x264 HD Benchmark 4.0
Discussion in 'Reviews & Articles' started by Adrian Wong, Mar 7, 2011.
  1. ukdouble1
    ukdouble1 Newbie
    Results for x264.exe r1913
    Pass 1
    encoded 1442 frames, 130.03 fps, 3911.63 kb/s
    encoded 1442 frames, 134.21 fps, 3911.63 kb/s
    encoded 1442 frames, 132.66 fps, 3911.63 kb/s
    Pass 2
    encoded 1442 frames, 35.38 fps, 3959.79 kb/s
    encoded 1442 frames, 35.37 fps, 3959.04 kb/s
    encoded 1442 frames, 35.27 fps, 3958.30 kb/s
    encoded 1442 frames, 35.35 fps, 3959.69 kb/s
    System Details
    Name Intel Core i7 2600
    Codename Sandy Bridge
    Specification Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz
    Core Stepping D2
    Technology 32 nm
    Stock frequency 3400 MHz
    Core Speed 3492.5 MHz
    Northbridge Intel Sandy Bridge rev. 09
    Southbridge Intel P67 rev. B3
    CAS# latency (CL) 9.0
    RAS# to CAS# delay (tRCD) 9
    RAS# Precharge (tRP) 9
    Cycle Time (tRAS) 24
    Command Rate (CR) 1T
    Memory Frequency 665.3 MHz (1:5)
    Memory Type DDR3
    Memory Size 8192 MBytes
    Windows Version Microsoft Windows 7 (6.1) Ultimate Edition (Build 7600)
    Number of processors 1
    Number of threads 8
    Number of threads 8 (max 16)
    Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX
    Package (platform ID) Socket 1155 LGA (0x1)
    Temperature 0 37°C (98°F) [0x25] (SYSTIN)
    Temperature 1 64°C (147°F) [0x80] (CPUTIN)
    Temperature 2 0°C (32°F) [0x0] (AUXTIN)
    I agree with you that the source may be a little too short for newer CPUs, but we have to take into account the time it takes to run the benchmark on slower CPUs too.
    As you pointed out, most people would do a simple encode. In fact, I would point out that most people wouldn't even bother to do a 2-pass encode. So I'm not even sure if the 2-pass encode is even necessary... Then again, the 2-pass encode does show the effect of higher memory bandwidth on performance... :think:
    Frankly speaking, I think our benchmark sort of discourages people from upgrading. After all, you would expect a more significant reduction in encoding time going from a dual-core to a quad-core CPU. However, that's not what the benchmark shows. So I honestly think it's a poor marketing tool. Why do you think Intel or AMD hasn't picked it up as an official benchmark yet? :D
  3. far.in.out
    far.in.out Newbie
    These settings
    --quiet --preset slower --crf 18 --level 4.1 --thread-input --sar 1:1 --output "../run1-720p.mp4" "test-720p.avs" --mvrange 511
    result in
    encoded 1442 frames, 3.05 fps, 3797.75 kb/s
    while ur settings
    Pass 1
    encoded 1442 frames, 48.24 fps, 3909.88 kb/s
    Pass 2
    encoded 1442 frames, 9.56 fps, 3962.83 kb/s
    That's a big difference, and quality-wise too.
    I really think you should drop the 2-pass, noone is using it anymore. It's not effective. So y test smth that noone wiil be doing?
    Also, when doing complex encodes I don't think that performance is limited by memory bandwidth... 2 runs of crf should be enough to get an accurate picture. Also u should use more complex quality presets. Something like
    --slow or --slower
    The latter is preferable.
    Since we are testing CPU performance we should use complex, hard algorithms. What's the point of doing tests if we do fast, crappy encodes?
    There are lots of memory bandwidth tests out there. I don't think such resources as u have at ur disposal should be used to do such pointless tests. I really hope u'll change ur mind till next version of bench.
    System Details
    Name Intel Pentium E5400
    product System Product Name
    Codename Wolfdale
    Specification Pentium(R) Dual-Core CPU E5400 @ 2.70GHz
    Core Stepping R0
    Technology 45 nm
    Stock frequency 2700 MHz
    Core Speed 3327.7 MHz
    FID range 6.0x - 13.5x
    Northbridge Intel P965/G965 rev. C2
    Southbridge Intel 82801HB/HR (ICH8/R) rev. B0
    CAS# latency (CL) 4.0
    RAS# to CAS# delay (tRCD) 4
    RAS# Precharge (tRP) 4
    Cycle Time (tRAS) 12
    Command Rate (CR) 2T
    Memory Frequency 332.8 MHz (1:1)
    Memory Type DDR2
    Memory Size 3072 MBytes
    Channels Dual, (Symmetric)
    Windows Version Microsoft Windows 7 (6.1) Enterprise Edition Service Pack 1 (Build 7601)
    Number of threads 2
    Number of threads 2 (max 2)
    L2 cache 2048 KBytes, 8-way set associative, 64-byte line size
    Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T, VT-x
    Package (platform ID) Socket 775 LGA (0x0)
    Temperature 0 42°C (107°F) [0x2A] (SYSTIN)
    Temperature 1 56°C (131°F) [0x6F] (CPUTIN)
    Temperature 2 122°C (250°F) [0xF3] (AUXTIN)
  4. Adrian Wong
    Actually, I agree that the 2-pass test is quite worthless when it comes to real-world approximation because no one uses it. We kept it on mainly because it shows an appreciable performance difference in Xeons and higher-end Core i7 processors that can only be explained by their higher memory bandwidth and/or QPI speed.
