x264 Benchmark
Discussion in 'Reviews & Articles' started by Dashken, Sep 9, 2007.
  1. graysky
    graysky ARP Reviewer
    Updated the Intel table. It now contains several Yorkfield ES chips including:
    Xeon E5330 (Dual board)
    Q9550
    Q9350
    We are going to send news out on that. :thumb:
  3. Dashken
    Dashken Administrator!
    x264 Benchmark Results Updated
    graysky had just updated the Intel performance table. It now contains several quad-core Yorkfield ES chips including Xeon E5330 (Dual CPU - 8 cores), Q9550 and Q9350.
    The x264 benchmark measures how fast your machine can encode a short, DVD quality MPEG-2 video clip into a high-quality x264 video clip. It will give you results in FPS that can be used to compare the performance of different CPUs and different CPU settings.
    Here's a quote from the article :-
    Link : x264 Benchmark Results Updated
  4. graysky
    Updated the tables with another 45 nm chip: the QX9650 -- both at stock levels and @ overclocked to 4.2 GHz! With it, and the others (Xeon E5330 (Dual board), Q9550, and Q9350) there is now data on 4 different 45 nm chips.
    One thing that I found striking about these new chips is that they are only marginally faster than their 65 nm counterparts when encoding x264 (about 5-6 % faster with all other factors being equal or close to equal). Have a look at the general trends table for the Kentsfield vs. Yorkfield comparison at the official host.
  5. RD 600
    E6850@423X9
    2X1 gig SYNC 4,4,4,14
    Win XP32 home
    ---------- RUN1PASS1.LOG
    encoded 1749 frames, 105.60 fps, 1850.89 kb/s
    ---------- RUN2PASS1.LOG
    encoded 1749 frames, 106.41 fps, 1850.89 kb/s
    ---------- RUN3PASS1.LOG
    encoded 1749 frames, 105.70 fps, 1850.89 kb/s
    ---------- RUN4PASS1.LOG
    encoded 1749 frames, 106.10 fps, 1850.89 kb/s
    ---------- RUN5PASS1.LOG
    encoded 1749 frames, 106.20 fps, 1850.89 kb/s
    ---------- RUN1PASS2.LOG
    encoded 1749 frames, 26.29 fps, 1826.37 kb/s
    ---------- RUN2PASS2.LOG
    encoded 1749 frames, 26.47 fps, 1826.37 kb/s
    ---------- RUN3PASS2.LOG
    encoded 1749 frames, 26.43 fps, 1826.37 kb/s
    ---------- RUN4PASS2.LOG
    encoded 1749 frames, 26.34 fps, 1826.38 kb/s
    ---------- RUN5PASS2.LOG
    encoded 1749 frames, 26.33 fps, 1826.37 kb/s
  6. Mac Daddy
    Hey guys tried this out and maybe I am missing something or its too early and I haven't had enough Java yet :cool:
    I copied the file DGDecode.dll to the C:\Program Files\AviSynth 2.5\plugins directory as indicated in the instructions. I run the program and enter the file name when prompted but when I hit enter the screen just closes.
    Running XP Pro SP2 any ideas ?
  7. graysky
    There is a FAQ... see the first question. I'm guessing your not running it from c:\work2
    Tech ARP - x264 Benchmark
  8. Russianblue
    Russianblue Newbie
    an 'old skule' X2 4400+
    not too bad if i do say so myself. still better than some of the newer entry level Intel chips!
    XP Pro SP2
    X2 4400+ @ 2650 @ 1.5v
    2GB Mushkin Redline 99142 @ 265x10 w/ 3-3-2-8 2T @ 2.7v
    encoded 1749 frames, 69.87 fps, 1850.89 kb/s
    encoded 1749 frames, 70.35 fps, 1850.89 kb/s
    encoded 1749 frames, 70.71 fps, 1850.89 kb/s
    encoded 1749 frames, 70.93 fps, 1850.89 kb/s
    encoded 1749 frames, 70.75 fps, 1850.89 kb/s
    encoded 1749 frames, 16.91 fps, 1826.38 kb/s
    encoded 1749 frames, 17.14 fps, 1826.20 kb/s
    encoded 1749 frames, 17.27 fps, 1826.38 kb/s
    encoded 1749 frames, 17.30 fps, 1826.38 kb/s
    encoded 1749 frames, 17.27 fps, 1826.37 kb/s
  9. Mac Daddy
    Ahh OK will give that a try THX for the feedback :D
    EDIT: That worked like a charm now just need to find time to run it ;)
  10. Mac Daddy
    Well ran this dead stock for reference on this old Prescott 2.8 (21x133) let it run after I went to bed. The numbers I am sure won't impress anyone but like the test. I will set things back up the way I normally run and run it again tonight if I get a chance :)
    encoded 1749 frames, 15.83 fps, 1854.10 kb/s
    encoded 1749 frames, 15.92 fps, 1854.10 kb/s
    encoded 1749 frames, 16.05 fps, 1854.10 kb/s
    encoded 1749 frames, 15.99 fps, 1854.10 kb/s
    encoded 1749 frames, 3.39 fps, 1825.89 kb/s
    encoded 1749 frames, 3.36 fps, 1825.89 kb/s
    encoded 1749 frames, 3.38 fps, 1825.89 kb/s
    encoded 1749 frames, 3.35 fps, 1825.89 kb/s
  11. drp
    drp Newbie
    x2 5200
    System:
    Athlon 64 X2 5200+ F3 3 F 43 (Windsor EE)
    Bus Speed 220.5, multiplier x13 ([email protected])
    Mainboard GA-MA69GM-S2H, TS690 (ATI 1250 integrated), Bios FW F3
    Memory, Freq 409.2MHz, 5,5,18 2GB DDR2 800 Kingston Valueram (chips Elpida) 1.8V in dual channel.
    Winwdows XP SP2.
    encoded 1749 frames, 76.77 fps, 1850.89 kb/s
    encoded 1749 frames, 76.93 fps, 1850.89 kb/s
    encoded 1749 frames, 77.52 fps, 1850.89 kb/s
    encoded 1749 frames, 77.68 fps, 1850.89 kb/s
    encoded 1749 frames, 18.62 fps, 1826.37 kb/s
    encoded 1749 frames, 18.77 fps, 1826.37 kb/s
    encoded 1749 frames, 18.78 fps, 1826.37 kb/s
    encoded 1749 frames, 18.84 fps, 1826.37 kb/s
    encoded 1749 frames, 18.87 fps, 1826.37 kb/s
  12. graysky
    Thanks for the data, guys. I'll include them in the next update.
  13. -=chf=-
    -=chf=- Newbie
    AMD Athlon XP-M Barton, 10 x 202.3MHz, nForce2 Ultra 400, 3.0-4-4-8 @ 202.3MHz, XP Pro SP2 (build 2600), DirectX 9.0c
    encoded 1749 frames, 22.41 fps, 1854.10 kb/s
    encoded 1749 frames, 20.52 fps, 1854.10 kb/s
    encoded 1749 frames, 22.29 fps, 1854.10 kb/s
    encoded 1749 frames, 22.53 fps, 1854.10 kb/s
    encoded 1749 frames, 22.68 fps, 1854.10 kb/s
    encoded 1749 frames, 5.59 fps, 1825.89 kb/s
    encoded 1749 frames, 5.60 fps, 1825.89 kb/s
    encoded 1749 frames, 5.53 fps, 1825.89 kb/s
    encoded 1749 frames, 5.65 fps, 1825.89 kb/s
    encoded 1749 frames, 5.68 fps, 1825.89 kb/s
  14. Mac Daddy
    As promised Graysky ran this again with the moderate O/C settings I use with this board (multiplier is locked). Still playing with memory timings and that will keep me busy until my upgrade .. should be picking up the mobo in the next week or two :)
    (Both test runs were using XP SP2)
    encoded 1749 frames, 17.41 fps, 1854.10 kb/s
    encoded 1749 frames, 17.35 fps, 1854.10 kb/s
    encoded 1749 frames, 17.21 fps, 1854.10 kb/s
    encoded 1749 frames, 18.05 fps, 1854.10 kb/s
    encoded 1749 frames, 17.56 fps, 1854.10 kb/s
    encoded 1749 frames, 3.74 fps, 1825.89 kb/s
    encoded 1749 frames, 3.70 fps, 1825.89 kb/s
    encoded 1749 frames, 3.71 fps, 1825.89 kb/s
  15. legend63
    legend63 Newbie
    Hi
    My system
    q6700es@3700
    Tg Extreem 4-4-4-8
    Mb asus p5b deluxe
    encoded 1749 frames, 193.67 fps, 1850.94 kb/s
    encoded 1749 frames, 192.35 fps, 1850.94 kb/s
    encoded 1749 frames, 192.01 fps, 1850.94 kb/s
    encoded 1749 frames, 192.66 fps, 1850.94 kb/s
    encoded 1749 frames, 192.98 fps, 1850.94 kb/s
    encoded 1749 frames, 51.35 fps, 1829.24 kb/s
    encoded 1749 frames, 51.61 fps, 1829.20 kb/s
    encoded 1749 frames, 51.16 fps, 1829.07 kb/s
    encoded 1749 frames, 50.95 fps, 1829.37 kb/s
    encoded 1749 frames, 51.87 fps, 1829.50 kb/s
  16. calpchen
    calpchen Newbie
    Athlon 64 3700+
    Here's an oldie for you:
    AMD Athlon 64 3700+ (San Diego, Socket 939)
    FSB: 200 MHz
    Multiplier: 11x
    Chipset: nForce4
    Memory: 2GB, 3-3-3-7
    Code:
    encoded 1749 frames, 28.66 fps, 1854.10 kb/s
    encoded 1749 frames, 28.70 fps, 1854.10 kb/s
    encoded 1749 frames, 28.64 fps, 1854.10 kb/s
    encoded 1749 frames, 7.35 fps, 1825.89 kb/s
    encoded 1749 frames, 7.39 fps, 1825.89 kb/s
    encoded 1749 frames, 7.33 fps, 1825.89 kb/s
  17. freecableguy
    freecableguy Newbie
