Thanks for the results!! Keep 'em coming! OT : Yeah, the temps are too high. The idle temp is especially high.
Results for x264.exe r1342 -------------------------- encoded 1442 frames, 20.06 fps, 3899.26 kb/s encoded 1442 frames, 20.70 fps, 3899.26 kb/s encoded 1442 frames, 20.59 fps, 3899.26 kb/s encoded 1442 frames, 20.34 fps, 3899.26 kb/s encoded 1442 frames, 4.57 fps, 3970.78 kb/s encoded 1442 frames, 4.61 fps, 3971.58 kb/s encoded 1442 frames, 4.56 fps, 3971.09 kb/s encoded 1442 frames, 4.61 fps, 3971.87 kb/s System Details -------------- Name Intel Celeron E1400 Codename Conroe Specification Intel(R) Celeron(R) CPU E1400 @ 2.00GHz Core Stepping M0 Technology 65 nm manufacturer Gigabyte Technology Co., Ltd. vendor Gigabyte Technology Co., Ltd. manufacturer Gigabyte Technology Co., Ltd. Stock frequency 2000 MHz Core Speed 1800.0 MHz FID range 6.0x - 10.0x Northbridge Intel P35/G33/G31 rev. 10 Southbridge Intel 82801GB (ICH7/R) rev. A1 CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 18 Command Rate (CR) 2T Memory Frequency 400.0 MHz (1:2) Memory Type DDR2 Memory Size 2048 MBytes Channels Dual, (Symmetric) Windows Version Microsoft Windows Server 2003 Enterprise Edition Service Pack 2, v.4666 (Build 3790) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 512 KBytes, 2-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T Package (platform ID) Socket 775 LGA (0x0) Temperature 2 51°C (123°F) [0x33] (TMPIN2) Temperature 0 55°C (130°F) [0x1E] (Core #0) Temperature 1 56°C (132°F) [0x1D] (Core #1)
Thanks for the result, Tomek. However, it looks like your Celeron E1400 was underclocked to 1.8 GHz. Can you confirm that it was running at the proper 2.0 GHz, instead of 1.8 GHz? Thanks!
Ah, I totally forgot to change clock speed, here's the proper result: -- Results for x264.exe r1342 -------------------------- encoded 1442 frames, 21.73 fps, 3899.26 kb/s encoded 1442 frames, 21.71 fps, 3899.26 kb/s encoded 1442 frames, 21.77 fps, 3899.26 kb/s encoded 1442 frames, 22.17 fps, 3899.26 kb/s encoded 1442 frames, 4.86 fps, 3970.82 kb/s encoded 1442 frames, 4.87 fps, 3972.05 kb/s encoded 1442 frames, 4.85 fps, 3971.17 kb/s encoded 1442 frames, 4.87 fps, 3971.27 kb/s System Details -------------- Name Intel Celeron E1400 Name ASUS EAH3450 Series Codename Conroe Codename RV620 Specification Intel(R) Celeron(R) CPU E1400 @ 2.00GHz Core Stepping M0 Technology 65 nm manufacturer Gigabyte Technology Co., Ltd. vendor Gigabyte Technology Co., Ltd. manufacturer Gigabyte Technology Co., Ltd. Technology 55 nm Stock frequency 2000 MHz Core Speed 2000.0 MHz FID range 6.0x - 10.0x Northbridge Intel P35/G33/G31 rev. 10 Southbridge Intel 82801GB (ICH7/R) rev. A1 CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 18 Command Rate (CR) 2T Memory Frequency 400.0 MHz (1:2) Memory Type DDR2 Memory Size 2048 MBytes Channels Dual, (Symmetric) Windows Version Microsoft Windows Server 2003 Enterprise Edition Service Pack 2, v.4666 (Build 3790) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 512 KBytes, 2-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T Package (platform ID) Socket 775 LGA (0x0) Temperature 0 55°C (130°F) [0x1E] (Core #0) Temperature 1 56°C (132°F) [0x1D] (Core #1) Temperature 0 47°C (116°F) (GPU Core)
