x264benchmark64v2 Results: --- preset medium encoded 225 frames, 13.88 fps, 75194.18 kb/s encoded 225 frames, 13.88 fps, 75194.18 kb/s encoded 225 frames, 13.96 fps, 75194.18 kb/s --- preset veryslow encoded 225 frames, 1.93 fps, 72179.81 kb/s encoded 225 frames, 1.96 fps, 72179.81 kb/s encoded 225 frames, 1.94 fps, 72179.81 kb/s --- \22f6f4867f99c1d357c6468078cd9d19 *..\\benchmark.bat 6ffb95ead8f0cdb19b012ae21166f341 *x264.exe e511c3c844e212026d7f271822a7954a *ffmpeg.exe 94301ae0fb9882f8c7fb56fd00e7c00a *park_joy_1080p50_225f.mkv 15323aae225c384496f98f8a5bf4d36d *video.y4m 8eba73dc132543b425e5026c64047a55 *cpuz64.exe --- x264 core:120 r2164 da19765 x264 [info]: using cpu capabilities: MMX2 SSE2Fast FastShuffle SSEMisalign LZCNT --- CPU-Z version 1.59 Name AMD Phenom II X6 1600T Codename Thuban Specification AMD Six-Core Processor Core Stepping PH-E0 Technology 45 nm manufacturer Gigabyte Technology Co., Ltd. vendor Gigabyte Technology Co., Ltd. manufacturer Gigabyte Technology Co., Ltd. Stock frequency 4000 MHz Core Speed 4100.0 MHz Northbridge AMD 880G rev. 00 Southbridge AMD SB850 rev. 40 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Command Rate (CR) 1T Memory Frequency 820.0 MHz (1:4) Memory Type DDR3 Memory Size 8190 MBytes Channels Dual, (Unganged) Windows Version Microsoft Windows 7 (6.1) Home Premium Edition Service Pack 1 (Build 7601) Voltage 0 1.46 Volts [0x5B] (CPU VCORE) Number of processors 1 Number of threads 5 Number of threads 5 (max 5) L2 cache 5 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V Package Socket AM3 (938) Package Type 0x1 Temperature 0 25°C (77°F) [0x19] (TMPIN0) Temperature 1 40°C (104°F) [0x28] (TMPIN1) Temperature 2 52°C (125°F) [0x34] (TMPIN2)
Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 151.53 fps, 3911.79 kb/s encoded 1442 frames, 151.53 fps, 3911.79 kb/s encoded 1442 frames, 151.79 fps, 3911.79 kb/s encoded 1442 frames, 151.28 fps, 3911.79 kb/s Pass 2 ------ encoded 1442 frames, 33.66 fps, 3961.12 kb/s encoded 1442 frames, 33.44 fps, 3960.89 kb/s encoded 1442 frames, 33.56 fps, 3961.11 kb/s encoded 1442 frames, 33.60 fps, 3960.69 kb/s
Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 172.47 fps, 3912.26 kb/s encoded 1442 frames, 172.78 fps, 3912.26 kb/s encoded 1442 frames, 172.14 fps, 3912.26 kb/s encoded 1442 frames, 173.42 fps, 3912.26 kb/s Pass 2 ------ encoded 1442 frames, 37.51 fps, 3960.77 kb/s encoded 1442 frames, 37.61 fps, 3961.62 kb/s encoded 1442 frames, 37.44 fps, 3961.28 kb/s encoded 1442 frames, 37.53 fps, 3961.69 kb/s System Details -------------- Name Intel Core i5 Codename Sandy Bridge Specification Intel(R) Core(TM) i5-2550K CPU @ 3.40GHz Specification PC3-12800 Specification PC3-12800 Core Stepping D2 Technology 32 nm manufacturer Gigabyte Technology Co., Ltd. vendor Gigabyte Technology Co., Ltd. manufacturer Gigabyte Technology Co., Ltd. Stock frequency 3400 MHz Core Speed 4464.4 MHz Northbridge Intel Sandy Bridge rev. 09 Southbridge Intel ID1C44 rev. 05 CAS# latency (CL) 6.0 RAS# to CAS# delay (tRCD) 6 RAS# Precharge (tRP) 6 Cycle Time (tRAS) 20 Command Rate (CR) 2T Command Rate 2T Command Rate 2T Memory Frequency 830.6 MHz (1:6) Memory Type DDR3 Memory Size 4096 MBytes Windows Version Microsoft Windows 7 (6.1) Ultimate Edition Service Pack 1 (Build 7601) Number of processors 1 Number of threads 4 Number of threads 4 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX Package (platform ID) Socket 1155 LGA (0x1) Temperature 0 31°C (87°F) [0x1F] (TMPIN0) Temperature 1 25°C (76°F) [0x19] (TMPIN1) Temperature 2 43°C (109°F) [0x2B] (TMPIN2)
That is a powerful overclock with high voltage. What are your load temps. What water cooler are you using?
x264benchmark64v2 Results: --- preset medium encoded 225 frames, 7.15 fps, 75238.19 kb/s encoded 225 frames, 7.77 fps, 75238.19 kb/s encoded 225 frames, 7.86 fps, 75238.19 kb/s --- preset veryslow encoded 225 frames, 1.08 fps, 72184.28 kb/s encoded 225 frames, 1.14 fps, 72184.28 kb/s encoded 225 frames, 1.13 fps, 72184.28 kb/s --- \22f6f4867f99c1d357c6468078cd9d19 *..\\benchmark.bat 6ffb95ead8f0cdb19b012ae21166f341 *x264.exe e511c3c844e212026d7f271822a7954a *ffmpeg.exe 94301ae0fb9882f8c7fb56fd00e7c00a *park_joy_1080p50_225f.mkv 15323aae225c384496f98f8a5bf4d36d *video.y4m 8eba73dc132543b425e5026c64047a55 *cpuz64.exe --- x264 core:120 r2164 da19765 x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 Cache64 --- CPU-Z version 1.59 Name Intel Core 2 Quad Q6600 product System Product Name Codename Kentsfield Specification Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz Core Stepping G0 Technology 65 nm Stock frequency 2400 MHz Core Speed 3000.6 MHz FID range 6.0x - 9.0x Northbridge ATI Xpress 1250 (RS600) rev. 00 Southbridge ATI SB600 rev. 00 CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 18 Command Rate (CR) 2T Memory Frequency 400.0 MHz () Memory Type DDR2 Memory Size 3840 MBytes Channels Dual Windows Version Microsoft Windows 7 (6.1) Home Premium Edition Service Pack 1 (Build 7601) Max VID 1.238 V Voltage 0 1.11 Volts [0x8B] (CPU VCORE) Number of processors 1 Number of threads 4 Number of threads 4 (max 4) L2 cache 2 x 4096 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T, VT-x Package (platform ID) Socket 775 LGA (0x4) Temperature 0 39°C (102°F) [0x27] (SYSTIN) Temperature 1 57°C (133°F) [0x71] (CPUTIN) Temperature 2 72°C (160°F) [0x8F] (AUXTIN) Temperature 0 56°C (132°F) [0xCDC] (THRM) Same computer but 32 bit application Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 76.47 fps, 3912.26 kb/s encoded 1442 frames, 77.36 fps, 3912.26 kb/s encoded 1442 frames, 76.29 fps, 3912.26 kb/s encoded 1442 frames, 76.63 fps, 3912.26 kb/s Pass 2 ------ encoded 1442 frames, 18.59 fps, 3961.69 kb/s encoded 1442 frames, 18.64 fps, 3962.09 kb/s encoded 1442 frames, 18.56 fps, 3961.74 kb/s encoded 1442 frames, 18.63 fps, 3961.36 kb/s
I was pointed here by a member on the Overclock3d forums and did the test and here are my result's. Well ran it at 4.8ghz and at 5.2ghz and didn't need to swap the fans from 5v to 12v either which wasn't to bad. 4.8ghz result's x264 HD BENCHMARK 4.0 RESULTS Please do NOT compare it with older versions of the benchmark! Please copy/paste everything below the line to to report your data ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 191.25 fps, 3911.63 kb/s encoded 1442 frames, 188.50 fps, 3911.63 kb/s encoded 1442 frames, 188.74 fps, 3911.63 kb/s encoded 1442 frames, 187.52 fps, 3911.63 kb/s Pass 2 ------ encoded 1442 frames, 49.60 fps, 3959.61 kb/s encoded 1442 frames, 49.76 fps, 3959.86 kb/s encoded 1442 frames, 49.77 fps, 3959.26 kb/s encoded 1442 frames, 48.63 fps, 3959.61 kb/s System Details It didn't do the system information though on any of the runs which is weird, maybe it has something to do with CPUZ not loading up at the end had to start it manually for this result and didn't bother loading it for the next run. 5.2ghz result's x264 HD BENCHMARK 4.0 RESULTS Please do NOT compare it with older versions of the benchmark! Please copy/paste everything below the line to to report your data ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 207.33 fps, 3911.63 kb/s encoded 1442 frames, 202.07 fps, 3911.63 kb/s encoded 1442 frames, 203.93 fps, 3911.63 kb/s encoded 1442 frames, 204.86 fps, 3911.63 kb/s Pass 2 ------ encoded 1442 frames, 52.61 fps, 3959.57 kb/s encoded 1442 frames, 52.57 fps, 3959.38 kb/s encoded 1442 frames, 53.26 fps, 3960.14 kb/s encoded 1442 frames, 53.11 fps, 3959.96 kb/s System Details -------------- My System spec's are Intel Core I7 2700K MSI P67A-GD53 8gb Corsair Vengence DDR3 1600MHZ Cannot post link's as I don't have the 5 post's needed but, I do have screenshot's from when I did the test's. At 4.8ghz (1.410v) Max Core Temp's were: 52c 59c 57c 54c At 5.2ghz (1.525v) Max Core Temp's were: 63c 70c 68c 65c
Adrian Wong, I sent you an email a few days ago. biffzinker and Madwolf, x264benchmark64(v2) is very incomplete. I did not mean it for general use. However, thanks for testing.
