i don't think he wants to put the rig on a table. my chieftec case comes originally with wheels (it's so big I wouldn't put it up on any table anyway) and its handy and stable.
:thumbs: Very Good Update For Today Taking Off the top case Cutting out the piece need to be cut ] Very satisfied with my work today really need a respray, still gotta find a way to rivet the Top Casing.
Heh heh waiting for my new top side panel,then ready to fix those components and other stuffs anyway what kind of radiator is this currently looking for this rad
oh i c Thx for da info ,sigh, theres no any liquid chemical can wash the inner part or da oil cooler? which pump it in
Update!!! :thumbs: fixed cm 120mm fan behind Planning to make the front panel Took out the c5 badge from the centurion 5 front panel Measuring the front panel Doin some sleeving Having Hard Time to cut 3mm arcylic :blink: ,halfway done Thats all for today
:thumbs: Update For Today,just finish modding :blink: Cutted those bezels out Done cutting the front panel bezel's file + wet sanding edges Use epoxy glue to glue those sides top panel glued, i know u can see fingerprints tomorow i will cleaned it off Tested Fit Tomorow im gonna spray inner part black of the front panel,hope will be a good hot weather tomorow :w B]
Project Dragzon case, The old name was Project Spinner Case>that time i cant even think a name for it heh so decide to change the name to Project Dragzon Case
Update,fixin the electronic key hole sprayed the inner part of the front panel heres the finish product of the Front panel can u see the reflections of the tiles? :thumbs:
