CPU-Z does not have time to write a system_details.txt. At first time when the bench_script.bat run, the System Details section remains empty. At second time the System Details section gets data from the old system_details.txt. I think that much more significant is one-thread performance. Decoding uses only one thread and maybe it is bottleneck in the Pass 1. Also, x264 does not have a good multi-thread support in fast settings: http://git.videolan.org/?p=x264.git;a=blob_plain;f=doc/threads.txt;hb=HEAD Something like this could be better in the next version: x264 --quiet --thread-input --preset slow --crf 18 -o NUL test-720p.avs
Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 16.12 fps, 3909.88 kb/s encoded 1442 frames, 16.17 fps, 3909.88 kb/s encoded 1442 frames, 16.13 fps, 3909.88 kb/s encoded 1442 frames, 16.35 fps, 3909.88 kb/s Pass 2 ------ encoded 1442 frames, 2.83 fps, 3962.31 kb/s encoded 1442 frames, 2.83 fps, 3962.57 kb/s encoded 1442 frames, 2.83 fps, 3962.10 kb/s encoded 1442 frames, 2.84 fps, 3962.68 kb/s System Details -------------- Name Intel Pentium 4 630 product System Product Name Codename Prescott Specification Intel(R) Pentium(R) 4 CPU 3.00GHz Core Stepping R0 Technology 90 nm Stock frequency 3000 MHz Core Speed 2999.8 MHz FID range 14.0x - 15.0x Northbridge VIA P4M890 rev. 00 Southbridge VIA VT8237A rev. 00 CAS# latency (CL) 4.0 RAS# to CAS# delay (tRCD) 4 RAS# Precharge (tRP) 4 Cycle Time (tRAS) 12 Command Rate (CR) 2T Memory Frequency 266.6 MHz (3:4) Memory Type DDR2 Memory Size 1024 MBytes Channels Single Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 2048 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, EM64T Package (platform ID) Socket 775 LGA (0x4) Temperature 0 39°C (102°F) [0x27] (TMPIN0) Temperature 1 43°C (109°F) [0x2B] (TMPIN1) Temperature 2 29°C (84°F) [0x1D] (TMPIN2) Temperature 0 40°C (103°F) [0xC3C] (THRM)
AMD Athlon 64 X2 4400+ Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 33.79 fps, 3909.85 kb/s encoded 1442 frames, 33.81 fps, 3909.84 kb/s encoded 1442 frames, 33.88 fps, 3909.82 kb/s encoded 1442 frames, 33.93 fps, 3909.84 kb/s Pass 2 ------ encoded 1442 frames, 5.83 fps, 3962.84 kb/s encoded 1442 frames, 5.83 fps, 3962.45 kb/s encoded 1442 frames, 5.83 fps, 3962.18 kb/s encoded 1442 frames, 5.83 fps, 3962.48 kb/s System Details -------------- Name AMD Athlon 64 X2 4400+ Codename Brisbane Specification AMD Athlon(tm) 64 X2 Dual Core Processor 4400+ Core Stepping BH-G2 Technology 65 nm manufacturer Gigabyte Technology Co., Ltd. vendor Gigabyte Technology Co., Ltd. manufacturer Gigabyte Technology Co., Ltd. Stock frequency 2300 MHz Core Speed 2310.5 MHz Northbridge NVIDIA nForce 560 rev. A3 Southbridge NVIDIA nForce 560 rev. A3 CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 18 Command Rate (CR) 2T Memory Frequency 385.1 MHz (CPU/6) Memory Type DDR2 Memory Size 2048 MBytes Channels Dual Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 2 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64, AMD-V Package Socket AM2 (940) Temperature 0 43°C (109°F) [0x2B] (TMPIN0) Temperature 1 57°C (134°F) [0x39] (TMPIN1) Temperature 2 48°C (118°F) [0x30] (TMPIN2)
AMD Turion II M520 Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 41.66 fps, 3909.87 kb/s encoded 1442 frames, 40.32 fps, 3909.83 kb/s encoded 1442 frames, 40.28 fps, 3909.90 kb/s encoded 1442 frames, 41.65 fps, 3909.83 kb/s Pass 2 ------ encoded 1442 frames, 7.75 fps, 3962.78 kb/s encoded 1442 frames, 7.68 fps, 3962.56 kb/s encoded 1442 frames, 7.70 fps, 3962.73 kb/s encoded 1442 frames, 7.77 fps, 3962.61 kb/s System Details -------------- Name AMD Turion II M520 Codename Caspian Specification AMD Turion(tm) II Dual-Core Mobile M520 Core Stepping DA-C2 Technology 45 nm Manufacturer (ID) Ramaxel Technology (7F7F7F7F43000000) Stock frequency 2300 MHz Core Speed 801.2 MHz FID range 4.0x - 11.5x Northbridge AMD 785G rev. 00 Southbridge AMD SB700 rev. 00 CAS# latency (CL) 6.0 RAS# to CAS# delay (tRCD) 6 RAS# Precharge (tRP) 6 Cycle Time (tRAS) 18 Command Rate (CR) 2T Memory Frequency 400.6 MHz (1:2) Memory Type DDR2 Memory Size 3072 MBytes Channels Dual, (Unganged) Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 2 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V Package Socket S1 (638) Package Type 0x2 Temperature 0 67°C (152°F) [0xD4A] (CPUZ) Temperature 1 60°C (139°F) [0xD04] (GFXZ)
Intel Atom N270 Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 9.02 fps, 3909.87 kb/s encoded 1442 frames, 9.06 fps, 3909.88 kb/s encoded 1442 frames, 9.04 fps, 3909.88 kb/s encoded 1442 frames, 9.03 fps, 3909.88 kb/s Pass 2 ------ encoded 1442 frames, 1.53 fps, 3962.65 kb/s encoded 1442 frames, 1.53 fps, 3962.71 kb/s encoded 1442 frames, 1.54 fps, 3962.70 kb/s encoded 1442 frames, 1.53 fps, 3961.83 kb/s System Details -------------- Name Intel Atom N270 Codename Diamondville Specification Intel(R) Atom(TM) CPU N270 @ 1.60GHz Core Stepping C0 Technology 45 nm Stock frequency 1600 MHz Core Speed 798.0 MHz FID range 6.0x - 12.0x Northbridge Intel i945GSE rev. 03 Southbridge Intel 82801GHM (ICH7-M/U) rev. A1 CAS# latency (CL) 4.0 RAS# to CAS# delay (tRCD) 4 RAS# Precharge (tRP) 4 Cycle Time (tRAS) 12 Memory Frequency 266.0 MHz (1:2) Memory Type DDR2 Memory Size 1016 MBytes Channels Single Windows Version Microsoft Windows XP Home Edition Service Pack 3 (Build 2600) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 512 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3 Package (platform ID) Socket 437 FCBGA8 (0x2) Temperature 0 60°C (139°F) [0xCFF] (THM_)
^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 40.64 fps, 3909.87 kb/s encoded 1442 frames, 40.82 fps, 3909.86 kb/s encoded 1442 frames, 40.91 fps, 3909.81 kb/s encoded 1442 frames, 40.82 fps, 3909.84 kb/s Pass 2 ------ encoded 1442 frames, 7.12 fps, 3962.56 kb/s encoded 1442 frames, 7.12 fps, 3962.59 kb/s encoded 1442 frames, 7.12 fps, 3962.08 kb/s encoded 1442 frames, 7.15 fps, 3963.06 kb/s System Details -------------- Name AMD Athlon 64 X2 5050e Codename Specification AMD Athlon(tm) Dual Core Processor 5050e Core Stepping DH-G2 Technology 65 nm Manufacturer (ID) A-Data Technology (7F7F7F7FCB000000) Manufacturer (ID) A-Data Technology (7F7F7F7FCB000000) Stock frequency 2600 MHz Core Speed 2860.1 MHz Northbridge AMD 780G rev. 00 Southbridge AMD SB700 rev. 00 CAS# latency (CL) 4.0 RAS# to CAS# delay (tRCD) 4 RAS# Precharge (tRP) 4 Cycle Time (tRAS) 12 Command Rate (CR) 1T Memory Frequency 408.6 MHz (CPU/7) Memory Type DDR2 Memory Size 4096 MBytes Channels Dual Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 2 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64, AMD-V Package Socket AM2 (940) Temperature 0 36°C (96°F) [0x24] (TMPIN0) Temperature 1 125°C (256°F) [0x7D] (TMPIN1) Temperature 2 31°C (87°F) [0x1F] (TMPIN2)
