x264 HD Benchmark 3.10 The new x264 HD Benchmark 3.0 is here! This is the improved version of the x264 HD Benchmark 2.0 benchmark which has become a standard CPU benchmark for Tech ARP as well as many other hardware enthusiasts. The new x264 HD Benchmark 3.0 ups the ante by using the latest r1342 x264 encoder as well as other changes under the hood. This makes the x264 HD Benchmark 3.0 the new best tool for testing the full capabilities of modern multi-core processors. Do note that due to the changes, the results from x264 HD Benchmark 3.0 are NOT comparable with results from older versions of the benchmark. In addition to the release of the benchmark, we will be compiling benchmark results for this new version. There are now 55 CPUs in this article, but we need MORE results! So please contribute your new benchmark results to this project! Check out the latest results! Link : x264 HD Benchmark 3.10
Results for x264.exe r1342 -------------------------- encoded 1442 frames, 41.23 fps, 3899.26 kb/s encoded 1442 frames, 37.58 fps, 3899.26 kb/s encoded 1442 frames, 37.06 fps, 3899.26 kb/s encoded 1442 frames, 37.05 fps, 3899.26 kb/s encoded 1442 frames, 10.80 fps, 3971.84 kb/s encoded 1442 frames, 10.41 fps, 3971.96 kb/s encoded 1442 frames, 10.42 fps, 3971.06 kb/s encoded 1442 frames, 10.14 fps, 3971.51 kb/s System Details -------------- Name Intel Pentium E5200 Codename Wolfdale Specification Pentium(R) Dual-Core CPU E5200 @ 2.50GHz Core Stepping M0 Technology 45 nm manufacturer Gigabyte Technology Co., Ltd. vendor Gigabyte Technology Co., Ltd. manufacturer Gigabyte Technology Co., Ltd. Stock frequency 2500 MHz Core Speed 3500.0 MHz FID range 6.0x - 12.5x Northbridge Intel P35/G33/G31 rev. 10 Southbridge Intel 82801GB (ICH7/R) rev. A1 CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 17 Command Rate (CR) 2T Memory Frequency 373.3 MHz (3:4) Memory Type DDR2 Memory Size 4096 MBytes Channels Dual, (Symmetric) Windows Version Microsoft Windows 7 (6.1) (Build 7600) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 2048 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T Package (platform ID) Socket 775 LGA (0x0) Temperature 0 68°C (154°F) [0x20] (Core #0) Temperature 1 65°C (148°F) [0x23] (Core #1)
Results core2duo e8500 3.16 Ghz @ 4.18 Ghz ******************************************************************************* * Results core2duo e8500 3,16 Ghz OC @ 4,18 Ghz * ******************************************************************************* Results for x264.exe r1342 -------------------------- encoded 1442 frames, 55.04 fps, 3899.26 kb/s encoded 1442 frames, 53.90 fps, 3899.26 kb/s encoded 1442 frames, 54.45 fps, 3899.26 kb/s encoded 1442 frames, 54.75 fps, 3899.26 kb/s encoded 1442 frames, 14.01 fps, 3970.81 kb/s encoded 1442 frames, 13.93 fps, 3971.95 kb/s encoded 1442 frames, 14.12 fps, 3971.51 kb/s encoded 1442 frames, 14.02 fps, 3970.80 kb/s System Details -------------- Name Intel Core 2 Duo E8500 product System Product Name Codename Wolfdale Specification Intel(R) Core(TM)2 Duo CPU E8500 @ 3.16GHz Core Stepping E0 Technology 45 nm Stock frequency 3166 MHz Core Speed 4180.0 MHz FID range 6.0x - 9.5x Northbridge Intel P45/P43 rev. A3 Southbridge Intel 82801JR (ICH10R) rev. 00 CAS# latency (CL) 8.0 RAS# to CAS# delay (tRCD) 8 RAS# Precharge (tRP) 8 Cycle Time (tRAS) 20 Command Rate (CR) 2T Memory Frequency 660.0 MHz (2:3) Memory Type DDR3 Memory Size 4096 MBytes Channels Dual, (Symmetric) Windows Version Microsoft Windows 7 (6.1) Ultimate Edition (Build 7600) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 6144 KBytes, 24-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T Package (platform ID) Socket 775 LGA (0x0) Temperature 0 41°C (105°F) [0x29] (SYSTIN) Temperature 1 52°C (124°F) [0x67] (CPUTIN) Temperature 2 9°C (48°F) [0x12] (AUXTIN) Temperature 0 55°C (130°F) [0x2D] (Core #0) Temperature 1 51°C (123°F) [0x31] (Core #1) ******************************************************************************* * Results core2duo e8500 3,16 Ghz stock speed * ******************************************************************************* Results