You did?? I didn't get it. Let me check my spam box. BTW, Dashken's helping me with the benchmark. I think he got it to work but there's still some work left to do. Also, guys, we may possibly come up with both 32-bit and 64-bit versions, but not sure if it's what we need. Should we just go with one 64-bit benchmark? Or should we do both 32-bit and 64-bit?
It is also technically possible to make a benchmark, which detects the type of Windows. That is fine with me.
Off-the-shelf motherboard and CPU Tested on a Off-the-shelf motherboard with standard nonoverclocked quad core CPU on 1600 DDR3. Changed the run benchmark script to handle Windows 7 Enterprise : If Instr(objItem.Caption, "Vista") Then into If Instr(objItem.Caption, "Windows 7") Then HWMonitorPro64.exe case temp was 37 celcius, CPU was 70 celcius (max) Temperature 0 37°C (98°F) [0x25] (SYSTIN) Temperature 1 64°C (147°F) [0x80] (CPUTIN) 4 GB main memory, slow harddisk Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 168.69 fps, 3911.63 kb/s encoded 1442 frames, 166.86 fps, 3911.63 kb/s encoded 1442 frames, 167.15 fps, 3911.63 kb/s encoded 1442 frames, 168.07 fps, 3911.63 kb/s Pass 2 ------ encoded 1442 frames, 43.11 fps, 3959.53 kb/s encoded 1442 frames, 43.22 fps, 3959.78 kb/s encoded 1442 frames, 43.15 fps, 3960.13 kb/s encoded 1442 frames, 43.17 fps, 3958.93 kb/s
Time to revisit this thread (at least) one last time before Ivy Bridge comes along! Anyways, here are my results - specs can be taken from the sig as it didn't successfully retrieve them when the benchmark-run ended. For those interested in some nostalgia, old results can be found here and the specs were this circa 2005 gaming rig: DFI LANParty UT nF4 SLI-DR Expert, Rev. A02 | AMD Athlon64 X2 3800+ @ 2430MHz w/ Zalman CNPS9500 LED | OCZ EL PC-4000 2x1024 Gold Ed. Kit @ 3-4-3-7-1T @ 486MHz DDR | 2 x Leadtek WinFast PX7800 GTX TDH MyVIVO 256MB | Creative Sound Blaster X-Fi Elite Pro | 1xWDC SE 200GB | 2xWDC SE 160GB @ RAID-0 | Lite-On DVD/CD-RW SOHC5232K | NEC DVD-RW ND-4550A | Enermax Liberty 620W | Antec Performance One P160 | Dell UltraSharp 24" 2407WFP Rev. A02 Regards,
Hi, At the moment I have a Phenom II x4 940, but I'm thinking about upgrading my system in the next weeks. Could someone with a Core i5 2500K run the benchmark (x264 HD BENCHMARK 4.0) WITH activated Turbo Boost and post the results here? That would be very nice. I just want to know the real speed difference between my actual cpu and the 2500K in x264 encoding.
