[email protected] Results for x264.exe r1342 -------------------------- encoded 1442 frames, 78.74 fps, 3900.68 kb/s encoded 1442 frames, 77.81 fps, 3900.68 kb/s encoded 1442 frames, 78.73 fps, 3901.21 kb/s encoded 1442 frames, 77.94 fps, 3900.68 kb/s encoded 1442 frames, 25.44 fps, 3971.90 kb/s encoded 1442 frames, 25.53 fps, 3971.72 kb/s encoded 1442 frames, 25.58 fps, 3972.03 kb/s encoded 1442 frames, 25.49 fps, 3971.27 kb/s System Details -------------- Name Intel Core 2 Quad Q9400 Codename Yorkfield Specification Intel(R) Core(TM)2 Quad CPU Q9400 @ 2.66GHz Core Stepping R0 Technology 45 nm manufacturer Gigabyte Technology Co., Ltd. vendor Gigabyte Technology Co., Ltd. manufacturer Gigabyte Technology Co., Ltd. Stock frequency 2666 MHz Core Speed 3904.3 MHz FID range 6.0x - 8.0x Northbridge Intel P45/P43 rev. A3 Southbridge Intel 82801JR (ICH10R) rev. 00 CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 6 RAS# Precharge (tRP) 6 Cycle Time (tRAS) 16 Command Rate (CR) 2T Memory Frequency 488.0 MHz (1:1) Memory Type DDR2 Memory Size 4096 MBytes Channels Dual, (Symmetric) Windows Version Microsoft Windows 7 (6.1) Enterprise Edition (Build 7600) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 2 x 3072 KBytes, 12-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T, VT-x Package (platform ID) Socket 775 LGA (0x4) Temperature 0 39°C (102°F) [0x27] (System) Temperature 1 43°C (109°F) [0x2B] (CPU) Temperature 0 46°C (114°F) [0x36] (Core #0) Temperature 1 39°C (102°F) [0x3D] (Core #1) Temperature 2 41°C (105°F) [0x3B] (Core #2) Temperature 3 45°C (112°F) [0x37] (Core #3)
The thing is the benchmark compilation is new, but the changes do not affect the results. The reason why I still kept the benchmark filename as 3.0 is because I don't want folks to assume it's a totally different version and start posting their results as 3.18 or 3.19.
What I actually meant is, the benchmark version remains as 3.0, while the article should have a different title format which is completely different from the benchmark itself. For example: x264 HD Benchmark 3.0 for the benchmark program, and x264 HD Benchmark 3.0 (Article Update 18) refers to the comparison guide.
Actually, the benchmark package has been modified. Maybe I should just renamed it as 3.19 and let them post as 3.19 (or whatever revision). Just as long as everyone is clear that the results are the same and remain comparable.
E7500 @ 4 GHZ (8x500) x264 HD BENCHMARK 3.0 RESULTS Please do not compare it with older versions of the benchmark! Please copy/paste everything below the line to to report your data ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r1342 -------------------------- encoded 1442 frames, 57.86 fps, 3899.26 kb/s encoded 1442 frames, 57.86 fps, 3899.26 kb/s encoded 1442 frames, 57.97 fps, 3899.26 kb/s encoded 1442 frames, 57.75 fps, 3899.26 kb/s encoded 1442 frames, 13.77 fps, 3971.06 kb/s encoded 1442 frames, 13.79 fps, 3970.49 kb/s encoded 1442 frames, 13.85 fps, 3971.20 kb/s encoded 1442 frames, 13.80 fps, 3971.35 kb/s System Details -------------- Name Intel Core 2 Duo E7500 Codename Wolfdale Specification Intel(R) Core(TM)2 Duo CPU E7500 @ 2.93GHz Specification PC3-12800 Specification PC3-14200 Specification PC3-12800 Specification PC3-14200 Core Stepping R0 Technology 45 nm manufacturer Gigabyte Technology Co., Ltd. vendor Gigabyte Technology Co., Ltd. manufacturer Gigabyte Technology Co., Ltd. Stock frequency 2933 MHz Core Speed 4000.1 MHz FID range 6.0x - 11.0x Northbridge Intel P45/P43 rev. A3 Southbridge Intel 82801JR (ICH10R) rev. 00 CAS# latency (CL) 7.0 RAS# to CAS# delay (tRCD) 6 RAS# Precharge (tRP) 6 Cycle Time (tRAS) 16 Command Rate (CR) 2T Memory Frequency 800.0 MHz (5:8) Memory Type DDR3 Memory Size 4096 MBytes Channels Dual, (Symmetric) Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 3072 KBytes, 12-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T Package (platform ID) Socket 775 LGA (0x0) Temperature 0 30°C (85°F) [0x1E] (TMPIN0) Temperature 1 48°C (118°F) [0x30] (TMPIN1) Temperature 0 46°C (114°F) [0x36] (Core #0) Temperature 1 44°C (111°F) [0x38] (Core #1)
I don't suppose you take requests? If so can you add 2 lines under the results print to include average pass 2 and total average results? I know you can just add it all up but it would be so much nicer if the bench just spit the numbers out for you.