for x264.exe r1342 -------------------------- encoded 1442 frames, 43.50 fps, 3899.26 kb/s encoded 1442 frames, 43.91 fps, 3899.26 kb/s encoded 1442 frames, 40.45 fps, 3899.26 kb/s encoded 1442 frames, 43.03 fps, 3899.26 kb/s encoded 1442 frames, 10.69 fps, 3972.89 kb/s encoded 1442 frames, 10.60 fps, 3971.58 kb/s encoded 1442 frames, 10.46 fps, 3970.44 kb/s encoded 1442 frames, 10.89 fps, 3972.02 kb/s System Details -------------- Name Intel Core 2 Duo E8500 product System Product Name Codename Wolfdale Specification Intel(R) Core(TM)2 Duo CPU E8500 @ 3.16GHz Core Stepping E0 Technology 45 nm Stock frequency 3166 MHz Core Speed 3172.7 MHz FID range 6.0x - 9.5x Northbridge Intel P45/P43 rev. A3 Southbridge Intel 82801JR (ICH10R) rev. 00 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Command Rate (CR) 2T Memory Frequency 667.9 MHz (1:2) Memory Type DDR3 Memory Size 4096 MBytes Channels Dual, (Symmetric) Windows Version Microsoft Windows 7 (6.1) Ultimate Edition (Build 7600) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 6144 KBytes, 24-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T Package (platform ID) Socket 775 LGA (0x0) Temperature 0 42°C (107°F) [0x2A] (SYSTIN) Temperature 1 39°C (101°F) [0x4D] (CPUTIN) Temperature 2 10°C (49°F) [0x14] (AUXTIN) Temperature 0 43°C (109°F) [0x39] (Core #0) Temperature 1 42°C (107°F) [0x3A] (Core #1)
x264 HD Benchmark 3.11 The new x264 HD Benchmark 3.0 is here! This is the improved version of the x264 HD Benchmark 2.0 benchmark which has become a standard CPU benchmark for Tech ARP as well as many other hardware enthusiasts. The new x264 HD Benchmark 3.0 ups the ante by using the latest r1342 x264 encoder as well as other changes under the hood. This makes the x264 HD Benchmark 3.0 the new best tool for testing the full capabilities of modern multi-core processors. Do note that due to the changes, the results from x264 HD Benchmark 3.0 are NOT comparable with results from older versions of the benchmark. In addition to the release of the benchmark, we will be compiling benchmark results for this new version. There are now 59 CPUs in this article, but we need MORE results! So please contribute your new benchmark results to this project! Check out the latest results! Link : x264 HD Benchmark 3.11
My results for my E5200 @ 3.75 GHz: Results for x264.exe r1342 -------------------------- encoded 1442 frames, 45.42 fps, 3899.26 kb/s encoded 1442 frames, 46.06 fps, 3899.26 kb/s encoded 1442 frames, 46.26 fps, 3899.26 kb/s encoded 1442 frames, 44.10 fps, 3899.26 kb/s encoded 1442 frames, 12.02 fps, 3971.01 kb/s encoded 1442 frames, 12.03 fps, 3971.48 kb/s encoded 1442 frames, 12.04 fps, 3971.74 kb/s encoded 1442 frames, 12.01 fps, 3970.52 kb/s System Details -------------- Name Intel Pentium E5200 Codename Wolfdale Specification Pentium(R) Dual-Core CPU E5200 @ 2.50GHz Core Stepping M0 Technology 45 nm manufacturer Gigabyte Technology Co., Ltd. vendor Gigabyte Technology Co., Ltd. manufacturer Gigabyte Technology Co., Ltd. Stock frequency 2500 MHz Core Speed 3749.7 MHz FID range 6.0x - 12.5x Northbridge Intel P35/G33/G31 rev. 10 Southbridge Intel 82801GB (ICH7/R) rev. A1 CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 18 Command Rate (CR) 2T Memory Frequency 400.0 MHz (3:4) Memory Type DDR2 Memory Size 4096 MBytes Channels Dual, (Symmetric) Windows Version Microsoft Windows 7 (6.1) (Build 7600) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 2048 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T Package (platform ID) Socket 775 LGA (0x0) Temperature 0 75°C (166°F) [0x19] (Core #0) Temperature 1 70°C (157°F) [0x1E] (Core #1)