Athlon X2 5200+ 2GB PC6400 RAM Geforce 8400GS Results Results for x264.exe r1342 -------------------------- encoded 1442 frames, 28.85 fps, 3899.26 kb/s encoded 1442 frames, 28.81 fps, 3899.26 kb/s encoded 1442 frames, 28.72 fps, 3899.26 kb/s encoded 1442 frames, 28.72 fps, 3899.26 kb/s encoded 1442 frames, 6.71 fps, 3970.95 kb/s encoded 1442 frames, 6.68 fps, 3971.67 kb/s encoded 1442 frames, 6.67 fps, 3971.58 kb/s encoded 1442 frames, 6.66 fps, 3970.94 kb/s System Details -------------- Name AMD Athlon 64 X2 5200+ Codename Brisbane Specification AMD Athlon(tm) 64 X2 Dual Core Processor 5200+ Core Stepping BH-G2 Technology 65 nm Manufacturer (ID) Crucial Technology (7F7F7F7F7F9BFFFF) Manufacturer (ID) Crucial Technology (7F7F7F7F7F9BFFFF) Stock frequency 2700 MHz Core Speed 2712.7 MHz Northbridge NVIDIA MCP61 rev. A3 Southbridge NVIDIA MCP61 rev. A2 CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 18 Command Rate (CR) 2T Memory Frequency 387.5 MHz (CPU/7) Memory Type DDR2 Memory Size 2048 MBytes Channels Dual Windows Version Microsoft Windows XP Home Edition Service Pack 3 (Build 2600) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 2 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64 Package Socket AM2 (940) Temperature 0 43°C (109°F) [0x2B] (TMPIN0) Temperature 1 43°C (109°F) [0x2B] (TMPIN1) Temperature 2 25°C (76°F) [0x19] (TMPIN2) Temperature 0 59°C (138°F) [0x15C] (Core #0) Temperature 1 58°C (136°F) [0x159] (Core #1)
Finally got around to updating the BIOS which allowed me to disable Cool 'n Quiet. My scores didn't really change though. I think it has to do with the fact that I'm still rocking some old DDR2. Results for x264.exe r1342 -------------------------- encoded 1442 frames, 82.71 fps, 3898.70 kb/s encoded 1442 frames, 82.60 fps, 3898.70 kb/s encoded 1442 frames, 82.51 fps, 3898.70 kb/s encoded 1442 frames, 82.74 fps, 3898.70 kb/s encoded 1442 frames, 34.89 fps, 3972.74 kb/s encoded 1442 frames, 34.97 fps, 3969.23 kb/s encoded 1442 frames, 35.28 fps, 3968.83 kb/s encoded 1442 frames, 35.00 fps, 3965.42 kb/s System Details -------------- Name AMD K10 product System Product Name Codename Specification AMD Phenom(tm) II X6 1090T Processor Core Stepping Core Speed 4014.5 MHz Northbridge AMD 790FX rev. 00 Southbridge ATI SB750 rev. 00 CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 15 Command Rate (CR) 2T Memory Frequency 535.3 MHz (3:8) Memory Type DDR2 Memory Size 8192 MBytes Channels Dual, (Unganged) Windows Version Microsoft Windows 7 (6.1) Home Premium Edition (Build 7600) Number of processors 1 Number of threads 6 Number of threads 6 (max 6) L2 cache 6 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64 Package Socket AM2+ (940) Package Type 0x1 Temperature 0 47°C (116°F) [0x2F] (TMPIN0) Temperature 1 29°C (84°F) [0x1D] (TMPIN1) Temperature 0 40°C (103°F) [0x13C] (Core #0) Temperature 1 40°C (103°F) [0x13E] (Core #1) Temperature 2 40°C (103°F) [0x13E] (Core #2) Temperature 3 40°C (103°F) [0x13C] (Core #3) Temperature 4 40°C (103°F) [0x13D] (Core #4) Temperature 5 40°C (103°F) [0x13D] (Core #5)
That's actually a much better result. It moved your CPU up 6 spots in Pass 1, and 1 spot in Pass 2. Overall, your CPU went up 5 spots.
