x264 HD Benchmark 4.0
Discussion in 'Reviews & Articles' started by Adrian Wong, Mar 7, 2011.
  1. biggiebody
    biggiebody Newbie
    x264 HD BENCHMARK 4.0 RESULTS
    Results for x264.exe r1913
    Pass 1
    encoded 1442 frames, 200.50 fps, 3912.26 kb/s
    encoded 1442 frames, 204.05 fps, 3912.26 kb/s
    encoded 1442 frames, 203.59 fps, 3912.26 kb/s
    encoded 1442 frames, 203.16 fps, 3912.26 kb/s
    Pass 2
    encoded 1442 frames, 38.23 fps, 3962.06 kb/s
    encoded 1442 frames, 37.88 fps, 3962.11 kb/s
    encoded 1442 frames, 38.32 fps, 3961.83 kb/s
    encoded 1442 frames, 38.26 fps, 3961.27 kb/s
    System Details
    Intel Core i5-2500k @ 4.5ghz
    G.Skill Ripjaws (2x4gb) DDR3 1600 @ 9-9-9-24-1t
    hitachi deskstar 7k2000 500gb
    MSI P67a-C43 (b3)
    Windows 7 Ultimate x64
    Thanks, biggiebody! :thumb:
    BTW, if possible, please retest your processor at stock speed, with Turbo Boost disabled of course. Thanks! :)
  3. DarKSeeD
    DarKSeeD BOG Translator
    Pass 1
    encoded 1442 frames, 92.75 fps, 3912.26 kb/s
    encoded 1442 frames, 92.60 fps, 3912.26 kb/s
    encoded 1442 frames, 91.99 fps, 3912.26 kb/s
    encoded 1442 frames, 92.16 fps, 3912.26 kb/s
    Pass 2
    encoded 1442 frames, 18.60 fps, 3962.16 kb/s
    encoded 1442 frames, 18.35 fps, 3961.40 kb/s
    encoded 1442 frames, 18.60 fps, 3961.36 kb/s
    encoded 1442 frames, 18.60 fps, 3961.43 kb/s
    System Details
    Asus P5Q Deluxe
    Intel Q9550
    Corsair Dominator CM2X2048-8500C5D
    Windows 7 x64 SP1
    MSI GTX 460-1024DDR5
    All components at default speed.
    For some unknown reason I had to enter the system details manually.
  4. DarKSeeD
    Pass 1
    encoded 1442 frames, 90.46 fps, 3912.26 kb/s
    encoded 1442 frames, 91.98 fps, 3912.26 kb/s
    encoded 1442 frames, 91.05 fps, 3912.26 kb/s
    encoded 1442 frames, 92.10 fps, 3912.26 kb/s
    Pass 2
    encoded 1442 frames, 18.42 fps, 3961.65 kb/s
    encoded 1442 frames, 18.33 fps, 3961.19 kb/s
    encoded 1442 frames, 18.36 fps, 3961.56 kb/s
    encoded 1442 frames, 18.33 fps, 3961.87 kb/s
    System Details
    Name Intel Core 2 Quad Q9550
    product System Product Name
    Codename Yorkfield
    Specification Intel(R) Core(TM)2 Quad CPU Q9550 @ 2.83GHz
    Core Stepping C1
    Technology 45 nm
    Stock frequency 2833 MHz
    Core Speed 1999.8 MHz
    FID range 6.0x - 8.5x
    Northbridge Intel P45/P43/G45/G43 rev. A2
    CAS# latency (CL) 5.0
    RAS# to CAS# delay (tRCD) 5
    RAS# Precharge (tRP) 5
    Cycle Time (tRAS) 18
    Command Rate (CR) 2T
    Memory Frequency 533.3 MHz (5:8)
    Memory Type DDR2
    Memory Size 4096 MBytes
    Channels Dual, (Symmetric)
    Windows Version Microsoft Windows 7 (6.1) Ultimate Edition Service Pack 1 (Build 7601)
    Number of processors 1
    Number of threads 4
    Number of threads 4 (max 4)
    L2 cache 2 x 6144 KBytes, 24-way set associative, 64-byte line size
    Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T, VT-x
    Package (platform ID) Socket 775 LGA (0x4)
    Temperature 0 36°C (96°F) [0x24] (SYSTIN)
    Temperature 1 30°C (85°F) [0x3B] (CPUTIN)
    Temperature 2 36°C (95°F) [0x47] (AUXTIN)
    This time the report in full.