E5200 @ Stock speeds Results for x264.exe r1342 -------------------------- encoded 1442 frames, 32.41 fps, 3899.26 kb/s encoded 1442 frames, 29.21 fps, 3899.26 kb/s encoded 1442 frames, 32.31 fps, 3899.26 kb/s encoded 1442 frames, 31.25 fps, 3899.26 kb/s encoded 1442 frames, 8.05 fps, 3971.71 kb/s encoded 1442 frames, 7.98 fps, 3971.89 kb/s encoded 1442 frames, 8.15 fps, 3971.84 kb/s encoded 1442 frames, 8.06 fps, 3970.65 kb/s System Details -------------- Name Intel Pentium E5200 Codename Wolfdale Specification Pentium(R) Dual-Core CPU E5200 @ 2.50GHz Core Stepping M0 Technology 45 nm manufacturer Gigabyte Technology Co., Ltd. vendor Gigabyte Technology Co., Ltd. manufacturer Gigabyte Technology Co., Ltd. Stock frequency 2500 MHz Core Speed 2499.9 MHz FID range 6.0x - 12.5x Northbridge Intel P35/G33/G31 rev. 10 Southbridge Intel 82801GB (ICH7/R) rev. A1 CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 18 Command Rate (CR) 2T Memory Frequency 400.0 MHz (1:2) Memory Type DDR2 Memory Size 4096 MBytes Channels Dual, (Symmetric) Windows Version Microsoft Windows 7 (6.1) (Build 7600) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 2048 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T Package (platform ID) Socket 775 LGA (0x0) Temperature 0 56°C (132°F) [0x2C] (Core #0) Temperature 1 54°C (129°F) [0x2E] (Core #1)
results core2duo e8500 OC @ 4.41 ghz ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r1342 -------------------------- encoded 1442 frames, 58.90 fps, 3899.26 kb/s encoded 1442 frames, 59.01 fps, 3899.26 kb/s encoded 1442 frames, 58.95 fps, 3899.26 kb/s encoded 1442 frames, 60.03 fps, 3899.26 kb/s encoded 1442 frames, 15.69 fps, 3972.89 kb/s encoded 1442 frames, 14.89 fps, 3971.58 kb/s encoded 1442 frames, 15.46 fps, 3970.44 kb/s encoded 1442 frames, 15.12 fps, 3972.02 kb/s System Details -------------- Name Intel Core 2 Duo E8500 product System Product Name Codename Wolfdale Specification Intel(R) Core(TM)2 Duo CPU E8500 @ 3.16GHz Core Stepping E0 Technology 45 nm Stock frequency 3166 MHz Core Speed 4410.7 MHz FID range 6.0x - 9.0x Northbridge Intel P45/P43 rev. A3 Southbridge Intel 82801JR (ICH10R) rev. 00 CAS# latency (CL) 8.0 RAS# to CAS# delay (tRCD) 8 RAS# Precharge (tRP) 8 Cycle Time (tRAS) 24 Command Rate (CR) 2T Memory Frequency 667.9 MHz (1:2) Memory Type DDR3 Memory Size 4096 MBytes Channels Dual, (Symmetric) Windows Version Microsoft Windows 7 (6.1) Ultimate Edition (Build 7600) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 6144 KBytes, 24-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T Package (platform ID) Socket 775 LGA (0x0) Temperature 0 55°C (107°F) [0x2A] (SYSTIN) Temperature 1 67°C (101°F) [0x4D] (CPUTIN) Temperature 2 10°C (49°F) [0x14] (AUXTIN) Temperature 0 70°C (109°F) [0x39] (Core #0) Temperature 1 69°C (107°F) [0x3A] (Core #1)
x264 HD BENCHMARK 3.0 RESULTS Please do not compare it with older versions of the benchmark! Please copy/paste everything below the line to to report your data ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r1342 -------------------------- encoded 1442 frames, 71.54 fps, 3901.21 kb/s encoded 1442 frames, 72.61 fps, 3900.68 kb/s encoded 1442 frames, 72.05 fps, 3900.68 kb/s encoded 1442 frames, 71.21 fps, 3900.68 kb/s encoded 1442 frames, 21.56 fps, 3971.63 kb/s encoded 1442 frames, 21.70 fps, 3971.69 kb/s encoded 1442 frames, 21.77 fps, 3971.27 kb/s encoded 1442 frames, 21.62 fps, 3971.16 kb/s System Details -------------- Name Intel Core 2 Quad Q6600 Codename Kentsfield Specification Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz Core Stepping G0 Technology 65 nm Stock frequency 2400 MHz Core Speed 3399.4 MHz FID range 6.0x - 9.0x Northbridge Intel P45/P43/G45/G43 rev. A2 Southbridge Intel 82801JR (ICH10R) rev. 00 CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 7 RAS# Precharge (tRP) 7 Cycle Time (tRAS) 16 Command Rate (CR) 2T Memory Frequency 566.6 MHz (3:4) Memory Type DDR2 Memory Size 4096 MBytes Channels Dual, (Symmetric) Windows Version Microsoft Windows 7 (6.1) Ultimate Edition (Build 7600) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 2 x 4096 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T Package (platform ID) Socket 775 LGA (0x4) Temperature 0 33°C (91°F) [0x21] (TMPIN0) Temperature 1 25°C (76°F) [0x19] (TMPIN1) Temperature 0 46°C (114°F) [0x36] (Core #0) Temperature 1 48°C (118°F) [0x34] (Core #1) Temperature 2 38°C (100°F) [0x3E] (Core #2) Temperature 3 47°C (116°F) [0x35] (Core #3)
