hi peoples performance not modded necessary install maxtreme. maxtreme not install my system windows xp x64 Graphics API: Direct3D 9.0 (NVIDIA GeForce 8800 GTS) Resolution: [1680 x 1050] Color Depth: 32 Version: v1.0 ----- Test0020 - MovingCamera - 4 View SmoothShade, 126.391 Test0030 - MovingCamera - 1 View WireFrame, 57.734 Test0040 - MovingCamera - 1 View SmoothShade, 15.094 Test0041 - Gizmo Transforms - Move, 26.047 Test0042 - Gizmo Transforms - Rotate, 33.64 Test0043 - Gizmo Transforms - Scale, 36.313 Test0050 - Changing Color Test, 1.797 Test0070 - SubObject Vertices, 9.234 Test0080 - SubObject Edges, 14.875 Test0090 - SubObject Faces, 15.36 Test0100 - Extrude Faces, 31.359 Test0110 - Bevel Faces, 8.375 Test0121 - Vertex Soft-Selection, 22.0 Test0130 - Multi-SubObject Texturing, 214.734 Test0140 - Moving Blended Lights, 8.094 Test0171 - Modify Objects - Short, 88.625 Test0210 - Softbody Objects - Flag, 17.313 Test0220 - Sphere Array - Wireframe, 42.172 Test0260 - Sphere Array - Smooth Shaded, 15.0 Test0320 - Xray Objects - Sphere Array, 78.438 Test0323 - Opacity Performance - Blended, 22.281 Test0340 - IK Group, 43.75 Test0370 - Create Tank Scene, 22.187 Test0380 - Test Large Textures, 9.391 Test0390 - Particle Tests, 282.672 Test0400 - Max Hardware Light Test, 22.343 Test0410 - Brutal Flower - Multiple Object Stress, 4.391 Test0531 - UnderWater Animation, 18.109 Test0541 - Architecture Wireframe, 30.031 Test0542 - Architecture Smooth with Edges, 31.734 Test0543 - Architecture Smooth, 2.281 Test0551 - Landscape Wireframe, 78.218 Test0552 - Landscape Smooth with Edges, 71.156 Test0553 - Landscape Smooth, 14.844 Test0561 - Train Wireframe, 18.266 Test0562 - Train Smooth with Edges, 27.344 Test0600 - SpaceFlyby Wireframe, 42.922 Test0601 - SpaceFlyby Smooth with Edges, 67.906 Test0602 - SpaceFlyby Smooth, 38.219 Test0622 - HugeFish Smooth, 30.531 Test0625 - HugeFish Rotate, 19.094 Test1000 - Radiosity, 46.203 Test1010 - Throne Shadowmap, 162.859 Test1020 - CBALLS2, 20.203 Test1030 - SinglePipe2, 89.579 Test1040 - UnderWater, 151.187 Test1050 - SpaceFlyby , 82.032 Test1060 - UnderwaterEscape, 99.062 Test2000 - Rotate Polygon Spaceship, 2.36 Test2010 - MeshSmooth-Polygon Spaceship, 5.64 Test2020 - Effects Gallery, 19.344 Test2030 - Train Smooth, 9.938 Test2040 - FishFlock Smooth, 86.281 Total Test Time , 2534.95 Graphics API: Direct3D 9.0 (NVIDIA Quadro FX 4600) Resolution: [1680 x 1050] Color Depth: 32 Version: v1.0 ----- Test0020 - MovingCamera - 4 View SmoothShade, 123.938 Test0030 - MovingCamera - 1 View WireFrame, 57.031 Test0040 - MovingCamera - 1 View SmoothShade, 14.484 Test0041 - Gizmo Transforms - Move, 26.11 Test0042 - Gizmo Transforms - Rotate, 33.797 Test0043 - Gizmo Transforms - Scale, 36.343 Test0050 - Changing Color Test, 1.813 Test0070 - SubObject Vertices, 9.344 Test0080 - SubObject Edges, 15.031 Test0090 - SubObject Faces, 15.562 Test0100 - Extrude Faces, 31.141 Test0110 - Bevel Faces, 8.484 Test0121 - Vertex Soft-Selection, 21.969 Test0130 - Multi-SubObject Texturing, 35.156 Test0140 - Moving Blended Lights, 8.219 Test0171 - Modify Objects - Short, 91.047 Test0210 - Softbody Objects - Flag, 17.437 Test0220 - Sphere Array - Wireframe, 42.406 Test0260 - Sphere Array - Smooth Shaded, 14.938 Test0320 - Xray Objects - Sphere Array, 