RE: missing Avisynth-Problem Well, the batch file simply checks if the "Avisynth 2.5" folder exists in %PROGRAMFILES% or %PROGRAMFILES(x86)%. Maybe there's something odd with your system variables. After copying the files avisynth.dll and devil.dll from your %WINDIR%\system32 folder to the x264 bench "test" folder insert the following into your batch file above everything else: if exist "%~dp0\test\avisynth.dll" goto start This little trick neatly solved my problem of me having to let the x264-benchmark run TWICE on every single machine because the system_details.txt was not written properly after the first run.
Thanks Fixit. The directory was Avisynt. After renaming in Avisynt 2.5 it works now. I appreciate your help.
sandy bridge e Here's a Sandy Bridge E for you. ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 160.29 fps, 3913.50 kb/s encoded 1442 frames, 161.19 fps, 3913.50 kb/s encoded 1442 frames, 161.82 fps, 3913.50 kb/s encoded 1442 frames, 161.51 fps, 3913.50 kb/s Pass 2 ------ encoded 1442 frames, 49.74 fps, 3956.44 kb/s encoded 1442 frames, 49.92 fps, 3955.72 kb/s encoded 1442 frames, 49.94 fps, 3957.81 kb/s encoded 1442 frames, 49.90 fps, 3955.90 kb/s System Details -------------- Name Intel Processor product System Product Name Codename Sandy Bridge-EP Specification Intel(R) Core(TM) i7-3960X CPU @ 3.30GHz Core Stepping Technology 32 nm Stock frequency 3300 MHz Core Speed 1200.0 MHz Northbridge Intel ID3C00 rev. 06 Southbridge Intel ID1D41 rev. 05 Memory Type Memory Size 16362 MBytes Windows Version Microsoft Windows 7 (6.1) Service Pack 1 (Build 7601) Number of processors 1 Number of threads 12 Number of threads 12 (max 32) L2 cache 6 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX Package (platform ID) (0x2) Temperature 0 51°C (123°F) [0x33] (SYSTIN) Temperature 1 0°C (32°F) [0x0] (CPUTIN) Temperature 2 64°C (147°F) [0x80] (AUXTIN) Report didn't include RAM for some reason. It's 16GB of DDR3 @ 1600.
results i5 2500k@4300 Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 178.44 fps, 3912.26 kb/s encoded 1442 frames, 180.54 fps, 3912.26 kb/s encoded 1442 frames, 179.13 fps, 3912.26 kb/s encoded 1442 frames, 179.49 fps, 3912.26 kb/s Pass 2 ------ encoded 1442 frames, 36.29 fps, 3961.16 kb/s encoded 1442 frames, 36.43 fps, 3961.49 kb/s encoded 1442 frames, 36.36 fps, 3961.22 kb/s encoded 1442 frames, 36.38 fps, 3961.15 kb/s System Details -------------- Processor 1 ID = 0 Number of cores 4 (max 8) Number of threads 4 (max 16) Name Intel Core i5 2500K Codename Sandy Bridge Specification Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz Package (platform ID) Socket 1155 LGA (0x1) CPUID 6.A.7 Extended CPUID 6.2A Core Stepping D2 Technology 32 nm TDP Limit 95 Watts Core Speed 1600.0 MHz Multiplier x FSB 16.0 x 100.0 MHz Stock frequency 3300 MHz Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX L1 Data cache 4 x 32 KBytes, 8-way set associative, 64-byte line size L1 Instruction cache 4 x 32 KBytes, 8-way set associative, 64-byte line size L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size L3 cache 6 MBytes, 12-way set associative, 64-byte line size FID/VID Control yes Turbo Mode supported, enabled Max non-turbo ratio 33x Max turbo ratio 43x Max efficiency ratio 16x Min Power 60 Watts O/C bins unlimited
Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 115.13 fps, 3911.61 kb/s encoded 1442 frames, 116.36 fps, 3911.61 kb/s encoded 1442 frames, 117.01 fps, 3911.61 kb/s encoded 1442 frames, 115.78 fps, 3911.61 kb/s Pass 2 ------ encoded 1442 frames, 36.03 fps, 3959.50 kb/s encoded 1442 frames, 36.05 fps, 3960.35 kb/s encoded 1442 frames, 35.93 fps, 3959.58 kb/s encoded 1442 frames, 36.05 fps, 3959.86 kb/s System Details -------------- Name AMD Processor Name AMD Processor Name AMD Processor Name AMD Processor Name AMD Processor Name AMD Processor Name AMD Processor Name AMD Processor product System Product Name Codename Codename Codename Codename Codename Codename Codename Codename Specification AMD FX(tm)-8150 Eight-Core Processor Specification AMD FX(tm)-8150 Eight-Core Processor Specification AMD FX(tm)-8150 Eight-Core Processor Specification AMD FX(tm)-8150 Eight-Core Processor Specification AMD FX(tm)-8150 Eight-Core Processor Specification AMD FX(tm)-8150 Eight-Core Processor Specification AMD FX(tm)-8150 Eight-Core Processor Specification AMD FX(tm)-8150 Eight-Core Processor Core Stepping Core Stepping Core Stepping Core Stepping Core Stepping Core Stepping Core Stepping Core Stepping Core Speed 3612.2 MHz Core Speed 3612.6 MHz Core Speed 3612.4 MHz Core Speed 3611.6 MHz Core Speed 3612.5 MHz Core Speed 3612.3 MHz Core Speed 3612.4 MHz Core Speed 3611.7 MHz Northbridge AMD 890FX rev. 02 Southbridge AMD SB850 rev. 40 CAS# latency (CL) 7.0 RAS# to CAS# delay (tRCD) 7 RAS# Precharge (tRP) 7 Cycle Time (tRAS) 20 Memory Type DDR3 Memory Size 4096 MBytes Channels Dual Windows Version Microsoft Windows 7 (6.1) Service Pack 1 (Build 7601) Number of processors 8 Number of threads 8 Number of threads 1 (max 1) Number of threads 1 (max 1) Number of threads 1 (max 1) Number of threads 1 (max 1) Number of threads 1 (max 1) Number of threads 1 (max 1) Number of threads 1 (max 1) Number of threads 1 (max 1) L2 cache 2048 KBytes, 16-way set associative, 64-byte line size L2 cache 2048 KBytes, 16-way set associative, 64-byte line size L2 cache 2048 KBytes, 16-way set associative, 64-byte line size L2 cache 2048 KBytes, 16-way set associative, 64-byte line size L2 cache 2048 KBytes, 16-way set associative, 64-byte line size L2 cache 2048 KBytes, 16-way set associative, 64-byte line size L2 cache 2048 KBytes, 16-way set associative, 64-byte line size L2 cache 2048 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, x86-64, AMD-V, AES, AVX, XOP Instructions sets MMX (+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, x86-64, AMD-V, AES, AVX, XOP Instructions sets MMX (+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, x86-64, AMD-V, AES, AVX, XOP Instructions sets MMX (+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, x86-64, AMD-V, AES, AVX, XOP Instructions sets MMX (+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, x86-64, AMD-V, AES, AVX, XOP Instructions sets MMX (+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, x86-64, AMD-V, AES, AVX, XOP Instructions sets MMX (+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, x86-64, AMD-V, AES, AVX, XOP Instructions sets MMX (+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, x86-64, AMD-V, AES, AVX, XOP Package Package Package Package Package Package Package Package Temperature 0 48°C (118°F) [0x30] (CPU) Temperature 1 38°C (100°F) [0x26] (Mainboard) Temperature 0 42°C (107°F) [0x2A] (SB) Temperature 1 51°C (123°F) [0x33] (NB)
