Is this a usual problem with RX-580
Discussion in 'Graphics Cards & Displays' started by David Pettenati, Jan 13, 2020.
  1. Bought a used RX580 putit in PC and it fried (smoked) instantly, Took it apart and found melted chips. I mean is that even possibel unless somone trired to fix it and did a crap job or took the card apart and somehow physcially cause it to short out? i cannot figure out how to upload apicture but will as soon as i do.
    Can this be fixed and is it expensive?
    The melted chips are towards the input side of the card to the left of a bunch of larger square-ish things - i know nothing much about GCs but can tell a melted chip when i see one so sorry for the bad description
  2. ok after searching a bit i found out it is the V-core onthe board if that helps
  3. Chai
    You may try to fix it, but I don't think it is easy to fix, since it may also burn the traces. I tried doing the same, and realised that more than the component itself was burnt.
  4. Hi David! you need to see a specialist for that problem. Yes, the card is a little bit pricey.
  5. Diana Scarpa
    Diana Scarpa Newbie
    Hi David, how was your problem, did you fix it?
  6. zinc711
    zinc711 Newbie
    I think this is not an easy fix, try to have this checked from a specialized tech.
