Lian Li Introduces LANCOOL ONE White Edition
Discussion in 'General Hardware' started by angel777109, Sep 26, 2018.
Tags:
  1. angel777109
    angel777109 Newbie
    September 26th, 2018, Taipei, Taiwan – Lian Li Industrial Co. Ltd., world’s leading manufacturer of aluminum chassis for enthusiasts, custom OEM/ODM case solutions and case accessories is pleased to announce the debut of the LANCOOL ONE White Edition chassis and to celebrate this exciting release, Lian Li is proud to announce the commemorative LANCOOL ONE Special Edition. A special, customized variation of the White Edition, the LANCOOL ONE Special Edition features a crafted champagne gold front panel that exudes elegance and class. This rare beauty is a limited production run and is exclusively available for this occasion only. And Lian Li is giving away this special chassis for its global followers!
    LANCOOL ONE Champagne Special Edition Global Giveaway
    The LANCOOL ONE Champagne Special Edition is limited to only 5 and you can be the lucky owner of one of these. Find out how to join at the end of this document.
    Lian Li is proud of this milestone and is celebrating this event by giving away the incredibly limited LANCOOL ONE Champagne Gold Special Edition chassis. There are only five of this chassis in existence and Lian Li is giving away all 5 to its global audience.
    To join, follow the instructions in the raffle link: LANCOOL ONE LIMITED EDITION CHAMPAGNE GOLD
    Promo period runs from September 20 to October 3, 2018.
    The LANCOOL ONE Special Edition and the White Edition both feature the same Lian Li signature brushed aluminum finish and quality of the original LANCOOL ONE, combined with modern RGB lighting, the LANCOOL ONE White Edition brings a modern touch to Lian Li’s breakthrough reimagination of its classic design. The LANCOOL ONE has already impressed during its initial unveiling and the White Edition intends to expand that audience further.
    Classic Look with Modern RGB Loaded with Modern Features
    Nobody in the business does aluminum better than Lian Li and the LANCOOL ONE continues that legacy with its stylish aluminum front panel which exudes a timeless, elegant vibe but is given a modern touch with impressive RGB lighting. The RGB lighting serves as both an accent piece for the front panel as well an ambient lighting for the internal chamber giving it a two-in-one function that provides a lot of value. The LEDs also illuminate front fans directly so users not using RGB fans on the front can get the illusion of using RGB fans on the front thanks to the front panel lighting.
    The LANCOOL ONE supports up to 360mm radiators on the top or front (only one at a time) or users can also mount a single 280mm radiator on the front. A total of nine 120mm fans can be installed on the LANCOOL ONE for incredible airflow possibilities.
    The modular drive cage caddy can be removed for easier cable routing and the LANCOOL ONE also features plenty of tie down points for easier cable management. This enables a cleaner look and an easier time when doing maintenance.
    Pre-Order Information
    The LANCOOL ONE White Edition will be available by the middle of October. Pre-orders will be available during that time period. Follow Lian Li on social media to stay updated on pre-order details!