Athlon II X2 260 See updated results (Windows XP SP3) two posts below. Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 51.33 fps, 3909.84 kb/s encoded 1442 frames, 55.80 fps, 3909.86 kb/s encoded 1442 frames, 55.60 fps, 3909.87 kb/s encoded 1442 frames, 55.70 fps, 3909.81 kb/s Pass 2 ------ encoded 1442 frames, 10.81 fps, 3962.30 kb/s encoded 1442 frames, 10.72 fps, 3962.24 kb/s encoded 1442 frames, 10.82 fps, 3962.73 kb/s encoded 1442 frames, 10.75 fps, 3962.60 kb/s System Details -------------- Name AMD Athlon II X2 260 Codename Regor Specification AMD Athlon(tm) II X2 260 Processor Specification PC3-12800 Specification PC3-12800 Core Stepping DA-C3 Technology 45 nm Stock frequency 3200 MHz Core Speed 3214.9 MHz FID range 4.0x - 16.0x Northbridge NVIDIA GeForce 7025 rev. A3 Southbridge NVIDIA nForce 630a rev. A2 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 12 RAS# Precharge (tRP) 12 Cycle Time (tRAS) 30 Command Rate (CR) 2T Command Rate 2T Command Rate 2T Memory Frequency 669.8 MHz (3:10) Memory Type DDR3 Memory Size 4096 MBytes Channels Dual, (Unganged) Windows Version Microsoft Windows XP Professional Service Pack 2 (Build 2600) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 2 x 1024 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V Package Socket AM3 (938) Package Type 0x1 Temperature 0 26°C (78°F) [0x1A] (SYSTIN) Temperature 1 38°C (99°F) [0x4B] (CPUTIN) Temperature 2 36°C (96°F) [0x48] (AUXTIN)
Pass 1 ------ encoded 1442 frames, 46.19 fps, 3909.89 kb/s encoded 1442 frames, 46.61 fps, 3909.89 kb/s encoded 1442 frames, 46.71 fps, 3909.86 kb/s encoded 1442 frames, 46.77 fps, 3909.86 kb/s Pass 2 ------ encoded 1442 frames, 8.74 fps, 3962.42 kb/s encoded 1442 frames, 8.71 fps, 3962.58 kb/s encoded 1442 frames, 8.67 fps, 3962.26 kb/s encoded 1442 frames, 8.75 fps, 3962.38 kb/s System Details -------------- Intel Core2 CPU 6300 Freq : 2666.89 MHz (380.98 * 7)
Athlon II X2 260 - revised results The XP SP2 fresh install was probably doing some background updating or something that lowered the first pass fps. Here's the results with SP3 installed and no background activity AFAIK: Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 55.53 fps, 3909.83 kb/s encoded 1442 frames, 55.73 fps, 3909.81 kb/s encoded 1442 frames, 55.93 fps, 3909.80 kb/s encoded 1442 frames, 55.87 fps, 3909.77 kb/s Pass 2 ------ encoded 1442 frames, 10.85 fps, 3962.68 kb/s encoded 1442 frames, 10.83 fps, 3962.71 kb/s encoded 1442 frames, 10.82 fps, 3962.13 kb/s encoded 1442 frames, 10.85 fps, 3962.54 kb/s Name AMD Athlon II X2 260 Codename Regor Specification AMD Athlon(tm) II X2 260 Processor Specification PC3-12800 Specification PC3-12800 Core Stepping DA-C3 Technology 45 nm Stock frequency 3200 MHz Core Speed 3214.9 MHz FID range 4.0x - 16.0x Northbridge NVIDIA GeForce 7025 rev. A3 Southbridge NVIDIA nForce 630a rev. A2 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 