    QX9650 @ 4.40GHz (11x400), ASUS P5E3 Dlx (X38), 4x1GB OCZ PC3-14400 @ DDR-1600, 7-7-7-15-2N, Vista Ultimate 64-bit
    encoded 1749 frames, 238.06 fps, 1851.15 kb/s
    encoded 1749 frames, 238.84 fps, 1850.68 kb/s
    encoded 1749 frames, 237.64 fps, 1850.95 kb/s
    encoded 1749 frames, 237.57 fps, 1850.69 kb/s
    encoded 1749 frames, 65.28 fps, 1829.04 kb/s
    encoded 1749 frames, 65.32 fps, 1829.09 kb/s
    encoded 1749 frames, 64.21 fps, 1829.41 kb/s
    encoded 1749 frames, 63.86 fps, 1829.36 kb/s
    encoded 1749 frames, 63.84 fps, 1829.32 kb/s
    -FCG
  18. Mighty1
    Mighty1 Newbie
    AthlonXP 3000+
    Machine: Home Built Athlon XP system Overclocked
    Reports as AthlonXP 3000+, 1GB PC2700
    Name: AMD Athlon XP
    Code Name: Barton
    Core Speed: 2104.9MHz
    Multiplier: x10.5
    Buss Speed: 200.5
    Rated FSB: 400.9
    Chipset: NVIDIA nForce2 Ultra 400
    Frequency: 167.1MHz
    FSB: DRAM: 6:5
    CAS# Latency: 2.5 clocks
    RAS# to CAS# Delay: 3 clocks
    RAS# Precharage: 3 clocks
    Cycle Time (Tras): 7 clocks
    OS: Windows XP Pro SP2
    encoded 1749 frames, 23.96 fps, 1854.10 kb/s
    encoded 1749 frames, 23.95 fps, 1854.10 kb/s
    encoded 1749 frames, 23.98 fps, 1854.10 kb/s
    encoded 1749 frames, 23.99 fps, 1854.10 kb/s
    encoded 1749 frames, 5.95 fps, 1825.89 kb/s
    encoded 1749 frames, 5.94 fps, 1825.89 kb/s
    encoded 1749 frames, 5.93 fps, 1825.89 kb/s
  19. Mighty1
    Mighty1 Newbie
    Dell Precision 530 Workstation, Dual Xeon 603 3.0GHz
    I tried running this one twice. Once with Hyperthreading on, and once with it disabled. Hyperthreading appears to add a nice boost.
    Machine: Dell Precision 530 Workstation
    Dual 3.0 Xeon 603, 1Gb RDRAM
    Name: Intel Xeon (Dual CPU)
    Code Name: Prestonia
    Core Speed: 2991.0MHz
    Multiplier: x30
    Buss Speed: 99.7
    Rated FSB: 398.8
    Chipset: Intel i860
    Frequency: 398.8MHz
    FSB: DRAM: 1:1
    Total CAS# (tRDRAM): 12 clocks
    Rot To Column (tRCD): 9 clocks
    with Hyperthreading:
    encoded 1749 frames, 43.54 fps, 1850.94 kb/s
    encoded 1749 frames, 43.76 fps, 1850.94 kb/s
    encoded 1749 frames, 43.66 fps, 1850.94 kb/s
    encoded 1749 frames, 43.57 fps, 1850.94 kb/s
    encoded 1749 frames, 43.71 fps, 1850.94 kb/s
    encoded 1749 frames, 10.97 fps, 1829.46 kb/s
    encoded 1749 frames, 10.96 fps, 1829.21 kb/s
    encoded 1749 frames, 10.92 fps, 1829.20 kb/s
    encoded 1749 frames, 10.82 fps, 1829.23 kb/s
    encoded 1749 frames, 11.01 fps, 1829.53 kb/s
    without Hyperthreading:
    encoded 1749 frames, 36.46 fps, 1850.89 kb/s
    encoded 1749 frames, 36.66 fps, 1850.89 kb/s
    encoded 1749 frames, 36.26 fps, 1850.89 kb/s
    encoded 1749 frames, 36.59 fps, 1850.89 kb/s
    encoded 1749 frames, 36.52 fps, 1850.89 kb/s
    encoded 1749 frames, 9.85 fps, 1826.37 kb/s
    encoded 1749 frames, 9.90 fps, 1826.37 kb/s
    encoded 1749 frames, 9.88 fps, 1826.37 kb/s
    encoded 1749 frames, 9.87 fps, 1826.38 kb/s
    encoded 1749 frames, 9.88 fps, 1826.38 kb/s
  20. Mac Daddy
