saving $$ for other hobbies heres the sidepanel after cut still need to file to achieve better results
Pretty good looking cut I must say, dremel? Looks like you make a few slips in the panel. Those are going to be difficult to remove. How are you attaching the window?
Thanks gain experience and skills, I Used A Black And Decker Rotary Tool RTX 1 attachment Normal B&D Cutting Disc used about 10 Discs, took me 2 hour 30 minutes to cut off that side panel window for Precission straight cuts , yea about the few slips,the paint came off, i still havent file the sides of the side panel window and sandpaper.
Will you be repainting the side panel then? I would assume so. Make sure you get those slips really smooth before repainting because they will stick out like a sore thumb when you paint. If they are really deep try using something like jb weld to fill it in, then sandpaper it and paint.
yea i will be repainting it, tomorow need to sand paper first Here they are,Check out The Results it may not be good as perfect, still need to sandpaper the sides took me half an hour to file all the sides nicely,Pictures are better quality now taken with Canon A710 IS :thumbs: more pics of the side panels
When is your project going to finish? It take so long time, we are so wanting to see the finished product already...
As Soon as Possbile,even i want to finish it fast as i can, dont worry it be soon coming K here are the updates Top Panel Ready to be Cut My Work Place Halfway Cutting ____________________________________________________________________ Finish Cut Off Filed, sanded off the epoxy resin which i covered the old holes which i drilled last time. Here Are The Side Panels need to be sandpapered and needs a respray together as the top window top only.Which Im gonna do tomorow.
heres updates from yesterday as you can see the right 2 bezel's i put there as the alu u can see 4 pointers i had to file abit so the screw can screw in thru properly screwed nicely i just bought Two lian li rom slot cover's heres the top part drillled and screwed to do list, Cut arcylic for the side panel window, top panel, Front Panel Custom Front Panel Sanding side panels , respray. and etc
Heres The Alu i want to use for the front panel, so it match with the top roof,and give it an ALU look Drilled and screwed on with nuts,sorry didnt take pics of the process of drilling, Heres the Front Panel Arcylic , measured and made markings I havent cut the Front panel arcylic yet , it was late already, plus i havent sanded the side panels yet , i do it by tomorow. Heres some Pics with the roof,sidepanel, halfway done front panel :blush: assembling the top roof
Almost close to Final heres the arcylic top roof arcylic with 120mm blowhole :thumbs: heres the test fit still gotta do some filing its going to finish soon,
Its Going To be Finish soon Heres the Front panel sprayed, and glued More pics of the front panel :hehe: :thumbs: B] Left Side panel, to be sanded, respray :thumbs: , by now i can start doing the electronics eace:
Heres the switch fitted Taking out components from old casing Good Air Space pump, which blow air, helps me clean the mobo, its suppose to be for the Air SPace bed Hdd,soundcard,Graphic CArd the mobo,Dustless after cleaned Mobo Fitted in the new casing The internals is not finish yet, still got more to do Side panel not yet done,tomorow gonna sand it and respray.Stay tune
ok im back guys added the side panel window and two eye's[80mm fan] + repsrayed side panels left panel right panel whole case and i got a new stuffs for Dragzon specs Amd Athlon 64 X2 5200+ Abit AN52 S Kingston 1GB x2 DDR2 667 Gigabyte 8500GT Turbo Force Ultra Edition Please Ignore the Asus Motherboard and the Geforce 7200gs that was borrowed from my dad to run for while. Thermaltake Ruby Orb and Abit AN52S, got a nice bag indeed man i love this mobo orange colour board The mounting fittings for Ruby Orb Man, This thing is HUGE the overall look some night shots There will be an Upcoming Lan party will be held in Penang which is around Nov/Dec 07, i be participating for the case modification, there are Overclocking/underclocking , Gaming compettion too, im not sure what games yet. Planning now for the upcoming lan party penang 2007 case modding compettion