motherboard swap These DDR3 1333 sticks are as high as there going to get (1633.4 MHz.) Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 114.12 fps, 3912.32 kb/s encoded 1442 frames, 114.40 fps, 3912.32 kb/s encoded 1442 frames, 114.40 fps, 3912.32 kb/s encoded 1442 frames, 114.83 fps, 3912.32 kb/s Pass 2 ------ encoded 1442 frames, 23.64 fps, 3961.51 kb/s encoded 1442 frames, 23.50 fps, 3961.07 kb/s encoded 1442 frames, 23.58 fps, 3961.81 kb/s encoded 1442 frames, 23.54 fps, 3961.55 kb/s System Details -------------- Name AMD Athlon II X4 635 Codename Propus Specification AMD Athlon(tm) II X4 635 Processor Core Stepping BL-C3 Technology 45 nm manufacturer Gigabyte Technology Co., Ltd. vendor Gigabyte Technology Co., Ltd. manufacturer Gigabyte Technology Co., Ltd. Stock frequency 2900 MHz Core Speed 3552.3 MHz FID range 4.0x - 14.5x Northbridge AMD 880G rev. 00 Southbridge AMD SB850 rev. 40 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Command Rate (CR) 2T Memory Frequency 816.7 MHz (3:10) Memory Type DDR3 Memory Size 4096 MBytes Channels Dual, (Unganged) Windows Version Microsoft Windows 7 (6.1) Home Premium Edition Service Pack 1 (Build 7601) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V Package Socket AM3 (938) Package Type 0x1 Temperature 0 32°C (89°F) [0x20] (TMPIN0) Temperature 1 37°C (98°F) [0x25] (TMPIN1) Temperature 2 43°C (109°F) [0x2B] (TMPIN2)
Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 133.40 fps, 3913.31 kb/s encoded 1442 frames, 132.81 fps, 3913.31 kb/s encoded 1442 frames, 133.00 fps, 3913.31 kb/s encoded 1442 frames, 133.19 fps, 3913.31 kb/s Pass 2 ------ encoded 1442 frames, 36.68 fps, 3959.81 kb/s encoded 1442 frames, 36.80 fps, 3961.15 kb/s encoded 1442 frames, 36.68 fps, 3959.83 kb/s encoded 1442 frames, 36.74 fps, 3959.40 kb/s System: ID : 2087979 Submitted by NEBULA | Tue, 08 Nov 2011 18:07:18 +0100 | Validated by CPU-Z 1.58 AMD Phenom II X6 1055T Windows 7 Ultimate Edition SP1 (Build 7601) CPU Arch : 1 CPU - 6 Cores - 6 Threads CPU PSN : AMD Phenom II X6 1055T Processor CPU EXT : MMX(+), 3DNow!(+), SSE (1, 2, 3, 4A), x86-64, AMD-V CPUID : F.A.0 / Extended : 10.A CPU Cache : L1 : 6 x 64 / 6 x 64 KB - L2 : 6 x 512 KB CPU Cache : L3 : 6144 KB Core : Thuban (45 nm) / Stepping : PH-E0 Freq : 3710.08 MHz (265.01 * 14) MB Brand : MSI MB Model : 990XA-GD55 (MS-7640) NB : ATI ID5A14 rev 02 SB : AMD SB850 rev 40 GPU Type : NVIDIA GeForce GTX 460 GPU Clocks : Core 675 MHz / RAM 1800 MHz DirectX Version : 11.0 RAM : 8192 MB DDR3 Dual Channel RAM Speed : 706.7 MHz (3:8) @ 9-9-9-24 Slot 1 : 4096MB (10700) Slot 1 Manufacturer : Corsair Slot 2 : 4096MB (10700) Slot 2 Manufacturer : Corsair
Is there any other reason to use the AVS than repeat twice the video? FFMS is slightly faster and does not need DLLs: x264-32 -o NUL --quiet --thread-input --demuxer avs test-720p.avs --frames 721 encoded 721 frames, 23.56 fps, 1730.74 kb/s encoded 721 frames, 23.84 fps, 1730.74 kb/s encoded 721 frames, 23.85 fps, 1730.74 kb/s x264-32 -o NUL --quiet --no-interlaced --demuxer ffms test-720p.mpg encoded 721 frames, 24.06 fps, 1731.16 kb/s encoded 721 frames, 24.11 fps, 1731.16 kb/s encoded 721 frames, 24.05 fps, 1731.16 kb/s --- Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 73.60 fps, 3912.26 kb/s encoded 1442 frames, 74.67 fps, 3912.26 kb/s encoded 1442 frames, 73.95 fps, 3912.26 kb/s encoded 1442 frames, 73.36 fps, 3912.26 kb/s Pass 2 ------ encoded 1442 frames, 15.97 fps, 3961.30 kb/s encoded 1442 frames, 15.95 fps, 3961.51 kb/s encoded 1442 frames, 15.87 fps, 3961.67 kb/s encoded 1442 frames, 15.00 fps, 3961.63 kb/s System Details -------------- Name Intel