The Linux Kernel As An Exquisitely Sensitive Stability Test For Overclocked Systems
Discussion in 'Reviews & Articles' started by Adrian Wong, Jun 19, 2013.
  1. Adrian Wong
    Running an overclocked PC is not a problem, provided that the PC is stable at the overclocked settings. Several programs are available to assess system stability by stress-testing the overclocked system. However, most overclockers do not know that the Linux kernel is an exquisitely sensitive tool to detect instabilities in an overclocked system. In fact, it is more accurate and sensitive than either Prime95 or IBT/LinX.
    The Linux kernel supplies users with a dead simple method for measuring hardware instabilities - like those caused by an 'unstable' overclock. There is nothing special to install as this functionality seems to be naively included in the kernel itself. To use it, simply run a standard stress test such as Prime95 or Linpack and watch the output from dmesg. If the system is unstable due to insufficient voltage settings, excessive heat, it will report...
    Link : The Linux Kernel As An Exquisitely Sensitive Stability Test For Overclocked Systems
  2. Chai
    Cool, I may try this one day. I feel right at home using Linux, although I don't like it at all... :haha:
