’ll see what your Volume Label is under the icon for the drive in My Computer.
    Typically is will say Local Disk (C:) and this actually means that no volume label was assigned. If you have renamed it to, for example – XPpro (C:) – then the volume label is ‘XPpro’.
    If no volume label has been assigned then just press Enter when you get asked for it.
    1 person likes this.
  7. peaz
    just do a DIR C: and you'll get the volume label
    If you don't have any and want to set one, then set one using "label <name>" on the command line.
  8. luqman
    luqman Newbie
    thank u thank u thank u!!!!! :dance: :dance: :clap: :clap: :clap: it will take place next time the system restarts!!!!
  9. castaneda
    castaneda Newbie
    I use SystemCommander 7 - it's like the manager which allows to have several OS's on your PC... it can perform lots of operations with partitions... Looks like Windows (i mean interface) :cool:
  10. ZuePhok
    ZuePhok Just Started
    i suggest a clean reformat.
    there are a few limitation if you convert from FAT32
  11. Dashken
    Dashken Administrator!
    Wow... digging again. :faint:
