about x264 hd benchmark Here's my results on: MB: Asrock 4CoreDual-SATA2. Memory: DDR2 1024 @ 346 MHz @ 4-4-4-12-2T CPU: Intel Core 2 Duo E4700 @ 2.60GHz OS: Microsoft Windows XP Home Edition Service Pack 3 (Build 2600) Some opinions: I disagree what user "far.in.out" said about being a marketing tool, but he is right about using more complex settings and thus more image quality outputs. About using only 1-pass, i think some of us wants to test also 2-pass, it should be used as a choice (see choice command in Batch programming)for every user. Also should ask user in Batch if they overclocked the PC and include this in the report. I ask you to grep only useful information from CPU-Z (so that user don't needed to include information such, motherboard, multiplier x FSB) such as (IMO i think this makes more sense and brings clarity): I used for this example my motherboard, which isn't a bright one. From Hardware Monitors: DMI Baseboard vendor ASRock model 4CoreDual-SATA2. From CPU: Name Intel Core 2 Duo E4700 Codename Conroe Specification Intel(R) Core(TM)2 Duo CPU E4700 @ 2.60GHz Package (platform ID) Socket 775 LGA (0x0) Stock frequency 2600 MHz Core Speed 2600.1 MHz Multiplier x FSB 10.0 x 260.0 MHz Multiplier x FSB 10.0 x 260.0 MHz L1 Data cache 2 x 32 KBytes, 8-way set associative, 64-byte line size L1 Instruction cache 2 x 32 KBytes, 8-way set associative, 64-byte line size L2 cache 2048 KBytes, 8-way set associative, 64-byte line size From Chipset: Northbridge VIA PT880 Pro rev. 00 Southbridge VIA VT8237S rev. 00 Graphic Interface PCI-Express Memory Type DDR2 Memory Size 1024 MBytes Memory Frequency 346.7 MHz (3:4) DRAM Interleave 4-way CAS# latency (CL) 4.0 RAS# to CAS# delay (tRCD) 4 RAS# Precharge (tRP) 4 Cycle Time (tRAS) 12 Command Rate (CR) 2T From Memory SPD: JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency JEDEC #1 3.0-3-3-9-12 @ 200 MHz JEDEC #2 4.0-4-4-12-16 @ 266 MHz JEDEC #3 5.0-5-5-18-23 @ 400 MHz From Hardware Monitors: Temperature 0 32°C (89°F) [0x20] (TMPIN0) Temperature 1 36°C (96°F) [0x48] (TMPIN1) Fan 1 2411 RPM [0x46] (FANIN1) From Display Adapters (why i included Display Adapters ? Because of CUDA, search google about how it affects speed encoding, but not sure if x264 supports it): Display adapter 0 Name NVIDIA GeForce 8600 GT Revision A2 Codename G84 Technology 80 nm Memory size 256 MB Memory bus width 128 bits PCI device bus 2 (0x2), device 0 (0x0), function 0 (0x0) Vendor ID 0x10DE (0x1458) Model ID 0x0402 (0x3452) Performance Level 0 Core clock 600.0 MHz Shader clock 1450.0 MHz Memory clock 720.0 MHz From Software: Windows Version Microsoft Windows XP Home Edition Service Pack 3 (Build 2600) DirectX Version 9.0c x264 HD BENCHMARK 4.0 RESULTS Please do NOT compare it with older versions of the benchmark! Please copy/paste everything below the line to to report your data to (i deleted url so that i can post, i'm new registered on this site and it don't let me) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 44.11 fps, 3909.88 kb/s encoded 1442 frames, 44.52 fps, 3909.88 kb/s encoded 1442 frames, 44.65 fps, 3909.88 kb/s encoded 1442 frames, 44.78 fps, 3909.79 kb/s Pass 2 ------ encoded 1442 frames, 8.65 fps, 3962.61 kb/s encoded 1442 frames, 8.66 fps, 3962.50 kb/s encoded 1442 frames, 8.66 fps, 3962.70 kb/s encoded 1442 frames, 8.66 fps, 3962.70 kb/s System Details -------------- Name Intel Core 2 Duo E4700 Codename Conroe Specification Intel(R) Core(TM)2 Duo CPU E4700 @ 2.60GHz Core Stepping G0 Technology 65 nm Stock frequency 2600 MHz Core Speed 2600.2 MHz FID range 6.0x - 13.0x Northbridge VIA PT880 Pro rev. 00 Southbridge VIA VT8237S rev. 00 CAS# latency (CL) 4.0 RAS# to CAS# delay (tRCD) 4 RAS# Precharge (tRP) 4 Cycle Time (tRAS) 12 Command Rate (CR) 2T Memory Frequency 346.7 MHz (3:4) Memory Type DDR2 Memory Size 1024 MBytes Channels Dual Windows Version Microsoft Windows XP Home Edition Service Pack 3 (Build 2600) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 2048 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T Package (platform ID) Socket 775 LGA (0x0) Temperature 0 35°C (94°F) [0x23] (TMPIN0) Temperature 1 47°C (115°F) [0x5D] (TMPIN1)
Thanks, DexterLab23! Well, offering an option is nice but for the purpose of easy comparison, I think we should have the same set of results from everyone. Otherwise, some users might submit only partial results which would make comparisons difficult.
Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 57.03 fps, 3909.84 kb/s encoded 1442 frames, 55.92 fps, 3909.87 kb/s encoded 1442 frames, 56.78 fps, 3909.87 kb/s encoded 1442 frames, 55.95 fps, 3909.89 kb/s Pass 2 ------ encoded 1442 frames, 10.61 fps, 3962.62 kb/s encoded 1442 frames, 10.66 fps, 3962.67 kb/s encoded 1442 frames, 10.66 fps, 3962.78 kb/s encoded 1442 frames, 10.65 fps, 3962.48 kb/s System Details -------------- Processors Information ------------------------------------------------------------------------- Name AMD Athlon II X2 220 Codename Regor Specification AMD Athlon(tm) II X2 220 Processor Package Socket AM3 (938) CPUID F.6.3 Extended CPUID 10.6 Brand ID 12 Core Stepping DA-C3 Technology 45 nm TDP Limit 64 Watts Core Speed 3261.0 MHz Multiplier x FSB 14.0 x 232.9 MHz HT Link speed 931.7 MHz Stock frequency 2800 MHz Chipset ------------------------------------------------------------------------- Northbridge NVIDIA MCP61 rev. A3 Southbridge NVIDIA MCP61 rev. A2 Graphic Interface PCI-Express PCI-E Link Width x16 PCI-E Max Link Width x16 Memory Type DDR3 Memory Size 4096 MBytes Channels Dual, (Unganged) Memory Frequency 621.1 MHz (3:8) CAS# latency (CL) 7.0 RAS# to CAS# delay (tRCD) 7 RAS# Precharge (tRP) 7 Cycle Time (tRAS) 20 Bank Cycle Time (tRC) 27 Command Rate (CR) 1T Uncore Frequency 1863.4 MHz Software ------------------------------------------------------------------------- Windows Version Microsoft Windows 7 (6.1) Home Premium Edition Service Pack 1 (Build 7601) x64 DirectX Version 11.0
2600k @5175Mhz Details of computer : Asus P8P67 MB Intel 2600k processor Corsair Vengeance Blue 8GB DDR3 1600MHz, 9-9-9-24, 1.5V CPU overclocked at ~5175 Mhz. Multiplier set to 50 and BCLK at 103.5 Mhz. Hyperthreading disabled and Intel Turbo Boost disabled. Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 212.50 fps, 3912.26 kb/s encoded 1442 frames, 213.98 fps, 3912.26 kb/s encoded 1442 frames, 212.00 fps, 3912.26 kb/s encoded 1442 frames, 212.97 fps, 3912.26 kb/s Pass 2 ------ encoded 1442 frames, 44.02 fps, 3961.66 kb/s encoded 1442 frames, 44.08 fps, 3961.68 kb/s encoded 1442 frames, 44.00 fps, 3961.74 kb/s encoded 1442 frames, 44.10 fps, 3961.80 kb/s System Details -------------- Name Intel Core i7 2600K product System Product Name Codename Sandy Bridge Specification Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz Specification PC3-12800 Specification PC3-12800 Core Stepping D2 Technology 32 nm Stock frequency 3400 MHz Core Speed 1655.4 MHz Northbridge Intel Sandy Bridge rev. 09 Southbridge Intel P67 rev. B3 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 24 Command Rate (CR) 2T Command Rate 2T Command Rate 2T Memory Frequency 827.6 MHz (1:6) Memory Type DDR3 Memory Size 8192 MBytes Channels Dual
Interesting, my pass 2 results are lower than the reported 49.77 for the 2600k at 5.00 GHz. Wonder what is different. However my first pass has higher results than what was reported for 2600k at 5.00 GHz.