Found culprit - dirty heatsink Temps went down by 30°C BTW Here is new benchmark with pair opteron 290 cpu's. ================================ Results for x264.exe r1342 -------------------------- encoded 1442 frames, 44.80 fps, 3900.68 kb/s encoded 1442 frames, 43.29 fps, 3901.21 kb/s encoded 1442 frames, 43.27 fps, 3900.68 kb/s encoded 1442 frames, 43.27 fps, 3901.21 kb/s encoded 1442 frames, 13.52 fps, 3970.59 kb/s encoded 1442 frames, 13.61 fps, 3971.63 kb/s encoded 1442 frames, 13.52 fps, 3971.60 kb/s encoded 1442 frames, 13.40 fps, 3970.98 kb/s System Details -------------- Name AMD Opteron 290 (DP) Name AMD Opteron 290 (DP) Codename Italy Codename Italy Specification Dual Core AMD Opteron(tm) Processor 290 Specification Dual Core AMD Opteron(tm) Processor 290 Core Stepping JH9-E6 Core Stepping JH9-E6 Technology 90 nm Technology 90 nm Stock frequency 2800 MHz Stock frequency 2800 MHz Core Speed 2813.2 MHz Core Speed 2813.2 MHz Northbridge NVIDIA nForce Pro 2050 rev. A3 Southbridge NVIDIA nForce Pro 2200 rev. A3 CAS# latency (CL) 3.0 RAS# to CAS# delay (tRCD) 3 RAS# Precharge (tRP) 3 Cycle Time (tRAS) 8 Command Rate (CR) 1T Memory Frequency 200.9 MHz (CPU/14) Memory Type DDR Memory Size 4096 MBytes Channels Dual Windows Version Microsoft Windows 7 (6.1) Ultimate Edition (Build 7600) Number of processors 2 Number of threads 4 Number of threads 2 (max 2) Number of threads 2 (max 2) L2 cache 2 x 1024 KBytes, 16-way set associative, 64-byte line size L2 cache 2 x 1024 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64 Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64 Package Socket 940 Package Socket 940 Temperature 0 73°C (163°F) [0x7A] (Core #0) Temperature 1 70°C (157°F) [0x77] (Core #1) Temperature 0 67°C (152°F) [0x74] (Core #0) Temperature 1 67°C (152°F) [0x74] (Core #1)
Hello, First post so might be good to start with a thanks for this utility, really useful in order to quickly see an overclocking impact when you do a lot of video compression. So thank you Here are some results from an Intel i5 750 at several speed. Also in attached file is an Excel sheet that I've created to analyze those results with more details. Feel free to use it as you like for your own tests. ################################### Results for x264.exe r1342 -------------------------- encoded 1442 frames, 66.29 fps, 3900.09 kb/s encoded 1442 frames, 66.57 fps, 3900.68 kb/s encoded 1442 frames, 66.67 fps, 3900.68 kb/s encoded 1442 frames, 65.92 fps, 3900.68 kb/s encoded 1442 frames, 20.20 fps, 3970.85 kb/s encoded 1442 frames, 20.39 fps, 3971.94 kb/s encoded 1442 frames, 20.34 fps, 3970.18 kb/s encoded 1442 frames, 20.39 fps, 3971.91 kb/s System Details -------------- Name Intel Core i5 750 product System Product Name Codename Lynnfield Specification Intel(R) Core(TM) i5 CPU 750 @ 2.67GHz Specification PC3-12800 Specification PC3-12800 Core Stepping B1 Technology 45 nm Stock frequency 2666 MHz Core Speed 2675.1 MHz Northbridge Intel DMI Host Bridge rev. 11 Southbridge Intel P55 rev. 06 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Command Rate (CR) 1T Command Rate 2T Command Rate 2T Memory Frequency 668.8 MHz (2:10) Memory Type DDR3 Memory Size 4096 MBytes Channels Dual Windows Version Microsoft Windows 7 (6.1) Home Premium Edition (Build 7600) Number of processors 1 Number of threads 4 Number of threads 4 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T Package (platform ID) Socket 1156 LGA (0x1) Temperature 0 49°C (120°F) [0x31] (SYSTIN) Temperature 1 49°C (120°F) [0x62] (CPUTIN) Temperature 2 44°C (110°F) [0x57] (AUXTIN) Temperature 0 49°C (120°F) [0x32] (Core #0) Temperature 1 46°C (114°F) [0x35] (Core #1) Temperature 2 48°C (118°F) [0x33] (Core #2) Temperature 3 48°C (118°F) [0x33] (Core #3) ################################### ################################### Results for x264.exe r1342 -------------------------- encoded 1442 frames, 67.73 fps, 3900.68 kb/s encoded 1442 frames, 69.61 fps, 3901.21 kb/s encoded 1442 frames, 69.45 fps, 3900.68 kb/s encoded 1442 frames, 69.35 fps, 3900.68 kb/s encoded 1442 frames, 20.92 fps, 3970.34 kb/s encoded 1442 frames, 20.99 fps, 3971.20 kb/s encoded 1442 frames, 21.04 fps, 3971.86 kb/s encoded 1442 frames, 20.96 fps, 3971.24 kb/s System Details -------------- Name Intel Core i5 750 product System Product Name Codename Lynnfield Specification Intel(R) Core(TM) i5 CPU 750 @ 2.67GHz Specification PC3-12800 Specification PC3-12800 Core Stepping B1 Technology 45 nm Stock frequency 2666 MHz Core Speed 2731.2 MHz Northbridge Intel DMI Host Bridge rev. 11 Southbridge Intel P55 rev. 06 CAS# latency (CL) 7.0 RAS# to CAS# delay (tRCD) 8 RAS# Precharge (tRP) 7 Cycle Time (tRAS) 24 Command Rate (CR) 2T Command Rate 2T Command Rate 2T Memory Frequency 803.3 MHz (2:10) Memory Type DDR3 Memory Size 4096 MBytes Channels Dual Windows Version Microsoft Windows 7 (6.1) Home Premium Edition (Build 7600) Number of processors 1 Number of threads 4 Number of threads 4 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T Package (platform ID) Socket 1156 LGA (0x1) Temperature 0 46°C (114°F) [0x2E] (SYSTIN) Temperature 1 47°C (115°F) [0x5D] (CPUTIN) Temperature 2 42°C (106°F) [0x53] (AUXTIN) Temperature 0 46°C (114°F) [0x35] (Core #0) Temperature 1 45°C (112°F) [0x36] (Core #1) Temperature 2 45°C (112°F) [0x36] (Core #2) Temperature 3 43°C (109°F) [0x38] (Core #3) ################################### ################################### Results for x264.exe r1342 -------------------------- encoded 1442 frames, 79.38 fps, 3901.21 kb/s encoded 1442 frames, 79.36 fps, 3900.68 kb/s encoded 1442 frames, 79.26 fps, 3900.68 kb/s encoded 1442 frames, 79.94 fps, 3900.68 kb/s encoded 1442 frames, 24.13 fps, 3971.70 kb/s encoded 1442 frames, 24.17 fps, 3970.77 kb/s encoded 1442 frames, 24.25 fps, 3971.03 kb/s encoded 1442 frames, 24.11 fps, 3971.36 kb/s System Details -------------- Name Intel Core i5 750 product System Product Name Codename Lynnfield Specification Intel(R) Core(TM) i5 CPU 750 @ 2.67GHz Specification PC3-12800 Specification PC3-12800 Core Stepping B1 Technology 45 nm Stock frequency 2666 MHz Core Speed 3213.2 MHz Northbridge Intel DMI Host Bridge rev. 11 Southbridge Intel P55 rev. 06 CAS# latency (CL) 7.0 RAS# to CAS# delay (tRCD) 8 RAS# Precharge (tRP) 7 Cycle Time (tRAS) 24 Command Rate (CR) 2T Command Rate 2T Command Rate 2T Memory Frequency 803.3 MHz (2:10) Memory Type DDR3 Memory Size 4096 MBytes Channels Dual Windows Version Microsoft Windows 7 (6.1) Home Premium Edition (Build 7600) Number of processors 1 Number of threads 4 Number of threads 4 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T Package (platform ID) Socket 1156 LGA (0x1) Temperature 0 49°C (120°F) [0x31] (SYSTIN) Temperature 1 50°C (121°F) [0x63] (CPUTIN) Temperature 2 42°C (107°F) [0x54] (AUXTIN) Temperature 0 48°C (118°F) [0x33] (Core #0) Temperature 1 44°C (111°F) [0x37] (Core #1) Temperature 2 48°C (118°F) [0x33] (Core #2) Temperature 3 48°C (118°F) [0x33] (Core #3) ################################### ################################### Results for x264.exe r1342 -------------------------- encoded 1442 frames, 96.90 fps, 3900.68 kb/s encoded 1442 frames, 96.98 fps, 3900.68 kb/s encoded 1442 frames, 97.56 fps, 3900.68 kb/s