  5. Adrian Wong
    Yeah, for some reason, the CPU-Z portion doesn't load properly sometimes.
    Thanks for the results! :thumb:
  6. That was my result at stock speed. Here it is at 4.8GHz overclock:
    Pass 1
    encoded 1442 frames, 199.72 fps, 3912.26 kb/s
    encoded 1442 frames, 198.62 fps, 3912.26 kb/s
    encoded 1442 frames, 198.90 fps, 3912.26 kb/s
    Pass 2
    encoded 1442 frames, 40.65 fps, 3961.26 kb/s
    encoded 1442 frames, 40.72 fps, 3961.84 kb/s
    encoded 1442 frames, 40.73 fps, 3961.16 kb/s
    encoded 1442 frames, 40.57 fps, 3961.39 kb/s
    System Details
    Name Intel Core i5 2500K
    Codename Sandy Bridge
    Specification Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
    Specification PC3-12800
    Specification PC3-12800H
    Core Stepping D2
    Technology 32 nm
    Stock frequency 3300 MHz
    Core Speed 1600.3 MHz
    Northbridge Intel Sandy Bridge rev. 09
    Southbridge Intel P67 rev. B3
    CAS# latency (CL) 9.0
    RAS# to CAS# delay (tRCD) 9
    RAS# Precharge (tRP) 9
    Cycle Time (tRAS) 24
    Command Rate 2T
    Command Rate 1T
    Command Rate 2T
    Command Rate 1T
    Memory Frequency 800.2 MHz (1:6)
    Memory Type DDR3
    Memory Size 12288 MBytes
    Windows Version Microsoft Windows 7 (6.1) Home Premium Edition Service Pack 1 (Build 7601)
    Number of threads 4
    Number of threads 4 (max 16)
    Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX
    Package (platform ID) Socket 1155 LGA (0x1)
    Temperature 0 25°C (76°F) [0x19] (SYSTIN)
    Temperature 1 0°C (32°F) [0x0] (CPUTIN)
    Temperature 2 64°C (147°F) [0x80] (AUXTIN)
  7. Adrian Wong
    Thanks!! Keep 'em coming!! :beer:
  8. mloot
    mloot Newbie
    Pass 1
    encoded 1442 frames, 73.66 fps, 3912.32 kb/s
    encoded 1442 frames, 74.48 fps, 3912.32 kb/s
    encoded 1442 frames, 74.24 fps, 3912.32 kb/s
    encoded 1442 frames, 69.04 fps, 3912.32 kb/s
    Pass 2
    encoded 1442 frames, 15.20 fps, 3961.58 kb/s
    encoded 1442 frames, 15.16 fps, 3961.41 kb/s
    encoded 1442 frames, 14.45 fps, 3961.93 kb/s
    encoded 1442 frames, 13.72 fps, 3961.33 kb/s
    System Details
    Name AMD Phenom X4 9650
    Codename Agena
    Specification AMD Phenom(tm) 9650 Quad-Core Processor
    Core Stepping DR-B3
    Technology 65 nm
    manufacturer Gigabyte Technology Co., Ltd.
    vendor Gigabyte Technology Co., Ltd.
