Hi this is my first post here so here goes. I have recently purchased one QX6850 OEM but the cpu seems a little funny to me. I cant really do more than 2 things at a time with it or it really starts to struggle. Just tonight I tried installing assasin’s creed and open IE and man did it slow down. Just wondering if you have any ideas at all. SYS SPECS : Asus Slient Square CPU Coller. Thermaltake Toughpower 750 watt. XFX 790i Ultra Motherboard. XFX GTX280 XXX Edition. Team EXTREME DDR-3 1333Mhz QX6850 SLAFN G0 Western Digital 250GB Sata as primary and 3 other Hard drives just used for storage of pics and stuff. Proview 19” Wide LCD and 17”LCD Benq as secondary. If you could help out that would be fantastic as I have contacted the manufacturer and my supplier and they basically couldn’t give a toss. P.S as a side note when I first removed my old Q6600 and installed the new qx6850, I checked it in bios and it posted telling me that it was running at 5000Mhz with a multi of x9. Then CPUID is picking it up running at 2000mhz core instead of 3000. I have included a couple of screenies one showing 2000mhz then like a second later showing 3000 so friken wierd. Thanks in advance.
Got speed step on? What is the cpu temp? Not overheating is it? Checked for the latest bios for your mobo?
Hi yeah speed step is currently turned on in BIOS and i also have the latest version of the bios. Heres another pic for the Temps.
Try completely uninstalling everything related to nvidia ESA. Another guy had a similar problem to yours and fixed it by doing that.
Nothing wrong with that. That's because it automatically steps down the clock speed (by reducing the multiplier) and voltage when the processor is idle in order to save power. If you don't want this to happen, disable C1E & SpeedStep. As for the BIOS, it is reporting the CPU speed wrongly.
Enthusiast System Architecture here..this might help..Hmm, maybe Max could provide more information in this matter
BTW, you have an OEM chip... or an engineering sample? If you have an engineering sample, please read this - Tech ARP - Why You Should AVOID Core 2 Duo Engineering Samples Rev. 3.0
ok an answer for the masses. I have 2GB of team extreme ddr3 1333. The CPU is an OEM not a eng sample, the supplier buys in packs of ten without the fansink and box to save dollars. I have uninstalled the esa software that came with the board and no differance. I acctually managed last night to OC it upto 3.66GHZ by upping the Multi to x11 still no performance increase. Then I got to 4.00GHz on x12 multi still nothing. upped the vcore to next level BOOOOMMMMM !!!!! then she started screaming with speed. BOOMMMM BSOD !!! droped it back to stock. now all of a sudden it seems to perform a little better for some reason. So confused it isnt funny I might keep playing I think see what she can do. Oh by the way at an x11 multi x2 above stock the cpu's temp dropped 6 degrees celcius.
