How about it? Anyone else using these sticks? I'm interested in comparing my settings to whatever you happen to be running. My settings (out of everest simple copy/paste): Code: Memory Timings CAS Latency (CL) 5T RAS To CAS Delay (tRCD) 5T RAS Precharge (tRP) 5T RAS Active Time (tRAS) 15T Row Refresh Cycle Time (tRFC) 52T Command Rate (CR) 2T RAS To RAS Delay (tRRD) 3T Write Recovery Time (tWR) 14T Read To Read Delay (tRTR) Same Rank: 4T, Different Rank: 6T Read To Write Delay (tRTW) 8T Write To Read Delay (tWTR) Same Rank: 11T, Different Rank: 5T Write To Write Delay (tWTW) Same Rank: 4T, Different Rank: 6T Read To Precharge Delay (tRTP) 5T Write To Precharge Delay (tWTP) 14T Precharge To Precharge Delay (tPTP) 1T Refresh Period (tREF) 2600T DRAM Read ODT 3T DRAM Write ODT 6T MCH Read ODT 8T Performance Level 6 Read Delay Phase Adjust +9T DIMM1 Clock Fine Delay 13T DIMM2 Clock Fine Delay 4T DIMM3 Clock Fine Delay 12T DIMM4 Clock Fine Delay 3T
Not running this ram Graysky but my OCZ ReaperX PC8500 looks very similar in timings wish I had 8G though While playing around and not sure if this applies to your ram or not but its always fun to experiment I run this @ DDR400 @522 usually. 5-5-5-18 works fine (OCZ spec) 5-5-4-12 is quite attainable. Playing with your (tRFC) on these yields different results as well using 60 loosens the other timings and sometimes you can obtain interesting results. Yours is at: Row Refresh Cycle Time (tRFC) 52T You could try lowering this one increment at a time as well and see what happens mine I usually run @ 46T
