There are many notebook coolers out there. So, how can Jetart differentiate their top Xcool NP5000 portable notebook cooler from the competition? Try an integrated USB hub with four ports! But is that all that is special with this notebook cooler? Find out in our in-depth review of the Jetart Xcool NP5000 portable notebook cooler! Link : Jetart Xcool NP5000 Portable Notebook Cooler Review!
Oh, they're run off your laptop's battery. I see, I see! I thought they had their own battery or something.
The Xcool NP4000 (http://www.rojakpot.com/showarticle.aspx?artno=132&pgno=0) comes with an internal NiMH battery. This model just comes with an integrated USB hub with four ports.
LOL! Definitely. The fans really cool down the notebook significantly and the USB ports are VERY useful.
Yeah, that would be helpful. I also like it being powered off the laptop. You don't have to deal with charging the fan thing's battery.
errr... its a review on Jetart Xcool NP5000 portable notebook cooler as well, which i saw the dollar pricing.
Vantec? Dear Adrian, Thanks for the reply man. Do you mean to say that they are the same brands? I was in Low Yat the whole day and almost every shop i went to either didn't know what i was talking about or only had the cooler masters. Could you point me in the right direction? And is the np5000 really better than the cooler master notepal? Salut, Solo
Dear xy, Now i see. Thank so much for your enlightenment master. So now back to the important questions. Which shop in Low Yat carries Vantec? I walked to almost every shop but all have cooler masters. Help! And is vantec better than cooler master? Salut Solo
Actually, Jetart makes the NP5000. Vantec just buys them from Jetart and rebrands it as a Vantec cooler. Unfortunately, the Cooler Master CoolPad is nothing compared to the Jetart NP5000. If you haven't already done so, you can check out the CoolPad review here - http://www.rojakpot.com/showarticle.aspx?artno=126 Compare that against our NP5000 review. Regarding where you can actually get one, well, it's been some time since I've been to Low Yat. So, I don't know if you can now get the NP5000 over there. Maybe you can try showing them a picture of it.. or show them the review? Some of the shops are connected to the Internet over there.
