I'm being fed up with my crappy monitor, and plan to buy a new one. I've got my eyes on a Samsung SyncMaster 940B, which is at a reasonable price level. Reviews (that are all about one year old) says this is a great monitor. Question is if there are other, newer, monitors at the same size and price that are even better for general use? Comments? /Olle
I don't think that's a worry. HD or not, the monitor resolution stays the same... Anyway watching movies is my least use for it. /Olle
yup there is one. the new samsung 971p. the display quality is (it does look better than my 20inch ultrasharp) viewangle is and design is leet...touch sensitive on/off button. and flexible. very flexible. i lowered the panel all the way down, and tilted it a litte so that I do not have to raise my head when looknig at the panel.
Doesn't fit my requirement regarding price. 940B is ~2500 SEK, 971P is >4000 SEK. I won't go above 3000 unless I get something way better just above. /Olle
You don't mean they both cost about the same (as the other) where you live? Consumer electronics is generally fairly expensive in Sweden, not least because of the 25% VAT. (Not quite as expensive as in Norway though...) What interests me more is the price relation between different products, and that shouldn't differ much between different markets. /Olle
Yea, VAT really cranks up the price. 971p is like 339USD on newegg (~2300 sek according to google.) That is a beautiful panel though...
