There are no drivers installed for my pci device. In device manager there is just a question mark next to it. I try to search for it but no luck. I never had any problems before because there was nothing in the pci slots, but now i just put something there and i remembered theres no drivers. How can i install these drivers? If this helps here is my dxdiag: ------------------ System Information ------------------ Time of this report: 7/18/2005, 15:57:31 Machine name: DEV2005 Operating System: Windows XP Professional (5.1, Build 2600) (2600.xpclnt_qfe.021108-2107) Language: English (Regional Setting: English) System Manufacturer: IBM System Model: 831027U BIOS: PhoenixBIOS 4.0 Release 6.0 for IBM NetVista. Processor: Intel(R) Pentium(R) 4 CPU 2.00GHz, ~2.0GHz Memory: 254MB RAM Page File: 170MB used, 2071MB available Windows Dir: C:\WINNT DirectX Version: DirectX 9.0c (4.09.0000.0904) DX Setup Parameters: Not found DxDiag Version: 5.03.0001.0904 32bit Unicode ------------ DxDiag Notes ------------ DirectX Files Tab: No problems found. Display Tab 1: No problems found. Sound Tab 1: No problems found. Music Tab: No problems found. Input Tab: No problems found. Network Tab: No problems found. -------------------- DirectX Debug Levels -------------------- Direct3D: 0/4 (n/a) DirectDraw: 0/4 (retail) DirectInput: 0/5 (n/a) DirectMusic: 0/5 (n/a) DirectPlay: 0/9 (retail) DirectSound: 0/5 (retail) DirectShow: 0/6 (retail) --------------- Display Devices --------------- Card name: NVIDIA GeForce4 MX 440 Manufacturer: NVIDIA Chip type: GeForce4 MX 440 DAC type: Integrated RAMDAC Device Key: Enum\PCI\VEN_10DE&DEV_0171&SUBSYS_00001B13&REV_A3 Display Memory: 64.0 MB Current Mode: 1024 x 768 (32 bit) (85Hz) Monitor: Plug and Play Monitor Monitor Max Res: 1600,1200 Driver Name: nv4_disp.dll Driver Version: 6.14.0010.7772 (English) DDI Version: 9 (or higher) Driver Attributes: Final Retail Driver Date/Size: 6/15/2005 17:20:00, 3896320 bytes WHQL Logo'd: Yes WHQL Date Stamp: n/a VDD: n/a Mini VDD: nv4_mini.sys Mini VDD Date: 6/15/2005 17:20:00, 3200256 bytes Device Identifier: {D7B71E3E-4231-11CF-FF66-0A2002C2CB35} Vendor ID: 0x10DE Device ID: 0x0171 SubSys ID: 0x00001B13 Revision ID: 0x00A3 Revision ID: 0x00A3 Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D Deinterlace Caps: {212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YUY2,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch {212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch Registry: OK DDraw Status: Enabled D3D Status: Enabled AGP Status: Enabled DDraw Test Result: Not run D3D7 Test Result: Not run D3D8 Test Result: Not run D3D9 Test Result: Not run ------------- Sound Devices ------------- Description: SoundMAX Digital Audio Default Sound Playback: Yes Default Voice Playback: Yes Hardware ID: PCI\VEN_8086&DEV_24C5&SUBSYS_02671014&REV_01 Manufacturer ID: 1 Product ID: 100 Type: WDM Driver Name: smwdm.sys Driver Version: 5.12.0001.3624 (English) Driver Attributes: Final Retail WHQL Logo'd: Yes Date and Size: 10/27/2003 17:09:06, 578432 bytes Other Files: Driver Provider: Analog Devices HW Accel Level: Full Cap Flags: 0xB5B Min/Max Sample Rate: 8000, 48000 Static/Strm HW Mix Bufs: 1, 0 Static/Strm HW 3D Bufs: 0, 0 HW Memory: 0 Voice Management: No EAX(tm) 2.0 Listen/Src: No, No I3DL2(tm) Listen/Src: No, No Sensaura(tm) ZoomFX(tm): No Registry: OK Sound Test Result: Not run --------------------- Sound Capture Devices --------------------- Description: SoundMAX Digital Audio Default Sound Capture: Yes Default Voice Capture: Yes Driver Name: smwdm.sys Driver Version: 5.12.0001.3624 (English) Driver Attributes: Final Retail Date and Size: 10/27/2003 17:09:06, 578432 bytes Cap Flags: 0x41 Format Flags: 0xCCC ----------- DirectMusic ----------- DLS Path: C:\WINNT\SYSTEM32\drivers\GM.DLS DLS Version: 1.00.0016.0002 Acceleration: n/a Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port SoundMAX Digital Audio, Software (Kernel Mode), Output, DLS, Internal Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal Registry: OK Test Result: Not run ------------------- DirectInput Devices ------------------- Device Name: Mouse Attached: 1 Controller ID: n/a Vendor/Product ID: n/a FF Driver: n/a Device Name: Keyboard Attached: 1 Controller ID: n/a Vendor/Product ID: n/a FF Driver: n/a Poll w/ Interrupt: No Registry: OK ----------- USB Devices ----------- + USB Root Hub | Vendor/Product ID: 0x8086, 0x24C7 | Matching Device ID: usb\root_hub | Service: usbhub | Driver: usbhub.sys, 8/23/2001 15:00:00, 50688 bytes | Driver: usbd.sys, 8/23/2001 15:00:00, 