Core 2 Quad Q6600 product System Product Name Codename Kentsfield Specification Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz Core Stepping G0 Technology 65 nm Stock frequency 2400 MHz Core Speed 2404.0 MHz FID range 6.0x - 9.0x Northbridge Intel i975X rev. C0 Southbridge Intel 82801GB (ICH7/R) rev. A1 CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 12 Memory Frequency 267.1 MHz (1:1) Memory Type DDR2 Memory Size 6144 MBytes Channels Dual Windows Version Microsoft Windows 7 (6.1) Ultimate Edition Service Pack 1 (Build 7601) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 2 x 4096 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T, VT-x Package (platform ID) Socket 775 LGA (0x4) Temperature 0 42°C (107°F) [0x2A] (SYSTIN) Temperature 1 55°C (130°F) [0x6E] (CPUTIN) Temperature 2 22°C (70°F) [0x2B] (AUXTIN)
Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 40.93 fps, 3909.84 kb/s encoded 1442 frames, 41.18 fps, 3909.80 kb/s encoded 1442 frames, 41.16 fps, 3909.86 kb/s encoded 1442 frames, 41.22 fps, 3909.81 kb/s Pass 2 ------ encoded 1442 frames, 7.19 fps, 3962.78 kb/s encoded 1442 frames, 7.16 fps, 3962.11 kb/s encoded 1442 frames, 7.19 fps, 3962.60 kb/s encoded 1442 frames, 7.18 fps, 3962.64 kb/s System Details -------------- Name AMD Athlon 64 X2 5050e Codename Specification AMD Athlon(tm) Dual Core Processor 5050e Core Stepping DH-G2 Technology 65 nm Manufacturer (ID) A-Data Technology (7F7F7F7FCB000000) Manufacturer (ID) A-Data Technology (7F7F7F7FCB000000) Stock frequency 2600 MHz Core Speed 2860.4 MHz Northbridge AMD 780G rev. 00 Southbridge AMD SB700 rev. 00 CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 15 Command Rate (CR) 1T Memory Frequency 357.6 MHz (CPU/8) Memory Type DDR2 Memory Size 4096 MBytes Channels Dual Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 2 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64, AMD-V Package Socket AM2 (940) Temperature 0 33°C (91°F) [0x21] (TMPIN0) Temperature 1 106°C (222°F) [0x6A] (TMPIN1) Temperature 2 28°C (82°F) [0x1C] (TMPIN2) RAM [email protected]
Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 80.30 fps, 3912.26 kb/s encoded 1442 frames, 87.35 fps, 3912.26 kb/s encoded 1442 frames, 88.18 fps, 3912.26 kb/s encoded 1442 frames, 87.71 fps, 3912.26 kb/s Pass 2 ------ encoded 1442 frames, 17.88 fps, 3961.11 kb/s encoded 1442 frames, 18.08 fps, 3961.26 kb/s encoded 1442 frames, 18.01 fps, 3961.45 kb/s encoded 1442 frames, 17.97 fps, 3961.63 kb/s System Details -------------- _Dell 3007-WFP-HC (30" wide 2560*1600) _Dfi Lanparty Lt X38 _Seasonic M12 700W _Xeon 3350 @ Stock @ 2.66 ghz _Antec Kuhler H20 920 _HD 6970 HIS _2*2 Go DDR2 Chaintech PC8500 @ 400Mhz @ 6-6-6-18-52/2T _Vista Ultimate 64 bits
AMD Phenom(tm) II X6 1090T Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 117.34 fps, 3913.31 kb/s encoded 1442 frames, 125.51 fps, 3913.31 kb/s encoded 1442 frames, 125.62 fps, 3913.31 kb/s encoded 1442 frames, 118.76 fps, 3913.31 kb/s Pass 2 ------ encoded 1442 frames, 33.49 fps, 3956.39 kb/s encoded 1442 frames, 33.46 fps, 3957.99 kb/s encoded 1442 frames, 33.36 fps, 3960.00 kb/s encoded 1442 frames, 33.45 fps, 3959.98 kb/s System Details -------------- Name AMD Phenom II X6 1095T Codename Thuban Specification AMD Phenom(tm) II X6 1090T Processor Specification PC3-12800 Specification PC3-12800 Core Stepping PH-E0 Technology 45 nm Stock frequency 3200 MHz Core Speed 3371.70 MHz Northbridge AMD 890GX rev. 00 Southbridge AMD SB850 rev. 40 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Command Rate (CR) 1T Command Rate 2T Command Rate 2T Memory Frequency 802.7 MHz (3:10) Memory Type DDR3 Memory Size 4096 MBytes Channels Dual, (Unganged) Temperature 0 46°C (114°F) [0x2E] (CPU) Temperature 1 31°C (87°F) [0x1F] (Mainboard)
