Results for x264.exe r1342 -------------------------- encoded 1442 frames, 36.78 fps, 3899.26 kb/s encoded 1442 frames, 35.75 fps, 3899.26 kb/s encoded 1442 frames, 37.23 fps, 3899.26 kb/s encoded 1442 frames, 35.05 fps, 3899.26 kb/s encoded 1442 frames, 9.30 fps, 3971.31 kb/s encoded 1442 frames, 9.17 fps, 3971.50 kb/s encoded 1442 frames, 9.13 fps, 3971.21 kb/s encoded 1442 frames, 9.20 fps, 3970.86 kb/s System Details -------------- Name Intel Pentium E2180 Codename Conroe Specification Intel(R) Pentium(R) Dual CPU E2180 @ 2.00GHz Core Stepping M0 Technology 65 nm manufacturer Gigabyte Technology Co., Ltd. vendor Gigabyte Technology Co., Ltd. manufacturer Gigabyte Technology Co., Ltd. Stock frequency 2000 MHz Core Speed 3199.9 MHz FID range 6.0x - 10.0x Northbridge Intel P35/G33/G31 rev. A2 Southbridge Intel 82801GB (ICH7/R) rev. A1 CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 15 Command Rate (CR) 2T Memory Frequency 400.0 MHz (4:5) Memory Type DDR2 Memory Size 4096 MBytes Channels Dual, (Symmetric) Windows Version Microsoft Windows 7 (6.1) Enterprise Edition Service Pack 1 (Build 7601) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 1024 KBytes, 4-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T Package (platform ID) Socket 775 LGA (0x0) Temperature 2 45°C (112°F) [0x2D] (TMPIN2) Temperature 0 47°C (116°F) [0x26] (Core #0) Temperature 1 51°C (123°F) [0x22] (Core #1)
I have a Phenom II X4 965 Black Edition (stock) but my results are lower than the 955 on the list. Is it a memory limitation or..?
incorrect test results? Adrian: Thanks for test, it really helps me to fine tune my machine for x264 video encoding. I just looked at the result and I think there is an error in the test report. A couple of records reporting tripple channel memory, but I don't think that is possible since the CPU on those record only support dual channel (i.e. the i7-2600k). X
Thanks for the results, brainstormer2010! @chidragon : It is possible. If you check the specs in the table below the charts, you will see that that AMD Phenom II X4 955 system was using DDR3-1333 memory.
Oops!! Sorry, my mistake. I probably got too used to typing triple channel for Core i7s! And thanks for the heads-up!! +rep!
My 4Ghz Thuban and I think it shows a decent result to be an AMD rig or am I wrong x264 HD BENCHMARK 3.0 RESULTS Please do not compare it with older versions of the benchmark! Please copy/paste everything below the line to to report your data ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r1342 -------------------------- encoded 1442 frames, 89.76 fps, 3898.70 kb/s encoded 1442 frames, 89.67 fps, 3898.70 kb/s encoded 1442 frames, 89.70 fps, 3898.70 kb/s encoded 1442 frames, 89.14 fps, 3898.70 kb/s encoded 1442 frames, 37.64 fps, 3957.41 kb/s encoded 1442 frames, 37.60 fps, 3957.42 kb/s encoded 1442 frames, 37.59 fps, 3969.43 kb/s encoded 1442 frames, 37.56 fps, 3972.01 kb/s System Details -------------- Name AMD Phenom II X6 1055T product System Product Name Codename Thuban Specification AMD Phenom(tm) II X6 1055T Processor Specification PC3-12800 Specification PC3-12800 Core Stepping PH-E0 Technology 45 nm Stock frequency 2800 MHz Core Speed 4019.8 MHz FID range 4.0x - 16.5x Northbridge AMD 890FX rev. 02 Southbridge AMD SB850 rev. 40 CAS# latency (CL) 7.0 RAS# to CAS# delay (tRCD) 8 RAS# Precharge (tRP) 7 Cycle Time (tRAS) 20 Command Rate (CR) 1T Command Rate 2T Command Rate 2T Memory Frequency 765.7 MHz (3:8) Memory Type DDR3 Memory Size 4096 MBytes Channels Dual, (Unganged) Windows Version Microsoft Windows 7 (6.1) Ultimate Edition (Build 7600) Number of processors 1 Number of threads 6 Number of threads 6 (max 6) L2 cache 6 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V Package Socket AM3 (938) Package Type 0x1 Temperature 0 45°C (112°F) [0x2D] (CPU) Temperature 1 31°C (87°F) [0x1F] (Mainboard) Temperature 0 33°C (91°F) [0x107] (Core #0) Temperature 1 33°C (91°F) [0x108] (Core #1) Temperature 2 33°C (91°F) [0x108] (Core #2) Temperature 3 33°C (91°F) [0x108] (Core #3) Temperature 4 33°C (90°F) [0x106] (Core #4) Temperature 5 33°C (90°F) [0x104] (Core #5)