4736 bytes ---------------- Gameport Devices ---------------- ------------ PS/2 Devices ------------ + Standard 101/102-Key or Microsoft Natural PS/2 Keyboard | Matching Device ID: *pnp0303 | Service: i8042prt | Driver: i8042prt.sys, 8/23/2001 15:00:00, 50944 bytes | Driver: kbdclass.sys, 8/23/2001 15:00:00, 23424 bytes | + Terminal Server Keyboard Driver | Matching Device ID: root\rdp_kbd | Upper Filters: kbdclass | Service: TermDD | Driver: termdd.sys, 8/18/2001 01:38:00, 37896 bytes | Driver: kbdclass.sys, 8/23/2001 15:00:00, 23424 bytes | + PS/2 Compatible Mouse | Matching Device ID: *pnp0f13 | Service: i8042prt | Driver: i8042prt.sys, 8/23/2001 15:00:00, 50944 bytes | Driver: mouclass.sys, 8/23/2001 15:00:00, 22016 bytes | + Terminal Server Mouse Driver | Matching Device ID: root\rdp_mou | Upper Filters: mouclass | Service: TermDD | Driver: termdd.sys, 8/18/2001 01:38:00, 37896 bytes | Driver: mouclass.sys, 8/23/2001 15:00:00, 22016 bytes ---------------------------- DirectPlay Service Providers ---------------------------- DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.0000.0900) DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.0000.0900) DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.0000.0900) DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.0000.0900) Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.0001.0904) IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.0001.0904) Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.0000.0900) Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.0000.0900) DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run DirectPlay Test Result: Not run Registry: OK ------------------- DirectPlay Adapters ------------------- DirectPlay8 Serial Service Provider: COM1 DirectPlay8 Serial Service Provider: COM2 DirectPlay8 TCP/IP Service Provider: Local Area Connection 2 - IPv4 - ----------------------- DirectPlay Voice Codecs ----------------------- Voxware VR12 1.4kbit/s Voxware SC06 6.4kbit/s Voxware SC03 3.2kbit/s MS-PCM 64 kbit/s MS-ADPCM 32.8 kbit/s Microsoft GSM 6.10 13 kbit/s TrueSpeech(TM) 8.6 kbit/s ------------------------- DirectPlay Lobbyable Apps ------------------------- ------------------------ Disk & DVD/CD-ROM Drives ------------------------ Drive: C: Free Space: 17.8 GB Total Space: 38.2 GB File System: NTFS Model: WDC WD400BB-32CXA0 Drive: E: Model: OEM CD-ROM F522E Driver: c:\winnt\system32\drivers\cdrom.sys, 5.01.2600.0000 (English), 8/23/2001 15:00:00, 47488 bytes Drive: D: Model: AXV CD/DVD-ROM SCSI CdRom Device Driver: c:\winnt\system32\drivers\cdrom.sys, 5.01.2600.0000 (English), 8/23/2001 15:00:00, 47488 bytes -------------- System Devices -------------- Name: PCI standard PCI-to-PCI bridge Device ID: PCI\VEN_8086&DEV_2561&SUBSYS_00000000&REV_01\3&61AAA01&0&08 Driver: C:\WINNT\System32\DRIVERS\pci.sys, 5.01.2600.0000 (English), 8/17/2001 13:58:06, 62464 bytes Name: PCI standard host CPU bridge Device ID: PCI\VEN_8086&DEV_2560&SUBSYS_00000000&REV_01\3&61AAA01&0&00 Driver: n/a Name: Universal Serial Bus (USB) Controller Device ID: PCI\VEN_8086&DEV_24CD&SUBSYS_02671014&REV_01\3&61AAA01&0&EF Driver: n/a Name: Standard Dual Channel PCI IDE Controller Device ID: PCI\VEN_8086&DEV_24CB&SUBSYS_02671014&REV_01\3&61AAA01&0&F9 Driver: C:\WINNT\System32\DRIVERS\pciide.sys, 5.01.2600.0000 (English), 8/23/2001 15:00:00, 3328 bytes Driver: C:\WINNT\System32\DRIVERS\pciidex.sys, 5.01.2600.0000 (English), 8/23/2001 15:00:00, 23680 bytes Driver: C:\WINNT\System32\DRIVERS\atapi.sys, 5.01.2600.0000 (English), 8/23/2001 15:00:00, 86656 bytes Name: Standard Universal PCI to USB Host Controller Device ID: PCI\VEN_8086&DEV_24C7&SUBSYS_02671014&REV_01\3&61AAA01&0&EA Driver: C:\WINNT\system32\drivers\usbuhci.sys, 5.01.2600.0000 (English), 8/23/2001 15:00:00, 18944 bytes Driver: C:\WINNT\system32\drivers\usbport.sys, 5.01.2600.0000 (English), 8/23/2001 15:00:00, 123264 bytes Driver: C:\WINNT\System32\usbui.dll, 5.01.2600.0000 (English), 8/23/2001 15:00:00, 67072 bytes Driver: C:\WINNT\system32\drivers\usbhub.sys, 5.01.2600.0000 (English), 8/23/2001 15:00:00, 50688 bytes Name: SoundMAX Integrated Digital Audio Device ID: PCI\VEN_8086&DEV_24C5&SUBSYS_02671014&REV_01\3&61AAA01&0&FD Driver: C:\WINNT\system32\drivers\drmk.sys, 5.01.2600.0000 (English), 8/17/2001 17:01:20, 57344 bytes Driver: C:\WINNT\system32\drivers\portcls.sys, 5.01.2600.0000 (English), 8/18/2001 01:24:38, 135040 bytes Driver: C:\WINNT\system32\drivers\stream.sys, 5.03.0001.0904 (English), 7/9/2004 04:27:28, 48512 bytes Driver: C:\WINNT\System32\wdmaud.drv, 