just got a wireless router not long. i'd setup the network following the wizard on xp. the wireless router dont hv printer server feature, if i want to do a print job from the laptop thru the desktop, do i hv to install printer driver on the laptop?
On the PC that the printer is physically hooked up to, right click on the icon (once you go into Printers and Fax in Control Panel) and select sharing. From there select allow sharing. At the other PC, go into control panel, select printers and fax. Click on Add printer, choose from network printer (workgroup name has to be the same on both PCs) and then follow the onscreen instructions (it will install the driver on your pc.)
when come to selecting the drivers, it wasn't able to find the drivers but i dwnload it from the net and it works. thanks for the instruction!!
