Check out the main page now -- particularly the general trends table. It contains data from a yet-to-be-released Yorkfield ES chip in a head-to-head comparison to Kentfield core quad. Pretty cool.
Core Duo T2500 (Yonah), 12x166, i945GM, 5-5-5-15 @ 333 MHz(DDR 667) , XP Pro SP2 Tablet PC Edition 2005 ---------- RUN1PASS1.LOG encoded 1749 frames, 46.89 fps, 1850.89 kb/s ---------- RUN2PASS1.LOG encoded 1749 frames, 46.93 fps, 1850.89 kb/s ---------- RUN3PASS1.LOG encoded 1749 frames, 46.56 fps, 1850.89 kb/s ---------- RUN4PASS1.LOG encoded 1749 frames, 46.52 fps, 1850.89 kb/s ---------- RUN5PASS1.LOG encoded 1749 frames, 46.74 fps, 1850.89 kb/s ---------- RUN1PASS2.LOG encoded 1749 frames, 11.49 fps, 1826.38 kb/s ---------- RUN2PASS2.LOG encoded 1749 frames, 11.52 fps, 1826.38 kb/s ---------- RUN3PASS2.LOG encoded 1749 frames, 11.35 fps, 1826.38 kb/s ---------- RUN4PASS2.LOG encoded 1749 frames, 11.39 fps, 1826.37 kb/s ---------- RUN5PASS2.LOG encoded 1749 frames, 11.43 fps, 1826.27 kb/s
Hello again graysky, GJ on your ongoing efforts to keep this benchmark alive! My results from here seem to have been erased from the charts. Can u check it out please? Regards, Samuel.
Vista Ultimate 64bit C2D E4300 @ 9x340, 4 x 1GB DDR2 5-6-6-17 @ 340MHz P965 (965P-DS3) ---------- RUN1PASS1.LOG encoded 1749 frames, 76.53 fps, 1850.89 kb/s ---------- RUN2PASS1.LOG encoded 1749 frames, 76.08 fps, 1850.89 kb/s ---------- RUN3PASS1.LOG encoded 1749 frames, 77.05 fps, 1850.89 kb/s ---------- RUN4PASS1.LOG encoded 1749 frames, 76.88 fps, 1850.89 kb/s ---------- RUN5PASS1.LOG encoded 1749 frames, 76.94 fps, 1850.89 kb/s ---------- RUN1PASS2.LOG encoded 1749 frames, 19.56 fps, 1826.38 kb/s ---------- RUN2PASS2.LOG encoded 1749 frames, 19.51 fps, 1826.38 kb/s ---------- RUN3PASS2.LOG encoded 1749 frames, 19.48 fps, 1826.37 kb/s ---------- RUN4PASS2.LOG encoded 1749 frames, 19.52 fps, 1826.38 kb/s ---------- RUN5PASS2.LOG encoded 1749 frames, 19.55 fps, 1826.38 kb/s
---------- RUN1PASS1.LOG encoded 1749 frames, 59.23 fps, 1850.89 kb/s ---------- RUN2PASS1.LOG encoded 1749 frames, 59.26 fps, 1850.89 kb/s ---------- RUN3PASS1.LOG encoded 1749 frames, 58.88 fps, 1850.89 kb/s ---------- RUN4PASS1.LOG encoded 1749 frames, 59.16 fps, 1850.89 kb/s ---------- RUN5PASS1.LOG encoded 1749 frames, 59.04 fps, 1850.89 kb/s ---------- RUN1PASS2.LOG encoded 1749 frames, 14.48 fps, 1826.33 kb/s ---------- RUN2PASS2.LOG encoded 1749 frames, 14.53 fps, 1826.37 kb/s ---------- RUN3PASS2.LOG encoded 1749 frames, 14.53 fps, 1826.37 kb/s ---------- RUN4PASS2.LOG encoded 1749 frames, 14.52 fps, 1826.38 kb/s ---------- RUN5PASS2.LOG encoded 1749 frames, 14.49 fps, 1826.37 kb/s
Very cool! When the new site goes up (ETA Nov'07), we will have a DB-based system for all the results.
@AW - I'm just waiting a few missing pieces of data and I'll upload the current xls to the FTP... you have any idea how easy it'll be to update/add additional data points under the new system?
Hey sorry for the lack of updates on the new system. Well, it will be an online system. Most likely you just need to enter the new data online and it will instantly tabulate and display the newly updated table.
Here are mine results on an occed E2140 @2.37Ghz ---------- RUN1PASS1.LOG encoded 1749 frames, 57.40 fps, 1850.89 kb/s ---------- RUN2PASS1.LOG encoded 1749 frames, 57.58 fps, 1850.89 kb/s ---------- RUN3PASS1.LOG encoded 1749 frames, 57.28 fps, 1850.89 kb/s ---------- RUN4PASS1.LOG encoded 1749 frames, 55.72 fps, 1850.89 kb/s ---------- RUN5PASS1.LOG encoded 1749 frames, 57.49 fps, 1850.89 kb/s ---------- RUN1PASS2.LOG encoded 1749 frames, 14.44 fps, 1826.37 kb/s ---------- RUN2PASS2.LOG encoded 1749 frames, 14.45 fps, 1826.22 kb/s ---------- RUN3PASS2.LOG encoded 1749 frames, 14.12 fps, 1826.37 kb/s ---------- RUN4PASS2.LOG encoded 1749 frames, 14.01 fps, 1826.39 kb/s ---------- RUN5PASS2.LOG encoded 1749 frames, 14.47 fps, 1826.38 kb/s Specs: Running on Windows XP SP2 (x86)
Abit IP35 Pro, q6600 / 9x400 / 3.6Ghz, 2Gb DDR2 800 4-4-4-12, Vista 32 ---------- RUN1PASS1.LOG encoded 1749 frames, 186.88 fps, 1850.94 kb/s ---------- RUN2PASS1.LOG encoded 1749 frames, 186.86 fps, 1850.94 kb/s ---------- RUN3PASS1.LOG encoded 1749 frames, 186.56 fps, 1850.94 kb/s ---------- RUN4PASS1.LOG encoded 1749 frames, 186.56 fps, 1850.94 kb/s ---------- RUN5PASS1.LOG encoded 1749 frames, 185.33 fps, 1850.94 kb/s ---------- RUN1PASS2.LOG encoded 1749 frames, 50.49 fps, 1829.28 kb/s ---------- RUN2PASS2.LOG encoded 1749 frames, 50.20 fps, 1829.08 kb/s ---------- RUN3PASS2.LOG encoded 1749 frames, 50.31 fps, 1829.05 kb/s ---------- RUN4PASS2.LOG encoded 1749 frames, 50.15 fps, 1829.40 kb/s ---------- RUN5PASS2.LOG encoded 1749 frames, 49.99 fps, 1829.21 kb/s
