Several questions about vista 32
Discussion in 'General Software' started by dukeman, Jun 16, 2007.
  1. dukeman
    dukeman Newbie
    I just got Vista 32 Ultimate and i have a question.
    Can you OC your 8800 gts with vista? i have tried several different programs to oc and none of them work.
    Plus i thought i purchase that cool looking view program, the one with the multi screens that you can click on but i cant find it. i think it is called aurora or something like that.
    thanks
  2. zy
    zy zynine.com Staff Member
    i think you can use nVidia nTune software to do it :think:
  3. dukeman
    dukeman Newbie
    thanks, that worked.
    i have duel boot with xp home and vista to set the record straight.
    now how do i get into safe mode. i hit tab and it does that memory test, if i hit F8 like in xp nothing happens
  4. peaz
    Hmm u mean the 3d flip thing? press windows key + tab
  5. dukeman
    dukeman Newbie
  6. Chai
  7. dukeman
    dukeman Newbie
    thanks. if i took more then 2 seconds to read his post i would of seen that. it is cool but doesnt seem to have a real purpose besides looking neat.
    now if ea/nvidia can figure out how to fix the memory error in bf2142 i would be a real happy camper.
  8. dukeman
    dukeman Newbie
    how do i get into safe mode with a dual boot. f8 is no longer working since i installed vista
  9. zy
    if you have dual boot you should be able to see 2 options to choose which OS .. from there, there should be an advanced option by pressing a key ..
    unless, you are using a different boot loader
  10. dukeman
    dukeman Newbie
    it says press F8 for advanced options but nothing happens when i press it.
    i am using whatever vista installed for booting program. this is annoying the crap out of me
  11. dukeman
    dukeman Newbie
    i found a work around for it.
    i have to start loading the operating system that i want to use and then after the windows thing pops up i reboot and then when i start over i get the opition for safemode. works for xp and vista
  12. Maximus_Detritus
    Maximus_Detritus Moderator
  13. PsYkHoTiK
    PsYkHoTiK Admin nerd
    One thing about Vista that I do hate. Whenever you swap hardware, you need to reactivate windows. :\ It'd be easy if it was as easy as activating it online... BUT NOOOOO! I gotta call and talk to an off shored person to reactivate it... :doh:
  14. Adrian Wong
    Yeah, they want to ascertain that you are really upgrading your hardware, and not installing it on another system. :doh:
  15. dukeman
    dukeman Newbie
    i got a oem copy that is always activated so that is not a problem for me.
  16. PsYkHoTiK
    Actually the OEMs lock the copy onto your hardware. Mine is retail.
  17. dukeman
    dukeman Newbie
    then i guess i would just reload vista.
  18. Adrian Wong
    Eh, I don't think so. OEM copies don't seem to need activation or reactivation. :think:
  19. Chai
    I think for OEM, if you try to install it on other machines, it just wont work. :p
  20. zy
    OEM copies no need activate ? :think:
    i dont even know mine is what.. i only know its express upgrade & i need to activate ;p