5.01.2600.0000 (English), 8/18/2001 01:37:04, 22016 bytes Driver: C:\WINNT\System32\ksuser.dll, 5.03.0000.0900 (English), 12/12/2002 00:14:32, 4096 bytes Driver: C:\WINNT\system32\drivers\smwdm.sys, 5.12.0001.3624 (English), 10/27/2003 17:09:06, 578432 bytes Driver: C:\WINNT\system32\drivers\smsens.sys, 5.12.0001.0000 (English), 4/8/2003 14:30:48, 3744 bytes Driver: C:\WINNT\system32\drivers\aeaudio.sys, 3.00.0002.0036 (English), 10/23/2003 14:17:10, 100384 bytes Driver: C:\WINNT\system32\a3d.dll, 4.12.0001.2008 (English), 9/19/2001 17:32:26, 720896 bytes Name: Standard Universal PCI to USB Host Controller Device ID: PCI\VEN_8086&DEV_24C4&SUBSYS_02671014&REV_01\3&61AAA01&0&E9 Driver: C:\WINNT\system32\drivers\usbuhci.sys, 5.01.2600.0000 (English), 8/23/2001 15:00:00, 18944 bytes Driver: C:\WINNT\system32\drivers\usbport.sys, 5.01.2600.0000 (English), 8/23/2001 15:00:00, 123264 bytes Driver: C:\WINNT\System32\usbui.dll, 5.01.2600.0000 (English), 8/23/2001 15:00:00, 67072 bytes Driver: C:\WINNT\system32\drivers\usbhub.sys, 5.01.2600.0000 (English), 8/23/2001 15:00:00, 50688 bytes Name: PCI Device Device ID: PCI\VEN_8086&DEV_24C3&SUBSYS_02671014&REV_01\3&61AAA01&0&FB Driver: n/a Name: Standard Universal PCI to USB Host Controller Device ID: PCI\VEN_8086&DEV_24C2&SUBSYS_02671014&REV_01\3&61AAA01&0&E8 Driver: C:\WINNT\system32\drivers\usbuhci.sys, 5.01.2600.0000 (English), 8/23/2001 15:00:00, 18944 bytes Driver: C:\WINNT\system32\drivers\usbport.sys, 5.01.2600.0000 (English), 8/23/2001 15:00:00, 123264 bytes Driver: C:\WINNT\System32\usbui.dll, 5.01.2600.0000 (English), 8/23/2001 15:00:00, 67072 bytes Driver: C:\WINNT\system32\drivers\usbhub.sys, 5.01.2600.0000 (English), 8/23/2001 15:00:00, 50688 bytes Name: PCI standard ISA bridge Device ID: PCI\VEN_8086&DEV_24C0&SUBSYS_00000000&REV_01\3&61AAA01&0&F8 Driver: C:\WINNT\System32\DRIVERS\isapnp.sys, 5.01.2600.0000 (English), 8/23/2001 15:00:00, 35840 bytes Name: Intel(R) 82801 PCI Bridge - 244E Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_00000000&REV_81\3&61AAA01&0&F0 Driver: C:\WINNT\System32\DRIVERS\pci.sys, 5.01.2600.0000 (English), 8/17/2001 13:58:06, 62464 bytes Name: Intel(R) PRO/100 VE Network Connection Device ID: PCI\VEN_8086&DEV_1039&SUBSYS_02671014&REV_81\4&25296D99&0&40F0 Driver: C:\WINNT\System32\DRIVERS\e100b325.sys, 6.01.0003.0000 (English), 2/25/2002 11:54:02, 139776 bytes Driver: C:\WINNT\System32\Prounstl.exe, 4.09.0000.0000 (English), 6/22/2001 14:25:02, 53248 bytes Driver: C:\WINNT\System32\net82557.din, 2/13/2002 07:55:50, 2983 bytes Driver: C:\WINNT\System32\IntelNic.dll, 1.07.0000.0000 (English), 7/20/2001 10:40:28, 23040 bytes Name: NVIDIA GeForce4 MX 440 Device ID: PCI\VEN_10DE&DEV_0171&SUBSYS_00001B13&REV_A3\4&6F1E3D&0&0008 Driver: C:\WINNT\System32\DRIVERS\nv4_mini.sys, 6.14.0010.7772 (English), 6/15/2005 17:20:00, 3200256 bytes Driver: C:\WINNT\System32\nvsvc32.exe, 6.14.0010.7772 (English), 6/15/2005 17:20:00, 127043 bytes Driver: C:\WINNT\System32\nvcod.dll, 1.00.0000.0024 (English), 6/15/2005 17:20:00, 32768 bytes Driver: C:\WINNT\System32\nvcodins.dll, 1.00.0000.0024 (English), 6/15/2005 17:20:00, 32768 bytes Driver: C:\WINNT\System32\nv4_disp.dll, 6.14.0010.7772 (English), 6/15/2005 17:20:00, 3896320 bytes Driver: C:\WINNT\System32\nvhwvid.dll, 6.14.0010.7772 (), 6/15/2005 17:20:00, 540672 bytes Driver: C:\WINNT\System32\nvoglnt.dll, 6.14.0010.7772 (English), 6/15/2005 17:20:00, 5136384 bytes Driver: C:\WINNT\System32\nvcpl.dll, 6.14.0010.7772 (English), 6/15/2005 17:20:00, 6803456 bytes Driver: C:\WINNT\System32\nvcplins.dll, , 0 bytes Driver: C:\WINNT\System32\nvmctray.dll, 6.14.0010.7772 (English), 6/15/2005 17:20:00, 86016 bytes Driver: C:\WINNT\System32\nvwddi.dll, 6.14.0010.7772 (English), 6/15/2005 17:20:00, 81920 bytes Driver: C:\WINNT\System32\nvnt4cpl.dll, 6.14.0010.10525 (English), 6/15/2005 17:20:00, 286720 bytes Driver: C:\WINNT\help\nvcpl.hlp, 6/15/2005 17:20:00, 167645 bytes Driver: C:\WINNT\help\nvwcplen.hlp, 6/15/2005 17:20:00, 55444 bytes Name: Multimedia Controller Device ID: PCI\VEN_109E&DEV_0878&SUBSYS_13EB0070&REV_02\4&25296D99&0&49F0 Driver: n/a Name: Multimedia Video Controller Device ID: PCI\VEN_109E&DEV_036E&SUBSYS_13EB0070&REV_02\4&25296D99&0&48F0 Driver: n/a Name: A347SCSI SCSI Controller Device ID: PCI\A347SCSI\0000 Driver: n/a ------------------ DirectX Components ------------------ ddraw.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28 292864 bytes ddrawex.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 24064 bytes dxapi.sys: 5.01.2600.0000 English Final Retail 8/23/2001 15:00:00 10496 bytes d3d8.