AMD FX(tm)-8150 Eight-Core Processor (unoverclocked) This week I had a chance to get my hands on one of the brand spanking new AMD FX Eight Core Bulldozers. At stock clock it was just a little faster than the 1090T I tested a few months ago. It was cooled by the Corsair Hydro H100. It averages at 74,4725fps over two passes. Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 112.04 fps, 3911.61 kb/s encoded 1442 frames, 113.14 fps, 3911.61 kb/s encoded 1442 frames, 112.04 fps, 3911.61 kb/s encoded 1442 frames, 113.42 fps, 3911.61 kb/s Pass 2 ------ encoded 1442 frames, 35.77 fps, 3960.15 kb/s encoded 1442 frames, 36.25 fps, 3959.99 kb/s encoded 1442 frames, 36.54 fps, 3960.23 kb/s encoded 1442 frames, 36.58 fps, 3959.38 kb/s System Details -------------- Name AMD FX-8130P Name Radeon HD 5900 Name Radeon HD 5900 Codename Bulldozer Codename RV870 Codename RV870 Specification AMD FX(tm)-8150 Eight-Core Processor (Engineering Sample) Specification PC3-12800 Specification PC3-12800 Specification PC3-12800 Specification PC3-12800 Core Stepping Technology 32 nm Technology 40 nm Technology 40 nm Core Speed 1404.7 MHz Northbridge ATI ID5A14 rev. 02 Southbridge AMD SB850 rev. 40 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Command Rate 2T Command Rate 2T Command Rate 2T Command Rate 2T Memory Frequency 668.9 MHz (3:10) Memory Type DDR3 Memory Size 16384 MBytes Channels Dual Windows Version Microsoft Windows 7 (6.1) (Build 7600) Number of processors 1 Number of threads 8 Number of threads 8 (max 8) L2 cache 4 x 2048 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, x86-64, AMD-V, AES, AVX, XOP Package Socket AM3+ (942) Package Type 0x1 Temperature 0 55°C (130°F) [0x37] (CPU) Temperature 1 34°C (93°F) [0x22] (Mainboard) Temperature 0 49°C (120°F) [0x31] (TMPIN0)
AMD FX(tm)-8150 Eight-Core Processor ([email protected]) After this I juiced it up to 4.6GHz wich let it run a little bit hotter but the Corsair Hyrdo kept it at 70°C This way it averaged 92,11fps overall. Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 137.56 fps, 3911.61 kb/s encoded 1442 frames, 140.27 fps, 3911.61 kb/s encoded 1442 frames, 137.56 fps, 3911.61 kb/s encoded 1442 frames, 137.35 fps, 3911.61 kb/s Pass 2 ------ encoded 1442 frames, 46.03 fps, 3959.21 kb/s encoded 1442 frames, 46.03 fps, 3958.42 kb/s encoded 1442 frames, 46.08 fps, 3959.13 kb/s encoded 1442 frames, 46.06 fps, 3960.06 kb/s System Details -------------- Name AMD FX-8130P Name Radeon HD 5900 Name Radeon HD 5900 Codename Bulldozer Codename RV870 Codename RV870 Specification AMD FX(tm)-8150 Eight-Core Processor (Engineering Sample) Specification PC3-12800 Specification PC3-12800 Specification PC3-12800 Specification PC3-12800 Core Stepping Technology 32 nm Technology 40 nm Technology 40 nm Core Speed 1404.8 MHz Northbridge ATI ID5A14 rev. 02 Southbridge AMD SB850 rev. 40 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Command Rate 2T Command Rate 2T Command Rate 2T Command Rate 2T Memory Frequency 668.9 MHz (3:10) Memory Type DDR3 Memory Size 16384 MBytes Channels Dual Windows Version Microsoft Windows 7 (6.1) (Build 7600) Number of processors 1 Number of threads 8 Number of threads 8 (max 8) L2 cache 4 x 2048 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, x86-64, AMD-V, AES, AVX, XOP Package Socket AM3+ (942) Package Type 0x1 Temperature 0 54°C (129°F) [0x36] (CPU) Temperature 1 34°C (93°F) [0x22] (Mainboard) Temperature 0 50°C (121°F) [0x31] (TMPIN0)
