x264 Benchmark
Discussion in 'Reviews & Articles' started by Dashken, Sep 9, 2007.
  1. PsYkHoTiK
    PsYkHoTiK Admin nerd
    Vista Ultimate 32bit.
    New validation.
  2. graysky
    graysky ARP Reviewer
    killer man, thanks (added to the table and will update with the hour)
  3. PsYkHoTiK
    Hey no problem man. I'll keep pushing my stuff and update as needed. :thumb:
    You know what would be real cool? If we could make that table like a pivot table / add filters to the columns so people could come in and interactively check stuff out (i.e: filter out all other CPUs and just look at Kentsfield results). Also, I wonder if you could add a checksum (sorta like superpi) to circumvent cheatzors.
    If its do-able, it'd be really awesome.
  4. graysky
    @PsYkHoTiK - yeah a sortible html would be pretty nice... I think Adrian was going to ask around, I'll have to pm him. About the MD5 idea. I did think of it, but so long as this is batch file driven, that won't matter because someone could easily modify it to generate an md5 for whatever they would want.
    I think keeping people's names out of the table might be some what of an incentive not to cheat, but you never can tell.
  5. PsYkHoTiK
    Hmm good point. Well cpuz validation is another way too I guess. People by large generally aren't lame enough to cheat but like you said, can never tell I guess. By having a list like that, any apparant cheating can be spotted out (it would be an outlier compared to similar spec'd results).
    Off topic: Go Colts (grew up in Indianapolis)! Go Seahawks (live up here in Washington)!
    :p
  6. JnZ
    JnZ Newbie
    Thanks for long reply. First of all, I'm pretty sure, that my machine is 100% stable at oc state (1\it runs many hours on Prime95. 2\This machine runs many days without shutdown with HD encodings. 3\2.8GHz oc isn't so high, it's working in windows even at 3GHz, but Prime95 says that isn't stable (mayby litlle increase of CPU voltage helps). :) )
    Second thing. Thing about different FPS, I'm talking about this: I do many bench and every run give different FPS.
    Example: (rounded fps)
    1) 120/121/119/120/121 - 34/34/34/34/34
    2) 104/105/105/104/105 - 33/33/33/33/33
    3) 122/123/121/122/122 - 34/34/34/34/34
    Then reboot:
    4) 98/100/ 96/104/101 - 31/31/31/30/31
    5) 115/115/113/116/117 - 33/32/32/33/32
    6) 119/120/121/120/120 - 33/33/33/33/32
    Then run and close some apps:
    7) 109/107/110/108/108 - 34/33/33/34/33
    8) 119/120/121/121/120 - 34/34/34/34/34
    You see - every run different results.
    Then testing number of threads:
    Code:
    | thds |  1p-1  |  2p-1 |  1p-2  |  2p-2 |  1p-3  |  1p-3 || 1p-avg | 2p-avg |
    | AUTO | 116,84 | 33,99 | 116,72 | 33,65 | 121,15 | 33,74 || 118,24 | 33,79  |
    |   1  |  42,38 |  9,27 |  41,89 |  9,58 |  42,14 |  9,53 ||  42,14 |  9,46  |
    |   2  |  77,63 | 16,64 |  77,90 | 16,71 |  77,95 | 16,75 ||  77,83 | 16,70  |
    |   3  |  86,30 | 20,72 |  85,51 | 20,42 |  85,12 | 20,56 ||  85,64 | 20,57  |
    |   4  | 115,76 | 23,45 | 116,97 | 23,64 | 116,00 | 23,44 || 116,24 | 23,51  |
    |   5  | 111,82 | 32,05 | 105,80 | 32,30 | 107,84 | 32,49 || 108,49 | 32,28  |
    |   6  | 119,85 | 33,49 | 120,49 | 34,19 | 120,75 | 33,68 || 120,36 | 33,79  |
    |   7  | 106,91 | 33,36 | 106,61 | 33,73 | 107,94 | 34,16 || 107,15 | 33,75  |
    |   8  | 120,62 | 34,95 | 121,67 | 35,07 | 120,75 | 35,20 || 121,01 | 35,07  |