Processors Information ------------------------------------------------------------------------- Processor 1 ID = 0 Number of cores 6 (max 16) Number of threads 12 (max 32) Name Intel Processor Codename Sandy Bridge-EP Specification Intel(R) Core(TM) i7-3930K CPU @ 3.20GHz Package (platform ID) (0x2) CPUID 6.D.7 Extended CPUID 6.2D Core Stepping Technology 32 nm TDP Limit 130 Watts Core Speed 4499.9 MHz Multiplier x FSB 45.0 x 100.0 MHz Stock frequency 3200 MHz Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX L1 Data cache 6 x 32 KBytes, 8-way set associative, 64-byte line size L1 Instruction cache 6 x 32 KBytes, 8-way set associative, 64-byte line size L2 cache 6 x 256 KBytes, 8-way set associative, 64-byte line size L3 cache 12 MBytes, 16-way set associative, 64-byte line size FID/VID Control yes Turbo Mode supported, enabled Max non-turbo ratio 32x Max turbo ratio 57x Max efficiency ratio 12x Min Power 53 Watts O/C bins unlimited Hardware Monitors ------------------------------------------------------------------------- Hardware monitor Nuvoton NCT6776 Voltage 0 1.34 Volts [0xA8] (CPU VCORE) Voltage 1 1.02 Volts [0x7F] (VIN1) Voltage 2 3.28 Volts [0xCD] (AVCC) Voltage 3 3.26 Volts [0xCC] (3VCC) Voltage 4 1.00 Volts [0x7D] (VIN4) Voltage 6 1.49 Volts [0xBA] (VIN6) Temperature 0 42°C (107°F) [0x2A] (SYSTIN) Temperature 1 64°C (147°F) [0x80] (CPUTIN) Fan 0 988 RPM [0x3DC] (SYSFANIN) Fan 1 2160 RPM [0x870] (CPUFANIN) Fan 3 4981 RPM [0x1375] (AUXFANIN1) Register space LPC, base address = 0x0290 Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 196.56 fps, 3913.50 kb/s encoded 1442 frames, 194.71 fps, 3913.50 kb/s encoded 1442 frames, 193.71 fps, 3913.50 kb/s encoded 1442 frames, 196.59 fps, 3913.50 kb/s Pass 2 ------ encoded 1442 frames, 62.24 fps, 3957.11 kb/s encoded 1442 frames, 62.97 fps, 3957.42 kb/s encoded 1442 frames, 63.11 fps, 3955.34 kb/s encoded 1442 frames, 62.90 fps, 3955.52 kb/s
Finally replaced the Ol' P4-2.4. Figured I'd give the new rig a spin. . Hmmm... Where did they move the Turbo Mode Turn Off option to? Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 170.03 fps, 3911.63 kb/s encoded 1442 frames, 169.25 fps, 3911.63 kb/s encoded 1442 frames, 163.98 fps, 3911.63 kb/s encoded 1442 frames, 166.74 fps, 3911.63 kb/s Pass 2 ------ encoded 1442 frames, 43.15 fps, 3960.34 kb/s encoded 1442 frames, 41.46 fps, 3960.78 kb/s encoded 1442 frames, 42.45 fps, 3959.76 kb/s encoded 1442 frames, 42.46 fps, 3959.03 kb/s System Details -------------- Name Intel Processor product System Product Name Codename Specification Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz Core Stepping Core Speed 3418.9 MHz Northbridge Intel ID0150 rev. 09 Southbridge Intel ID1E44 rev. 04 Memory Type Memory Size 16272 MBytes Windows Version Microsoft Windows 7 (6.1) Ultimate Edition Service Pack 1 (Build 7601) Number of processors 1 Number of threads 8 Number of threads 8 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX Package Temperature 0 32°C (89°F) [0x20] (SYSTIN) Temperature 1 52°C (125°F) [0x68] (CPUTIN) Temperature 0 28°C (82°F) [0xBC2] (TZ00) Temperature 1 30°C (85°F) [0xBD6] (TZ01)
Made available on April 28th here in US. I would imagine that we should see some price drop on the SB stuff.
i7-2600k @4.5 ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 164.99 fps, 3911.63 kb/s encoded 1442 frames, 167.48 fps, 3911.63 kb/s encoded 1442 frames, 166.90 fps, 3911.63 kb/s encoded 1442 frames, 164.05 fps, 3911.63 kb/s Pass 2 ------ encoded 1442 frames, 44.75 fps, 3960.32 kb/s encoded 1442 frames, 44.71 fps, 3959.91 kb/s encoded 1442 frames, 44.74 fps, 3959.11 kb/s encoded 1442 frames, 44.81 fps, 3958.77 kb/s System Details -------------- Name Intel Core i7 2600K Codename Sandy Bridge Specification Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz Core Stepping D2 Technology 32 nm Stock frequency 3400 MHz Core Speed 4499.9 MHz Northbridge Intel Sandy Bridge rev. 09 Southbridge Intel ID1E44 rev. 04 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Command Rate (CR) 2T Memory Frequency 666.7 MHz (1:5) Memory Type DDR3 Memory Size 32722 MBytes Windows Version Microsoft Windows 7 (6.1) Service Pack 1 (Build 7601) Number of processors 1 Number of threads 8 Number of threads 8 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX Package (platform ID) Socket 1155 LGA (0x1) Temperature 0 45°C (112°F) [0x2D] (TMPIN0) Temperature 1 76°C (168°F) [0x4C] (TMPIN1) Temperature 2 31°C (87°F) [0x1F] (TMPIN2) Temperature 0 28°C (82°F) [0xBC2] (TZ00) Temperature 1 30°C (85°F) [0xBD6] (TZ01)
