if someone is interrested in thuban (1055T 270HTT, 3.8 all cores, 4.4 turbo)... not my own test (done by ridney from xtremesystems.org), if it is not allowed to post other results, please delete and sorry. x264 HD BENCHMARK 3.0 RESULTS Please do not compare it with older versions of the benchmark! Please copy/paste everything below the line to to report your data ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r1342 -------------------------- encoded 1442 frames, 88.97 fps, 3898.70 kb/s encoded 1442 frames, 89.57 fps, 3898.70 kb/s encoded 1442 frames, 89.57 fps, 3898.70 kb/s encoded 1442 frames, 89.39 fps, 3898.70 kb/s encoded 1442 frames, 35.91 fps, 3968.57 kb/s encoded 1442 frames, 36.00 fps, 3971.60 kb/s encoded 1442 frames, 35.84 fps, 3960.24 kb/s encoded 1442 frames, 35.87 fps, 3954.02 kb/s System Details -------------- Name AMD K10 Codename Specification AMD Phenom(tm) II X6 1055T Processor Specification PC3-12800 Specification PC3-12800 Core Stepping Stock frequency 3300 MHz Core Speed 4455.2 MHz FID range 5.0x - 16.5x Northbridge AMD 790FX rev. 00 Southbridge ATI SB750 rev. 00 CAS# latency (CL) 7.0 RAS# to CAS# delay (tRCD) 7 RAS# Precharge (tRP) 7 Cycle Time (tRAS) 24 Command Rate (CR) 1T Command Rate 2T Command Rate 2T Memory Frequency 720.0 MHz (3:8) Memory Type DDR3 Memory Size 4096 MBytes Channels Dual, (Unganged) Windows Version Microsoft Windows 7 (6.1) Ultimate Edition (Build 7600) Number of processors 1 Number of threads 6 Number of threads 6 (max 6) L2 cache 6 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64 Package Socket AM2+ (940) Package Type 0x1 Temperature 0 29°C (84°F) [0x1D] (TMPIN0) Temperature 1 50°C (121°F) [0x32] (TMPIN1) Temperature 2 42°C (107°F) [0x2A] (TMPIN2) Temperature 0 27°C (80°F) [0xD7] (Core #0) Temperature 1 27°C (81°F) [0xDA] (Core #1) Temperature 2 28°C (81°F) [0xDD] (Core #2) Temperature 3 28°C (81°F) [0xDE] (Core #3) Temperature 4 28°C (82°F) [0xE1] (Core #4) Temperature 5 29°C (83°F) [0xE4] (Core #5)
I have two results to post. ____________________________________ x264 HD BENCHMARK 3.0 RESULTS Please do not compare it with older versions of the benchmark! Please copy/paste everything below the line to to report your data ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r1342 -------------------------- encoded 1442 frames, 59.35 fps, 3900.65 kb/s encoded 1442 frames, 59.77 fps, 3900.68 kb/s encoded 1442 frames, 59.85 fps, 3900.68 kb/s encoded 1442 frames, 59.39 fps, 3900.68 kb/s encoded 1442 frames, 18.39 fps, 3971.56 kb/s encoded 1442 frames, 18.25 fps, 3970.66 kb/s encoded 1442 frames, 18.35 fps, 3970.88 kb/s encoded 1442 frames, 18.25 fps, 3971.61 kb/s System Details -------------- Name Intel Core i5 750 Codename Lynnfield Specification Intel(R) Core(TM) i5 CPU 750 @ 2.67GHz Core Stepping B1 Technology 45 nm Stock frequency 2666 MHz Core Speed 2408.6 MHz Northbridge Intel DMI Host Bridge rev. 11 Southbridge Intel P55 rev. 05 CAS# latency (CL) 4.