Re: AppleScript property "bounds" of window
Discussion in 'BIOS Optimization Guide (BOG)' started by idunknow, Apr 13, 2015.
  1. idunknow
    idunknow Newbie
    Hi guys:
    I have a Asus P5G41T-M LX motherboard. In JumperFree Configuration menu of BIOS Setup, when I set [AI Overclocking] item to [Overclock Profile], appears [Overclock Options] item, whose configuration options are: [Overclock 5%] [Overclock 10%], [overclock 15%] [overclock 20%], [Test Mode].
    What is [Test Mode]? When should I use it?
    Thanks.
    ___________________
    dolii
    AFAIK, Test Mode allows you to exceed the overclock limits by manually adjusting the overclock speeds.
