Hello! First post... E3 Xeon in a Gigabyte board ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 135.63 fps, 3911.63 kb/s encoded 1442 frames, 135.49 fps, 3911.63 kb/s encoded 1442 frames, 137.65 fps, 3911.63 kb/s encoded 1442 frames, 136.90 fps, 3911.63 kb/s Pass 2 ------ encoded 1442 frames, 34.05 fps, 3958.74 kb/s encoded 1442 frames, 33.85 fps, 3959.96 kb/s encoded 1442 frames, 33.85 fps, 3958.43 kb/s encoded 1442 frames, 33.93 fps, 3959.19 kb/s System Details -------------- Name Intel Core i7 Codename Sandy Bridge Specification Intel(R) Xeon(R) CPU E31230 @ 3.20GHz Core Stepping D2 Technology 32 nm Manufacturer (ID) Crucial Technology (7F7F7F7F7F9B0000) Manufacturer (ID) Micron Technology (2C00000000000000) Manufacturer (ID) Crucial Technology (7F7F7F7F7F9B0000) Manufacturer (ID) Micron Technology (2C00000000000000) manufacturer Gigabyte Technology Co., Ltd. vendor Gigabyte Technology Co., Ltd. manufacturer Gigabyte Technology Co., Ltd. Stock frequency 3200 MHz Core Speed 1596.3 MHz Northbridge Intel ID0108 rev. 09 Southbridge Intel ID1C44 rev. 05 Memory Type Memory Size 8192 MBytes Windows Version Microsoft Windows 7 (6.1) Ultimate Edition Service Pack 1 (Build 7601) Number of processors 1 Number of threads 8 Number of threads 8 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX Package (platform ID) Socket 1155 LGA (0x1) Temperature 0 36°C (96°F) [0x24] (TMPIN0) Temperature 1 25°C (76°F) [0x19] (TMPIN1) Temperature 2 30°C (85°F) [0x1E] (TMPIN2)
Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 198.32 fps, 3911.63 kb/s encoded 1442 frames, 198.16 fps, 3911.63 kb/s encoded 1442 frames, 198.05 fps, 3911.63 kb/s encoded 1442 frames, 196.35 fps, 3911.63 kb/s Pass 2 ------ encoded 1442 frames, 51.45 fps, 3959.05 kb/s encoded 1442 frames, 51.34 fps, 3958.57 kb/s encoded 1442 frames, 51.31 fps, 3959.66 kb/s encoded 1442 frames, 51.38 fps, 3959.80 kb/s System Details -------------- Asus P8Z77-V Deluxe 3770K 4700 DRAM 1600 8,8,8,24 NH-D14 Cooler Speed-Step On IS this good???
Thanks for the results! Keep 'em coming! BTW, Dashken's working on the new version. Hopefully, it will be done soon!
I made some improvements to my version. Now it works on 32-bit and 64-bit Windows: http://www.nbl.fi/~nbl3388/x264benchmark 0.1.zip (69 MB). Maybe in it is something useful that can be used in the new version. Some results (in Finnish): Juce's x264 Benchmark - MuroBBS - Plaza
I5 2500K 4.4Ghz Hello, first post before new overclocking. I5 2500k 4401.2Mhz (don't know why is just 1600.2Mhz in the report. got same problem of wrong core speed in 3dmark vantage, maybye someone could help me to fix it?) Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 182.28 fps, 3912.26 kb/s encoded 1442 frames, 182.74 fps, 3912.26 kb/s encoded 1442 frames, 179.51 fps, 3912.26 kb/s encoded 1442 frames, 180.91 fps, 3912.26 kb/s Pass 2 ------ encoded 1442 frames, 36.63 fps, 3961.40 kb/s encoded 1442 frames, 36.16 fps, 3961.59 kb/s encoded 1442 frames, 36.13 fps, 3961.26 kb/s encoded 1442 frames, 36.55 fps, 3961.60 kb/s System Details -------------- Name Intel Core i5 2500K product System Product Name Codename Sandy Bridge Specification Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz Specification PC3-12800 Specification PC3-12800 Core Stepping D2 Technology 32 nm Stock frequency 3300 MHz Core Speed 1600.2 MHz Northbridge Intel Sandy Bridge rev. 09 Southbridge Intel ID1C44 rev. 05 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Command Rate (CR) 2T Command Rate 2T Command Rate 2T Memory Frequency 800.1 MHz (1:6) Memory Type DDR3 Memory Size 8192 MBytes Windows Version Microsoft Windows 7 (6.1) Ultimate Edition Service Pack 1 (Build 7601) Number of processors 1 Number of threads 4 Number of threads 4 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX Package (platform ID) Socket 1155 LGA (0x1) Temperature 0 28°C (82°F) [0x1C] (SYSTIN) Temperature 1 0°C (32°F) [0x0] (CPUTIN) Temperature 0 28°C (82°F) [0xBC2] (TZ00) Temperature 1 30°C (85°F) [0xBD6] (TZ01)
Juce, FYI, we completed the new version! We are just running some final tests and preparing the HTML pages before releasing the benchmark.