In your post, in both the title and the link it says "x264 HD Benchmark 3.19" At least to me it reads as if there's a new program, especially when the "link" has that title to it.
Actually, that should be the true version number of the benchmark because the files inside have changed. The only reason why I left the actual filename as 3.0 is to avoid people thinking that the results of 3.19 would be different (and not comparable) with other 3.x versions.
I Am Now Depressed Dr. Wong: I can feel you are elegant human and Bless You for all you offer. Before I blow my brains out.....I can not afford a system with the i7 chip I yearn for, I willl paste the results of your excellent test for which I thank you. Results for x264.exe r1342 -------------------------- encoded 1442 frames, 22.47 fps, 3899.26 kb/s encoded 1442 frames, 22.49 fps, 3899.26 kb/s encoded 1442 frames, 22.43 fps, 3899.26 kb/s encoded 1442 frames, 22.62 fps, 3899.26 kb/s encoded 1442 frames, 5.23 fps, 3970.68 kb/s encoded 1442 frames, 5.24 fps, 3971.59 kb/s encoded 1442 frames, 5.22 fps, 3971.82 kb/s encoded 1442 frames, 5.20 fps, 3970.60 kb/s System Details -------------- Name Intel Pentium D 945 Codename Presler Specification Intel(R) Pentium(R) D CPU 3.40GHz Core Stepping C1 Technology 65 nm Manufacturer (ID) Micron Technology (2C00000000000000) Manufacturer (ID) Micron Technology (2C00000000000000) Stock frequency 3400 MHz Core Speed 3391.5 MHz FID range 14.0x - 17.0x Northbridge Intel i945P/PL/G/GZ rev. A2 Southbridge Intel 82801GB (ICH7/R) rev. A1 CAS# latency (CL) 4.0 RAS# to CAS# delay (tRCD) 4 RAS# Precharge (tRP) 4 Cycle Time (tRAS) 12 Memory Frequency 266.0 MHz (3:4) Memory Type DDR2 Memory Size 3072 MBytes Channels Dual Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 2 x 2048 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, EM64T Package (platform ID) Socket 775 LGA (0x2)
Thanks! But most of the credit goes rightfully to graysky. Don't be depressed. I am still using a Pentium EE 840, which used to be EXTREMELY expensive but as you can see, it's still slower than your Pentium D 945!