Here are mine Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 191.17 fps, 3913.50 kb/s encoded 1442 frames, 187.54 fps, 3913.50 kb/s encoded 1442 frames, 190.16 fps, 3913.50 kb/s encoded 1442 frames, 192.11 fps, 3913.50 kb/s Pass 2 ------ encoded 1442 frames, 56.62 fps, 3956.49 kb/s encoded 1442 frames, 56.78 fps, 3955.30 kb/s encoded 1442 frames, 56.67 fps, 3954.36 kb/s encoded 1442 frames, 56.78 fps, 3956.57 kb/s System Details -------------- Name Intel Core i7 970 product System Product Name Codename Gulftown Specification Intel(R) Core(TM) i7 CPU 970 @ 3.20GHz Specification PC3-16000 Specification PC3-16000 Specification PC3-16000 Core Stepping B1 Technology 32 nm Stock frequency 3200 MHz Core Speed 4252.6 MHz Northbridge Intel X58 rev. 13 Southbridge Intel 82801JR (ICH10R) rev. 00 CAS# latency (CL) 6.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 6 Cycle Time (tRAS) 24 Command Rate (CR) 2T Command Rate 1T Command Rate 1T Command Rate 1T Memory Frequency 1012.5 MHz (2:10) Memory Type DDR3 Memory Size 6144 MBytes Channels Triple Windows Version Microsoft Windows 7 (6.1) Ultimate Edition Service Pack 1 (Build 7601) Number of processors 1 Number of threads 12 Number of threads 12 (max 32) L2 cache 6 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES Package (platform ID) Socket 1366 LGA (0x1) Temperature 0 41°C (105°F) [0x29] (SYSTIN) Temperature 1 42°C (106°F) [0x53] (CPUTIN) Temperature 2 36°C (96°F) [0x48] (AUXTIN) Temperature 0 55°C (130°F) [0x37] (SB) Temperature 1 65°C (148°F) [0x41] (NB)
Results on DELL T5400 Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 94.94 fps, 3911.63 kb/s encoded 1442 frames, 96.33 fps, 3911.63 kb/s encoded 1442 frames, 96.43 fps, 3911.63 kb/s encoded 1442 frames, 95.74 fps, 3911.63 kb/s Pass 2 ------ encoded 1442 frames, 33.01 fps, 3960.20 kb/s encoded 1442 frames, 33.02 fps, 3959.58 kb/s encoded 1442 frames, 33.07 fps, 3960.04 kb/s encoded 1442 frames, 33.16 fps, 3958.51 kb/s System Details -------------- Name Intel Xeon E5430 Name Intel Xeon E5430 Codename Harpertown Codename Harpertown Specification Intel(R) Xeon(R) CPU E5430 @ 2.66GHz Specification Intel(R) Xeon(R) CPU E5430 @ 2.66GHz Core Stepping C0 Core Stepping C0 Technology 45 nm Technology 45 nm Manufacturer (ID) Nanya Technology (7F7F7F0B00000000) Manufacturer (ID) Nanya Technology (7F7F7F0B00000000) Stock frequency 2666 MHz Stock frequency 2666 MHz Core Speed 1995.1 MHz Core Speed 1995.1 MHz FID range 6.0x - 8.0x FID range 6.0x - 8.0x Northbridge Intel 5400A rev. C0 Southbridge Intel 6321ESB rev. 09 CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 5 RAS# Precharge (tRP) 5 Cycle Time (tRAS) 15 Memory Frequency 332.5 MHz (1:1) Memory Type FB-DDR2 Memory Size 3072 MBytes Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600) Number of processors 2 Number of threads 8 Number of threads 4 (max 4) Number of threads 4 (max 4) L2 cache 2 x 6144 KBytes, 24-way set associative, 64-byte line size L2 cache 2 x 6144 KBytes, 24-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T, VT-x Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, EM64T, VT-x Package (platform ID) Socket 771 LGA (0x6) Package (platform ID) Socket 771 LGA (0x6) Temperature 0 69°C (155°F) [0x89] (core) Temperature 0 68°C (153°F) [0x87] (core) Temperature 0 65°C (148°F) [0x81] (core) Temperature 0 64°C (146°F) [0x7F] (core)