    |   9  | 106,30 | 35,36 | 106,30 | 35,34 | 107,02 | 35,61 || 106,54 | 35,44  |
    |  10  | 119,98 | 36,07 | 119,38 | 36,06 | 119,98 | 36,21 || 119,78 | 36,11  |
    |  11  | 105,80 | 35,43 | 107,22 | 35,81 | 106,41 | 35,64 || 106,48 | 35,63  |
    |  12  | 120,88 | 36,24 | 121,53 | 36,18 | 121,67 | 36,20 || 121,36 | 36,21  |
    |  13  | 106,50 | 35,90 | 107,43 | 35,81 | 108,04 | 35,93 || 107,32 | 35,88  |
    |  14  | 120,88 | 36,13 | 120,49 | 36,32 | 120,49 | 36,25 || 120,62 | 36,23  |
    |  15  | 107,53 | 35,76 | 107,94 | 35,85 | 108,67 | 35,91 || 108,05 | 35,84  |
    |  16  | 121,53 | 36,17 | 121,67 | 36,23 | 120,88 | 36,19 || 121,36 | 36,20  |
    |  17  | 105,90 | 35,81 | 107,94 | 35,88 | 108,05 | 35,89 || 107,30 | 35,86  |
    |  18  | 120,23 | 36,16 | 120,23 | 36,21 | 119,98 | 36,25 || 120,15 | 36,21  |
    |  19  | 106,40 | 35,81 | 107,22 | 35,84 | 108,57 | 35,88 || 107,40 | 35,84  |
    |  20  | 121,27 | 36,16 | 120,23 | 36,27 | 120,88 | 36,24 || 120,79 | 36,22  |
    It seems, that AUTO threading model use 5-6 threads, but for my configuration 12 threads seems best choice. Another remark: Even number of threads give more FPS.
    When I encoding HD, CPU work almost at 100% (using AUTO threads) with this bench only 70-90%. The solution is to use 12 or more threads.
    Anyway great benchmark, thanks ;)
    J.
  7. rocketmen2k5
    rocketmen2k5 Newbie
    I could never get the damn thing to work so I uninstalled it.:confused:
  8. Team Scream
    Team Scream Newbie
    Here is my new V8 using SysTool to get a slight OC, 4 gigs of Crucial 667 FB (4x1GB)
    Intel Xeon X5355 (x2) Rev B3
    Multiplier: x6.0
    Bus Speed: 383.1 Mhz
    Rated FSB: 1532.2 Mhz
    Core Speed 3065.0 Mhz
    Chipset: Intel 5000x (Tyan S2696)
    Memory Timings 5-5-5-15 @ 333 Mhz
    Windows XP Pro SP2
    P.S. I also have a dual Opteron 285 System sitting right here that I will run the tests on as soon as my video card gets here, should be Wednesday at the latest, it is running completely stock speeds with 4 gigs of slightly slower ram than the V8 monster listed above.
    I also have a single QX6800 based system that I will run the tests on now, it is water cooled and running at 3.4Ghz....results to follow...
    Please let me know where I stack up in the list with this V8, it was a pricey bastard to build, and video editing/encoding is what it was built for so I am REALLY interested in knowing what the results actually mean.
    ---------- RUN1PASS1.LOG
    encoded 1749 frames, 150.24 fps, 1849.61 kb/s
    ---------- RUN2PASS1.LOG
    encoded 1749 frames, 151.47 fps, 1849.61 kb/s
    ---------- RUN3PASS1.LOG
    encoded 1749 frames, 150.66 fps, 1849.61 kb/s
    ---------- RUN4PASS1.LOG
    encoded 1749 frames, 151.06 fps, 1849.61 kb/s
    ---------- RUN5PASS1.LOG
    encoded 1749 frames, 151.27 fps, 1849.61 kb/s
    ---------- RUN1PASS2.LOG
    encoded 1749 frames, 75.58 fps, 1834.85 kb/s
    ---------- RUN2PASS2.LOG
    encoded 1749 frames, 75.74 fps, 1834.86 kb/s
    ---------- RUN3PASS2.LOG
    encoded 1749 frames, 75.38 fps, 1834.86 kb/s
    ---------- RUN4PASS2.LOG
    encoded 1749 frames, 75.18 fps, 1834.86 kb/s
    ---------- RUN5PASS2.LOG
    encoded 1749 frames, 74.87 fps, 1834.86 kb/s
  9. Team Scream
    Team Scream Newbie
    And here is the QX6800 System, it is quite a bit slower on the 2nd pass, but faster on the first pass? why is that?