encoded 1442 frames, 96.80 fps, 3900.10 kb/s encoded 1442 frames, 30.47 fps, 3970.72 kb/s encoded 1442 frames, 30.50 fps, 3972.00 kb/s encoded 1442 frames, 30.46 fps, 3971.39 kb/s encoded 1442 frames, 30.46 fps, 3970.70 kb/s System Details -------------- Name Intel Core i5 750 product System Product Name Codename Lynnfield Specification Intel(R) Core(TM) i5 CPU 750 @ 2.67GHz Specification PC3-12800 Specification PC3-12800 Core Stepping B1 Technology 45 nm Stock frequency 2666 MHz Core Speed 4013.4 MHz Northbridge Intel DMI Host Bridge rev. 11 Southbridge Intel P55 rev. 06 CAS# latency (CL) 7.0 RAS# to CAS# delay (tRCD) 8 RAS# Precharge (tRP) 7 Cycle Time (tRAS) 24 Command Rate (CR) 2T Command Rate 2T Command Rate 2T Memory Frequency 802.7 MHz (2:8) Memory Type DDR3 Memory Size 4096 MBytes Channels Dual Windows Version Microsoft Windows 7 (6.1) Home Premium Edition (Build 7600) Number of processors 1 Number of threads 4 Number of threads 4 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T Package (platform ID) Socket 1156 LGA (0x1) Temperature 0 74°C (165°F) [0x4A] (SYSTIN) Temperature 1 75°C (166°F) [0x95] (CPUTIN) Temperature 2 56°C (131°F) [0x6F] (AUXTIN) Temperature 0 72°C (161°F) [0x1B] (Core #0) Temperature 1 67°C (152°F) [0x20] (Core #1) Temperature 2 67°C (152°F) [0x20] (Core #2) Temperature 3 65°C (148°F) [0x22] (Core #3) ###################################
I have the same problem... probably much worse. I have to clean off the muck every few weeks! PS. Thanks for the results! Keep 'em coming!
No problem. I think I can speak for graysky and Dashken, when I say we are just happy that everyone liked it so much, and that everyone has been so nice taking their time to test their processors and contributing their results. Thanks for your results BTW!!! Keep 'em coming!
^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r1342 -------------------------- encoded 1442 frames, 83.02 fps, 3897.87 kb/s encoded 1442 frames, 83.68 fps, 3899.02 kb/s encoded 1442 frames, 82.61 fps, 3899.02 kb/s encoded 1442 frames, 82.20 fps, 3899.02 kb/s encoded 1442 frames, 33.57 fps, 3960.90 kb/s encoded 1442 frames, 33.53 fps, 3970.84 kb/s encoded 1442 frames, 33.61 fps, 3961.73 kb/s encoded 1442 frames, 33.64 fps, 3963.11 kb/s System Details -------------- Name Intel Core i7 860 Codename Lynnfield Specification Intel(R) Core(TM) i7 CPU 860 @ 2.80GHz Specification PC3-12800 Specification PC3-12800 Core Stepping B1 Technology 45 nm manufacturer Gigabyte Technology Co., Ltd. vendor Gigabyte Technology Co., Ltd. manufacturer Gigabyte Technology Co., Ltd. Stock frequency 2800 MHz Core Speed 3599.9 MHz Northbridge Intel DMI Host Bridge rev. 11 Southbridge Intel P55 rev. 06 CAS# latency (CL) 7.0 RAS# to CAS# delay (tRCD) 8 RAS# Precharge (tRP) 7 Cycle Time (tRAS) 24 Command Rate (CR) 2T Command Rate 2T Command Rate 2T Memory Frequency 800.0 MHz (2:8) Memory Type DDR3 Memory Size 4096 MBytes Channels Dual Windows Version Microsoft Windows 7 (6.1) (Build 7600) Number of processors 1 Number of threads 8 Number of threads 8 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T Package (platform ID) Socket 1156 LGA (0x1) Temperature 0 37°C (98°F) [0x25] (TMPIN0) Temperature 1 25°C (76°F) [0x19] (TMPIN1) Temperature 2 44°C (111°F) [0x2C] (TMPIN2) Temperature 0 48°C (118°F) [0x33] (Core #0) Temperature 1 56°C (132°F) [0x2B] (Core #1) Temperature 2 47°C (116°F) [0x34] (Core #2) Temperature 3 49°C (120°F) [0x32] (Core #3)
Thanks for the results! If you can retest the i7-860 at stock speed, or other clock speeds, do post the results. We will update the charts with the best results we get. Thanks!
New results with a dual X5650. ----------- x264 HD BENCHMARK 3.0 RESULTS Please do not compare it with older versions of the benchmark! Please copy/paste everything below the line to to report your data ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r1342 -------------------------- encoded 1442 frames, 67.37 fps, 3903.13 kb/s encoded 1442 frames, 67.62 fps, 3903.14 kb/s encoded 1442 frames, 67.67 fps, 3903.29 kb/s encoded 1442 frames, 66.79 fps, 3903.14 kb/s encoded 1442 frames, 52.91 fps, 3913.19 kb/s encoded 1442 frames, 53.46 fps, 3925.48 kb/s encoded 1442 frames, 52.91 fps, 3908.97 kb/s encoded 1442 frames, 53.40 fps, 3926.60 kb/s System Details -------------- Name Intel Core i7 Name Intel Core i7 Codename Gulftown Codename Gulftown Specification Intel(R) Xeon(R) CPU X5650 @ 2.67GHz Specification Intel(R) Xeon(R) CPU X5650 @ 2.67GHz Core Stepping Core Stepping Technology 32 nm Technology 32 nm Stock frequency 2666 MHz Stock frequency 2666 MHz Core Speed 2660.7 MHz Core Speed 2660.7 MHz Northbridge Intel 5500 rev. 22 Southbridge Intel 82801JR (ICH10R) rev. 00 Memory Type Memory Size 49084 MBytes Windows Version Microsoft Windows Server 2008 Enterprise Edition (Full) Service Pack 1 (Build 6001) Number of processors 2 Number of threads 24 Number of threads 12 (max 32) Number of threads 12 (max 32) L2 cache 6 x 256 KBytes, 8-way set associative, 64-byte line size L2 cache 6 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T Package (platform ID) Socket 1366 LGA (0x0) Package (platform ID) Socket 1366 LGA (0x0) Temperature 0 43°C (109°F) [0x35] (Core #0) Temperature 1 39°C (102°F) [0x39] (Core #1) Temperature 2 41°C (105°F) [0x37] (Core #2) Temperature 8 41°C (105°F) [0x37] (Core #8) Temperature 9 42°C (107°F) [0x36] (Core #9) Temperature 10 38°C (100°F) [0x3A] (Core #10) Temperature 0 44°C (111°F) [0x34] (Core #0) Temperature 1 41°C (105°F) [0x37] (Core #1) Temperature 2 46°C (114°F) [0x32] (Core #2) Temperature 8 47°C (116°F) [0x31] (Core #8) Temperature 9 42°C (107°F) [0x36] (Core #9) Temperature 10 40°C (103°F) [0x38] (Core #10)
Acer aspire5520 AMD TL60 @2.2Ghz Cheap laptop results Results for x264.exe r1342 -------------------------- encoded 1442 frames, 24.32 fps, 3899.26 kb/s encoded 1442 frames, 24.23 fps, 3899.26 kb/s encoded 1442 frames, 24.25 fps, 3899.26 kb/s encoded 1442 frames, 24.00 fps, 3899.26 kb/s encoded 1442 frames, 5.45 fps, 3971.59 kb/s encoded 1442 frames, 5.45 fps, 3971.89 kb/s encoded 1442 frames, 5.46 fps, 3971.07 kb/s encoded 1442 frames, 5.52 fps, 3971.69 kb/s System Details -------------- Name AMD Turion 64 X2 Mobile TL-60 Codename Tyler Specification AMD Turion(tm) 64 X2 Mobile Technology TL-60 Core Stepping Specification AMD Turion(tm) 64 X2 Mobile Technology TL-60 Technology 65 nm Stock frequency 2000 MHz Core Speed 2196.9 MHz Northbridge NVIDIA nForce 560 rev. A2 Southbridge NVIDIA nForce 560 rev. A2 CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 15 Command Rate (CR) 1T Memory Frequency 366.1 MHz (CPU/6) Memory Type DDR2 Memory Size 2048 MBytes Channels Dual Windows Version Microsoft Windows XP Professional Service Pack 2 (Build 2600) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 2 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64 Package Socket S1 (638) Temperature 0 80°C (175°F) [0x202] (Core #0) Temperature 1 73°C (162°F) [0x1E6] (Core #1)
Wow.. 12 cores in all. The scores are, oddly, very low. Any idea why? BTW, what RAM did you use, and what speed were they running at? Thanks!
RAM is DDR3 1066 with 7-7-7-20 timings. Yeah, the scores do seem very low. I ran this on a fresh install of WS2K8 on new hardware via an RDP session. I'll try running from the console and see if I missed something obvious that would kill the performance.