i did little changes to my pc - changed celeron dual core to c2d e6300, switched from srv03 to win7x64 and i changed my 2x1gb mem to 2x2, and i still don't know why cpu temp is so high -_- Results for x264.exe r1342 -------------------------- encoded 1442 frames, 23.59 fps, 3899.26 kb/s encoded 1442 frames, 23.49 fps, 3899.26 kb/s encoded 1442 frames, 23.78 fps, 3899.26 kb/s encoded 1442 frames, 21.84 fps, 3899.26 kb/s encoded 1442 frames, 5.88 fps, 3970.84 kb/s encoded 1442 frames, 5.88 fps, 3971.27 kb/s encoded 1442 frames, 5.87 fps, 3971.79 kb/s encoded 1442 frames, 5.88 fps, 3971.23 kb/s System Details -------------- Name Intel Core 2 Duo E6300 Codename Conroe Specification Intel(R) Core(TM)2 CPU 6300 @ 1.86GHz Core Stepping B2 Technology 65 nm manufacturer Gigabyte Technology Co., Ltd. vendor Gigabyte Technology Co., Ltd. manufacturer Gigabyte Technology Co., Ltd. Stock frequency 1866 MHz Core Speed 1866.6 MHz FID range 6.0x - 7.0x Northbridge Intel P35/G33/G31 rev. 10 Southbridge Intel 82801GB (ICH7/R) rev. A1 CAS# latency (CL) 6.0 RAS# to CAS# delay (tRCD) 6 RAS# Precharge (tRP) 6 Cycle Time (tRAS) 18 Command Rate (CR) 2T Memory Frequency 400.0 MHz (2:3) Memory Type DDR2 Memory Size 4096 MBytes Channels Dual, (Symmetric) Windows Version Microsoft Windows 7 (6.1) Enterprise Edition (Build 7600) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 2048 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T, VT-x Package (platform ID) Socket 775 LGA (0x0) Temperature 0 68°C (154°F) [0x11] (Core #0) Temperature 1 62°C (143°F) [0x17] (Core #1)
Results for x264.exe r1342 -------------------------- encoded 1442 frames, 94.43 fps, 3901.99 kb/s encoded 1442 frames, 94.69 fps, 3901.99 kb/s encoded 1442 frames, 94.41 fps, 3901.99 kb/s encoded 1442 frames, 94.96 fps, 3901.99 kb/s encoded 1442 frames, 49.77 fps, 3916.27 kb/s encoded 1442 frames, 49.32 fps, 3940.95 kb/s encoded 1442 frames, 49.72 fps, 3934.51 kb/s encoded 1442 frames, 49.54 fps, 3942.34 kb/s System Details -------------- Name Intel Core i7 Extreme 980X Codename Gulftown Specification Intel(R) Core(TM) i7 CPU X 980 @ 3.33GHz Specification PC3-12800 Specification PC3-12800 Specification PC3-12800 Core Stepping B1 Technology 32 nm manufacturer Gigabyte Technology Co., Ltd. vendor Gigabyte Technology Co., Ltd. manufacturer Gigabyte Technology Co., Ltd. Stock frequency 3333 MHz Core Speed 3730.8 MHz Northbridge Intel X58 rev. 12 Southbridge Intel 82801JR (ICH10R) rev. 00 CAS# latency (CL) 7.0 RAS# to CAS# delay (tRCD) 7 RAS# Precharge (tRP) 7 Cycle Time (tRAS) 20 Command Rate (CR) 1T Command Rate 2T Command Rate 2T Command Rate 2T Memory Frequency 533.0 MHz (2:8) Memory Type DDR3 Memory Size 6144 MBytes Channels Triple Windows Version Microsoft Windows 7 (6.1) (Build 7600) Number of processors 1 Number of threads 12 Number of threads 12 (max 32) L2 cache 6 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES Package (platform ID) Socket 1366 LGA (0x1) Temperature 0 38°C (100°F) [0x26] (PCH) Temperature 1 47°C (116°F) [0x2F] (CPU) Temperature 0 48°C (118°F) [0x35] (Core #0) Temperature 1 51°C (123°F) [0x32] (Core #1) Temperature 2 46°C (114°F) [0x37] (Core #2) Temperature 8 46°C (114°F) [0x37] (Core #8) Temperature 9 43°C (109°F) [0x3A] (Core #9) Temperature 10 51°C (123°F) [0x32] (Core #10)
Thanks for the results, ekotan! Think you can retest at stock speed, with Turbo Boost disabled? Thanks!
