^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r1342 -------------------------- encoded 1442 frames, 64.26 fps, 3901.21 kb/s encoded 1442 frames, 66.27 fps, 3901.21 kb/s encoded 1442 frames, 66.98 fps, 3901.21 kb/s encoded 1442 frames, 65.87 fps, 3900.68 kb/s encoded 1442 frames, 21.40 fps, 3971.59 kb/s encoded 1442 frames, 21.54 fps, 3971.78 kb/s encoded 1442 frames, 21.42 fps, 3971.21 kb/s encoded 1442 frames, 21.30 fps, 3971.75 kb/s System Details -------------- Name AMD Phenom II X4 Codename Deneb Specification AMD Phenom(tm) II X4 20 Processor Core Stepping RB-C2 Technology 45 nm manufacturer Gigabyte Technology Co., Ltd. vendor Gigabyte Technology Co., Ltd. manufacturer Gigabyte Technology Co., Ltd. Core Speed 3399.0 MHz Northbridge AMD 790X rev. 00 Southbridge AMD SB700 rev. 00 CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 15 Command Rate (CR) 2T Memory Frequency 343.3 MHz (3:5) Memory Type DDR2 Memory Size 4096 MBytes Channels Dual, (Unganged) Windows Version Microsoft Windows 7 (6.1) Home Premium Edition (Build 7600) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V Package Socket AM3 (938) Package Type 0x1 Temperature 0 34°C (93°F) [0x22] (TMPIN0) => DD temp Temperature 1 44°C (111°F) [0x2C] (TMPIN1) => Cpu temp Temperature 2 39°C (102°F) [0x27] (TMPIN2) => Mb temp Temperature 0 0°C (32°F) [0x0] (Core #0) Temperature 1 0°C (32°F) [0x0] (Core #1) Temperature 2 0°C (32°F) [0x0] (Core #2) Temperature 3 0°C (32°F) [0x0] (Core #3)
x264 HD BENCHMARK 3.0 RESULTS ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r1342 -------------------------- encoded 1442 frames, 70.55 fps, 3900.68 kb/s encoded 1442 frames, 71.07 fps, 3900.68 kb/s encoded 1442 frames, 71.28 fps, 3900.68 kb/s encoded 1442 frames, 71.07 fps, 3900.68 kb/s encoded 1442 frames, 22.33 fps, 3971.28 kb/s encoded 1442 frames, 22.57 fps, 3971.61 kb/s encoded 1442 frames, 22.43 fps, 3971.48 kb/s encoded 1442 frames, 22.36 fps, 3971.35 kb/s System Details -------------- Name AMD Phenom II X4 Codename Deneb Specification AMD Phenom(tm) II X4 20 Processor Core Stepping RB-C2 Technology 45 nm manufacturer Gigabyte Technology Co., Ltd. vendor Gigabyte Technology Co., Ltd. manufacturer Gigabyte Technology Co., Ltd. Core Speed 3514.5 MHz Northbridge AMD 790X rev. 00 Southbridge AMD SB700 rev. 00 CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 6 RAS# Precharge (tRP) 6 Cycle Time (tRAS) 18 Command Rate (CR) 2T Memory Frequency 426.0 MHz (1:2) Memory Type DDR2 Memory Size 4096 MBytes Channels Dual, (Unganged) Windows Version Microsoft Windows 7 (6.1) Home Premium Edition (Build 7600) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V Package Socket AM3 (938) Package Type 0x1 Temperature 0 32°C (89°F) [0x20] (TMPIN0) => DD temp Temperature 1 44°C (111°F) [0x2C] (TMPIN1) => Cpu temp Temperature 2 38°C (100°F) [0x26] (TMPIN2) => Mb temp Temperature 0 0°C (32°F) [0x0] (Core #0) Temperature 1 0°C (32°F) [0x0] (Core #1) Temperature 2 0°C (32°F) [0x0] (Core #2) Temperature 3 0°C (32°F) [0x0] (Core #3)
x264 HD BENCHMARK 3.0 RESULTS Please do not compare it with older versions of the benchmark! Please copy/paste everything below the line to to report your data ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r1342 -------------------------- encoded 1442 frames, 65.52 fps, 3899.90 kb/s encoded 1442 frames, 65.01 fps, 3899.90 kb/s encoded 1442 frames, 65.97 fps, 3899.90 kb/s encoded 1442 frames, 65.01 fps, 3899.90 kb/s encoded 1442 frames, 14.84 fps, 3971.45 kb/s encoded 1442 frames, 14.80 fps, 3971.68 kb/s encoded 1442 frames, 14.87 fps, 3971.04 kb/s encoded 1442 frames, 14.82 fps, 3970.99 kb/s System Details -------------- Name AMD Phenom II X3 720 product System Product Name Codename Heka Specification AMD Phenom(tm) II X3 720 Processor Core Stepping RB-C2 Technology 45 nm Manufacturer (ID) A-Data Technology (7F7F7F7FCB000000) Manufacturer (ID) A-Data Technology (7F7F7F7FCB000000) Core Speed 3541.3 MHz Northbridge AMD 890GX rev. 00 Southbridge AMD SB850 rev. 40 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Command Rate (CR) 1T Memory Frequency 674.5 MHz (3:10) Memory Type DDR3 Memory Size 4096 MBytes Channels Dual, (Unganged) Windows Version Microsoft Windows 7 (6.1) Home Premium Edition (Build 7600) Number of processors 1 Number of threads 3 Number of threads 3 (max 3) L2 cache 3 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V Package Socket AM3 (938) Package Type 0x1 Temperature 0 38°C (100°F) [0x26] (CPU) Temperature 1 27°C (80°F) [0x1B] (Mainboard) Temperature 0 30°C (86°F) [0xF3] (Core #0) Temperature 1 30°C (86°F) [0xF3] (Core #1) Temperature 2 30°C (86°F) [0xF3] (Core #2)
x264 HD BENCHMARK 3.0 RESULTS Please do not compare it with older versions of the benchmark! Please copy/paste everything below the line to to report your data ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r1342 -------------------------- encoded 1442 frames, 71.42 fps, 3901.21 kb/s encoded 1442 frames, 73.38 fps, 3900.68 kb/s encoded 1442 frames, 73.84 fps, 3900.68 kb/s encoded 1442 frames, 73.84 fps, 3900.68 kb/s encoded 1442 frames, 22.09 fps, 3966.70 kb/s encoded 1442 frames, 22.22 fps, 3970.50 kb/s encoded 1442 frames, 22.17 fps, 3971.39 kb/s encoded 1442 frames, 22.03 fps, 3971.47 kb/s System Details -------------- Name AMD Phenom II X4 product System Product Name Codename Deneb Specification AMD Phenom(tm) II X4 20 Processor Core Stepping RB-C2 Technology 45 nm Manufacturer (ID) A-Data Technology (7F7F7F7FCB000000) Manufacturer (ID) A-Data Technology (7F7F7F7FCB000000) Core Speed 3411.5 MHz Northbridge AMD 890GX rev. 00 Southbridge AMD SB850 rev. 40 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Command Rate (CR) 1T Memory Frequency 802.7 MHz (1:4) Memory Type DDR3 Memory Size 4096 MBytes Channels Dual, (Unganged) Windows Version Microsoft Windows 7 (6.1) Home Premium Edition (Build 7600) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V Package Socket AM3 (938) Package Type 0x1 Temperature 0 41°C (105°F) [0x29] (CPU) Temperature 1 28°C (82°F) [0x1C] (Mainboard) Temperature 0 0°C (32°F) [0x0] (Core #0) Temperature 1 0°C (32°F) [0x0] (Core #1) Temperature 2 0°C (32°F) [0x0] (Core #2) Temperature 3 0°C (32°F) [0x0] (Core #3)