980X - default Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 151.30 fps, 3913.50 kb/s encoded 1442 frames, 152.19 fps, 3913.50 kb/s encoded 1442 frames, 152.56 fps, 3913.50 kb/s encoded 1442 frames, 152.33 fps, 3913.50 kb/s Pass 2 ------ encoded 1442 frames, 47.34 fps, 3955.63 kb/s encoded 1442 frames, 47.23 fps, 3955.39 kb/s encoded 1442 frames, 47.26 fps, 3956.80 kb/s encoded 1442 frames, 47.27 fps, 3955.91 kb/s System Details -------------- Name Intel Core i7 Extreme 980X product System Product Name Codename Gulftown Specification Intel(R) Core(TM) i7 CPU X 980 @ 3.33GHz Specification PC3-12800 Specification PC3-12800 Specification PC3-12800 Core Stepping B1 Technology 32 nm Stock frequency 3333 MHz Core Speed 3474.8 MHz Northbridge Intel X58 rev. 13 Southbridge Intel 82801JR (ICH10R) rev. 00 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Command Rate (CR) 1T Memory Frequency 801.9 MHz (2:12) Memory Type DDR3 Memory Size 12288 MBytes Channels Triple Windows Version Microsoft Windows 7 (6.1) Service Pack 1 (Build 7601) Number of processors 1 Number of threads 12 Number of threads 12 (max 32) L2 cache 6 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES Package (platform ID) Socket 1366 LGA (0x1) Temperature 0 29°C (84°F) [0x1D] (SYSTIN) Temperature 1 31°C (86°F) [0x3D] (CPUTIN) Temperature 2 32°C (89°F) [0x1C0] (AUXTIN)
Results using a processor from 2006: Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 27.52 fps, 3909.84 kb/s encoded 1442 frames, 27.52 fps, 3909.83 kb/s encoded 1442 frames, 27.88 fps, 3909.84 kb/s encoded 1442 frames, 27.78 fps, 3909.84 kb/s Pass 2 ------ encoded 1442 frames, 5.30 fps, 3962.62 kb/s encoded 1442 frames, 5.28 fps, 3962.75 kb/s encoded 1442 frames, 5.33 fps, 3962.68 kb/s encoded 1442 frames, 5.32 fps, 3962.54 kb/s System Details -------------- CPU: DualCore AMD Athlon 64 X2 (Manchester), 2200 MHz (11 x 200) 4200+ CPU stepping : BH-E4 Motherboard: ASRock 939A790GMH (2 PCI, 1 PCI-E x1, 1 PCI-E x16, 4 DDR DIMM, Audio, Video, Gigabit LAN) AMD 790GX, AMD Hammer RAM: 1 x G.SKILL F1-4400DSU2-1GBFC 1024 MB (PC4400 DDR SDRAM) 2 x G Skill CL3-4-4-8-Gskill PC4400 DDR SDRAM (2.5-4-4-8 @ 200 MHz) Video card: Radeon X1600 XT 256 MB HDD: SAMSUNG HD103SJ ATA Device (1000 GB, 7200 RPM, SATA-II)
Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 197.51 fps, 3911.63 kb/s encoded 1442 frames, 197.94 fps, 3911.63 kb/s encoded 1442 frames, 197.53 fps, 3911.63 kb/s encoded 1442 frames, 191.37 fps, 3911.63 kb/s Pass 2 ------ encoded 1442 frames, 50.48 fps, 3958.39 kb/s encoded 1442 frames, 50.07 fps, 3958.71 kb/s encoded 1442 frames, 48.29 fps, 3958.14 kb/s encoded 1442 frames, 47.06 fps, 3959.53 kb/s System Details -------------- QuadCore Intel Core i7-3770K, 4500 MHz (45 x 100) CPU stepping : E1/L1/N0/P0 Gigabyte GA-Z77X-UP4 TH F3-2400C10D-16GTX (CL 10-12-12-31-2N @ 2400 MHz) SAMSUNG HD103SJ ATA Device (1000 GB, 7200 RPM, SATA-II)
Hello, here my results: Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 36.35 fps, 3909.81 kb/s encoded 1442 frames, 36.51 fps, 3909.83 kb/s encoded 1442 frames, 36.54 fps, 3909.84 kb/s encoded 1442 frames, 36.55 fps, 3909.88 kb/s Pass 2 ------ encoded 1442 frames, 7.61 fps, 3962.75 kb/s encoded 1442 frames, 7.65 fps, 3962.07 kb/s encoded 1442 frames, 7.65 fps, 3962.05 kb/s encoded 1442 frames, 7.64 fps, 3962.22 kb/s System Details -------------- Number of processors 1 Number of cores 2 (max 2) Number of threads 2 (max 2) Name AMD Athlon 64 X2 6400+ Codename Windsor Specification AMD Athlon(tm) 64 X2 Dual Core Processor 6400+ Package Socket AM2 (940) Core Speed 1005.0 MHz Multiplier x FSB 5.0 x 201.0 MHz HT Link speed 804.0 MHz Stock frequency 3200 MHz Windows XP sp3 Memory Size 3 GBytes
Hi. Here are my results: x264 HD BENCHMARK 4.0 RESULTS Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 75.89 fps, 3911.63 kb/s encoded 1442 frames, 76.33 fps, 3911.63 kb/s encoded 1442 frames, 76.27 fps, 3911.63 kb/s encoded 1442 frames, 76.20 fps, 3911.63 kb/s Pass 2 ------ encoded 1442 frames, 17.83 fps, 3960.25 kb/s encoded 1442 frames, 17.71 fps, 3959.51 kb/s encoded 1442 frames, 17.63 fps, 3960.02 kb/s encoded 1442 frames, 17.62 fps, 3960.50 kb/s The benchmark didn't collect info about my laptop but here they are: Acer Aspire 5740G CPU: 4 cores / 8 threads, 6MB cache CPU: i7-740QM 1,73 GHz (Turbo Boost ON - no more than 1,86 GHz when all 4 cores active) (no other manual overclocking) RAM:4 GB 1066 MHz dual channel DDR3 memory Chipset: Intel HM55 Chipset GPU: Radeon 5650M 1 GB GDDR3