my x2 555 unlocked x3 & overlocked 3.8 Results for x264.exe r1342 -------------------------- encoded 1442 frames, 69.76 fps, 3899.90 kb/s encoded 1442 frames, 70.08 fps, 3899.90 kb/s encoded 1442 frames, 69.29 fps, 3899.90 kb/s encoded 1442 frames, 68.52 fps, 3899.90 kb/s encoded 1442 frames, 15.96 fps, 3971.05 kb/s encoded 1442 frames, 16.12 fps, 3971.81 kb/s encoded 1442 frames, 16.04 fps, 3971.61 kb/s encoded 1442 frames, 16.13 fps, 3971.19 kb/s System Details -------------- Name AMD Phenom II X4 product System Product Name Codename Deneb Specification AMD Phenom(tm) II X4 B55 Processor Specification PC3-12800 Specification PC3-12800 Specification PC3-12800 Specification PC3-12800 Core Stepping RB-C3 Technology 45 nm Core Speed 3812.8 MHz Northbridge AMD 890FX rev. 02 Southbridge AMD SB850 rev. 40 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Command Rate (CR) 2T Command Rate 2T Command Rate 2T Command Rate 2T Command Rate 2T Memory Frequency 668.9 MHz (3:10) Memory Type DDR3 Memory Size 8192 MBytes Channels Dual, (Unganged) Windows Version Microsoft Windows 7 (6.1) Home Premium Edition Service Pack 1 (Build 7601) Number of processors 1 Number of threads 3 Number of threads 3 (max 3) L2 cache 3 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V Package Socket AM3 (938) Package Type 0x1 Temperature 0 46°C (114°F) [0x2E] (CPU) Temperature 1 34°C (93°F) [0x22] (Mainboard) Temperature 0 0°C (32°F) [0x0] (Core #0) Temperature 1 0°C (32°F) [0x0] (Core #1) Temperature 2 0°C (32°F) [0x0] (Core #2) revision 1913 92 fps pass 1 17 fps pass 2
Results for x264.exe r1342 -------------------------- encoded 1442 frames, 63.44 fps, 3899.02 kb/s encoded 1442 frames, 63.71 fps, 3898.50 kb/s encoded 1442 frames, 62.69 fps, 3899.02 kb/s encoded 1442 frames, 50.98 fps, 3899.02 kb/s encoded 1442 frames, 25.40 fps, 3961.18 kb/s encoded 1442 frames, 25.33 fps, 3961.70 kb/s encoded 1442 frames, 25.15 fps, 3967.44 kb/s encoded 1442 frames, 25.28 fps, 3960.60 kb/s System Details -------------- Name Intel Core i7 920 product System Product Name Codename Bloomfield Specification Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz Core Stepping C0/C1 Technology 45 nm Stock frequency 2666 MHz Core Speed 2811.7 MHz Northbridge Intel X58 rev. 12 Southbridge Intel 82801JR (ICH10R) rev. 00 CAS# latency (CL) 8.0 RAS# to CAS# delay (tRCD) 8 RAS# Precharge (tRP) 8 Cycle Time (tRAS) 20 Command Rate (CR) 2T Memory Frequency 535.6 MHz (2:8) Memory Type DDR3 Memory Size 12288 MBytes Channels Triple Windows Version Microsoft Windows 7 (6.1) Ultimate Edition Service Pack 1 (Build 7601) Number of processors 1 Number of threads 8 Number of threads 8 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x Package (platform ID) Socket 1366 LGA (0x1) Temperature 0 38°C (100°F) [0x26] (SYSTIN) Temperature 1 68°C (153°F) [0x87] (CPUTIN) Temperature 2 3°C (36°F) [0x5] (AUXTIN) Temperature 0 70°C (157°F) [0x1E] (Core #0) Temperature 1 67°C (152°F) [0x21] (Core #1) Temperature 2 67°C (152°F) [0x21] (Core #2) Temperature 3 67°C (152°F) [0x21] (Core #3)