A little more overclock System Details -------------- Name AMD Phenom II X4 product System Product Name Codename Deneb Specification AMD Phenom(tm) II X4 20 Processor Core Stepping RB-C2 Technology 45 nm Manufacturer (ID) A-Data Technology (7F7F7F7FCB000000) Manufacturer (ID) A-Data Technology (7F7F7F7FCB000000) Core Speed 3541.4 MHz Northbridge AMD 890GX rev. 00 Southbridge AMD SB850 rev. 40 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Command Rate (CR) 1T Memory Frequency 809.5 MHz (1:4) Memory Type DDR3 Memory Size 4096 MBytes Channels Dual, (Unganged) Windows Version Microsoft Windows 7 (6.1) Home Premium Edition (Build 7600) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V Package Socket AM3 (938) Package Type 0x1 Temperature 0 44°C (111°F) [0x2C] (CPU) Temperature 1 32°C (89°F) [0x20] (Mainboard) Temperature 0 0°C (32°F) [0x0] (Core #0) Temperature 1 0°C (32°F) [0x0] (Core #1) Temperature 2 0°C (32°F) [0x0] (Core #2) Temperature 3 0°C (32°F) [0x0] (Core #3)
Oops missed this part x264 HD BENCHMARK 3.0 RESULTS Please do not compare it with older versions of the benchmark! Please copy/paste everything below the line to to report your data ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r1342 -------------------------- encoded 1442 frames, 74.37 fps, 3900.68 kb/s encoded 1442 frames, 74.79 fps, 3900.68 kb/s encoded 1442 frames, 75.26 fps, 3900.68 kb/s encoded 1442 frames, 73.68 fps, 3900.68 kb/s encoded 1442 frames, 22.73 fps, 3966.44 kb/s encoded 1442 frames, 22.72 fps, 3971.73 kb/s encoded 1442 frames, 22.78 fps, 3971.88 kb/s encoded 1442 frames, 22.67 fps, 3970.80 kb/s System Details -------------- Name AMD Phenom II X4 product System Product Name Codename Deneb Specification AMD Phenom(tm) II X4 20 Processor Core Stepping RB-C2 Technology 45 nm Manufacturer (ID) A-Data Technology (7F7F7F7FCB000000) Manufacturer (ID) A-Data Technology (7F7F7F7FCB000000) Core Speed 3541.4 MHz Northbridge AMD 890GX rev. 00 Southbridge AMD SB850 rev. 40
i7-950 X58A-UD3R 6GB Corsair Results for x264.exe r1342 -------------------------- encoded 1442 frames, 99.52 fps, 3899.02 kb/s encoded 1442 frames, 101.46 fps, 3899.02 kb/s encoded 1442 frames, 99.00 fps, 3899.02 kb/s encoded 1442 frames, 100.57 fps, 3899.02 kb/s encoded 1442 frames, 38.87 fps, 3970.56 kb/s encoded 1442 frames, 39.01 fps, 3960.65 kb/s encoded 1442 frames, 39.18 fps, 3958.21 kb/s encoded 1442 frames, 39.30 fps, 3965.52 kb/s System Details -------------- Name Intel Core i7 950 Codename Bloomfield Specification Intel(R) Core(TM) i7 CPU 950 @ 3.07GHz Specification PC3-12800 Specification PC3-12800 Specification PC3-12800 Core Stepping D0 Technology 45 nm manufacturer Gigabyte Technology Co., Ltd. vendor Gigabyte Technology Co., Ltd. manufacturer Gigabyte Technology Co., Ltd. Stock frequency 3066 MHz Core Speed 4199.9 MHz Northbridge Intel X58 rev. 13 Southbridge Intel 82801JR (ICH10R) rev. 00 CAS# latency (CL) 8.0 RAS# to CAS# delay (tRCD) 8 RAS# Precharge (tRP) 8 Cycle Time (tRAS) 20 Command Rate (CR) 1T Command Rate 2T Command Rate 2T Command Rate 2T Memory Frequency 800.0 MHz (2:8) Memory Type DDR3 Memory Size 6144 MBytes Channels Triple Windows Version Microsoft Windows 7 (6.1) (Build 7600) Number of processors 1 Number of threads 8 Number of threads 8 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x Package (platform ID) Socket 1366 LGA (0x1) Temperature 0 35°C (94°F) [0x23] (TMPIN0) Temperature 1 47°C (116°F) [0x2F] (TMPIN1) Temperature 2 38°C (100°F) [0x26] (TMPIN2) Temperature 0 54°C (129°F) [0x2E] (Core #0) Temperature 1 58°C (136°F) [0x2A] (Core #1) Temperature 2 51°C (123°F) [0x31] (Core #2) Temperature 3 52°C (125°F) [0x30] (Core #3)
Thanks for the result, Salty! If you can, please retest at the stock clock speed, with TurboBoost disabled. Thansk!