    It might be a good idea to switch from the 2-pass to a single-pass but harder test that you propose.
  5. far.in.out
    far.in.out Newbie
    Well, yeah, the crf or 1-pass is not that important, however I don't see the point in 1 pass... But harder settings should be used 100%.
  6. bigmat
    bigmat Newbie
    phenom II b50 x3 (unlocked 550)
    Pass 1
    encoded 1442 frames, 101.26 fps, 3910.12 kb/s
    encoded 1442 frames, 101.84 fps, 3910.14 kb/s
    encoded 1442 frames, 101.76 fps, 3910.14 kb/s
    encoded 1442 frames, 102.20 fps, 3910.14 kb/s
    Pass 2
    encoded 1442 frames, 18.24 fps, 3962.65 kb/s
    encoded 1442 frames, 18.25 fps, 3962.53 kb/s
    encoded 1442 frames, 18.22 fps, 3962.66 kb/s
    encoded 1442 frames, 18.25 fps, 3962.64 kb/s
    System Details
    Name AMD Phenom II X4
    Codename Deneb
    Specification AMD Phenom(tm) II X4 B50 Processor
    Core Stepping RB-C2
    Technology 45 nm
    manufacturer Gigabyte Technology Co., Ltd.
    vendor Gigabyte Technology Co., Ltd.
    Core Speed 3791.1 MHz
    Northbridge AMD 790X rev. 00
    Southbridge AMD SB700 rev. 00
    CAS# latency (CL) 8.0
    RAS# to CAS# delay (tRCD) 8
    RAS# Precharge (tRP) 8
    Memory Frequency 892.0 MHz (1:4)
    Memory Type DDR3
    Memory Size 4096 MBytes
    Channels Dual, (Unganged)
    Windows Version Microsoft Windows 7 (6.1) Ultimate Edition Service Pack 1 (Build 7601)
    Number of threads 3
    Number of threads 3 (max 3)
    L2 cache 3 x 512 KBytes, 16-way set associative, 64-byte line size
    Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V
    Package Socket AM3 (938)
    Package Type 0x1
    Temperature 0 36°C (96°F) [0x24] (System)
    Temperature 1 47°C (116°F) [0x2F] (CPU)
  7. Adrian Wong
    Thanks for the results, bigmat! :thumb:
  8. clayton006
    clayton006 Newbie
    Here are my results (my memory is reported incorrectly. It is running at 1600MHz instead of 800. May be due to DDR?):
    Pass 1
    encoded 1442 frames, 171.56 fps, 3911.81 kb/s
    encoded 1442 frames, 170.87 fps, 3911.81 kb/s
    encoded 1442 frames, 171.32 fps, 3911.81 kb/s
    encoded 1442 frames, 169.67 fps, 3911.81 kb/s
    Pass 2
    encoded 1442 frames, 86.30 fps, 3951.26 kb/s
    encoded 1442 frames, 86.69 fps, 3951.51 kb/s
    encoded 1442 frames, 86.76 fps, 3952.15 kb/s
    encoded 1442 frames, 86.01 fps, 3952.65 kb/s
    System Details
    Name Intel Xeon X5650
    Codename Westmere-EP
    Specification Intel(R) Xeon(R) CPU X5650 @ 2.67GHz
    Specification PC3-12800
    Core Stepping B1
    Core Stepping B1
    Technology 32 nm
    Technology 32 nm
    Stock frequency 2666 MHz
    Core Speed 4000.1 MHz
    Northbridge Intel 5520 rev. 22
    Memory Frequency 800.0 MHz (2:8)
    Memory Type DDR3
    Memory Size 49152 MBytes
    Channels Triple
    Number of processors 2
    Number of threads 24
    Number of threads 12 (max 32)
    L2 cache 6 x 256 KBytes, 8-way set associative, 64-byte line size
    Package (platform ID) Socket 1366 LGA (0x0)
    Temperature 0 60°C (139°F) [0x3C] (CPU1 PWM)
    Temperature 1 59°C (138°F) [0x3B] (System 2)
    Temperature 0 53°C (127°F) [0x35] (CPU0 Socket)
    Temperature 1 52°C (125°F) [0x34] (CPU0 PWM)
    Temperature 2 44°C (111°F) [0x2C] (System)
  9. Joe Average
    Joe Average Newbie
    Hadn't been around here in a long time (last post in Nov 2009) but I had to pop in and say I had asked clayton006 to post his results of that monster freakin' dual hex-core 24-thread x264 crunching monster machine (note the 48GB of RAM too)... ;)
    Didn't want to thread-crap or anything but, damn, is that some powerful machine or what? Even at stock speeds - since he's at 4 GHz for a stable overclock I'm assuming - that machine would obviously be at the top of the 2nd pass results. I asked him (at another forum) if he'd do a proper test with the stock speeds so I suppose if he can he will probably do so.