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28 1201152 bytes d3d8thk.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 8192 bytes d3d9.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28 1703936 bytes d3dim.dll: 5.01.2600.0000 English Final Retail 8/23/2001 15:00:00 436224 bytes d3dim700.dll: 5.03.0001.0902 English Final Retail 5/30/2003 09:00:02 797184 bytes d3dramp.dll: 5.01.2600.0000 English Final Retail 8/23/2001 15:00:00 590336 bytes d3drm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 15:00:00 350208 bytes d3dxof.dll: 5.01.2600.0000 English Final Retail 8/23/2001 15:00:00 47616 bytes d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/23/2001 15:00:00 34816 bytes dplay.dll: 5.00.2134.0001 English Final Retail 8/23/2001 15:00:00 33040 bytes dplayx.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28 230400 bytes dpmodemx.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 77824 bytes dpwsock.dll: 5.00.2134.0001 English Final Retail 8/23/2001 15:00:00 42768 bytes dpwsockx.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28 79360 bytes dplaysvr.exe: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 28160 bytes dpnsvr.exe: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 16896 bytes dpnet.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 723968 bytes dpnlobby.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 3072 bytes dpnaddr.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 3072 bytes dpvoice.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 381952 bytes dpvsetup.exe: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 80896 bytes dpvvox.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 112128 bytes dpvacm.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 19968 bytes dpnhpast.dll: 5.03.0000.0901 English Final Retail 3/24/2003 09:00:02 32768 bytes dpnhupnp.dll: 5.03.0000.0901 English Final Retail 3/24/2003 09:00:02 68096 bytes dpserial.dll: 5.00.2134.0001 English Final Retail 8/23/2001 15:00:00 53520 bytes dinput.dll: 5.01.2600.1106 English Final Retail 8/29/2002 03:40:00 648704 bytes dinput8.dll: 5.01.2600.1106 English Final Retail 8/29/2002 03:40:00 667648 bytes dimap.dll: 5.01.2600.0000 English Final Retail 8/23/2001 15:00:00 44032 bytes diactfrm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 15:00:00 394240 bytes joy.cpl: 5.01.2600.1106 English Final Retail 8/29/2002 03:41:00 208896 bytes gcdef.dll: 5.01.2600.0000 English Final Retail 8/23/2001 15:00:00 76800 bytes pid.dll: 5.01.2600.1106 English Final Retail 8/29/2002 03:41:00 31744 bytes dsound.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28 381952 bytes dsound3d.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 1294336 bytes dswave.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 18432 bytes dsdmo.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 186880 bytes dsdmoprp.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 491520 bytes dmusic.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28 122880 bytes dmband.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 27136 bytes dmcompos.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 58368 bytes dmime.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28 181248 bytes dmloader.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 33280 bytes dmstyle.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 98816 bytes dmsynth.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 100864 bytes dmscript.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 76800 bytes system.dll: 1.00.3705.0000 English Final Retail 6/25/2005 09:24:14 1163264 bytes system.dll: 1.01.4322.0573 English Final Retail 6/25/2005 09:32:47 1216512 bytes dx7vb.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 602624 bytes dx8vb.dll: 5.03.0001.0902 English Final Retail 5/30/2003 09:00:02 1189888 bytes dxdiagn.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28 1769472 bytes mfc40.dll: 4.01.0000.6140 English Final Retail 8/23/2001 15:00:00 924432 bytes mfc42.dll: 6.00.8665.0000 English Beta Retail 8/23/2001 15:00:00 995383 bytes wsock32.dll: 5.01.2600.0000 English Final Retail 8/23/2001 15:00:00 21504 bytes amstream.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 64512 bytes devenum.dll: 6.05.0001.0902 English Final Retail 5/30/2003 09:00:02 132608 bytes dxmasf.dll: 6.04.0009.1121 English Final Retail 10/4/2001 10:58:30 498960 bytes mciqtz32.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 34304 bytes mpg2splt.ax: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 136192 bytes msdmo.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 13312 bytes encapi.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 18944 bytes qasf.dll: 10.00.0000.3802 English Final Retail 1/28/2005 13:44:28 221184 bytes qcap.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 257024 bytes qdv.dll: 6.05.0001.0904 English Final Retail 7/9/2004 04:27:28 316928 bytes qdvd.dll: 6.05.0001.0904 English Final Retail 7/9/2004 04:27:28 470528 bytes qedit.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 1798144 bytes qedwipes.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 733184 bytes quartz.dll: 6.05.0001.0902 English Final Retail 5/30/2003 09:00:02 1962496 bytes strmdll.dll: 4.01.0000.3925 English Final Retail 8/23/2001 15:00:00 246302 bytes iac25_32.ax: 2.00.0005.0053 English Final Retail 8/23/2001 15:00:00 199680 bytes ir41_32.ax: 4.51.0016.0003 English Final Retail 8/23/2001 15:00:00 848384 bytes ir41_qc.dll: 4.30.0062.0002 English Final Retail 8/23/2001 15:00:00 120320 bytes ir41_qcx.dll: 4.30.0064.0001 English Final Retail 8/23/2001 15:00:00 338432 bytes ir50_32.dll: 5.2562.0015.0055 English Final Retail 8/23/2001 15:00:00 755200 bytes ir50_qc.dll: 5.00.0063.0048 English Final Retail 8/23/2001 15:00:00 200192 bytes ir50_qcx.dll: 5.00.0064.0048 English Final Retail 8/23/2001 15:00:00 183808 bytes ivfsrc.ax: 5.10.0002.0051 English Final Retail 8/23/2001 15:00:00 154624 bytes mswebdvd.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 324096 bytes msdvdopt.dll: 5.01.2600.0000 English Final Retail 8/23/2001 15:00:00 74240 bytes ks.sys: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 130304 bytes ksproxy.ax: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 117248 bytes ksuser.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 4096 bytes stream.sys: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28 48512 bytes mspclock.sys: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 5248 bytes mspqm.sys: 5.01.2600.0000 English Final Retail 8/23/2001 15:00:00 4608 bytes mskssrv.sys: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 7424 bytes swenum.sys: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 4096 bytes mstee.sys: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 5504 bytes bdaplgin.ax: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 16896 bytes bdasup.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 11392 bytes msdvbnp.ax: 6.05.0001.0900 English Final Retail 7/9/2004 04:26:38 52224 bytes psisdecd.dll: 6.05.0001.0900 English Final Retail 7/9/2004 04:26:40 354816 bytes psisrndr.ax: 6.05.0001.0900 English Final Retail 7/9/2004 04:26:40 30208 bytes ipsink.ax: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 14848 bytes mpeg2data.ax: 6.05.0001.0900 English Final Retail 7/9/2004 04:26:38 57856 bytes ndisip.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 10112 bytes mpe.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 15104 bytes streamip.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:40 14976 bytes msvidctl.dll: 6.05.0001.0900 English Final Retail 7/9/2004 04:26:38 1230336 bytes slip.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:40 10880 bytes nabtsfec.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 83968 bytes ccdecode.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 16384 bytes vbisurf.ax: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:40 27648 bytes msyuv.dll: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 16896 bytes kstvtune.ax: 5.03.0001.0904 English Final Retail 7/19/2004 16:19:30 285696 bytes ksxbar.ax: 5.03.0001.0902 English Final Retail 7/9/2004 04:26:38 39424 bytes kswdmcap.ax: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:40 226304 bytes wstcodec.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:40 18688 bytes wstdecod.dll: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:40 47104 bytes msdv.sys: 5.01.2600.0000 English Final Retail 7/9/2004 04:26:38 52096 bytes ------------------ DirectShow Filters ------------------ DirectShow Filters: WMAudio Decoder DMO,0x00800800,1,1,, WMAPro over S/PDIF DMO,0x00600800,1,1,, WMSpeech Decoder DMO,0x00600800,1,1,, WMVideo Advanced Decoder DMO,0x00800001,1,1,, WMV Screen decoder DMO,0x00800001,1,1,, WMVideo Decoder DMO,0x00800001,1,1,, Mpeg43 Decoder DMO,0x00800001,1,1,, Mpeg4 Decoder DMO,0x00800001,1,1,, RTP Source Filter,0x00200000,0,1,dxmrtp.dll,5.01.2600.0000 RTP Render Filter,0x00200000,1,0,dxmrtp.dll,5.01.2600.0000 Vorbis Decoder,0x00600000,1,1,OggDS.DLL, Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.0001.0902 DV Muxer,0x00400000,0,0,qdv.dll,6.05.0001.0904 Color Space Converter,0x00400001,1,1,quartz.dll,6.05.0001.0902 WM ASF Reader,0x00400000,0,0,qasf.dll,10.00.0000.3802 Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,10.00.0000.3802 Intel RTP SPH for G.711/G.723.1,0x00200000,1,1,dxmrtp.dll,5.01.2600.0000 AVI Splitter,0x00600000,1,1,quartz.dll,6.05.0001.0902 VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.0001.0902 Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055 Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4477 RealVideo Decoder,0x00400000,1,1,rmalt.ax,1.00.0000.0004 PCM Silence Suppressor,0x00200000,1,1,dxmrtp.dll,5.01.2600.0000 AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.0001.0900 MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.0001.0902 Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055 H261 Decode Filter,0x00200000,1,1,h261_32.ax, Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4477 H263 Decode Filter,0x00200000,1,1,h263_32.ax, MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.0001.0902 SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.0001.0902 MPEG Layer-3 Decoder,0x00810000,1,1,L3CODECX.AX,1.05.0000.0050 Intel RTP Demux Filter,0x00200000,1,1,dxmrtp.dll,5.01.2600.0000 MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.0001.0900 Intel RTP SPH for Generic Audio,0x00200000,1,1,dxmrtp.dll,5.01.2600.0000 ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000 Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.0001.0902 MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.0001.0902 File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,10.00.0000.3802 DV Splitter,0x00600000,1,2,qdv.dll,6.05.0001.0904 Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4477 Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.0001.0902 Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000 Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,10.00.0000.3802 ASX file Parser,0x00600000,1,1,wmpasf.dll,10.00.0000.3802 ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,10.00.0000.3802 NSC file Parser,0x00600000,1,1,wmpasf.dll,10.00.0000.3802 XviD MPEG-4 Video Decoder,0x00800000,1,1,xvid.ax, ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.0001.0902 Windows Media source filter,0x00600000,0,2,wmpasf.dll,10.00.0000.3802 Video Renderer,0x00800001,1,0,quartz.dll,6.05.0001.0902 Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.0001.0904 Video Port Manager,0x00600000,2,1,quartz.dll,6.05.0001.0902 WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.0000.0900 Video Renderer,0x00400000,1,0,quartz.dll,6.05.0001.0902 RealMedia Source,0x00400000,0,0,rmalt.ax,1.00.0000.0004 DivX Decoder Filter,0xff800000,1,1,divxdec.ax,6.00.0000.1571 WM ASF Writer,0x00400000,0,0,qasf.dll,10.00.0000.3802 VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.0000.0900 Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.axu,8.00.0000.4477 DivX Demux,0x00600000,1,0,DivXMedia.ax,0.00.0000.0026 File writer,0x00200000,1,0,qcap.dll,6.05.0001.0900 Vorbis Encoder,0x00200000,1,1,OggDS.DLL, Ogg Multiplexer,0x00400000,1,1,OggDS.DLL, RealAudio Decoder,0x00400000,1,1,rmalt.ax,1.00.0000.0004 DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.0001.0904 Fraunhofer Audio Decoder,0x00601000,1,1,DVDAudio.ax, Fraunhofer Video Decoder,0x005ff000,2,2,DVDVideo.ax, Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.0001.0904 Cutlist File Source,0x00200000,0,1,qcut.dll,6.01.0009.0726 AC3Filter,0x40000000,1,1,ac3filter.ax,0.06.0008.0000 AVI Draw,0x00600064,9,1,quartz.dll,6.05.0001.0902 .RAM file Parser,0x00600000,1,0,wmpasf.dll,10.00.0000.3802 G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000 MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.0001.0900 DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.0001.0904 Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053 Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,10.00.0000.3802 ASF DIB Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3802 ASF ACM Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3802 ASF ICM Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3802 ASF URL Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3802 ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3802 ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3802 ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3802 DivX Subtitle Decoder,0x00600000,1,1,DivXMedia.ax,0.00.0000.0026 WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000 SampleGrabber,0x00200000,1,1,qedit.dll,6.05.0001.0900 Null Renderer,0x00200000,1,0,qedit.dll,6.05.0001.0900 