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Command Rate (CR) 2T Memory Frequency 669.1 MHz (2:10) Memory Type DDR3 Memory Size 8192 MBytes Channels Dual Windows Version Microsoft Windows 7 (6.1) Enterprise Edition (Build 7600) Number of processors 1 Number of threads 4 Number of threads 4 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T Package (platform ID) Socket 1156 LGA (0x1) Temperature 0 51°C (123°F) [0x30] (Core #0) Temperature 1 50°C (121°F) [0x31] (Core #1) Temperature 2 55°C (130°F) [0x2C] (Core #2) Temperature 3 49°C (120°F) [0x32] (Core #3) ____________________________________________________ x264 HD BENCHMARK 3.0 RESULTS Please do not compare it with older versions of the benchmark! Please copy/paste everything below the line to to report your data ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r1342 -------------------------- encoded 1442 frames, 65.60 fps, 3899.02 kb/s encoded 1442 frames, 65.75 fps, 3899.02 kb/s encoded 1442 frames, 65.37 fps, 3899.02 kb/s encoded 1442 frames, 65.93 fps, 3899.02 kb/s encoded 1442 frames, 27.04 fps, 3971.90 kb/s encoded 1442 frames, 26.68 fps, 3961.24 kb/s encoded 1442 frames, 27.00 fps, 3959.50 kb/s encoded 1442 frames, 26.82 fps, 3962.35 kb/s System Details -------------- Name Intel Core i7 870 Codename Lynnfield Specification Intel(R) Core(TM) i7 CPU 870 @ 2.93GHz Specification PC3-12800 Specification PC3-12800 Specification PC3-12800 Specification PC3-12800 Core Stepping B1 Technology 45 nm Stock frequency 2933 MHz Core Speed 2933.3 MHz Northbridge Intel DMI Host Bridge rev. 11 Southbridge Intel P55 rev. 05 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Command Rate (CR) 2T Command Rate 2T Command Rate 2T Command Rate 2T Command Rate 2T Memory Frequency 666.7 MHz (2:10) Memory Type DDR3 Memory Size 8192 MBytes Channels Dual Windows Version Microsoft Windows 7 (6.1) Enterprise Edition (Build 7600) Number of processors 1 Number of threads 8 Number of threads 8 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T Package (platform ID) Socket 1156 LGA (0x1) Temperature 0 38°C (100°F) [0x26] (SYSTIN) Temperature 2 12°C (52°F) [0x17] (AUXTIN) Temperature 0 52°C (125°F) [0x2F] (Core #0) Temperature 1 46°C (114°F) [0x35] (Core #1) Temperature 2 43°C (109°F) [0x38] (Core #2) Temperature 3 48°C (118°F) [0x33] (Core #3)
Hi realneil, It looks like your Core i5-750 was underclocked to 2.4 GHz. Can you retest at its stock speed? Thanks!
OK, Here goes,....... __________________________________ Results for x264.exe r1342 -------------------------- encoded 1442 frames, 58.97 fps, 3901.21 kb/s encoded 1442 frames, 60.56 fps, 3901.21 kb/s encoded 1442 frames, 58.71 fps, 3900.68 kb/s encoded 1442 frames, 58.67 fps, 3900.68 kb/s encoded 1442 frames, 20.09 fps, 3971.71 kb/s encoded 1442 frames, 20.10 fps, 3970.77 kb/s encoded 1442 frames, 20.05 fps, 3971.78 kb/s encoded 1442 frames, 19.93 fps, 3972.19 kb/s System Details -------------- Name Intel Core i5 750 Codename Lynnfield Specification Intel(R) Core(TM) i5 CPU 750 @ 2.67GHz Core Stepping B1 Technology 45 nm Stock frequency 2666 MHz Core Speed 2666.5 MHz Northbridge Intel DMI Host Bridge rev. 11 Southbridge Intel P55 rev. 05 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Command Rate (CR) 2T Memory Frequency 666.6 MHz (2:10) Memory Type DDR3 Memory Size 8192 MBytes Channels Dual Windows Version Microsoft Windows 7 (6.1) Enterprise Edition (Build 7600) Number of processors 1 Number of threads 4 Number of threads 4 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T Package (platform ID) Socket 1156 LGA (0x1) Temperature 0 51°C (123°F) [0x30] (Core #0) Temperature 1 49°C (120°F) [0x32] (Core #1) Temperature 2 54°C (129°F) [0x2D] (Core #2) Temperature 3 50°C (121°F) [0x31] (Core #3)
Lower power consumption. They are excellent when undervolted, better than most quad core processors. If only they overclock well at stock voltage, I would have upgraded instantly!