Thanks for the results, dictrix! BTW, you might want to give our latest x264 HD Benchmark 4.0 a try too -> Tech ARP - x264 HD Benchmark Ver. 4.0
My Result x264 HD BENCHMARK 3.0 RESULTS Please do not compare it with older versions of the benchmark! Please copy/paste everything below the line to to report your data ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r1342 -------------------------- encoded 1442 frames, 99.46 fps, 3899.02 kb/s encoded 1442 frames, 103.01 fps, 3899.02 kb/s encoded 1442 frames, 103.13 fps, 3899.02 kb/s encoded 1442 frames, 102.76 fps, 3899.02 kb/s encoded 1442 frames, 40.29 fps, 3966.60 kb/s encoded 1442 frames, 39.89 fps, 3960.79 kb/s encoded 1442 frames, 38.55 fps, 3957.75 kb/s encoded 1442 frames, 39.77 fps, 3961.99 kb/s System Details -------------- Name Intel Sandy Bridge product System Product Name Codename Specification Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz Core Stepping Technology 32 nm Stock frequency 3400 MHz Core Speed 4300.6 MHz Northbridge Intel ID0100 rev. 09 Southbridge Intel ID1C46 rev. 05 Memory Type Memory Size 8192 MBytes Windows Version Microsoft Windows 7 (6.1) Ultimate Edition Service Pack 1 (Build 7601) Number of processors 1 Number of threads 8 Number of threads 8 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX Package (platform ID) (0x1) Temperature 0 81°C (177°F) [0x11] (Core #0) Temperature 1 87°C (188°F) [0xB] (Core #1) Temperature 2 84°C (183°F) [0xE] (Core #2) Temperature 3 80°C (175°F) [0x12] (Core #3)
I'll also post a 4.0 benchmark to the correct thread but I just wanted to compare apples to apples with my previous results. I had to replace the motherboard, so I upgraded to 8GB DDR3 from 4GB DDR2. (I also replaced the stock CPU cooler with one that doesn't get ridiculously loud whenever I encode something, but that should only affect temps since I'm still not OCing) Rest of the system is identical. Pass 1 is about 5 fps faster while Pass 2 is only around .7 fps faster.
3570K@4,5GHz-2200MHZ RAm Results for x264.exe r1342 -------------------------- encoded 1442 frames, 136.05 fps, 3900.68 kb/s encoded 1442 frames, 134.99 fps, 3900.68 kb/s encoded 1442 frames, 136.54 fps, 3901.21 kb/s encoded 1442 frames, 137.05 fps, 3900.68 kb/s encoded 1442 frames, 40.25 fps, 3968.00 kb/s encoded 1442 frames, 40.52 fps, 3972.00 kb/s encoded 1442 frames, 40.51 fps, 3967.94 kb/s encoded 1442 frames, 40.43 fps, 3972.03 kb/s System Details -------------- Name Intel Processor product System Product Name Codename Specification Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz Core Stepping Core Speed 3398.8 MHz Northbridge Intel ID0150 rev. 09 Southbridge Intel ID1E44 rev. 04 Memory Type Memory Size 4044 MBytes Windows Version Microsoft Windows 7 (6.1) Ultimate Edition Service Pack 1 (Build 7601) Number of processors 1 Number of threads 4 Number of threads 4 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX Package Temperature 0 31°C (87°F) [0x1F] (SYSTIN) Temperature 1 47°C (115°F) [0x5D] (CPUTIN) Temperature 0 28°C (82°F) [0xBC2] (TZ00) Temperature 1 30°C (85°F) [0xBD6] (TZ01)
