The Mobile GPU Comparison Guide
Discussion in 'Reviews & Articles' started by peaz, May 2, 2004.
  1. Adrian Wong
    Oh, thanks for the heads-up again! +rep! :thumb:
    Mobile GPU Comparison Guide Rev. 10.1
    These days, there are so many mobile GPU models that it has become quite impossible to keep up with the different configurations. Therefore, we decided to compile this guide to provide an easy reference for those who are interested in comparing the specifications of the various mobile GPUs in the market as well as those already obsolescent or obsolete.
    Currently covering 240 mobile GPUs, this comprehensive comparison will allow you to easily compare 18 different specifications for each and every GPU. We hope it will prove to be a useful reference. We will keep this guide updated regularly so do check back for the latest updates.
    Here are the latest updates:
    Link : Mobile GPU Comparison Guide Rev. 10.1
  3. Angel
    Angel Newbie
    Memory speed of GeForce 305M is up to 700MHz, memory bandwidth of GeForce 305M is up to 11.2GB/s.
    Memory speed of GeForce 310M is up to 800MHz, memory bandwidth of GeForce 310M is up to 12.8GB/s.
    Memory bandwidth of GeForce 320M is ~17.06GB/s.
    Memory type of GeForce 8400M GS is DDR2/GDDR3, memory speed of GeForce 8400M GS is 400MHz/600Mhz, memory bandwidth of GeForce 8400M GS is 6.4GB/s or 9.6GB/s.
    Memory type of GeForce 9100M G is DDR2/DDR3, memory speed of GeForce 9100M G is 400MHz/533Mhz, memory bandwidth of GeForce 9100M G is ~12.8GB/s or ~17.06GB/s.
    GeForce 9400M GS should be modifed to GeForce 9400M G, memory bandwidth of GeForce 9400M G is ~12.8GB/s or ~17.06GB/s.
    Memory bandwidth of GeForce G102M is ~12.8GB/s.
    Memory bandwidth of Mobility Radeon HD 4220,4225,4250,4270 is ~12.8GB/s or ~17.06GB/s.
    All the comma should be removed from number, like Mobility Radeon HD 2,400 should be modified to Radeon HD 2400.
    1 person likes this.
  4. Adrian Wong
    Thanks for the heads up, Angel!! +rep! :thumb: :beer:
  5. Adrian Wong
    Angel, I went through the corrections you posted. FYI, I've corrected most of them. However, some of the GPUs are sharing memory with the CPU.
    In those cases, I've listed them as 128-bits (shared) and their memory bandwidth have a tilde (~) in front. There's no way to know for sure how much bandwidth the integrated GPUs have, so we assume they have half of the maximum bandwidth possible.
  6. Adrian Wong
    Mobile GPU Comparison Guide Rev. 10.2
    Currently covering 246 mobile GPUs, this comprehensive comparison will allow you to easily compare 18 different specifications for each and every GPU. We hope it will prove to be a useful reference. We will keep this guide updated regularly so do check back for the latest updates.
    Link : Mobile GPU Comparison Guide Rev. 10.2
  7. Adrian Wong
    Mobile GPU Comparison Guide Rev. 10.3
    Link : Mobile GPU Comparison Guide Rev. 10.3
  8. Adrian Wong
    Mobile GPU Comparison Guide Rev. 10.4
    Currently covering 250 mobile GPUs, this comprehensive comparison will allow you to easily compare 19 different specifications for each and every GPU. We hope it will prove to be a useful reference. We will keep this guide updated regularly so do check back for the latest updates.
    Link : Mobile GPU Comparison Guide Rev. 10.4
  9. Angel
    Angel Newbie
    The specifications of GeForce GT 120M, GT 220M and GeForce GT 320M have some mistakes
    Fabrication process of GeForce GT 120M is 65nm, Code name of it is G96M.
    Fabrication process of GeForce GT 220M is 65nm or 55nm.