Results for x264.exe r1342 -------------------------- encoded 1442 frames, 97.56 fps, 3899.02 kb/s encoded 1442 frames, 96.91 fps, 3899.02 kb/s encoded 1442 frames, 95.75 fps, 3898.50 kb/s encoded 1442 frames, 99.38 fps, 3899.02 kb/s encoded 1442 frames, 38.88 fps, 3957.16 kb/s encoded 1442 frames, 38.79 fps, 3961.77 kb/s encoded 1442 frames, 38.53 fps, 3960.73 kb/s encoded 1442 frames, 38.74 fps, 3971.21 kb/s System Details -------------- Name Intel Core i7 product System Product Name Codename Bloomfield Specification Intel(R) Core(TM) i7 CPU 930 @ 2.80GHz Specification PC3-12800 Specification PC3-12800 Specification PC3-12800 Specification PC3-12800 Specification PC3-12800 Specification PC3-12800 Core Stepping D0 Technology 45 nm Stock frequency 2800 MHz Core Speed 4200.1 MHz Northbridge Intel X58 rev. 13 Southbridge Intel 82801JR (ICH10R) rev. 00 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Command Rate (CR) 2T Command Rate 2T Command Rate 2T Command Rate 2T Command Rate 2T Command Rate 2T Command Rate 2T Memory Frequency 800.0 MHz (2:8) Memory Type DDR3 Memory Size 12288 MBytes Channels Triple Windows Version Microsoft Windows 7 (6.1) (Build 7600) Number of processors 1 Number of threads 8 Number of threads 8 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T Package (platform ID) Socket 1366 LGA (0x1) Temperature 0 38°C (100°F) [0x26] (SYSTIN) Temperature 1 58°C (135°F) [0x73] (CPUTIN) Temperature 2 36°C (95°F) [0x47] (AUXTIN) Temperature 0 73°C (163°F) [0x1B] (Core #0) Temperature 1 70°C (157°F) [0x1E] (Core #1) Temperature 2 63°C (145°F) [0x25] (Core #2) Temperature 3 65°C (148°F) [0x23] (Core #3)
^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r1342 -------------------------- encoded 1442 frames, 71.43 fps, 3901.21 kb/s encoded 1442 frames, 71.55 fps, 3900.68 kb/s encoded 1442 frames, 71.77 fps, 3900.68 kb/s encoded 1442 frames, 71.05 fps, 3900.68 kb/s encoded 1442 frames, 22.63 fps, 3970.51 kb/s encoded 1442 frames, 22.72 fps, 3971.11 kb/s encoded 1442 frames, 22.74 fps, 3972.08 kb/s encoded 1442 frames, 22.73 fps, 3970.89 kb/s System Details -------------- Name Intel Core 2 Quad Q6600 Codename Kentsfield Specification Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz Core Stepping G0 Technology 65 nm Stock frequency 2400 MHz Core Speed 3600.2 MHz FID range 6.0x - 9.0x Northbridge Intel P45/P43/G45/G43 rev. A2 Southbridge Intel 82801JR (ICH10R) rev. 00 CAS# latency (CL) 6.0 RAS# to CAS# delay (tRCD) 6 RAS# Precharge (tRP) 6 Cycle Time (tRAS) 20 Command Rate (CR) 2T Memory Frequency 500.0 MHz (4:5) Memory Type DDR2 Memory Size 6144 MBytes Channels Dual, (Symmetric) Windows Version Microsoft Windows 7 (6.1) (Build 7600) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 2 x 4096 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T, VT-x Package (platform ID) Socket 775 LGA (0x4) Temperature 0 23°C (73°F) [0x17] (SYSTIN) Temperature 1 65°C (148°F) [0x82] (CPUTIN) Temperature 2 51°C (123°F) [0x66] (AUXTIN) Temperature 0 61°C (141°F) [0x27] (Core #0) Temperature 1 57°C (134°F) [0x2B] (Core #1) Temperature 2 55°C (130°F) [0x2D] (Core #2) Temperature 3 54°C (129°F) [0x2E] (Core #3)
Thanks for the results, guys!! Keep 'em coming!!! I can't believe it but we have over 220 results in the database! Thanks to all of you!
[Intel Core i5 P6000 @ 1.87GHz] New LAPTOP [Toshiba Satelitte C650 PSC14E] Results for x264.exe r1342 -------------------------- encoded 1442 frames, 29.37 fps, 3899.26 kb/s encoded 1442 frames, 29.33 fps, 3899.26 kb/s encoded 1442 frames, 29.25 fps, 3899.26 kb/s encoded 1442 frames, 29.41 fps, 3899.26 kb/s encoded 1442 frames, 6.60 fps, 3970.58 kb/s encoded 1442 frames, 6.50 fps, 3970.88 kb/s encoded 1442 frames, 6.63 fps, 3971.62 kb/s encoded 1442 frames, 6.62 fps, 3970.94 kb/s System Details -------------- Name Intel Core i5 Codename Specification Intel(R) Pentium(R) CPU P6000 @ 1.87GHz Core Stepping Technology 32 nm Stock frequency 1866 MHz Core Speed 1862.0 MHz Northbridge Intel ID0044 rev. 02 Southbridge Intel HM55 rev. 05 Memory Type Memory Size 2048 MBytes Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600) Number of processors 1 Number of threads 2 Number of threads 2 (max 16) L2 cache 2 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T Package (platform ID) Socket 1156 LGA (0x4) Temperature 0 60°C (139°F) [0x1E] (Core #0) Temperature 2 64°C (147°F) [0x1A] (Core #2)
