I don't know if NGOhq is bullshitting but it looks they found an way to put Physx drivers on 3xxx series... Here the link If that's appears to be true it's would be kick ass Another way to bluff the system Update : He claims it will only works on the 38xx series for now because because AMD thinks NGOHQ.com is not worthy enough to borrow review samples. -The mod will work with VISTA and XP (x32-x64)
Ummm... ...so how exactly would that work if ATI hadn't implemented the PhysX API/command set on their chippery?
Sure...but I'm presuming that there are hardware-specific calls involved there that, on an ATI board, have no hardware to call on. Especially granted that I'm sure ATI hasn't tried any CUDA stuff or anything yet... Seems vaguely like saying "oh, I got Alpha code to run on an ARM processor"
...I guess I assumed that they would have adapted the Physx commands to their hardware though - would they have been daft enough to make it so generic it could run on anybody's card? Try it on a Kyro II.
Since both ATI and NVIDIA cards have a C++ ish programming language, both can be programmed.. If nvidia can program the nvidia card to run physics operations, then the ati card can be programed to run physics operations.
You have an GOOD example... the same guy who is making the driver(REGENERATION) tried the new drivers on his 8800GT (who dont have any PHYSIX hardware) and he got like 1200 pts more in 3d mark... so i think you dont need physx hardware all can be reprogramed ... you just need to know how... anyways.I remember the old slogan of NVIDIA ... who is about the same than now World Leader in Programmable Graphics... Give you an hint
Well, both ATI and NVIDIA GPUs are now based on the unified architecture, which means their stream processors are really general processors that can be programmed to do virtually anything. Kinda like a CPU. The NVIDIA PhysX, as we covered here, is a software solution that makes use of the GPU's stream processors. It doesn't require any special PhysX hardware. So it's not inconceivable that AMD-ATI might be able to do the same thing. Basically, it's about accelerating PhysX using the GPU instead of the CPU. Even NVIDIA has only managed to get two applications to support PhysX on the GPU even though there are even more applications that support PhysX. These only process PhysX on the CPU or the AGEIA PhysX PPU for now.
...apparently I over-read how important the hardware aspect of the PhysX engine was. If it can be done through pure software...why did PhysX ever have hardware to begin with, like the Aegia card?
It's not pure software. It's just to drivers that take advantage of the multipurpose GPU that's more than capable of just rendering graphics. It's even capable of doing Folding@Home. So what do you think?
hmm, Asus still selling their Ageia Physx card here..I wonder is it any difference from using the card with using the software based physx =/
I guess that's what I'm getting at...if what they do is un-hardware-specific enough to run on the GPU anyway, is there actually a point to the Ageia card? ...and if they didn't need the hardware, why didn't they just start at the beginning as a software technology?