    Core speed of GeForce GT 220M is 500MHz 1250MHz shaders with 65nm of G96M.
    Core speed of GeForce GT 220M is 550MHz 1350MHz shaders with 55nm of G96b.
    Fabrication process of GeForce GT 320M is 55nm or 40nm.
    GeForce GT 320M with 55nm has the same specification with GeForce GT 220M with 55nm.
    Code name of GeForce GT 320M is GT216, united shaders of it is 24, core speed of it is 500MHz 1100MHz shaders with 40nm.
    You can check all with pictures of gpu-z search by Internet.
    2 people like this.
  10. Max_87
    Max_87 huehuehue
    Thanks for informing us about the mistakes :thumb:
  11. Adrian Wong
    Thanks for the heads-up again, Angel! :thumb: :thumb:
    +rep!
  12. Adrian Wong
    Mobile GPU Comparison Guide Rev. 10.5
    Currently covering 254 mobile GPUs, this comprehensive comparison will allow you to easily compare 19 different specifications for each and every GPU. We hope it will prove to be a useful reference. We will keep this guide updated regularly so do check back for the latest updates.
    Here are the latest updates :
    Link : Mobile GPU Comparison Guide Rev. 10.5
  13. Angel
    Angel Newbie
    Why GT 540M has only 4 rops, not 16 rops?
    I think memory speed of GT 320M Rev.1 should be modifed to 500Mhz or 800Mhz like GT 220M Rev.2.
  14. Adrian Wong
    I will have to double-check on those specs.
  15. Adrian Wong
    Mobile GPU Comparison Guide Rev. 10.6
    Currently covering 260 mobile GPUs, this comprehensive comparison will allow you to easily compare 19 different specifications for each and every GPU. We hope it will prove to be a useful reference. We will keep this guide updated regularly so do check back for the latest updates.
    Link : Mobile GPU Comparison Guide Rev. 10.6
  16. Adrian Wong
    Mobile GPU Comparison Guide Rev. 10.7
    Currently covering 275 mobile GPUs, this comprehensive comparison will allow you to easily compare 20 different specifications for each and every GPU. We hope it will prove to be a useful reference. We will keep this guide updated regularly so do check back for the latest updates.
    Link : Mobile GPU Comparison Guide Rev. 10.7
  17. Adrian Wong
    Mobile GPU Comparison Guide Rev. 10.8
    Currently covering 284 mobile GPUs, this comprehensive comparison will allow you to easily compare 20 different specifications for each and every GPU. We hope it will prove to be a useful reference. We will keep this guide updated regularly so do check back for the latest updates.
    Link : Mobile GPU Comparison Guide Rev. 10.8
  18. Adrian Wong
    Mobile GPU Comparison Guide Rev. 10.9
    Currently covering 286 mobile GPUs, this comprehensive comparison will allow you to easily compare 20 different specifications for each and every GPU. We hope it will prove to be a useful reference. We will keep this guide updated regularly so do check back for the latest updates.
    Link : Mobile GPU Comparison Guide Rev. 10.9
  19. bp13
    bp13 Newbie
    For the NVIDIA Geforce Go 6150. The core is actually 425Mhz not 475Mhz. And the bandwidth is 5.3GB/s and the texture and pixel fill rates are both 0.4GPixels 0.4 GTexels/s. Also the memory clock takes the speed of the default system ram speed because that's where it gets the memory from. For example my system ram's mhz is 600Mhz and so is my memory clock.
    I also notice it says N/A for powermizer. This GPU does have powermizer of core speeds of 100Mhz 351Mhz and 425Mhz. Not sure what version of powermizer it is. I could check if I knew how to.
    Thanks.
  20. Adrian Wong
    Hi bp13,
    Thanks for the heads-up! I will double-check on the GeForce Go 6150's specs.
    Unfortunately, I'm not sure how to check the PowerMizer version either. :(