79.016 Test0323 - Opacity Performance - Blended, 22.203 Test0340 - IK Group, 44.047 Test0370 - Create Tank Scene, 22.25 Test0380 - Test Large Textures, 9.391 Test0390 - Particle Tests, 301.703 Test0400 - Max Hardware Light Test, 22.797 Test0410 - Brutal Flower - Multiple Object Stress, 4.469 Test0531 - UnderWater Animation, 18.187 Test0541 - Architecture Wireframe, 30.61 Test0542 - Architecture Smooth with Edges, 31.641 Test0543 - Architecture Smooth, 2.234 Test0551 - Landscape Wireframe, 89.703 Test0552 - Landscape Smooth with Edges, 97.719 Test0553 - Landscape Smooth, 65.547 Test0561 - Train Wireframe, 18.204 Test0562 - Train Smooth with Edges, 27.547 Test0600 - SpaceFlyby Wireframe, 43.032 Test0601 - SpaceFlyby Smooth with Edges, 68.187 Test0602 - SpaceFlyby Smooth, 38.406 Test0622 - HugeFish Smooth, 30.703 Test0625 - HugeFish Rotate, 19.094 Test1000 - Radiosity, 46.25 Test1010 - Throne Shadowmap, 188.64 Test1020 - CBALLS2, 20.25 Test1030 - SinglePipe2, 89.688 Test1040 - UnderWater, 151.594 Test1050 - SpaceFlyby , 82.734 Test1060 - UnderwaterEscape, 99.094 Test2000 - Rotate Polygon Spaceship, 2.391 Test2010 - MeshSmooth-Polygon Spaceship, 5.718 Test2020 - Effects Gallery, 19.609 Test2030 - Train Smooth, 9.953 Test2040 - FishFlock Smooth, 87.094 Total Test Time , 2493.95
Same performance. From what I can see the differences are all within the margin of error. In other words, it doesn't work, at least on the software that he is using.
hi friends, news to transformer its necessary patch SoftQuadro4 (func single win xp, in x64 not func ) 3ds max 6 + MAXtreme 6= bad performance 3ds max 8 + MAXtreme 8= bad performance 3ds max 2008 + MAXtreme 10= nice performance
Hmm.. You mean it will only work if you use the SoftQuadro4 patch? What's the performance difference like?
Sorry, what was it that you needed to post again? BTW, you can use the Attachment mod (just below the text entry area when you reply) to attach files like videos and pictures.
5 posts yeeee testing 3dsmax6 + directx driver http://www.viz.com.br/arquivos/video1.wmv 3dsmax 2008 + maxtreme driver http://www.viz.com.br/arquivos/video2.wmv
I got good results using Cinebench 10 8800 Ultra (Original Driver 6.14.11.7474) Open GL: 5780 Quadro FX 4600 (First install 6.14.11.6947) Open GL: 6682 8800 Ultra (Re-Installed 6.14.11.7474) Open GL: 5751 Quadro FX 4600 (Re-Installed 6.14.11.6947) Open GL: 6710 Thats a 16% increase in Open GL Viewports. Thanks for the article EDIT: I didn't have time to test SPECviewperf 10, but looking at the chart below (the top score as of this writing), the mod is scoring on par with a regular FX 4600. I'll test SPEC later and post back.
Ok, I have the SPECViewperf 10 resutls. Higher is Better 8800 Ultra (6.14.11.7474) SPECViewperf Maya: 39.04 SPECViewperf Max: 12.08 Cinebench 10 OpenGL: 5951 Quadro FX 4600 driver (6.14.11.7474) SPECViewperf Maya: 39.06 SPECViewperf Max: 23.05 Cinebench 10 OpenGL: 6823 Quadro FX 4600 driver (6.14.11.6947) SPECViewperf Maya: 38.99 SPECViewperf Max: 23.25 Cinebench 10 OpenGL: 6827
Ok, so it only works for 3dsmax but doesn't work for Maya, from the results and what I read so far. Is it possible for you to test it with the solidworks viewset? and also other viewsets if possible, then we can find out exactly what works, and what does not.
