Thin ITX motherboards
Discussion in 'Processors, Motherboards & Memory' started by zy, Oct 3, 2014.
  1. zy
    zy Staff Member
    Can someone shed some light on Thin-ITX boards. I'm not too familiar with them and I have not seen one in person before.
    Are all Thin-ITX power adapter socket the same size?
    If they are a standard (which I believe it should be), does any one know what laptop power adapter fits Thin-ITX boards? I haven't found too much info and had some conflicting info.
    I have many Dell adapters currently :lol:
  2. Trinity
    Work | Inspiron 15R | Core i5 M 460 | 8GB DDR3 | 120GB SSD | 240GB SSD
    Play | i5-3750K | 32GB DDR3 | HD7850 | 256GB SSD | 1.5TB + 1TB HDD
    Travel | i5-4250U | 4GB DDR3 | 120GB SSD
    Old | T7200 | 4GB DDR2 | GFGo7300 | 320GB HDD
    Look at those specs....:)
  3. zy
    zy Staff Member
    Those specs needs a minor update :lol:
    1 person likes this.
  4. Chai
    Unfortunately, it doesn't seem to have a standard, like any laptops even from the same manufacturer. You may need to get one of those universal adapters.
  5. zy
    zy Staff Member
    Ya, sometimes laptop same manufacturers have different plug designs. :wall:
    I think I just manage to find some information. Seems like manufacturers just wants to make our lives difficult. :lol:
    High Wattage Power Adapter Designs for AIO
    Socketed Thin-ITX
    19V, 7.4mm OD, 5.1mm ID
    Commonly used by Dell. And maybe HP.
    Atom-based ITX or those embedded boards or AMD ITX with DC in.
    19V, 5.5mm OD, 2.5mm ID
    Most common, used by many laptop manufacturers
  6. Chai
    But there are so many laptop manufacturers... I don't think it is really that standard.
    Sent from my Nexus 7 using Tapatalk
  7. Adrian Wong
    I think some of them are also using 12V power supplies, right?
