Hi there, I would like to ask if anyone knows how to set up password for wireless connection? There's WEP and WPA for available in the Wireless Setting... What is the differents between both of them?
WPA is a more secure form of wireless encryption. WEP is the more common, but weaker wireless encryption. You need to select either one, before you can set the password.
Well, enable it first by ticking the checkbox next to WPA in the screen above. Thereafter, you should be show additional options. You will need to screenshot those, of course.
Hmm.. I don't have much experience with WPA, but I would select PSK string and put in a password of my choice, preferably a complex mix of numbers and letters like f02n4k
Nowadays, people choose WPA, because you don't have to remmember the long keys of WEP. But not all devices suppport WEP, especially those first generation wireless device and those 802.11b ones. If you need additional security, you can opt for Mac Filtering where your modem only allows WLAN cards which have the specific MAC address to access the network.
