Patriot 1GB 3200+ XBL Dual Channel Memory Kit Review Posted!
Discussion in 'Reviews & Articles' started by Dashken, Mar 7, 2005.
  1. Chai
    TCCD don't like voltages as much as others do.
  2. ChampionLLY
    ChampionLLY News Writer
    hmm.. somebody told me that b4..
    i saw another review website pushing to to 275Mhz too, but they were @ 2.85V...
    my own result conclude that higher voltage = more stability
    mine is Rev2.0, i dunno if that affects anything..
  3. Papercut
    Papercut Newbie
    Different modules will need different settings to get the most out of them. Just do whatever works best for yours.
  4. ChampionLLY
    diff modules as in diff revision?
    i would like to know the PCB version of the one reviewed,
    heard that 808 is the best..
  5. ChampionLLY
    well, aft over 150 diff combinations & stability testing, i got these best results:
    max ram for CL2.0
    HTT215*11 DDR430@2-2-2-5
    max 11x for CL2.0:
    HTT235*11 DDR470@2-3-3-8
    max 9x for CL2.5:
    HTT290*9 [email protected]
  6. Papercut
    Papercut Newbie
    Different modules as in different modules...even within the same revision. It's the same with CPUs, graphics cards, etc...2 components may not overclock the same even if all other factors are constant. That's why you can't always copy others' settings and expect it to work fine on your hardware.
  7. Chai
    We have given this away in a contest, but it should be an early revision.
  8. ChampionLLY
    okok, u mean each component is unique, juz like the 2 cores in dual-core processors are diff... ;)
    shall keep further trying to the ultimate best setting
  9. ChampionLLY
    ic... nvm den..
    thx anyway
