Hello everyone! I'm researching something on V-Link. I need your help in confirming my findings. If you can, please help me do this : Thanks!
I checked my (latest) BIOS and see entries as follows: V-Link 8x Supported (Currently Enabled) -- I could disable if you wish to experiment. V-Link Data 2x Support (Currently Disabled) I will proceed if you wish, but am not sure about the mode selections in your instructions.
Hello Elkdad, In that case, just leave V-Link 8X Supported at Enabled. And just get me the V-Link status for V-Link Data 2X Support enabled and disabled. Thanks!!
You're going to have to be more specific as to where I can look at this status, or if Everest calls it something different. Thanks.
Hello Elkdad, Just click on Motherboard -> Motherboard. You should be able to see Bus Type : VIA V-Link. It's that screen. Thanks!
Ah darn, I just realized that your motherboard supports only V-Link 8X. It doesn't support Ultra V-Link. Does anyone here have a motherboard that supports Ultra V-Link? Thanks!
Adrian, I've got an Epox 9HDAI mobo with a VIA K8T800 Pro chipset. On the V-link mode selection, I have the option to go from 4x to 8x but I don't seem to be able to find this V-Link Data 2x Support. Could it be under a different name. sorry, i'm a real NoOb!!
Sorry. I'll try harder next time. Thanks for turning me on to the neat utility. I've been studying it.
All I need is a VIA motherboard that supports Ultra V-Link (1GB/s transfer rate between the north bridge and the south bridge). The motherboard should also have the BIOS features of V-Link Mode Selection and V-Link Data 2X Support. Some motherboards may come with V-Link 8X Support and V-Link Data 2X Support. They are useful too. Thanks!
Hello Domster, Would it be possible for you to get me a picture of the page with the V-Link options? Thanks!!
Hey, no fault of yours!! In actual fact, they were useful in helping me confirm one part of the issue. Thanks!!
Adrian, Don't know it this'll help. Dosen't seem to be a whole lotta options for V-Link in my BIOS. I don't know how to take screenshots in BIOS so I just got out the Nokia. I hope it helps. If you need more pics of me BIOS options, just ask.
Hello Domster, From what I can see, your chipset supports Ultra V-Link but the EPoX BIOS seems to allow only a maximum of V-Link 8X. Could you help me verify this by running Everest and getting the screenshots of the V-Link properties with Vlink Data Rate set to 8X and 4X? Thanks!
Yup, looks like your motherboard's fixed to a maximum of V-Link 8X. Probably they didn't implement all 16 data lines.