    Intel QX6800 (Kentsfield)
    Multiplier: x13.0
    Bus Speed: 266.7 Mhz
    Rated FSB: 1066.7 Mhz
    Core Speed 3467.2 Mhz
    Chipset: Intel i975x (Intel D975XBX2) (Bad Axe 2)
    Memory Timings 4-4-4-13 @ 400 Mhz
    Windows XP Pro SP2
    4 Gigs of Crucial DDR2-800
    encoded 1749 frames, 173.55 fps, 1850.94 kb/s
    encoded 1749 frames, 172.21 fps, 1850.94 kb/s
    encoded 1749 frames, 174.08 fps, 1850.94 kb/s
    encoded 1749 frames, 172.74 fps, 1850.94 kb/s
    encoded 1749 frames, 173.01 fps, 1850.94 kb/s
    encoded 1749 frames, 47.88 fps, 1829.06 kb/s
    encoded 1749 frames, 47.80 fps, 1829.22 kb/s
    encoded 1749 frames, 48.00 fps, 1829.43 kb/s
    encoded 1749 frames, 47.57 fps, 1829.27 kb/s
    encoded 1749 frames, 47.90 fps, 1829.50 kb/s
  10. graysky
    Thanks for the octa results. Also cool to see them.
    Are you sure about the 6x383? That's only 2.3 GHz. If you meant 9x383 then you're 3.45 GHz. Also, are you sure about your mem timing @ 333 (667 since DDR2). That ratio seems kinda odd to me 1.74:1.
    It's a trend with 4x2 = 8 vs. 4x1 = 4 throughout the table. Seems like the 2nd pass does a better job multithreading the workload (perhaps since it's more CPU-intensive than the 1st pass). I honestly don't know :)
  11. graysky
    @JnZ - wow dude, that's serious :) I'm not sure why your machine is giving the variable results. Mine is pretty darn consistent. Do you have some extra services (anti-virus, diskkeeper, etc.) that might be sucking up the CPU cycles?
  12. ditche
    ditche Newbie
    With o/c :
    Without o/c :
  13. Chai
    My result is missing...
  14. Team Scream
    Team Scream Newbie
    Sorry Graysky,
    I meant 8x383 which is 3064 Mhz.
    Memory is also at 383Mhz which puts it @ 1:1
    Here is a screenie from an Everest session 5 minutes ago.
  15. graysky
    missing from ditche's tables or the official table? I actually see your 6850 result in the official table...
  16. Team Scream
    Team Scream Newbie
    Where are the official results? I would love to see them.
  17. graysky
  18. Chai
    Missing from both...
  19. AlderaaN
    AlderaaN Newbie
    Hello!
    Thank you very much for this great thread!
    Makes me feel very secure on my next CPU upgrade for encoding purposes :beer:
    My results:
    encoded 1749 frames, 59.89 fps, 1850.89 kb/s
    encoded 1749 frames, 59.04 fps, 1850.89 kb/s
    encoded 1749 frames, 59.01 fps, 1850.89 kb/s
    encoded 1749 frames, 58.88 fps, 1850.89 kb/s
    encoded 1749 frames, 57.17 fps, 1850.89 kb/s
    encoded 1749 frames, 15.27 fps, 1826.38 kb/s
    encoded 1749 frames, 15.30 fps, 1826.38 kb/s
    encoded 1749 frames, 15.17 fps, 1826.38 kb/s
    encoded 1749 frames, 15.16 fps, 1826.37 kb/s
    My system specs:
    AMD X2 3800 (2.0GHz base) overclocked @ 2.43GHz
    Multiplier: x10.0
    Bus Speed: 243 Mhz
    Chipset: nVidia nForce4
    Memory Timings: 3-4-3-7-1T @ 486 MHz DDR
    Windows XP Pro SP2
    Take care and keep this great thread going! :clap:
    Samuel.
  20. graysky
    @AlderaaN - thanks for the data!
    @chai - it's there, I just made two mistakes (got your chipset wrong and got your OS wrong). It's corrected now - sorry about that.