My bench x264 HD BENCHMARK 3.0 RESULTS Please do not compare it with older versions of the benchmark! Please copy/paste everything below the line to to report your data ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r1342 -------------------------- encoded 1442 frames, 69.71 fps, 3900.68 kb/s encoded 1442 frames, 69.08 fps, 3900.68 kb/s encoded 1442 frames, 69.89 fps, 3900.68 kb/s encoded 1442 frames, 68.84 fps, 3900.68 kb/s encoded 1442 frames, 24.02 fps, 3970.38 kb/s encoded 1442 frames, 24.12 fps, 3970.54 kb/s encoded 1442 frames, 24.17 fps, 3970.72 kb/s encoded 1442 frames, 23.95 fps, 3971.76 kb/s System Details -------------- Name Intel Core 2 Quad Codename Yorkfield Specification Intel(R) Core(TM)2 Quad CPU Q8400 @ 2.66GHz Core Stepping R0 Technology 45 nm Stock frequency 2666 MHz Core Speed 3900.0 MHz FID range 6.0x - 8.0x Northbridge NVIDIA nForce 790i Ultra SLI SPP rev. B1 Southbridge NVIDIA nForce 790i Ultra SLI MCP rev. A3 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Command Rate (CR) 1T Memory Frequency 650.0 MHz (3:4) Memory Type DDR3 Memory Size 4096 MBytes Channels Dual Windows Version Microsoft Windows 7 (6.1) Ultimate Edition (Build 7600) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 2 x 2048 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T Package (platform ID) Socket 775 LGA (0x4) Temperature 1 53°C (127°F) [0x6A] (CPU) Temperature 2 29°C (84°F) [0x3A] (AUX) Temperature 0 55°C (130°F) [0x2D] (Core #0) Temperature 2 55°C (130°F) [0x2D] (Core #2) Temperature 3 51°C (123°F) [0x31] (Core #3) Temperature 1 51°C (123°F) [0x31] (Core #1)
Intel Q8400 Stock Hi Adrian, with pleasure, my bench at stock speeds. x264 HD BENCHMARK 3.0 RESULTS Please do not compare it with older versions of the benchmark! Please copy/paste everything below the line to to report your data ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r1342 -------------------------- encoded 1442 frames, 59.18 fps, 3900.68 kb/s encoded 1442 frames, 58.89 fps, 3901.21 kb/s encoded 1442 frames, 58.66 fps, 3900.68 kb/s encoded 1442 frames, 56.91 fps, 3900.68 kb/s encoded 1442 frames, 17.56 fps, 3971.79 kb/s encoded 1442 frames, 17.54 fps, 3971.88 kb/s encoded 1442 frames, 17.23 fps, 3970.77 kb/s encoded 1442 frames, 17.03 fps, 3969.64 kb/s System Details -------------- Name Intel Core 2 Quad Codename Yorkfield Specification Intel(R) Core(TM)2 Quad CPU Q8400 @ 2.66GHz Core Stepping R0 Technology 45 nm Stock frequency 2666 MHz Core Speed 2666.6 MHz FID range 6.0x - 8.0x Northbridge NVIDIA nForce 790i Ultra SLI SPP rev. B1 Southbridge NVIDIA nForce 790i Ultra SLI MCP rev. A3 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Command Rate (CR) 1T Memory Frequency 666.7 MHz (1:2) Memory Type DDR3 Memory Size 4096 MBytes Channels Dual Windows Version Microsoft Windows 7 (6.1) Ultimate Edition (Build 7600) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 2 x 2048 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T Package (platform ID) Socket 775 LGA (0x4) Temperature 1 44°C (111°F) [0x58] (CPU) Temperature 2 32°C (89°F) [0x40] (AUX) Temperature 0 48°C (118°F) [0x34] (Core #0) Temperature 2 46°C (114°F) [0x36] (Core #2) Temperature 3 43°C (109°F) [0x39] (Core #3) Temperature 1 45°C (112°F) [0x37] (Core #1)
