Weird thumbdrive issue.
Discussion in 'General Hardware' started by Lacus, Sep 6, 2008.
  1. Lacus
    Lacus Newbie
    Well, my thumbdrive seem to be giving me some problem..first, copy files to the thumbdrive is very slow and then data seems to get corrupted (for files 100mb and above).does this actually mean that the thumbdrive is faulty? The brand is Emtec though...
  2. Dashken
    Dashken Administrator!
    Try it on another PC, if you got the same result, then most probably is the thumbdrive.
  3. Adrian Wong
    Yeah, that's what I would do too.
  4. Lacus
    Lacus Newbie
    well, tested on both laptop and desktop..same also :(...can't be both usb slots are 1.1 o_O?
  5. Chai
    Looks like thumb drive problem.
  6. Lacus
    Lacus Newbie
    yeah..screw it -.-..gonna get a new 1 then >_>
  7. jamotto
    jamotto Newbie
    Did you try reformatting it?
  8. Lacus
    Lacus Newbie
    already formated it..took me like 10+ minutes for 2gb :faint:
  9. Dashken
    Pretty much can confirm sot already. :D
  10. Lacus
    Lacus Newbie
    somemore cannot rma it..can't find the receipt :wall:
  11. mikegas
    mikegas Newbie
    RMA need receipt? I tot just use serial number. Maybe can check with the distributors
  12. Adrian Wong
    You only need the receipt if you want to RMA it through the retailer. Otherwise, you can directly RMA the USB drive via the distributor... or better still, the manufacturer.
    I did so with my two SanDisk memory cards. So much easier to deal directly with the manufacturer.
