There are so many CPU models that it has become quite impossible to keep up with the different models or even remember their specifications! Therefore, we decided to compile this guide to provide an easy reference for those who are interested in comparing the specifications of the various mobile CPUs in the market, as well as those already obsolescent or obsolete. Currently covering over 390 mobile CPUs, this comprehensive comparison will allow you to easily compare up to 14 different specifications for each and every CPU! Link : Mobile CPU Comparison Guide!
Error in Article I do bleieve that the Clawhammer CPUs supported NXbit, however many of the ones listed in the guide (all?) do not support it. I know the desktop version of clawhammer did, and I believe that the laptop version was the same. Also the mobile AthlonXP-M socket is 563 and not 536. There is even a Wikipedia article on socket 563.
i second that.. the desktop clawhammer3500+ i owned has DEP enabled in windows.. but i'm not too sure abt the mobile ones though..
Ok I researched a bit, all clawhammers don't support NX-bit and yeah, made a mistake with the AXP-M socket. The mistakes will be corrected in the next update, thanks for letting us know!
http://wiki.extremeoverclocking.com/wiki/Clawhammer the one i owned was a FX cut down Clawhammer (CG stepping) (i'm not sure abt the mobile ones)
i guess so... but is there any other steppings for clawhammer? edit: http://www2.abit.com.tw/cpu-support-list/amd-athlon64-c.php
I think there's another C0 stepping other than CG... Update coming very soon for the Desktop CPU, with additional specs.
thought C0 is newcastle? (not sure) before u updated, add this in: Turion MK-36 http://forums.amd.com/index.php?showtopic=84503 http://www.amd.com/us-en/Processors/ProductInformation/0,,30_118_12651_12658,00.html
Hello guys! Revision 2.0 of the Mobile CPU Comparison Guide has just been posted! There are so many CPU models that it has become quite impossible to keep up with the different models or even remember their specifications! Therefore, we decided to compile this guide to provide an easy reference for those who are interested in comparing the specifications of the various mobile CPUs in the market, as well as those already obsolescent or obsolete. Currently covering over 395 mobile CPUs, this comprehensive comparison will allow you to easily compare up to 14 different specifications for each and every CPU! Link : Mobile CPU Comparison Guide!
The guide has just been updated! There are so many CPU models that it has become quite impossible to keep up with the different models or even remember their specifications! Therefore, we decided to compile this guide to provide an easy reference for those who are interested in comparing the specifications of the various mobile CPUs in the market, as well as those already obsolescent or obsolete. Currently covering over 390 mobile CPUs, this comprehensive comparison will allow you to easily compare up to 14 different specifications for each and every CPU! Here are the updates:- Link : Mobile CPU Comparison Guide Rev 2.1
eh, i didnt know that TurionX2s have doubled the L1 cache, nv seen it highlighted anywhere b4... anyway, i would suggest putting a note to tell ppl that intel & amd's TDP cannot be directly compared
Yeah, we got an e-mail from AMD about that. Hmm.. We are supposed to add that to our Tech Myths Guide....
Trouble with AMD is they only want to send you stuff they want you to post. They don't seem to be in a habit of replying e-mails.