^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r1342 -------------------------- encoded 1442 frames, 49.94 fps, 3900.68 kb/s encoded 1442 frames, 49.25 fps, 3900.68 kb/s encoded 1442 frames, 49.12 fps, 3900.68 kb/s encoded 1442 frames, 49.48 fps, 3900.68 kb/s encoded 1442 frames, 15.26 fps, 3971.28 kb/s encoded 1442 frames, 15.40 fps, 3971.47 kb/s encoded 1442 frames, 15.26 fps, 3971.97 kb/s encoded 1442 frames, 15.38 fps, 3971.58 kb/s System Details -------------- Name AMD Phenom X4 9850 Codename Agena Specification AMD Phenom(tm) 9850 Quad-Core Processor Core Stepping DR-B3 Technology 65 nm Stock frequency 2500 MHz Core Speed 2499.9 MHz FID range 6.3x - 12.5x Northbridge NVIDIA nForce 720a rev. A2 Southbridge NVIDIA ID075C rev. A2 CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 15 Command Rate (CR) 1T Memory Frequency 333.3 MHz (3:5) Memory Type DDR2 Memory Size 4096 MBytes Channels Dual, (Unganged) Windows Version Microsoft Windows 7 (6.1) Home Premium Edition (Build 7600) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V Package Socket AM2+ (940) Package Type 0x1 Temperature 0 62°C (143°F) [0x3E] (TMPIN0) Temperature 2 15°C (58°F) [0xF] (TMPIN2) Temperature 0 62°C (143°F) [0xD18] (THRM) Temperature 0 46°C (113°F) [0x16C] (Core #0) Temperature 3 48°C (117°F) [0x17C] (Core #3) Temperature 1 48°C (117°F) [0x17C] (Core #1) Temperature 2 48°C (117°F) [0x17C] (Core #2)
Results for x264.exe r1342 -------------------------- encoded 1442 frames, 44.27 fps, 3899.26 kb/s encoded 1442 frames, 45.75 fps, 3899.26 kb/s encoded 1442 frames, 44.11 fps, 3899.26 kb/s encoded 1442 frames, 43.33 fps, 3899.26 kb/s encoded 1442 frames, 11.30 fps, 3971.08 kb/s encoded 1442 frames, 11.25 fps, 3971.24 kb/s encoded 1442 frames, 11.28 fps, 3971.07 kb/s encoded 1442 frames, 11.33 fps, 3972.08 kb/s System Details -------------- Name Intel Core 2 Duo E8400 Codename Wolfdale Specification Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz Core Stepping E0 Technology 45 nm Stock frequency 3000 MHz Core Speed 3608.9 MHz FID range 6.0x - 9.0x Northbridge Intel P45/P43 rev. A3 Southbridge Intel 82801JR (ICH10R) rev. 00 CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 18 Command Rate (CR) 2T Memory Frequency 401.0 MHz (1:1) Memory Type DDR2 Memory Size 4096 MBytes Channels Dual, (Symmetric) Windows Version Microsoft Windows 7 (6.1) (Build 7600) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 6144 KBytes, 24-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T, VT-x Package (platform ID) Socket 775 LGA (0x0) Temperature 0 44°C (111°F) [0x2C] (TMPIN0) Temperature 1 47°C (116°F) [0x2F] (TMPIN1) Temperature 0 54°C (129°F) [0x2E] (Core #0) Temperature 1 53°C (127°F) [0x2F] (Core #1)
Hi Adrian, Here are my results:- Results for x264.exe r1342 -------------------------- encoded 1442 frames, 75.58 fps, 3900.68 kb/s encoded 1442 frames, 75.03 fps, 3901.21 kb/s encoded 1442 frames, 76.08 fps, 3900.68 kb/s encoded 1442 frames, 75.70 fps, 3901.21 kb/s encoded 1442 frames, 23.40 fps, 3971.78 kb/s encoded 1442 frames, 23.08 fps, 3971.87 kb/s encoded 1442 frames, 23.33 fps, 3971.40 kb/s encoded 1442 frames, 23.38 fps, 3971.89 kb/s System Details -------------- Name AMD Phenom II X4 955 product System Product Name Codename Deneb Specification AMD Phenom(tm) II X4 955 Processor Core Stepping RB-C2 Technology 45 nm Core Speed 3616.4 MHz Northbridge NVIDIA nForce 780a SLI SPP rev. A2 Southbridge NVIDIA nForce 780a SLI MCP rev. A2 CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 15 Command Rate (CR) 2T Memory Frequency 535.8 MHz (3:8) Memory Type DDR2 Memory Size 4096 MBytes Channels Dual, (Unganged) Windows Version Microsoft Windows 7 (6.1) Home Premium Edition (Build 7600) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V Package Socket AM3 (938) Package Type 0x1 Temperature 0 54°C (129°F) [0x36] (TMPIN0) Temperature 1 45°C (112°F) [0x2D] (TMPIN1) Temperature 0 40°C (103°F) [0xC3C] (THRM) Temperature 0 56°C (132°F) [0x1C0] (Core #0) Temperature 3 56°C (132°F) [0x1C0] (Core #3) Temperature 2 56°C (132°F) [0x1C0] (Core #2) Temperature 1 56°C (132°F) [0x1C0] (Core #1) I am running a Phenom 955 @ 3.6 (18 x 200) at 1.35V (standard volts), my ASUS board runs the 200MHz clock at 200.9MHz at default.