    Stock frequency 2300 MHz
    Core Speed 2420.6 MHz
    FID range 5.8x - 11.5x
    Northbridge ATI Radeon X1250 rev. 00
    Southbridge ATI SB600 rev. 00
    Cycle Time (tRAS) 15
    Memory Frequency 421.0 MHz (1:2)
    Memory Type DDR2
    Channels Dual, (Unganged)
    Windows Version Microsoft Windows 7 (6.1) Home Premium Edition (Build 7600)
    Number of threads 4
    L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size
    Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V
    Package Socket AM2+ (940)
    Package Type 0x1
    Temperature 0 37°C (98°F) [0x25] (System 1)
    Temperature 1 61°C (141°F) [0x3D] (CPU)
    Temperature 2 39°C (102°F) [0x27] (System 1)
  9. METAIKone
    METAIKone Newbie
    Pass 1
    encoded 1442 frames, 191.78 fps, 3911.63 kb/s
    encoded 1442 frames, 185.99 fps, 3911.63 kb/s
    encoded 1442 frames, 189.02 fps, 3911.63 kb/s
    Pass 2
    encoded 1442 frames, 46.75 fps, 3959.50 kb/s
    encoded 1442 frames, 46.66 fps, 3957.60 kb/s
    encoded 1442 frames, 46.73 fps, 3960.15 kb/s
    encoded 1442 frames, 46.71 fps, 3959.69 kb/s
    System Details
    Name Intel Core i7 2600K
    Specification Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz ([email protected])
    Specification PC3-17100
    Core Stepping D2
    Technology 32 nm
    Stock frequency 3400 MHz
    Core Speed 1600.1 MHz
    Southbridge Intel P67 rev. B2
    RAS# to CAS# delay (tRCD) 11
    Cycle Time (tRAS) 28
    Command Rate 1T
    Command Rate 1T
    Command Rate 1T
    Command Rate 1T
    Memory Frequency 1066.8 MHz (1:8)
    Memory Type DDR3
    Memory Size 16384 MBytes
    Windows Version Microsoft Windows 7 (6.1) Ultimate Edition (Build 7600)
    Number of threads 8
    Number of threads 8 (max 16)
    Temperature 0 28°C (82°F) [0x1C] (SYSTIN)
  10. Adrian Wong
    Did you overclock that? Or was it running at 2.3 GHz?
  11. I´m getting strange results
    Hello all!
    I´ve just did some testing and this is the resut:
    Pass 1
    encoded 1442 frames, 80.24 fps, 3911.63 kb/s
    encoded 1442 frames, 80.66 fps, 3911.63 kb/s
    encoded 1442 frames, 77.35 fps, 3911.63 kb/s
    encoded 1442 frames, 35.87 fps, 3911.63 kb/s
    Pass 2
    encoded 1442 frames, 18.56 fps, 3959.59 kb/s
    encoded 1442 frames, 17.71 fps, 3959.48 kb/s
    encoded 1442 frames, 15.18 fps, 3959.07 kb/s
    encoded 1442 frames, 8.39 fps, 3959.42 kb/s
    System Details
    Name Intel Core i7
    Specification Intel(R) Core(TM) i7-2630QM CPU @ 2.00GHz
    Core Stepping D2
    Technology 32 nm
    Stock frequency 2000 MHz
    Core Speed 798.2 MHz
    Southbridge Intel HM65 rev. B2
    Command Rate (CR) 1T
    Memory Frequency 665.2 MHz (1:5)
    Memory Type DDR3
    Number of threads 8
    Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AVX
    Package (platform ID) Socket 988B rPGA (0x4)
    Temperature 0 28°C (82°F) [0xBC2] (TZ00)
    Temperature 1 30°C (85°F) [0xBD6] (TZ01)
    Now, this is weird. The run 4 got lower results compared to the other 3 and even though the first pass it´s normal compared to other benchmarks that I saw on the internet, the second pass is below the 23-26 fps that I saw on all other benchmarks using the sandy bridge processor. Perhaps someone could help me on this? Thanks!
  12. Adrian Wong
    Yeah, I was about to mention that. That is very, very odd. Please make sure you disable Turbo Boost before you run this test. Also, make sure you don't have anything running in the background.
  13. I can´t disable turbo boost
    Hello again,
    I can´t disable turbo boost. There´s no such option on the BIOS.
    It´s a new formatted pc with nothing installed. I have no idea why this is happening. Sometimes the run 4 is ok and sometimes it get slower with no reason. When I´ve used CPU-Z and Turbo Boost monitor, I´ve notice that turbo boost it´s not being activated and the clock stucks at 1795.
