An update for today,anyway sorry for late updates,was relaxing these days Finished Cut off Side Panel Window,it needs a respray Cutting Arcylic into sizes for side/top panel window. Filing Done
An update for today :thumbs: Planned to fix wheels on my casing,but i drilled the hole on the casing underneath but it is to big so i did this... Use Left over wood Drilled holes Screwing The wheels on the wood screwed on below the case
having wheels ? .. bad idea .. \ thanks to your wheels .. you casing have been raised higher .. because of the wood too .. its not nice. . you cant place this kind of systems on the table .. besides.. you'll have problem locking the wheel
An Update For Today :thumbs: Drilling holes to fit arcylic Cutting The back panel Spraying sidepanel Cutting a hole for the psu wires to go through the back thats all for today Getting some stuffs from bombman :hehe: :$:
Part2 Finished :thumbs: heres what i done for today :hehe: sprayed the wood black fixed on the case fixed Blue ccfl :w Havent bought Radiator Yet Still looking heh,some soo exp!
go steal the radiotor from your mum's vios or maybe dad's Corolla or sherwin's kelisa .. now you put wheels you must becare ful of your feels when the are folded in .. your casing is not not that stable .. put putting your water cooling tak above .. even much more not stable .....
the troleys doesnt go well .. it made it looked not stable you cant put this kind ob big casing on the table .. the chances it might roll off tha table ... besides.. it will be pain in the *** if your floor is unlevel ( like my college )
might roll over to other place if the floor is not level the wheels made the modded casing not professional.. should do something on the wheels
Nth Much For Today Yuck Ugly guess gonna redo the top side panel,need to go get some new steel,to make same part of the window as the c5 looks funny now
yea did these modding inside the house,if cutting job outside lol,yea an old steering wheel Mad Catz lol
heh you can buy my water cooling i need to figure out the price though somewhere in the 300-350 range. Swiftech MCW6002-64 waterblock Swiftech MCW50+T 100W pelt TEC block Black Ice Pro 3x120mm radiator, 1/2" barbs http://www.frozencpu.com/ex-rad-41.html 3x120mm 80CFM ADDA fans 900L/hr Sacem SL35 pump and Waterchill resevoir built in Redundant PSU Mean Well SP-200-5 watt 200 (Link http://www.trcelectronics.com/Meanwell/pdf/sp200.pdf) 1 bottle of Red line water wetter 1tube of luberex for the vid card water block. 3 long 1/2" tubing all cords with it also including splitters and power controller. Heres a review on the kit http://www.devhardware.com/c/a/PC-C...r-Kit-Review/1/ thats not the water block included Heres a review on the water blocks http://www.devhardware.com/c/a/PC-C...0T-Waterblocks/
For that much money I would just go and buy one of the new Apex kits with the Apogee block. The Redundant PSU makes it a little tempting though.
Sry For late update,very tired Received Some stuffs which i bought from bombman Sleeving The Psu wires,Not Finished Sleeving yet did a little changed on the wheels cutting arcylic for backpanel of the case testing to fit the 2nd psu Polishing Arcylic with Meguair's Scratch X and Plastix X Fixed the wheel on the case,much more better and stable
