making water cooling
Discussion in 'Overclocking, Cooling & Modding' started by generalRage1982hrv, Apr 13, 2008.
  1. Mac Daddy
    Nice work lets see how a C2D does on the hot plate next time around Bro ... with a copper base :mrgreen:
    Since you can't make the aluminium walls any thinner, how about making them rougher? That should increase the surface area and turbulence for better thermal transfer... :think:
  3. generalRage1982hrv
    i know bro but there is some problems i have broken a drill that can make them rougher LOL i know
    it hapend when i started to enter material i dident know that this one cant take higher speeds
    it was made for higher speeds but i dont know what happen maybe a drill was damaged anyway i did not look
    on regular water block (made by aluminum) walls are same and its depth is 10mm but my is 20mm it is larger and flow and thermal transfer should be ok i think
  4. generalRage1982hrv
    bro i have copper but i dont have a C2D
    :cry: :cry: :cry: :cry: :cry: :cry: :cry:
  5. generalRage1982hrv
  6. Chai
    How do you seal the waterblock?
  7. generalRage1982hrv
    with thermal resistant silicon LOL
    it need atleast 12hours to seal it (well to dry it )
  8. Chai
    Make sure you leak test first...
  9. generalRage1982hrv
    i know that is why i hate plastics
    well i have made one before and no leaking from it
    i hope this one will work without any problems
  10. Chai
    Why didn't you seal it with aluminium plate?
  11. generalRage1982hrv
    because of testing and so i can see is there a air iside it
    if i get any air iside it will cause lower heat transfere
  12. Adrian Wong
    Wow.. With a transparent plastic top? :mrgreen:
  13. generalRage1982hrv
    was playing with it
    that plastic top is a mistake i hate it (have droped on a floor and it have broke uhhhhhhhhhhh )
    now i need to make new top , will use aluminum or plastic 5mm
  14. Mac Daddy
    Whoopsie :shock:
    You will make it better anyway bro ;)
  15. Chai
    Highly recommended that you use aluminium plate.
  16. Adrian Wong
    Yeah, plastic looks nice but I think aluminium is not only sturdier but it will also help dissipate the heat.
  17. The_YongGrand
    The_YongGrand Just Started
    Wow, that's pretty cool self-made watercooling!
    I wish I had that big machine that can carve or cut that metal block into something else. My college has one of these too. :)
  18. Mac Daddy
    I second that although the transparency is cool :D
  19. Chai
    Nope it doesn't. :p
  20. Adrian Wong
    Hmm.. Why not? It may not be much, but it sure is better than plastic.