    Any advice on this? It seens that the software it´s not using the processor as it should and I know this is not a problem with the software because a lot of people are getting higher benchmarks.
    Thanks!
  14. Adrian Wong
    Hmm.. You formatted it using your own copy of Windows 7, or was Windows 7 already pre-installed?
    If it's the former, then you may have missed some drivers. Check the Device Manager to see if any device has an exclamation mark which would denote some malfunction or a missing driver.
    If it's the latter, then it will most likely come with a coterie of mini applications running in the background. I would try disabling as many of them as possible before running the benchmark.
  15. DarKSeeD
    1st Run of i5-2500K
    Pass 1
    encoded 1442 frames, 166.32 fps, 3912.26 kb/s
    encoded 1442 frames, 174.64 fps, 3912.26 kb/s
    encoded 1442 frames, 174.41 fps, 3912.26 kb/s
    encoded 1442 frames, 174.45 fps, 3912.26 kb/s
    Pass 2
    encoded 1442 frames, 34.76 fps, 3961.82 kb/s
    encoded 1442 frames, 35.15 fps, 3961.64 kb/s
    encoded 1442 frames, 34.87 fps, 3961.62 kb/s
    encoded 1442 frames, 35.16 fps, 3961.63 kb/s
    System Details
    Core Stepping D2
    Technology 32 nm
    Core Speed 1648.3 MHz
    Command Rate 2T
    Command Rate 2T
    Memory Frequency 824.2 MHz (1:6)
    Memory Type DDR3
    Memory Size 8192 MBytes
    Number of threads 4
    Temperature 0 23°C (73°F) [0x17] (SYSTIN)
    Temperature 2 0°C (32°F) [0x0] (AUXTIN)
  16. DarKSeeD
    2nd Run of i5-2500K
    Pass 1
    encoded 1442 frames, 173.34 fps, 3912.26 kb/s
    encoded 1442 frames, 175.26 fps, 3912.26 kb/s
    encoded 1442 frames, 175.66 fps, 3912.26 kb/s
    Pass 2
    encoded 1442 frames, 35.01 fps, 3962.04 kb/s
    encoded 1442 frames, 35.04 fps, 3961.16 kb/s
    encoded 1442 frames, 35.02 fps, 3961.55 kb/s
    encoded 1442 frames, 35.15 fps, 3962.15 kb/s
    System Details
    Core Stepping D2
    Technology 32 nm
    Command Rate 2T
    Command Rate 2T
    Memory Type DDR3
    Number of threads 4
  17. Adrian Wong
    Thanks!! Keep 'em coming! :D
  18. Adrian Wong
    BTW, DarKSeeD, did you turn off Turbo Boost for your results? They seem rather high.
  19. Ishtim
    Ishtim Super Moderator
    Just running my first test on an old single core P4 2.4GHz. :haha:
    will fire up the E8600 & the new i7 core machine ASAP :wave:
    Please do NOT compare it with older versions of the benchmark!
    Please copy/paste everything below the line to to report your data
    to http://forums.techarp.com/reviews-articles/26363-x264-hd-benchmark-4-0-a.html
    Pass 1
    encoded 1442 frames, 8.84 fps, 3908.75 kb/s
    encoded 1442 frames, 8.92 fps, 3908.75 kb/s
    encoded 1442 frames, 8.95 fps, 3908.75 kb/s
    encoded 1442 frames, 8.81 fps, 3908.75 kb/s
    Pass 2
    encoded 1442 frames, 1.67 fps, 3962.67 kb/s
    encoded 1442 frames, 1.70 fps, 3962.67 kb/s
    encoded 1442 frames, 1.69 fps, 3962.67 kb/s
    encoded 1442 frames, 1.68 fps, 3962.67 kb/s
    System Details
    Asus P4500
    P4 2.4GHz (Circa 2004) :mrgreen:
  20. Adrian Wong
    Thanks for the results, Ishtim! :thumb:
    BTW, can you tell me what was the memory clock speed? Thanks!