Encoded at the speed of Snail If this hasn't convinced me of a timely xmas upgrade, not much will... and sorry for the untidy details, for some reason the webpage won't display them neatly, no matter what I do. x264 HD BENCHMARK 3.0 RESULTS Please do not compare it with older versions of the benchmark! Please copy/paste everything below the line to to report your data ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r1342 -------------------------- encoded 1442 frames, 6.72 fps, 3896.61 kb/s encoded 1442 frames, 6.74 fps, 3896.61 kb/s encoded 1442 frames, 6.74 fps, 3896.61 kb/s encoded 1442 frames, 6.73 fps, 3896.61 kb/s encoded 1442 frames, 1.84 fps, 3971.28 kb/s encoded 1442 frames, 1.84 fps, 3971.28 kb/s encoded 1442 frames, 1.84 fps, 3971.28 kb/s encoded 1442 frames, 1.82 fps, 3971.28 kb/s System Details -------------- Name AMD Athlon XP Codename Thoroughbred Specification AMD Athlon(TM) XP 2600+ Core Stepping B0 Technology 0.13 um Core Speed 1733.6 MHz Northbridge VIA KT400 (VT8377) rev. 00 Southbridge VIA VT8235 rev. 00 CAS# latency (CL) 3.0 RAS# to CAS# delay (tRCD) 3 RAS# Precharge (tRP) 3 Cycle Time (tRAS) 7 Memory Frequency 200.0 MHz (FSB + 66 MHz) Memory Type DDR Memory Size 1536 MBytes Windows Version Microsoft Windows XP Home Edition Service Pack 3 (Build 2600) Number of processors 1 Number of threads 1 Number of threads 1 (max 1) L2 cache 256 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE Package Socket A (462) Temperature 0 43°C (109°F) [0x2B] (TMPIN0) Temperature 1 27°C (80°F) [0x1B] (TMPIN1)
~25% increase w mild o'clock the step from 13x333MHz to 11x175MHz yielded better than expected boost... x264 HD BENCHMARK 3.0 RESULTS Please do not compare it with older versions of the benchmark! Please copy/paste everything below the line to to report your data ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r1342 -------------------------- encoded 1442 frames, 8.82 fps, 3896.61 kb/s encoded 1442 frames, 8.81 fps, 3896.61 kb/s encoded 1442 frames, 8.80 fps, 3896.61 kb/s encoded 1442 frames, 8.86 fps, 3896.61 kb/s encoded 1442 frames, 2.27 fps, 3971.28 kb/s encoded 1442 frames, 2.28 fps, 3971.28 kb/s encoded 1442 frames, 2.29 fps, 3971.28 kb/s encoded 1442 frames, 2.29 fps, 3971.28 kb/s System Details -------------- Name AMD Athlon XP product System Name Codename Thoroughbred Specification AMD Athlon(TM) XP 2600+ Core Stepping B0 Technology 0.13 um Core Speed 2100.1 MHz Northbridge VIA KT400 (VT8377) rev. 00 Southbridge VIA VT8235 rev. 00 CAS# latency (CL) 2.5 RAS# to CAS# delay (tRCD) 3 RAS# Precharge (tRP) 3 Cycle Time (tRAS) 7 Memory Frequency 175.0 MHz (1:1) Memory Type DDR Memory Size 1536 MBytes Windows Version Microsoft Windows XP Home Edition Service Pack 3 (Build 2600) Number of processors 1 Number of threads 1 Number of threads 1 (max 1) L2 cache 256 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE Package Socket A (462) Temperature 0 57°C (134°F) [0x39] (TMPIN0) Temperature 1 30°C (85°F) [0x1E] (TMPIN1)