    Geez... what a machine. Yes, I'm a Geek, can't help it. :p
  10. clayton006
    clayton006 Newbie
    I may get around to doing a stock clock test. I've had these numbers dialed in for a while so this overclock is rock solid.
  11. POLICE
    POLICE Newbie
    Hi! my result is:
    x264 HD BENCHMARK 4.0 RESULTS
    Pass 1
    encoded 1442 frames, 112.55 fps, 3911.63 kb/s
    encoded 1442 frames, 110.98 fps, 3911.63 kb/s
    encoded 1442 frames, 111.16 fps, 3911.63 kb/s
    encoded 1442 frames, 110.10 fps, 3911.63 kb/s
    Pass 2
    encoded 1442 frames, 26.68 fps, 3960.14 kb/s
    encoded 1442 frames, 26.71 fps, 3959.61 kb/s
    encoded 1442 frames, 26.45 fps, 3960.14 kb/s
    encoded 1442 frames, 26.57 fps, 3959.15 kb/s
    System Details
    Intel I7 930 @ Stock 2.8 Ghz
    2x3 GB DDR3 G.Skill 1600mhz
    Gigabyte UD7
  12. Adrian Wong
    Thanks, guys!! Keep 'em coming! :thumb:
  13. Pridebowl
    Pridebowl Newbie
    HP Z600 Workstation Xeon E5540
    Pass 1
    encoded 1442 frames, 105.13 fps, 3912.26 kb/s
    encoded 1442 frames, 107.04 fps, 3912.26 kb/s
    encoded 1442 frames, 106.18 fps, 3912.26 kb/s
    encoded 1442 frames, 106.84 fps, 3912.26 kb/s
    Pass 2
    encoded 1442 frames, 20.23 fps, 3961.33 kb/s
    encoded 1442 frames, 20.27 fps, 3961.46 kb/s
    encoded 1442 frames, 20.19 fps, 3961.95 kb/s
    encoded 1442 frames, 20.59 fps, 3961.36 kb/s
    System Details
    HP Z600 Workstation
    Name Intel Xeon E5540
    Codename Gainestown
    Specification Intel(R) Xeon(R) CPU E5540 @ 2.53GHz
    Core Stepping D0
    Technology 45 nm
    Stock frequency 2533 MHz
    Core Speed 2626.1 MHz
    Northbridge Intel 5520 rev. 13
    CAS# latency (CL) 7.0
    RAS# to CAS# delay (tRCD) 7
    RAS# Precharge (tRP) 7
    Cycle Time (tRAS) 20
    Memory Frequency 525.2 MHz (2:8)
    Memory Type DDR3
    Memory Size 12288 MBytes
    Channels Triple
    Number of threads 4
    Number of threads 4 (max 16)
  14. Pridebowl
    Pridebowl Newbie
    HP Z400 Workstation with Intel Xeon W3565
    Pass 1
    encoded 1442 frames, 121.78 fps, 3912.26 kb/s
    encoded 1442 frames, 131.86 fps, 3912.26 kb/s
    encoded 1442 frames, 131.29 fps, 3912.26 kb/s
    encoded 1442 frames, 131.68 fps, 3912.26 kb/s
    Pass 2
    encoded 1442 frames, 25.81 fps, 3961.41 kb/s
    encoded 1442 frames, 25.84 fps, 3961.71 kb/s
    encoded 1442 frames, 25.81 fps, 3961.55 kb/s
    encoded 1442 frames, 25.61 fps, 3961.28 kb/s
    System Details
    HP Z400 Workstation
    Name Intel Xeon W3565
    Codename Bloomfield
    Specification Intel(R) Xeon(R) CPU W3565 @ 3.20GHz
    Core Stepping D0
    Technology 45 nm
    Stock frequency 3200 MHz
    Core Speed 3331.8 MHz
    Northbridge Intel X58 rev. 13
    Memory Frequency 533.1 MHz (2:8)
    Memory Type DDR3
    Channels Triple
    Number of threads 4
    Package (platform ID) Socket 1366 LGA (0x1)
  15. Adrian Wong
    Thanks for the results, Pridebowl! Keep 'em coming!! :thumb:
  16. unilib
    unilib Newbie
    Please do NOT compare it with older versions of the benchmark!
    Please copy/paste everything below the line to to report your data
    to http://forums.techarp.com/reviews-articles/26363-x264-hd-benchmark-4-0-a.html
    Pass 1
    encoded 1442 frames, 164.46 fps, 3911.63 kb/s
    encoded 1442 frames, 162.99 fps, 3911.63 kb/s
    encoded 1442 frames, 166.03 fps, 3911.63 kb/s
    encoded 1442 frames, 161.28 fps, 3911.63 kb/s
    Pass 2
    encoded 1442 frames, 42.27 fps, 3959.36 kb/s
    encoded 1442 frames, 40.36 fps, 3959.72 kb/s
    encoded 1442 frames, 38.03 fps, 3959.89 kb/s
    encoded 1442 frames, 38.18 fps, 3958.68 kb/s
    System Details
    Name Intel Processor
    Specification Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
    Core Stepping D2
    Technology 32 nm
    Memory Type
    Memory Size 8172 MBytes
    Number of threads 8
    Package
  17. Adrian Wong
    Thanks for the results, but can you tell us more about your system?
    For example, what clock speed are your CPU and memory modules running at? Also, did you disable Turbo Boost?
    Thanks!
  18. zealotxx
    zealotxx Newbie
    Pass 1
    encoded 1442 frames, 153.08 fps, 3912.22 kb/s
    encoded 1442 frames, 159.25 fps, 3912.22 kb/s
    encoded 1442 frames, 156.94 fps, 3912.22 kb/s
    encoded 1442 frames, 157.63 fps, 3912.22 kb/s
    Pass 2
    encoded 1442 frames, 76.84 fps, 3966.14 kb/s
    encoded 1442 frames, 75.72 fps, 3967.43 kb/s
    encoded 1442 frames, 76.30 fps, 3967.21 kb/s
    encoded 1442 frames, 76.05 fps, 3967.71 kb/s
    System Details
    Specification Genuine Intel(R) CPU 000 @ 2.67GHz (Engineering Sample)
    Core Stepping A0
    Core Stepping A0
    Technology 32 nm
    Technology 32 nm
    Core Speed 2077.0 MHz
    Core Speed 3634.7 MHz
    Command Rate 2T
    Command Rate 2T
    Command Rate 2T
    Command Rate 2T
    Command Rate 2T
    Command Rate 2T
    Memory Frequency 519.2 MHz (2:6)
    Memory Type DDR3
    Memory Size 24576 MBytes
    Channels Triple
    Temperature 0 55癈 (130癋) [0x37] (CPU1 PWM)
    Temperature 1 54癈 (129癋) [0x36] (System 2)
    Temperature 0 44癈 (111癋) [0x2C] (CPU0 Socket)
    Temperature 1 53癈 (127癋) [0x35] (CPU0 PWM)
    Temperature 2 35癈 (94癋) [0x23] (System)
  19. Adrian Wong
    Thanks for the results, zealotxx!
    BTW, did you disable Turbo Boost for this test?
  20. Umit Ozyurek
    Umit Ozyurek Newbie
    to ...
    Pass 1
    encoded 1442 frames, 139.22 fps, 3913.31 kb/s
    encoded 1442 frames, 140.26 fps, 3913.31 kb/s
    encoded 1442 frames, 140.90 fps, 3913.31 kb/s
    encoded 1442 frames, 139.42 fps, 3913.31 kb/s
    Pass 2
    encoded 1442 frames, 38.68 fps, 3959.16 kb/s
    encoded 1442 frames, 38.60 fps, 3958.50 kb/s
    encoded 1442 frames, 38.51 fps, 3959.65 kb/s
    encoded 1442 frames, 38.40 fps, 3960.87 kb/s
    System Details
    CPU-Z Validator ID : 1962969
    CPU PSN : AMD Phenom II X6 1090T Processor
    Freq : 3999.99 MHz (250 * 16)
    MB Brand : Gigabyte
    MB Model : GA-MA785GT-UD3H
    RAM : 8192 MB DDR3 Dual Channel
    RAM Speed : 666.7 MHz[1333MHz] (3:8) @ 9-9-9-30
    Unoverclocked results was added on page 1 before.
    Have a nice day all! :)