Here's my results from my new Phenom II X6 @4 Ghz with the NB @ 2.6Ghz ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r1342 -------------------------- encoded 1442 frames, 80.62 fps, 3898.70 kb/s encoded 1442 frames, 80.46 fps, 3898.70 kb/s encoded 1442 frames, 80.22 fps, 3898.70 kb/s encoded 1442 frames, 79.84 fps, 3898.70 kb/s encoded 1442 frames, 34.33 fps, 3969.71 kb/s encoded 1442 frames, 34.14 fps, 3970.60 kb/s encoded 1442 frames, 34.40 fps, 3962.20 kb/s encoded 1442 frames, 34.42 fps, 3965.60 kb/s System Details -------------- Name AMD K10 product System Product Name Codename Specification AMD Phenom(tm) II X6 1090T Processor Core Stepping Core Speed 4013.6 MHz Northbridge AMD 790FX rev. 00 Southbridge ATI SB750 rev. 00 CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 15 Command Rate (CR) 2T Memory Frequency 535.1 MHz (3:8) Memory Type DDR2 Memory Size 8192 MBytes Channels Dual, (Unganged) Windows Version Microsoft Windows 7 (6.1) Home Premium Edition (Build 7600) Number of processors 1 Number of threads 6 Number of threads 6 (max 6) L2 cache 6 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64 Package Socket AM2+ (940) Package Type 0x1 Temperature 0 45°C (112°F) [0x2D] (TMPIN0) Temperature 1 28°C (82°F) [0x1C] (TMPIN1) Temperature 0 42°C (106°F) [0x14C] (Core #0) Temperature 1 42°C (106°F) [0x14C] (Core #1) Temperature 2 41°C (106°F) [0x14B] (Core #2) Temperature 3 41°C (106°F) [0x14B] (Core #3) Temperature 4 41°C (106°F) [0x14B] (Core #4) Temperature 5 41°C (106°F) [0x14B] (Core #5)
The Phenom II X6 1090T! Just the processor I've been waiting for. Thanks, SicKlown42012!! PS. I have the results of the 1090T at stock speed, but can you please run the benchmark on your 1090T at stock speed too? We will use your results if they are faster than the ones I have now.
i7 860 @3.8ghz x264 HD BENCHMARK 3.0 RESULTS Please do not compare it with older versions of the benchmark! Please copy/paste everything below the line to to report your data ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r1342 -------------------------- encoded 1442 frames, 80.98 fps, 3899.02 kb/s encoded 1442 frames, 80.51 fps, 3899.02 kb/s encoded 1442 frames, 81.47 fps, 3898.50 kb/s encoded 1442 frames, 80.02 fps, 3899.02 kb/s encoded 1442 frames, 33.70 fps, 3965.97 kb/s encoded 1442 frames, 34.01 fps, 3955.47 kb/s encoded 1442 frames, 33.81 fps, 3959.61 kb/s encoded 1442 frames, 33.83 fps, 3949.72 kb/s System Details -------------- Name Intel Core i7 860 Codename Lynnfield Specification Intel(R) Core(TM) i7 CPU 860 @ 2.80GHz Specification PC3-12800 Specification PC3-12800 Specification PC3-12800 Specification PC3-12800 Core Stepping B1 Technology 45 nm Stock frequency 2800 MHz Core Speed 3818.2 MHz Northbridge Intel DMI Host Bridge rev. 11 Southbridge Intel P55 rev. 05 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Command Rate (CR) 2T Command Rate 2T Command Rate 2T Command Rate 2T Command Rate 2T Memory Frequency 694.2 MHz (2:8) Memory Type DDR3 Memory Size 8192 MBytes Channels Dual Windows Version Microsoft Windows 7 (6.1) (Build 7600) Number of processors 1 Number of threads 8 Number of threads 8 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T Package (platform ID) Socket 1156 LGA (0x1) Temperature 0 44°C (111°F) [0x2C] (TMPIN0) Temperature 1 53°C (127°F) [0x35] (TMPIN1) Temperature 2 32°C (89°F) [0x20] (TMPIN2) Temperature 0 52°C (125°F) [0x2F] (Core #0) Temperature 1 52°C (125°F) [0x2F] (Core #1) Temperature 2 45°C (112°F) [0x36] (Core #2) Temperature 3 51°C (123°F) [0x30] (Core #3)
1050T stock and oc stock at stock V... Results for x264.exe r1342 -------------------------- encoded 1442 frames, 58.32 fps, 3898.70 kb/s encoded 1442 frames, 57.94 fps, 3898.70 kb/s encoded 1442 frames, 60.20 fps, 3898.70 kb/s encoded 1442 frames, 58.00 fps, 3898.70 kb/s encoded 1442 frames, 25.55 fps, 3960.35 kb/s encoded 1442 frames, 24.82 fps, 3969.84 kb/s encoded 1442 frames, 24.69 fps, 3966.73 kb/s encoded 1442 frames, 24.58 fps, 3953.93 kb/s System Details -------------- Name AMD K10 Codename Specification AMD Phenom(tm) II X6 1055T Processor Core Stepping Stock frequency 3300 MHz Core Speed 2800.4 MHz FID range 5.0x - 16.5x Northbridge AMD 790GX rev. 00 Southbridge ATI SB750 rev. 00 CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 15 Command Rate (CR) 2T Memory Frequency 533.4 MHz (3:8) Memory Type DDR2 Memory Size 4096 MBytes Channels Dual, (Unganged) Windows Version Microsoft Windows Vista (6.0) Business Edition Service Pack 2 (Build 6002) Number of processors 1 Number of threads 6 Number of threads 6 (max 6) L2 cache 6 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64 Package Socket AM2+ (940) Package Type 0x1 Temperature 0 46°C (114°F) [0x2E] (TMPIN0) Temperature 1 38°C (100°F) [0x26] (TMPIN1) Temperature 2 32°C (89°F) [0x20] (TMPIN2) Temperature 0 39°C (102°F) [0x138] (Core #0) Temperature 1 39°C (102°F) [0x139] (Core #1) Temperature 2 39°C (102°F) [0x13B] (Core #2) Temperature 3 40°C (103°F) [0x13C] (Core #3) Temperature 4 40°C (103°F) [0x13C] (Core #4) Temperature 5 40°C (103°F) [0x13E] (Core #5) oc at 1.40V (as high as i want to go, for now at least)... Results for x264.exe r1342 -------------------------- encoded 1442 frames, 73.14 fps, 3898.70 kb/s encoded 1442 frames, 73.15 fps, 3898.70 kb/s encoded 1442 frames, 73.67 fps, 3898.70 kb/s encoded 1442 frames, 73.34 fps, 3898.70 kb/s encoded 1442 frames, 31.57 fps, 3971.16 kb/s encoded 1442 frames, 31.78 fps, 3955.23 kb/s encoded 1442 frames, 31.61 fps, 3948.89 kb/s encoded 1442 frames, 31.64 fps, 3964.55 kb/s System Details -------------- Name AMD Phenom II X6 1055T Codename Thuban Specification AMD Phenom(tm) II X6 1055T Processor Core Stepping Technology 45 nm Stock frequency 3300 MHz Core Speed 3487.0 MHz FID range 4.0x - 16.5x Northbridge AMD 790GX rev. 00 Southbridge AMD ID439D rev. 00 CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 15 Command Rate (CR) 2T Memory Frequency 498.1 MHz (1:2) Memory Type DDR2 Memory Size 4096 MBytes Channels Dual, (Unganged) Windows Version Microsoft Windows Vista (6.0) Business Edition Service Pack 2 (Build 6002) Number of processors 1 Number of threads 6 Number of threads 6 (max 6) L2 cache 6 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V Package Socket AM3 (938) Package Type 0x1 Temperature 0 49°C (120°F) [0x31] (TMPIN0) Temperature 1 40°C (103°F) [0x28] (TMPIN1) Temperature 2 32°C (89°F) [0x20] (TMPIN2) Temperature 0 39°C (101°F) [0x137] (Core #0) Temperature 1 39°C (102°F) [0x13A] (Core #1) Temperature 2 40°C (103°F) [0x13C] (Core #2) Temperature 3 40°C (103°F) [0x13F] (Core #3) Temperature 4 40°C (104°F) [0x142] (Core #4) Temperature 5 41°C (105°F) [0x146] (Core #5)
For the Bossman's request, my 1090T at stock 3.2Ghz. Just to note, I did leave Cool 'n Quiet enabled on both of my runs, and the clocks did jump around a bit. Results for x264.exe r1342 -------------------------- encoded 1442 frames, 67.51 fps, 3898.70 kb/s encoded 1442 frames, 67.12 fps, 3898.70 kb/s encoded 1442 frames, 67.08 fps, 3898.70 kb/s encoded 1442 frames, 66.52 fps, 3898.70 kb/s encoded 1442 frames, 26.85 fps, 3960.18 kb/s encoded 1442 frames, 25.98 fps, 3968.47 kb/s encoded 1442 frames, 25.06 fps, 3971.14 kb/s encoded 1442 frames, 26.13 fps, 3948.11 kb/s System Details -------------- Name AMD K10 product System Product Name Codename Specification AMD Phenom(tm) II X6 1090T Processor Core Stepping Core Speed 3211.1 MHz Northbridge AMD 790FX rev. 00 Southbridge ATI SB750 rev. 00 CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 15 Command Rate (CR) 2T Memory Frequency 535.2 MHz (3:8) Memory Type DDR2 Memory Size 8192 MBytes Channels Dual, (Unganged) Windows Version Microsoft Windows 7 (6.1) Home Premium Edition (Build 7600) Number of processors 1 Number of threads 6 Number of threads 6 (max 6) L2 cache 6 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64 Package Socket AM2+ (940) Package Type 0x1 Temperature 0 38°C (100°F) [0x26] (TMPIN0) Temperature 1 30°C (85°F) [0x1E] (TMPIN1) Temperature 0 32°C (88°F) [0xFC] (Core #0) Temperature 1 32°C (88°F) [0xFC] (Core #1) Temperature 2 32°C (88°F) [0xFC] (Core #2) Temperature 3 32°C (88°F) [0xFC] (Core #3) Temperature 4 32°C (88°F) [0xFC] (Core #4) Temperature 5 32°C (88°F) [0xFC] (Core #5)
Thanks for the new results, guys!! @ SicKlown42012 : You might want to retest with CnQ disabled, and AMD Turbo turned off too. Your results seem to be a little lower than the current results we have. @ entireweb : Can you retest the i7-860 at stock speed please? Thanks!!
Cool 'n Quiet is enabled in my BIOS but not in Windows XP when the test was conducted. This is a Phenom II X2 550 BE unlocked to an X4 B50 and overclocked. It runs stable on Prime95 with "In-place large FFTs" for 6 hours (I haven't tried any longer). The core temperatures won't show up because they do not work when the extra cores are unlocked. I'm still tweaking the RAM and CPU because I think I can get more out of it. ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r1342 -------------------------- encoded 1442 frames, 72.95 fps, 3910.60 kb/s encoded 1442 frames, 71.99 fps, 3905.93 kb/s encoded 1442 frames, 74.36 fps, 3880.15 kb/s encoded 1442 frames, 75.16 fps, 3837.83 kb/s encoded 1442 frames, 23.16 fps, 3964.17 kb/s encoded 1442 frames, 22.69 fps, 3952.12 kb/s encoded 1442 frames, 23.08 fps, 3963.95 kb/s encoded 1442 frames, 23.48 fps, 3978.50 kb/s System Details -------------- Name AMD Phenom II X4 Codename Deneb Specification AMD Phenom(tm) II X4 B50 Processor Core Stepping RB-C2 Technology 45 nm Core Speed 3700.3 MHz Northbridge AMD 790GX rev. 00 Southbridge ATI SB750 rev. 00 CAS# latency (CL) 4.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 12 Command Rate (CR) 2T Memory Frequency 400.0 MHz (1:2) Memory Type DDR2 Memory Size 4096 MBytes Channels Dual, (Unganged) Windows Version Microsoft Windows XP Professional Service Pack 2 (Build 2600) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64 Package Socket AM2+ (940) Package Type 0x1 Temperature 0 35°C (94°F) [0x23] (TMPIN0) Temperature 1 23°C (73°F) [0x17] (TMPIN1) Temperature 2 41°C (105°F) [0x29] (TMPIN2) Temperature 0 0°C (32°F) [0x0] (Core #0) Temperature 1 0°C (32°F) [0x0] (Core #1) Temperature 2 0°C (32°F) [0x0] (Core #2) Temperature 3 0°C (32°F) [0x0] (Core #3)