Better than I expected actually considering this is a fairly low end laptop nowadays. HP Pavilion DV7 3067CL is the model btw. x264 HD BENCHMARK 3.0 RESULTS Please do not compare it with older versions of the benchmark! Please copy/paste everything below the line to to report your data ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r1342 -------------------------- encoded 1442 frames, 31.93 fps, 3899.26 kb/s encoded 1442 frames, 32.07 fps, 3899.26 kb/s encoded 1442 frames, 31.97 fps, 3899.26 kb/s encoded 1442 frames, 31.94 fps, 3899.26 kb/s encoded 1442 frames, 7.74 fps, 3970.95 kb/s encoded 1442 frames, 7.78 fps, 3970.54 kb/s encoded 1442 frames, 7.81 fps, 3971.09 kb/s encoded 1442 frames, 7.82 fps, 3971.25 kb/s System Details -------------- Name AMD K10 Codename Specification AMD Turion(tm) II Ultra Dual-Core Mobile M600 Core Stepping BL-C2 Technology 45 nm Stock frequency 2400 MHz Core Speed 2394.3 MHz FID range 5.0x - 12.0x Northbridge AMD 785GX rev. 00 Southbridge ATI SB750 rev. 00 CAS# latency (CL) 6.0 RAS# to CAS# delay (tRCD) 6 RAS# Precharge (tRP) 6 Cycle Time (tRAS) 18 Command Rate (CR) 2T Memory Frequency 399.0 MHz (1:2) Memory Type DDR2 Memory Size 4096 MBytes Channels Dual, (Unganged) Windows Version Microsoft Windows 7 (6.1) Home Premium Edition (Build 7600) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 2 x 1024 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64 Package Socket S1 (638) Package Type 0x2 Temperature 0 70°C (157°F) [0x230] (Core #0) Temperature 1 70°C (157°F) [0x22E] (Core #1)
round 2 Here is my second result with CPU at 3780Ghz and memory at 1520Mhz: Results for x264.exe r1342 -------------------------- encoded 1442 frames, 84.35 fps, 3899.02 kb/s encoded 1442 frames, 87.30 fps, 3899.02 kb/s encoded 1442 frames, 87.05 fps, 3899.02 kb/s encoded 1442 frames, 87.99 fps, 3898.50 kb/s encoded 1442 frames, 34.54 fps, 3958.67 kb/s encoded 1442 frames, 35.37 fps, 3961.30 kb/s encoded 1442 frames, 35.29 fps, 3957.07 kb/s encoded 1442 frames, 35.22 fps, 3954.12 kb/s System Details -------------- Name Intel Core i7 860 Codename Lynnfield Specification Intel(R) Core(TM) i7 CPU 860 @ 2.80GHz Specification PC3-12800 Specification PC3-12800 Specification PC3-12800 Specification PC3-12800 Core Stepping B1 Technology 45 nm manufacturer Gigabyte Technology Co., Ltd. vendor Gigabyte Technology Co., Ltd. manufacturer Gigabyte Technology Co., Ltd. Stock frequency 2800 MHz Core Speed 3780.9 MHz Northbridge Intel DMI Host Bridge rev. 11 Southbridge Intel P55 rev. 06 CAS# latency (CL) 7.0 RAS# to CAS# delay (tRCD) 8 RAS# Precharge (tRP) 7 Cycle Time (tRAS) 24 Command Rate (CR) 2T Command Rate 2T Command Rate 2T Command Rate 2T Command Rate 2T Memory Frequency 796.0 MHz (2:8) Memory Type DDR3 Memory Size 8192 MBytes Channels Dual Windows Version Microsoft Windows 7 (6.1) (Build 7600) Number of processors 1 Number of threads 8 Number of threads 8 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T Package (platform ID) Socket 1156 LGA (0x1) Temperature 0 37°C (98°F) [0x25] (TMPIN0) Temperature 1 25°C (76°F) [0x19] (TMPIN1) Temperature 2 48°C (118°F) [0x30] (TMPIN2) Temperature 0 50°C (121°F) [0x31] (Core #0) Temperature 1 56°C (132°F) [0x2B] (Core #1) Temperature 2 54°C (129°F) [0x2D] (Core #2) Temperature 3 49°C (120°F) [0x32] (Core #3)
