chai well you will see when the 2nd update comes 17 Oct Update eace: Filed The blowhole which i left out yesterday which i didnt file it properly Well its time to cut another hole on the 2nd case Stay tune for next update[ASAP]
Here Comes the Next Update Cutting through the lines RTX 1 Has to take a rest,fan blowing and enjoying the cushion[my gloves]LOL Very Dusty.... Done The 2nd Case Blowhole Close up, I Noticed I improved alot way then last time the two case blowhole Little close up,air duct attached LOL Next update coming
Last update For Today A Test Fit wit both case Attached Next Mod i was thinking of what can i do wtih this,strip off those which i wanted to remove.I need some ideas for this being removed attached the Alu sides back view top view
=) his dad has a collection of tools of almost every kind. Cool garage I tell you. ------------------ Ren, you scratched the dining table!!! (cimg1203bm1)
Upcoming plans for Project Dragzon Case once i get my soldering tools and etc: DIY> -Molex Hub -Fan controller -Lighting -Bezel[arcylic] to fit the 20x4 LCD module -Switchs bay -etc might be more Lastly Cable Management
Today's Update ok here is the back panel which is damaged.. this steel i found in the stor room,which I can replace the back panel holder drilling holes on the steel Done and sanded , More updates will be coming
wuah.. nowonder you took so long to do ur pedals lahh.. hahahahahahahaha!!! nice work there sherren.. wuah.. long time since I last log on.. kakakaka!!
Today's Update :thumbs: ,Well Back into Modding Mood well heres the same aloy piece, trimmed it As u can see in the picture i added something on top which is screwed Ok heres a pic wit the rubber legs I would to know some opinions should i use the rubber legs or just leave it close like this pic More Updates will be coming eace:
Not an update today,have to wait for stuffs to arrive, coming soon. by the way here are some close shots of the top case.Ignore the back plate [alu] gonna replace it wil L shaped Alu poles.
Today's Update, sorry for delay... Feel so Lazy to mod, because played on9 games till late.. Ok heres a pic of the front , i was thinking to replace the front 80mm to 120mm since that the front 80mm fan was not providing enough airflow, as well as adding the noise factor :blink: strip off the hdd/floppy bay Time to Measure 120mm hole to be cut Markings has been made out,time to chop off Cut and filed Test Fit 120mm fan Next Have to chop off some parts on the hdd/floppy bay,will update after my supper B]
Just Had my Supper. ok chopped out 1 part,sorry i didnt take a pic when the 2 parts are already chopped front view side view inside view Tomorow i should have my stuffs arrived :hyper:
nth much for today just trimed so be able to fit in the 120mm fan without removing the hdd cage Finally Got My Stuffs From a forumer:hyper: :thumbs: Alot Of Stuffs :flex:
