x264 HD Benchmark 4.0
Discussion in 'Reviews & Articles' started by Adrian Wong, Mar 7, 2011.
  1. cbjaust
    cbjaust Newbie
    Phenom II X4 940 DFI DK 790FXB-M2RSH 4GB
    Another result for you:
    Thanks, cbjaust!! :thumb:
    BTW, if possible, can you retest at stock speed? Thanks!
  3. Blazzok
    Blazzok Newbie
    Core2 Duo E6700
    This is my old system. Just posting it for funzies. Busy assembling my new PC, will bench it as soon as I am done and upload the results.
    Results for x264.exe r1913
    Pass 1
    encoded 1442 frames, 47.92 fps, 3909.83 kb/s
    encoded 1442 frames, 48.04 fps, 3909.84 kb/s
    encoded 1442 frames, 48.04 fps, 3909.85 kb/s
    encoded 1442 frames, 47.92 fps, 3909.89 kb/s
    Pass 2
    encoded 1442 frames, 8.98 fps, 3962.63 kb/s
    encoded 1442 frames, 9.00 fps, 3962.61 kb/s
    encoded 1442 frames, 8.99 fps, 3962.70 kb/s
    encoded 1442 frames, 8.99 fps, 3962.58 kb/s
    System Details
    Name Intel Core 2 Duo E6700
    Codename Conroe
    Specification Intel(R) Core(TM)2 CPU 6700 @ 2.66GHz
    Core Stepping B2
    Technology 65 nm
    manufacturer Gigabyte Technology Co., Ltd.
    vendor Gigabyte Technology Co., Ltd.
    Stock frequency 2666 MHz
    Core Speed 1600.0 MHz
    FID range 6.0x - 10.0x
    Northbridge Intel P35/G33/G31 rev. A2
    Southbridge Intel 82801IR (ICH9R) rev. 02
    CAS# latency (CL) 5.0
    RAS# to CAS# delay (tRCD) 5
    RAS# Precharge (tRP) 5
    Cycle Time (tRAS) 18
    Command Rate (CR) 2T
    Memory Frequency 400.0 MHz (2:3)
    Memory Type DDR2
    Memory Size 2048 MBytes
    Channels Dual, (Symmetric)
    Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600)
    Number of processors 1
    Number of threads 2
    Number of threads 2 (max 2)
    L2 cache 4096 KBytes, 16-way set associative, 64-byte line size
    Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T, VT-x
    Package (platform ID) Socket 775 LGA (0x0)
    Temperature 0 44°C (111°F) [0x2C] (System)
    Temperature 1 46°C (114°F) [0x2E] (CPU)
  4. volt2amp
    volt2amp Newbie
    Hope it helps you.
    volt2amp
    Pass 1
    encoded 1442 frames, 114.68 fps, 3911.63 kb/s
    encoded 1442 frames, 118.05 fps, 3911.63 kb/s
    encoded 1442 frames, 116.70 fps, 3911.63 kb/s
    Pass 2
    encoded 1442 frames, 29.13 fps, 3958.89 kb/s
    encoded 1442 frames, 29.13 fps, 3959.34 kb/s
    encoded 1442 frames, 29.09 fps, 3960.04 kb/s
    encoded 1442 frames, 29.10 fps, 3959.72 kb/s
    System Details
    Name Intel Core i7 950
    Codename Bloomfield
    Specification Intel(R) Core(TM) i7 CPU 950 @ 3.07GHz
    Specification PC3-12800
    Core Stepping D0
    Technology 45 nm
    Stock frequency 3066 MHz
    Core Speed 3049.9 MHz
    Northbridge Intel X58 rev. 13
    CAS# latency (CL) 7.0
    RAS# to CAS# delay (tRCD) 8
    RAS# Precharge (tRP) 7
    Cycle Time (tRAS) 24
    Command Rate 2T
    Command Rate 2T
    Command Rate 2T
    Command Rate 2T
    Command Rate 2T
    Command Rate 2T
    Memory Frequency 530.4 MHz (2:8)
    Memory Type DDR3
    Memory Size 12288 MBytes
    Channels Triple
    Windows Version Microsoft Windows 7 (6.1) Ultimate Edition Service Pack 1 (Build 7601)
    Number of threads 8
    Number of threads 8 (max 16)
    Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x
    Package (platform ID) Socket 1366 LGA (0x1)
    Temperature 0 38°C (100°F) [0x26] (CPU)
    Temperature 1 49°C (120°F) [0x31] (VREG)
    Temperature 2 29°C (84°F) [0x1D] (System)
    Temperature 0 38°C (100°F) [0xC28] (THRM)
  5. Adrian Wong
    Thanks, guys!! Keep 'em coming!!! :beer: :beer:
    PS. Results from old systems are always welcomed! :thumb:
  6. SicKlown42012
    SicKlown42012 Newbie
    THis is with my 1090t at 4Ghz and the IMC at 2.8Ghz.
    Pass 1
    encoded 1442 frames, 141.43 fps, 3913.31 kb/s
    encoded 1442 frames, 142.60 fps, 3913.31 kb/s
    encoded 1442 frames, 143.40 fps, 3913.31 kb/s
    encoded 1442 frames, 142.57 fps, 3913.31 kb/s
    Pass 2
    encoded 1442 frames, 38.88 fps, 3960.11 kb/s
    encoded 1442 frames, 39.03 fps, 3959.15 kb/s
    encoded 1442 frames, 39.01 fps, 3960.55 kb/s
    encoded 1442 frames, 39.11 fps, 3960.25 kb/s
    System Details
    Name AMD Phenom II X6 1095T
    product System Product Name
    Codename Thuban
    Specification AMD Phenom(tm) II X6 1090T Processor
    Core Stepping PH-E0
    Technology 45 nm
    Core Speed 4013.4 MHz
    Northbridge AMD 790FX rev. 00
    Southbridge AMD SB700 rev. 00
    Cycle Time (tRAS) 15
    Memory Frequency 535.1 MHz (3:8)
    Memory Type DDR2
    Memory Size 8192 MBytes
    Channels Dual, (Unganged)
    Windows Version Microsoft Windows 7 (6.1) Home Premium Edition (Build 7600)
    Number of threads 6
    Number of threads 6 (max 6)
    L2 cache 6 x 512 KBytes, 16-way set associative, 64-byte line size
    Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V
    Package Socket AM3 (938)
    Package Type 0x1
    Temperature 0 47°C (116°F) [0x2F] (TMPIN0)
    Temperature 1 30°C (85°F) [0x1E] (TMPIN1)
  7. Adrian Wong
    Thanks, SicKlown42012! :thumb:
  8. Ishtim
    Ishtim Super Moderator
    :wave: Work laptop: HP 8740w
    *just noticed those high temps* :faint:
    Pass 1
    encoded 1442 frames, 78.94 fps, 3911.63 kb/s
    encoded 1442 frames, 79.41 fps, 3911.63 kb/s
    encoded 1442 frames, 78.27 fps, 3911.63 kb/s
    encoded 1442 frames, 79.01 fps, 3911.63 kb/s
    Pass 2
    encoded 1442 frames, 17.14 fps, 3958.42 kb/s
    encoded 1442 frames, 17.25 fps, 3960.01 kb/s
    encoded 1442 frames, 17.21 fps, 3960.13 kb/s
    encoded 1442 frames, 9.97 fps, 3959.62 kb/s
    System Details
    Name Intel Core i7 820QM
    Codename Clarksfield
    Specification Intel(R) Core(TM) i7 CPU Q 820 @ 1.73GHz
    Core Stepping B1
    Technology 45 nm
    Stock frequency 1733 MHz
    Core Speed 1197.0 MHz
    Northbridge Intel DMI Host Bridge rev. 11
    Southbridge Intel QM57 rev. 06
    CAS# latency (CL) 9.0
    RAS# to CAS# delay (tRCD) 9
    RAS# Precharge (tRP) 9
    Command Rate (CR) 1T
    Memory Frequency 665.0 MHz (2:10)
    Memory Type DDR3
    Memory Size 4096 MBytes
    Channels Dual
    Windows Version Microsoft Windows 7 (6.1) Ultimate Edition (Build 7600)
    Number of threads 8
    Package (platform ID) Socket 989 rPGA (0x4)
    Temperature 0 0°C (32°F) [0xAAC] (EXTZ)
    Temperature 1 0°C (32°F) [0xAAC] (EX2Z)
    Temperature 2 21°C (69°F) [0xB7E] (PWMZ)
    Temperature 3 42°C (107°F) [0xC50] (LOCZ)
    Temperature 4 40°C (103°F) [0xC3C] (GFXZ)
    Temperature 5 29°C (83°F) [0xBCB] (BATZ)
    Temperature 6 41°C (105°F) [0xC46] (EGXZ)
    Temperature 7 69°C (156°F) [0xD5E] (CPUZ)
    Temperature 8 0°C (32°F) [0xAAC] (MCHZ)
    Temperature 9 59°C (138°F) [0xCFA] (PCHZ)
  9. Ishtim
    "Old Faithful" E8600 stock
    Pass 1
    encoded 1442 frames, 61.04 fps, 3909.84 kb/s
    encoded 1442 frames, 60.92 fps, 3909.88 kb/s
    encoded 1442 frames, 61.12 fps, 3909.85 kb/s
    encoded 1442 frames, 60.67 fps, 3909.82 kb/s
    Pass 2
    encoded 1442 frames, 11.66 fps, 3962.54 kb/s
    encoded 1442 frames, 11.63 fps, 3962.10 kb/s
    encoded 1442 frames, 11.61 fps, 3962.00 kb/s
    encoded 1442 frames, 11.56 fps, 3962.89 kb/s
    System Details
    Name Intel Core 2 Duo E8600
    Codename Wolfdale
    Specification Intel(R) Core(TM)2 Duo CPU E8600 @ 3.33GHz
    Core Stepping E0
    Technology 45 nm
    Stock frequency 3333 MHz
    Core Speed 1999.9 MHz
    Northbridge Intel P45/P43/G45/G43 rev. A2
    Memory Frequency 400.0 MHz (5:6)
    Memory Type DDR2
    Number of threads 2
    L2 cache 6144 KBytes, 24-way set associative, 64-byte line size
    Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T, VT-x
    Temperature 0 26°C (78°F) [0x1A] (SYSTIN)
    Temperature 1 23°C (73°F) [0x2E] (CPUTIN)
    Temperature 2 36°C (96°F) [0x48] (AUXTIN)
  10. Adrian Wong
    Wow, Ishtim, you took the time to post the scores when you have so much to do in Huntsville. Thanks a lot!!! :thumb: :thumb:
  11. Ishtim
    Amazing what you can get done while working from home! :mrgreen:
    Was actually putting these together the day we lost power...
    Another: Pentium IV @ 2.4Ghz :haha:
    Pass 1
    encoded 1442 frames, 9.39 fps, 3908.75 kb/s
    encoded 1442 frames, 9.49 fps, 3908.75 kb/s
    encoded 1442 frames, 9.51 fps, 3908.75 kb/s
    encoded 1442 frames, 9.43 fps, 3908.75 kb/s
    Pass 2
    encoded 1442 frames, 1.82 fps, 3962.67 kb/s
    encoded 1442 frames, 1.81 fps, 3962.67 kb/s
    System Details
    Name Intel Pentium 4
    product System Name
    Codename Northwood
    Specification Intel(R) Pentium(R) 4 CPU 2.40GHz
    Core Stepping C1
    Technology 0.13 um
    Stock frequency 2400 MHz
    Core Speed 2424.2 MHz
    Northbridge Intel i845E rev. E0
    Southbridge Intel 82801DB (ICH4) rev. 01
    CAS# latency (CL) 2.0
    RAS# to CAS# delay (tRCD) 3
    RAS# Precharge (tRP) 3
    Cycle Time (tRAS) 6
    Memory Frequency 134.7 MHz (1:1)
    Memory Type DDR
    Memory Size 1536 MBytes
    Number of threads 1
    Number of threads 1 (max 1)
    L2 cache 512 KBytes, 8-way set associative, 64-byte line size
    Package (platform ID) Socket 478 mPGA (0x2)
  12. Adrian Wong
    Thanks again, and keep 'em coming!! :beer: :beer:
  13. Ishtim
    Here's another: i5-2400
    Pass 1
    encoded 1442 frames, 130.38 fps, 3912.26 kb/s
    encoded 1442 frames, 130.73 fps, 3912.26 kb/s
    encoded 1442 frames, 130.97 fps, 3912.26 kb/s
    Pass 2
    encoded 1442 frames, 25.97 fps, 3961.10 kb/s
    encoded 1442 frames, 25.97 fps, 3961.65 kb/s
    encoded 1442 frames, 26.03 fps, 3960.96 kb/s
    encoded 1442 frames, 26.05 fps, 3961.84 kb/s
    System Details
    Name Intel Core i5 2400
    Codename Sandy Bridge
    Specification Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz
    Core Stepping D2
    Technology 32 nm
    Stock frequency 3100 MHz
    Core Speed 1596.3 MHz
    Northbridge Intel Sandy Bridge rev. 09
    Southbridge Intel H67 rev. B3
    RAS# to CAS# delay (tRCD) 7
    Cycle Time (tRAS) 20
    Memory Frequency 532.1 MHz (1:4)
    Memory Type DDR3
    Number of threads 4
    Number of threads 4 (max 16)
    Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX
    Package (platform ID) Socket 1155 LGA (0x1)
    Temperature 0 38°C (100°F) [0x26] (TMPIN0)
    Temperature 1 44°C (111°F) [0x2C] (TMPIN1)
    Temperature 2 28°C (82°F) [0x1C] (TMPIN2)
  14. benson733
    benson733 Newbie
    THIS IS MY FIRST POST!!!!
    i7 2600k OC to 4.6ghz @ 1.350v
    Pass 1
    encoded 1442 frames, 173.59 fps, 3911.63 kb/s
    encoded 1442 frames, 175.00 fps, 3911.63 kb/s
    encoded 1442 frames, 175.64 fps, 3911.63 kb/s
    encoded 1442 frames, 180.05 fps, 3911.63 kb/s
    Pass 2
    encoded 1442 frames, 46.80 fps, 3960.24 kb/s
    encoded 1442 frames, 47.05 fps, 3959.25 kb/s
    encoded 1442 frames, 46.87 fps, 3960.03 kb/s
    encoded 1442 frames, 46.95 fps, 3958.32 kb/s
    :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap:
    System Details
    Change the hxxp to http
    hxxp://img811.imageshack.us/img811/4170/pcspecs.jpg
  15. Ishtim
    i7-2600K not Overclocked (yet) :twisted:
    ...and my 4000th post, just 6 days before my 8th ARP anniversary!
    Pass 1
    encoded 1442 frames, 131.58 fps, 3911.63 kb/s
    encoded 1442 frames, 140.11 fps, 3911.63 kb/s
    encoded 1442 frames, 140.34 fps, 3911.63 kb/s
    encoded 1442 frames, 138.67 fps, 3911.63 kb/s
    Pass 2
    encoded 1442 frames, 34.63 fps, 3959.54 kb/s
    encoded 1442 frames, 34.11 fps, 3959.40 kb/s
    encoded 1442 frames, 34.67 fps, 3960.06 kb/s
    encoded 1442 frames, 34.56 fps, 3959.49 kb/s
    System Details
    Name Intel Core i7 2600K
    Specification Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
    Specification PC3-17600
    Core Stepping D2
    Technology 32 nm
    Stock frequency 3400 MHz
    Core Speed 2809.1 MHz
    Southbridge Intel P67 rev. B3
    Command Rate 1T
    Command Rate 1T
    Memory Frequency 668.9 MHz (1:5)
    Memory Type DDR3
    Number of threads 8
    Temperature 0 28°C (82°F) [0x1C] (SYSTIN)
    Temperature 1 0°C (32°F) [0x0] (CPUTIN)
    Temperature 2 0°C (32°F) [0x0] (AUXTIN)
  16. Adrian Wong
    Thanks, guys!!! :thumb: :thumb:
  17. MATiASc
    MATiASc Newbie
    Pass 1
    encoded 1442 frames, 142.12 fps, 3913.31 kb/s
    encoded 1442 frames, 140.83 fps, 3913.31 kb/s
    encoded 1442 frames, 141.33 fps, 3913.31 kb/s
    encoded 1442 frames, 140.70 fps, 3913.31 kb/s
    Pass 2
    encoded 1442 frames, 39.04 fps, 3958.83 kb/s
    encoded 1442 frames, 39.01 fps, 3958.39 kb/s
    encoded 1442 frames, 38.84 fps, 3959.99 kb/s
    encoded 1442 frames, 38.79 fps, 3960.08 kb/s
    System Details
    AMD Phemon II X6 1100T BE @ 4.01 GHz + CM Hyper 212 Plus
    ASUS Crosshair IV Formula
    G.Skill Ripjaws DDR3 1600MHZ CAS7
    HIS Radeon 5770 1GB GDRR5
    Western Digital Caviar Black 500GBx2 @ RAID 0
    PowerCooler 520w
    Windows 7 x64 Ultimate Service Pack 1
  18. Adrian Wong
    Thanks, MATiASc! :thumb:
    BTW, if possible, can you retest your system with the CPU at stock speed and with TurboCore disabled?
    Thanks!
  19. Ishtim
    HAPPY 8th ANNIVERSARY to ME! :thumb: :haha:
    i7-2600K @ 4.43GHz ("Auto" Overclock on P8P67 Pro)
    Pass 1
    encoded 1442 frames, 182.30 fps, 3911.63 kb/s
    encoded 1442 frames, 183.32 fps, 3911.63 kb/s
    encoded 1442 frames, 182.35 fps, 3911.63 kb/s
    encoded 1442 frames, 181.61 fps, 3911.63 kb/s
    Pass 2
    encoded 1442 frames, 44.51 fps, 3958.89 kb/s
    encoded 1442 frames, 43.85 fps, 3959.62 kb/s
    encoded 1442 frames, 44.54 fps, 3960.10 kb/s
    encoded 1442 frames, 44.60 fps, 3959.97 kb/s
    System Details
    Core Stepping D2
    Technology 32 nm
    Core Speed 1605.2 MHz
    Command Rate 1T
    Command Rate 1T
    Memory Type DDR3
    Number of threads 8
    Temperature 0 27°C (80°F) [0x1B] (SYSTIN)
    Temperature 2 64°C (147°F) [0x80] (AUXTIN)
  20. Ishtim
    I think I've maxed out the 2600K with air cooling anyway... :faint: added a Zalman NPS9900Max.
    x264 HD runs it up to 84C @ 1.475V
    5.02GHz :dance:
    Pass 1
    encoded 1442 frames, 204.83 fps, 3911.63 kb/s
    encoded 1442 frames, 205.15 fps, 3911.63 kb/s
    encoded 1442 frames, 204.45 fps, 3911.63 kb/s
    encoded 1442 frames, 204.48 fps, 3911.63 kb/s
    Pass 2
    encoded 1442 frames, 50.44 fps, 3959.50 kb/s
    encoded 1442 frames, 50.47 fps, 3959.43 kb/s
    encoded 1442 frames, 50.42 fps, 3958.12 kb/s
    encoded 1442 frames, 47.75 fps, 3960.16 kb/s
    System Details
    Name Intel Processor
    Core Stepping D2
    Technology 32 nm
    Memory Type
    Memory Size 3314 MBytes
    Number of threads 8
    Package