x264 HD BENCHMARK 4.0 RESULTS Please do NOT compare it with older versions of the benchmark! Please copy/paste everything below the line to to report your data to ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 80.99 fps, 3912.26 kb/s encoded 1442 frames, 81.28 fps, 3912.26 kb/s encoded 1442 frames, 80.55 fps, 3912.26 kb/s encoded 1442 frames, 81.50 fps, 3912.26 kb/s Pass 2 ------ encoded 1442 frames, 16.94 fps, 3961.39 kb/s encoded 1442 frames, 16.92 fps, 3961.58 kb/s encoded 1442 frames, 16.94 fps, 3961.85 kb/s encoded 1442 frames, 16.88 fps, 3961.28 kb/s System Details -------------- Name Intel Core 2 Quad Q8200 product System Product Name Codename Yorkfield Specification Intel(R) Core(TM)2 Quad CPU Q8200 @ 2.33GHz Core Stepping R0 Technology 45 nm Stock frequency 2333 MHz Core Speed 2304.0 MHz FID range 6.0x - 7.0x Northbridge Intel P35/G33/G31 rev. 10 Southbridge Intel 82801GB (ICH7/R) rev. A1 CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 15 Command Rate (CR) 2T Memory Frequency 384.0 MHz (1:1) Memory Type DDR2 Memory Size 4096 MBytes Channels Dual, (Symmetric) Windows Version Microsoft Windows 7 (6.1) Home Premium Edition Service Pack 1 (Build 7601) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 2 x 2048 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T Package (platform ID) Socket 775 LGA (0x4) Temperature 0 42°C (107°F) [0x2A] (SYSTIN) Temperature 1 58°C (136°F) [0x74] (CPUTIN) Temperature 2 52°C (125°F) [0x68] (AUXTIN)
Hello to all I try to run X264 V3 or V4 ans still have an issue with "Avisynth 2.2.8 not installed" and I am redirected to Avisynth download. Avisynth is alreday installed (Downloaded recently from the link). Apparently nothing change. Tried to run directly the batch file but the result is still the same. tried Google too, but I was not cery succesfull. Any help will be appreciated. thanks
Socket A (462) AMD Sempron 3000+ (default) x264 HD BENCHMARK 4.0 RESULTS Please do NOT compare it with older versions of the benchmark! Please copy/paste everything below the line to to report your data to ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 10.17 fps, 3908.74 kb/s encoded 1442 frames, 10.18 fps, 3908.74 kb/s encoded 1442 frames, 10.18 fps, 3908.74 kb/s encoded 1442 frames, 10.16 fps, 3908.74 kb/s Pass 2 ------ encoded 1442 frames, 2.06 fps, 3962.60 kb/s encoded 1442 frames, 2.06 fps, 3962.60 kb/s encoded 1442 frames, 2.06 fps, 3962.60 kb/s encoded 1442 frames, 2.05 fps, 3962.60 kb/s System Details -------------- Name AMD Sempron product System Name Codename Barton Specification AMD Sempron(TM) 3000+ Core Stepping Technology 0.13 um Core Speed 1988.3 MHz Northbridge VIA KT400A rev. 80 Southbridge VIA VT8235 rev. 00 CAS# latency (CL) 2.5 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 4 Cycle Time (tRAS) 9 Memory Frequency 165.7 MHz (1:1) Memory Type DDR Memory Size 768 MBytes Windows Version Microsoft Windows XP Professional Szervizcsomag 3 (Build 2600) Number of processors 1 Number of threads 1 Number of threads 1 (max 1) L2 cache 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE Package Socket A (462) Temperature 0 41°C (105°F) [0x29] (TMPIN0) Temperature 1 28°C (82°F) [0x1C] (TMPIN1) Run time : 56 min (1 hour)
