Yeah, these kind of paint does have enough time to 'stick' and 'bond' onto the surface of the aluminum because it dries up too fast. Just like what happened to my casing paint job only last for one or two months until the paint is starting to chipping off
you think spraying as many layers will work ar .. you are just making it thicker .. even my floppy drive i accidentally chip off a small part of it exposing the white part de
A little update on the reservoir :thumbs: but didnt do a great job :sweat: Cleaned The Arcylic with Turpentine. Fixed the barbs and silicon around the edges Glueing The arcylic with epoxy glue Finally Done,but still have to wait for the silicon to dry,tommorow should be dry edi quite messy abit stain on da arcylic,i know is not that good,as long as can use can edi :thumbs: anyway tommorow might be some updates,getting da stuffs tommorow B)
No that won't work because the paint still doesn't stick well to the surface, and you are making it chipping off even easier by making the paint thicker
white one silicon,aha no skill ma Teaser pics,Received B&D RTX 1& Work Bench Today RTX 1 Some of the parts taken from the old rotary tool From Left>Bosch Tripod,Bosch Drill,B&D RTX1 Assembling Work Bench
A little update for today, Havent finish filing,one panel done zy wanna use ?come over to my place lol
What's the price difference between the RTX and the Dremel? Here it's about 2,000 Philippine pesos or about $40USD. Retail price of an RTX is about 4,000Php if I recall correctly. Around $80USD give or take.