MPEG-2 Sections and Tables,0x005fffff,1,0,mpeg2data.ax,6.05.0001.0900 IVF source filter,0x00600000,0,1,ivfsrc.ax,5.10.0002.0051 H263 Encode Filter,0x00200000,1,1,h263_32.ax, Smart Tee,0x00200000,1,2,qcap.dll,6.05.0001.0900 Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.0001.0904 Microsoft PCM Audio Mixer,0x00200000,1,1,dxmrtp.dll,5.01.2600.0000 RealPlayer Audio Filter,0x00200000,1,1,rdsf3260.dll,6.00.0012.1010 AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.0001.0902 AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.0001.0902 Intel RTP RPH for G.711/G.723.1,0x00200000,1,1,dxmrtp.dll,5.01.2600.0000 QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.0001.0902 Wave Parser,0x00400000,1,1,quartz.dll,6.05.0001.0902 MIDI Parser,0x00400000,1,1,quartz.dll,6.05.0001.0902 Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.0001.0902 Lyric Parser,0x00400000,1,1,quartz.dll,6.05.0001.0902 File stream renderer,0x00400000,1,1,quartz.dll,6.05.0001.0902 XML Playlist,0x00400000,1,0,wmpasf.dll,10.00.0000.3802 RealMedia Splitter,0x00400000,1,0,rmalt.ax,1.00.0000.0004 AVI Mux,0x00200000,1,0,qcap.dll,6.05.0001.0900 CyberLink QuickTime Source Filter,0x00200000,0,2,qtalt.ax,1.00.0000.1016 Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.0001.0902 File Source (Async.),0x00400000,0,1,quartz.dll,6.05.0001.0902 File Source (URL),0x00400000,0,1,quartz.dll,6.05.0001.0902 Intel RTP SPH for H.263/H.261,0x00200000,1,1,dxmrtp.dll,5.01.2600.0000 Intel RTP RPH for H.263/H.261,0x00200000,1,1,dxmrtp.dll,5.01.2600.0000 Intel RTP RPH for Generic Audio,0x00200000,1,1,dxmrtp.dll,5.01.2600.0000 H261 Encode Filter,0x00200000,1,1,h261_32.ax, Ogg Splitter,0x00600000,1,1,OggDS.DLL, Windows Media Pad VU Data Grabber,0x00600000,1,0,wmmfilt.dll,1.01.2427.0000 Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.0001.0900 BDA MPEG2 Transport Information Filter,0x00200000,1,0,psisrndr.ax,6.05.0001.0900 QT Decompressor,0x00600000,1,1,quartz.dll,6.05.0001.0902 ShotBoundaryDet,0x00200000,1,1,wmmfilt.dll,1.01.2427.0000 MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.0001.0902 Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003 Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003 WDM Streaming Data Transforms: Microsoft Kernel Acoustic Echo Canceller,0x00200000,2,2,,5.03.0000.0900 Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.0000.0900 Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.0000.0900 Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.0000.0900 Video Compressors: WMVideo Encoder DMO,0x00600800,1,1,, MSScreen encoder DMO,0x00600800,1,1,, WMVideo9 Encoder DMO,0x00600800,1,1,, WMVideo Advanced Encoder DMO,0x00600800,1,1,, MSScreen 9 encoder DMO,0x00600800,1,1,, DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.0001.0904 Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055 MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.0001.0902 Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.0001.0900 DivX® 6.0 Codec,0x00200000,1,1,qcap.dll,6.05.0001.0900 Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.0001.0900 Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.0001.0900 Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.0001.0900 Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.0001.0900 Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.0001.0900 Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.0001.0900 Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.0001.0900 Microsoft MPEG-4 Video Codec V2,0x00200000,1,1,qcap.dll,6.05.0001.0900 Microsoft MPEG-4 Video Codec V1,0x00200000,1,1,qcap.dll,6.05.0001.0900 Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.0001.0900 Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.0001.0900 Microsoft Windows Media Video 9,0x00200000,1,1,qcap.dll,6.05.0001.0900 DivX® 6.0 YV12 Codec,0x00200000,1,1,qcap.dll,6.05.0001.0900 Audio Compressors: WM Speech Encoder DMO,0x00600800,1,1,, WMAudio Encoder DMO,0x00600800,1,1,, Vorbis Encoder,0x00200000,1,1,OggDS.DLL, IAC2,0x00200000,1,1,quartz.dll,6.05.0001.0902 Lernout & Hauspie CELP 4.8kbit/s,0x00200000,1,1,quartz.dll,6.05.0001.0902 Lernout & Hauspie SBC 8kbit/s,0x00200000,1,1,quartz.dll,6.05.0001.0902 Lernout & Hauspie SBC 12kbit/s,0x00200000,1,1,quartz.dll,6.05.0001.0902 Lernout & Hauspie SBC 16kbit/s,0x00200000,1,1,quartz.dll,6.05.0001.0902 IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.0001.0902 PCM,0x00200000,1,1,quartz.dll,6.05.0001.0902 Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.0001.0902 ACELP.net,0x00200000,1,1,quartz.dll,6.05.0001.0902 DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.0001.0902 Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.0001.0902 Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.0001.0902 GSM 6.10,0x00200000,1,1,quartz.dll,6.05.0001.0902 Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.0001.0902 CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.0001.0902 CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.0001.0902 MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.0001.0902 Audio Capture Sources: SoundMAX Digital Audio,0x00200000,0,0,qcap.dll,6.05.0001.0900 Midi Renderers: Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.0001.0902 Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.0001.0902 WDM Streaming Capture Devices: SoundMAX Digital Audio,0x00200000,3,2,,5.03.0000.0900 WDM Streaming Rendering Devices: SoundMAX Digital Audio,0x00200000,3,2,,5.03.0000.0900 BDA Network Providers: Microsoft ATSC Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900 Microsoft DVBC Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900 Microsoft DVBS Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900 Microsoft DVBT Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900 BDA Transport Information Renderers: BDA MPEG2 Transport Information Filter,0x00600000,1,0,psisrndr.ax,6.05.0001.0900 MPEG-2 Sections and Tables,0x00600000,1,0,mpeg2data.ax,6.05.0001.0900 WDM Streaming Mixer Devices: Microsoft Kernel Wave Audio Mixer,0x00200000,2,2,,5.03.0000.0900 Audio Renderers: SoundMAX Digital Audio,0x00200000,1,0,quartz.dll,6.05.0001.0902 Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.0001.0902 Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.0001.0902 DirectSound: SoundMAX Digital Audio,0x00200000,1,0,quartz.dll,6.05.0001.0902 WDM Streaming System Devices: SoundMAX Digital Audio,0x00200000,7,2,,5.03.0000.0900
So I guess Hauppauge, but which type/model? ^^ Just tell me and I'll check out a driver for you (if there's any).
So it should be a WinTV-Go or Theater. ^^ Try out the following: Latest driver -> http://hauppauge.lightpath.net/software/wdm/wdm345_22320.exe WinTV app -> http://hauppauge.lightpath.net/software/wintv2000/wintv2k_47_23045.exe
I installed the first one and it has a "!" next to it. I clicked on it and it says This device is not configured correctly. (Code 1) To reinstall the drivers for this device, click Reinstall Driver.
Then it should be the other chip, driver to be found here -> http://hauppauge.lightpath.net/software/wintv_881/wdm88x_346_23061.exe Ed.: Btw. .. before doing this, could you check which model-number the Conexant-chip got (to be found in the lower right corner of the card), just to make sure.
Woo never mind i got it. After i installed the driver it kept saying found new hardware and a thing popped up asking me where to install the drivers from. I had done that already but it couldnt find anything. I did it again and it worked. Thanks for finding the drivers for me. P.S. Anyone know how to hook up a Playstation 2 to this thing?
Never mind. ^^ @PS2-connect: 1x S-video cable 1x Surround (2xcinch) to klinke cable 1x WinTV SourceSelector -> ftp://ftp.shspvr.com/download/wintv_source_selector/wintvsel_1.11.22266.exe 1x WinTV2000 app (the second link under the driver I've posted) ^^
I missed out something ... if there's no S-video-in or even video-in on that card, you'd need a PS2 RF-unit (then you won't need the surround-klinke cable as well).
there is a thing attached to the card that has the red white and yellow cables that i can just plug the ps2 into but i know its more complicated than that EDIT: Nevermind all i did was plug it in and it worked
I used that. You have to use line in and i think something is messed up with that because i tried using line in with something before and it didnt work. I checked if it was muted and it wasnt. Is there another problem with line in that cause no sound?
The card came with a cable that plugs into the card. It has the 3 red white and yellow cords that i plugged the ps2 into and there was another one that could plug into the headphones slot and it was called line out, also on the card was a slot that said line in. I tried plugging the line out cord into the headphones slot and plugged my headphones into the line in slot on the tv card. I have done that and pretty much every other combination.
It'd be easier if you've got a shot of all the cabeling and how you've set it up ... Already tried WinTV line-out to soundcard line-in (pic)? 'Cause without soundcard-connect, there won't be any sound. ^^