12 RAS# Precharge (tRP) 12 Cycle Time (tRAS) 30 Command Rate (CR) 2T Command Rate 2T Command Rate 2T Memory Frequency 669.8 MHz (3:10) Memory Type DDR3 Memory Size 4096 MBytes Channels Dual, (Unganged) Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 2 x 1024 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V Package Socket AM3 (938) Package Type 0x1 Temperature 0 28°C (82°F) [0x1C] (SYSTIN) Temperature 1 39°C (102°F) [0x4E] (CPUTIN) Temperature 2 36°C (96°F) [0x48] (AUXTIN) Motherboard: ASrock N68C-S UCC (cheap-o AM2+ IGP MB) Ram: CORSAIR 2x2GB DDR3 1600MHZ CLASSIC / XMS3 (CL9) @1333Mhz. Results for a plain vanilla overclock @3600: Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 63.25 fps, 3909.84 kb/s encoded 1442 frames, 63.30 fps, 3909.84 kb/s encoded 1442 frames, 63.30 fps, 3909.84 kb/s encoded 1442 frames, 63.30 fps, 3909.84 kb/s Pass 2 ------ encoded 1442 frames, 12.16 fps, 3962.12 kb/s encoded 1442 frames, 12.17 fps, 3962.62 kb/s encoded 1442 frames, 12.15 fps, 3962.67 kb/s encoded 1442 frames, 12.12 fps, 3962.66 kb/s System Details -------------- Name AMD Athlon II X2 260 Codename Regor Specification AMD Athlon(tm) II X2 260 Processor Specification PC3-12800 Specification PC3-12800 Core Stepping DA-C3 Technology 45 nm Stock frequency 3200 MHz Core Speed 3600.0 MHz FID range 4.0x - 16.0x Northbridge NVIDIA GeForce 7025 rev. A3 Southbridge NVIDIA nForce 630a rev. A2 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 12 RAS# Precharge (tRP) 12 Cycle Time (tRAS) 30 Command Rate (CR) 2T Command Rate 2T Command Rate 2T Memory Frequency 750.0 MHz (3:10) Memory Type DDR3 Memory Size 4096 MBytes Channels Dual, (Unganged) Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 2 x 1024 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V Package Socket AM3 (938) Package Type 0x1 Temperature 0 28°C (82°F) [0x1C] (SYSTIN) Temperature 1 42°C (106°F) [0x53] (CPUTIN) Temperature 2 36°C (95°F) [0x47] (AUXTIN)
Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 44.74 fps, 3909.81 kb/s encoded 1442 frames, 45.17 fps, 3909.86 kb/s encoded 1442 frames, 45.40 fps, 3909.87 kb/s encoded 1442 frames, 45.09 fps, 3909.86 kb/s Pass 2 ------ encoded 1442 frames, 7.96 fps, 3962.72 kb/s encoded 1442 frames, 7.96 fps, 3962.70 kb/s encoded 1442 frames, 7.96 fps, 3962.69 kb/s encoded 1442 frames, 7.97 fps, 3962.56 kb/s System Details -------------- Name AMD Athlon 64 X2 5050e Codename Specification AMD Athlon(tm) Dual Core Processor 5050e Core Stepping DH-G2 Technology 65 nm Manufacturer (ID) A-Data Technology (7F7F7F7FCB000000) Manufacturer (ID) A-Data Technology (7F7F7F7FCB000000) Stock frequency 2600 MHz Core Speed 3200 MHz Northbridge AMD 780G rev. 00 Southbridge AMD SB700 rev. 00 CAS# latency (CL) 4.0 RAS# to CAS# delay (tRCD) 4 RAS# Precharge (tRP) 4 Cycle Time (tRAS) 12 Command Rate (CR) 1T Memory Frequency 408.6 MHz (CPU/7) Memory Type DDR2 Memory Size 4096 MBytes Channels Dual Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 2 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64, AMD-V Package Socket AM2 (940) Temperature 0 36°C (96°F) [0x24] (TMPIN0) Temperature 1 118°C (244°F) [0x76] (TMPIN1) Temperature 2 30°C (85°F) [0x1E] (TMPIN2)
Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 102.77 fps, 3913.44 kb/s encoded 1442 frames, 102.55 fps, 3913.44 kb/s encoded 1442 frames, 102.54 fps, 3913.44 kb/s encoded 1442 frames, 102.54 fps, 3913.44 kb/s Pass 2 ------ encoded 1442 frames, 28.76 fps, 3963.74 kb/s encoded 1442 frames, 28.87 fps, 3962.12 kb/s encoded 1442 frames, 28.83 fps, 3963.78 kb/s encoded 1442 frames, 28.69 fps, 3963.34 kb/s System Details -------------- Name AMD Phenom II X6 1055T Codename Thuban Specification AMD Phenom(tm) II X6 1055T Processor Core Stepping PH-E0 Technology 45 nm Stock frequency 2800 MHz Core Speed 2805.6 MHz FID range 4.0x - 16.5x Northbridge AMD 890GX rev. 00 Southbridge AMD SB850 rev. 40 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Command Rate (CR) 2T Memory Frequency 668.0 MHz (3:10) Memory Type DDR3 Memory Size 4096 MBytes Channels Single Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600) Number of processors 1 Number of threads 6 Number of threads 6 (max 6) L2 cache 6 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V Package Socket AM3 (938) Package Type 0x1 Temperature 0 31°C (87°F) [0x1F] (SYSTIN) Temperature 1 55°C (130°F) [0x6E] (CPUTIN) Temperature 2 75°C (166°F) [0x95] (AUXTIN)
Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 148.38 fps, 3911.79 kb/s encoded 1442 frames, 148.14 fps, 3911.79 kb/s encoded 1442 frames, 147.90 fps, 3911.79 kb/s encoded 1442 frames, 148.61 fps, 3911.79 kb/s Pass 2 ------ encoded 1442 frames, 32.74 fps, 3961.06 kb/s encoded 1442 frames, 32.78 fps, 3960.72 kb/s encoded 1442 frames, 32.77 fps, 3961.05 kb/s encoded 1442 frames, 32.81 fps, 3960.79 kb/s System Details -------------- Processor 1 ID = 0 Number of cores 5 (max 6) Number of threads 5 (max 5) Name AMD Phenom II X6 1600T Codename Thuban Specification AMD Six-Core Processor Package Socket AM3 (938) CPUID F.A.0 Extended CPUID 10.A Brand ID 9 Core Stepping PH-E0 Technology 45 nm TDP Limit 161 Watts Core Speed 1000.0 MHz Multiplier x FSB 4.0 x 250.0 MHz HT Link speed 2499.9 MHz (AMD Phenom II x4 960T 3.0 GHz Turbo to 3.4 GHz)
Update results Memory Timings changed ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 147.66 fps, 3911.79 kb/s encoded 1442 frames, 148.14 fps, 3911.79 kb/s encoded 1442 frames, 147.43 fps, 3911.79 kb/s encoded 1442 frames, 147.43 fps, 3911.79 kb/s Pass 2 ------ encoded 1442 frames, 32.80 fps, 3961.02 kb/s encoded 1442 frames, 32.84 fps, 3960.98 kb/s encoded 1442 frames, 32.85 fps, 3960.88 kb/s encoded 1442 frames, 32.74 fps, 3961.18 kb/s System Details -------------- Name AMD Phenom II X6 1600T Codename Thuban Specification AMD Six-Core Processor Core Stepping PH-E0 Technology 45 nm manufacturer Gigabyte Technology Co., Ltd. vendor Gigabyte Technology Co., Ltd. manufacturer Gigabyte Technology Co., Ltd. Stock frequency 4000 MHz Core Speed 4000.1 MHz Northbridge AMD 880G rev. 00 Southbridge AMD SB850 rev. 40 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Command Rate (CR) 2T Memory Frequency 800.0 MHz (1:4) Memory Type DDR3 Memory Size 4096 MBytes Channels Dual, (Unganged) Windows Version Microsoft Windows 7 (6.1) Home Premium Edition Service Pack 1 (Build 7601) Number of processors 1 Number of threads 5 Number of threads 5 (max 5) L2 cache 5 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V Package Socket AM3 (938) Package Type 0x1 Temperature 0 31°C (87°F) [0x1F] (TMPIN0) Temperature 1 31°C (87°F) [0x1F] (TMPIN1) Temperature 2 39°C (102°F) [0x27] (TMPIN2)
Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 198.29 fps, 3913.50 kb/s encoded 1442 frames, 199.03 fps, 3913.50 kb/s encoded 1442 frames, 199.75 fps, 3913.50 kb/s encoded 1442 frames, 199.83 fps, 3913.50 kb/s Pass 2 ------ encoded 1442 frames, 62.89 fps, 3955.80 kb/s encoded 1442 frames, 63.06 fps, 3956.68 kb/s encoded 1442 frames, 63.18 fps, 3955.56 kb/s encoded 1442 frames, 62.82 fps, 3957.33 kb/s System Details -------------- Name Intel Processor product System Product Name Codename Sandy Bridge-EP Specification Intel(R) Core(TM) i7-3930K CPU @ 3.20GHz (TurboV EVO OC @ 4.250GHz) Core Stepping Technology 32 nm Stock frequency 3200 MHz Core Speed 1500.0 MHz Northbridge Intel ID3C00 rev. 06 Southbridge Intel ID1D41 rev. 05 Memory Type Memory Size 32744 MBytes Windows Version Microsoft Windows 7 (6.1) Ultimate Edition Service Pack 1 (Build 7601) Number of processors 1 Number of threads 12 Number of threads 12 (max 32) L2 cache 6 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX Package (platform ID) (0x2) Temperature 0 24°C (75°F) [0x18] (SYSTIN) Temperature 1 64°C (147°F) [0x80] (CPUTIN) Temperature 2 0°C (32°F) [0x0] (AUXTIN)
Intel Core i7 960 @4,2GHz Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 147.49 fps, 3911.63 kb/s encoded 1442 frames, 155.42 fps, 3911.63 kb/s encoded 1442 frames, 155.39 fps, 3911.63 kb/s encoded 1442 frames, 153.34 fps, 3911.63 kb/s Pass 2 ------ encoded 1442 frames, 38.44 fps, 3958.74 kb/s encoded 1442 frames, 38.40 fps, 3960.30 kb/s encoded 1442 frames, 38.80 fps, 3959.70 kb/s encoded 1442 frames, 38.66 fps, 3958.06 kb/s System Details -------------- Name Intel Core i7 960 product System Product Name Codename Bloomfield Specification Intel(R) Core(TM) i7 CPU 960 @ 3.20GHz Core Stepping D0 Technology 45 nm Stock frequency 3200 MHz Core Speed 4209.4 MHz Northbridge Intel X58 rev. 13 Southbridge Intel 82801JR (ICH10R) rev. 00 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Command Rate (CR) 1T Memory Frequency 801.8 MHz (2:8) Memory Type DDR3 Memory Size 6144 MBytes Channels Triple Windows Version Microsoft Windows 7 (6.1) Ultimate Edition Service Pack 1 (Build 7601) Number of processors 1 Number of threads 8 Number of threads 8 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x Package (platform ID) Socket 1366 LGA (0x1) Temperature 0 31°C (87°F) [0x1F] (SYSTIN) Temperature 1 54°C (129°F) [0x6C] (CPUTIN) Temperature 2 34°C (92°F) [0x43] (AUXTIN)
Tech ARP - x264 HD Benchmark Ver. 4.0 50% improvement 32-bit r2106 vs. 64-bit r2146: x264 v2145 64bit bug? - Doom9's Forum Is there any plan to publish a new version?
Hi Adrian. Remember me? We had some minor discussion, starting at post №120. I made my own version of x264 benchmark using 2.5 minute SD source and CRF, preset slower. Take a look if u want. Let me know what u think. mediafire.com/?2jnb8cmpz1n4d5u
Oh really? How's that? Why is my i5 fully loaded with this bench then? Are u sure u know the subject well enough to post things like that?
