hey guys... post your pentium 4 temperature here.. including system , hard disk, northbridge etc etc.. please list down youir specs too .. here's mine.. Pentium 4 2.6C o/c @ 3.12Ghz Abit AI7 Maxtor DiamondMax Plus 8 Idle P4 : 46C Sys : 41C PWM : 46C Seti@home P4 : 60C System : 47C PWM : 60C
not suprising though reaching 60°c with an intel... mine is [email protected]... idle @3000RPM 46°c idle @4000RPM 44°c idle @6000RPM 42°c Full load @3000RPM 58°c Full load @4000RPM 55°c Full load @6000RPM 54°c haha... I used the distributed foldings to test it... crazy man this...
mobo:asus p4p800 2.4C to 3.0 (250x4) idle:36-39°c full load:folding;gaming;anything 50°c. seems quite normal to me. using stock cooling,crappiest casing and some ramsinks.[/list]
Nothing! Lets see mine : p4 [email protected] DDR 266@347 [kingmax ddr400] sysbus 130 temp : idle 37ºC ; fullload 54ºC pretty high
mine p4 2.8e 512 kingston pc3200 ram no o/c everything stock cpu temp at 52c system at 41c high huh...
My old [email protected] Mobo Abit IS7-E Ram 2x256 DDR 266 Thermaltake P4 Spark 7 Idle: 48C Load: 58-60C
P4 2.8E @ 3.64 ghz Abit IS7-E Cooling cheap H2O. Idle temp: 36 C Load temp @ Prime95 torture test 48 C Who said prescott's are too hot ?
new temps : IDLE case : 35c cpu : 39c pwm : 37c LOAD case : 37c cpu : 56c pwm : 55c stock cooler with coolermaster thermal paste
Mine is ECS P4S5A/DX+ Motherboard Intel Pentium 4 Proccessor 2A Ghz @ 2.66Ghz 400FSB Idle Temps CPU - 37 System - 38 Load CPU - 40 System - 39
i just picked up a cpu on ebay, a P4 2.53 @ 3.2 right now in my abit bd7II. Right now its 53c case is 50c (hot in socal). Should I downclock it? Edit - backed down to 3.1, did some burning time. temp at idle is like mid 40s now. but then again, I got teh AC on... gosh I hate socal heat!!!!
The temperature is still ok if you are not overvolting I don't worry much about the CPU temperature except it reaches 60c
what do u guys use to get this temps? speedfan's interface is complicating coz they juz name the temps, temp1, temp2 etc...and the only other way to check CPU temp is in the BIOs, can anyone reidrect me to another GUI interface that gives temps?
mine currently 2.8E at 3.6 with 1.55 vcore CM hyper6 msi 865pe board 2X256 kvr hynix d-43 ram idel temp around 38C or 39C...load 49c or to 51C..reading on speedfan
U guys do realise that posting your temps mean absolutely nothing at all right ? Each board has their own thermal sensor calibrated in their own way. Abit uses a formula based off running voltage. ASUS supposedly reads the onboard die. Yet using the same CPU and changing to different boards in a semi-controlled environment, u can witness temperature swings of up to 15degC from board to board. Only way to have any reasonable accurate temperatures is a way I discussed with Chai sometime ago. Drill a small hole through the IHS of the P4 and insert a calibrated temp probe right up against the core in there.
