I am used the notebook with Mobility 9600 I just success sperated the displaycard bios from system bios. and I want to HARDMOD to Mobility FireGL T2, HOW CAN I DO IT? Does anyboby can help me to modify the bios? I will upload the bios~ Thanks a lot~ P.S the zip file has two files one is the uncompress file(64k) the other is the real size(40k) in rom I don't know the differences between them
If you read the Radeon to FireGL Mod Guide, you should know that modding or flashing the video BIOS does not turn the Radeon into a FireGL. You need to patch the driver and control panels...
but i just read this article~ i am not very understand how can he do that~ the link:http://www.wimsbios.com/phpBB2/viewtopic.php?t=5736 it looks like so simple just change 45e0 to 45e4. but now i have a big problem~ how can i combine the display bios to system bios and the checksum is pass?
"HARDMOD mobility 9600 to mobility FireGL T2" the link:http://www.nvworld.ru/php/viewtopic.php?t=11326&sid=0da8febb511910e97926d562dcd6d275
.....The Reason is... maybe i think that is more perfect... because everything is the same just the 4e50 and 4e54, isn't it? but yesterday i flash my bios, fail... black screen, i think the most problem is the checksum is wrong how can i make the checksum valid...
Not really. You still need to patch the other driver files as well as the control panels. Try reading the guide first. IMHO, if you can't successfully soft-mod the Mobility Radeon 9600, don't bother with the BIOS hack. First, make sure you can soft-mod it.
LOL! Seriously, medking, please give the guide a good read. We have already mentioned that you may have to try several versions to see which works. We also mentioned a driver revision that worked. You might want to try that version first.
hoho~ Thanks I had already read the article serval times and I have install the FireGL Driver, and runs no problem. Thanks a lot. but i still try to hardmod... hoho~
Oh, I see! LOL!! I thought you never even tried it since you weren't even sure which driver version could be modded.
......you're right~~~ but can you help to mod the bios? it's ami bios~ P.S I use fosage driver 4.10 now~
