Kuala Lumpur, Oct 29th, 2015 – The featured-packed OPPO Neo 7, a new addition to the OPPO family will be available in Malaysia nationwide starting from 3rd November 2015 at the price of RM798. The Neo 7 is set to brighten up the entry-level with its wide range of performance upgrades and an attractive streamlined arc edge. Available in the color options of white and black, the 5.0 inch screen makes the Neo 7 a perfect fit for single-hand operation. The Neo 7’s mirror surface uses optical coating and fiber glass for increased strength and elasticity, with a thinness of only 0.56 mm. While the special laminating processes make the Neo 7's back look smooth and clear, OPPO also paired a high-strength magnesium aluminum alloy at the core of Neo 7 to reduce its weight to only 141g. Thus, users are able to feel the ease and premium comfort in hand with a unique streamlined arc that based on the methodology of concentric circular arc cutting. Additionally, its attractive design provides great structural strength and superb heat dissipation at the same time Powered with Quad-core CPU, 1GB RAM and 16GB ROM, the Neo 7 is ready to bring users an extraordinarily smooth gaming experience. Its 2420 mAh battery capacity satisfies the demand of cruising for a whole day. Moreover, the OPPO Neo 7 is configured with two SIM card slots to make switching between business and private use easy. Both slots support 4G networks with top speeds of up to 150 Mbps and make surfing the web or watching online videos a breeze. The microSD card slot supports memory expansion of up to 128 GB to document more moments of the user’s life. Packed with an 8-megapixel back-illuminated sensor with a photo sensitive area of up to 1/4 inch, a wide f/2.0 aperture; and an upgraded 5-megapixel front camera with high light-sensitivity and frame rate, the Neo 7 effectively reduces noise to take clear pictures and videos in all scenarios. Equipped with the Pure Image 2.0+ imaging platform, the new device offers a wide range of plug-ins for customized camera functionality. Nevertheless, the Neo 7 features a light-sensitive sensor that can adjust the screen brightness effortlessly to a user’s face, allowing users to take great selfies regardless of the light condition. Its “Colorful Night Mode” that uses the smart multi-frame optimization and synthesis algorithm is also designed to effectively remove noise and improve brightness and clarity during low light condition. There are 11 filters and 3 beautify modes available, and the Neo 7 can easily edit images without downloading additional apps. Special functions like Double Exposure, which allows users to take two separate photos and overlap them to create a single image, result in unique and fun photographic effect. As a special addition to the 4G edition, Ultra HD shoots six photos consecutively and combines the best parts of each to a create a 24-megapixel ultra HD image, which has four times the clarity of ordinary photos. Running in OPPO’s upgraded in-house ColorOS 2.1 that based on Android 5.1, users of Neo 7 are able to feel a smoother performance, a steady scrolling with more memory and power.