Please note for this benchmark the CPU is SLIGHTLY (86.1Mhz) overclocked due to the XMMS RAM profile (DDR3 2000). Since AMD Phenom 2 processors memory controller does not support DDR3-2000, the motherboard BIOS rised the base frequency from 200Mhz to 250 resulting in a huge overclock. so i've lowered the CPU multiplier to best match the stock frequency. Also, CPU-Z wrongly detected the CPU name (1105T in place of 1100T). x264 HD BENCHMARK 4.0 RESULTS ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 131.68 fps, 3913.31 kb/s encoded 1442 frames, 131.31 fps, 3913.31 kb/s encoded 1442 frames, 131.68 fps, 3913.31 kb/s encoded 1442 frames, 131.86 fps, 3913.31 kb/s Pass 2 ------ encoded 1442 frames, 34.05 fps, 3957.14 kb/s encoded 1442 frames, 33.96 fps, 3959.35 kb/s encoded 1442 frames, 33.96 fps, 3959.26 kb/s encoded 1442 frames, 33.97 fps, 3956.64 kb/s System Details -------------- Name AMD Phenom II X6 1105T Codename Thuban Specification AMD Phenom(tm) II X6 1100T Processor Specification PC3-16000 Specification PC3-16000 Specification PC3-16000 Specification PC3-16000 Core Stepping PH-E0 Technology 45 nm Stock frequency 3300 MHz Core Speed 3386.1 MHz Northbridge ATI ID5A14 rev. 02 Southbridge AMD SB850 rev. 40 CAS# latency (CL) 10.0 RAS# to CAS# delay (tRCD) 10 RAS# Precharge (tRP) 10 Cycle Time (tRAS) 27 Command Rate (CR) 2T Command Rate 2T Command Rate 2T Command Rate 2T Command Rate 2T Memory Frequency 1003.3 MHz (1:4) Memory Type DDR3 Memory Size 8192 MBytes Channels Dual, (Unganged) Windows Version Microsoft Windows 7 (6.1) Ultimate Edition Service Pack 1 (Build 7601) Number of processors 1 Number of threads 6 Number of threads 6 (max 6) L2 cache 6 x 512 KBytes, 16-way set associative, 64-byte line size Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64, AMD-V Package Socket AM3 (938) Package Type 0x1 Temperature 0 39°C (102°F) [0x27] (CPU) Temperature 1 34°C (93°F) [0x22] (Mainboard)
my results Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 43.75 fps, 3909.88 kb/s encoded 1442 frames, 44.44 fps, 3909.89 kb/s encoded 1442 frames, 44.27 fps, 3909.87 kb/s encoded 1442 frames, 44.23 fps, 3909.88 kb/s Pass 2 ------ encoded 1442 frames, 7.94 fps, 3962.53 kb/s encoded 1442 frames, 7.92 fps, 3962.56 kb/s encoded 1442 frames, 7.92 fps, 3962.62 kb/s encoded 1442 frames, 7.91 fps, 3962.62 kb/s System Details -------------- Basic Hardware information Motherboard: EP45-UD3P Basic I/O System(BIOS): Award Modular BIOS v6.00PG Central Processing Unit(CPU): Intel(R) Core(TM)2 Duo CPU E6550 @ 2.33GHz Physical Memory X 2 2GB 2GB Hard Disk X 3 Maxtor 6 Y080P0 SCSI Disk Device (76.21GB) SATA ST31000528AS SCSI Disk Device (0.91TB) SATA WDC WD800JD-22MS SCSI Disk Device (74.53GB) Video Card: ATI Radeon HD 3800 Series Monitor: Generic PnP Monitor Audio Device X 2 ATI HDMI Audio Realtek High Definition Audio Network Adapter Local Area Connection - Realtek PCIe GBE Family Controller (Media disconnected) Local Area Connection 2 - Realtek PCIe GBE Family Controller #2 (Connected) Modem: Standard Modem over Bluetooth link Keyboard: USB Input Device Keyboard: USB Input Device (Logitech Download Assistant) Mouse: Logitech HID-compliant Unifying Mouse Mouse: HID-compliant mouse Hardware Score (Base score: 5.6) Processor (Calculations per second): 5.6 Memory (Memory Operation per second): 6.3 Graphics (Desktop performance for Windows Aero): 6.9 Gaming graphics (3D business and gaming graphics performance): 6.9 Primary hard disk (Disk data transfer rate): 5.9
Intel Core i7 2,8 Ghz OC @4,00 Ghz Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 155.02 fps, 3912.26 kb/s encoded 1442 frames, 160.54 fps, 3912.26 kb/s encoded 1442 frames, 160.53 fps, 3912.26 kb/s encoded 1442 frames, 161.33 fps, 3912.26 kb/s Pass 2 ------ encoded 1442 frames, 31.28 fps, 3961.62 kb/s encoded 1442 frames, 31.25 fps, 3961.81 kb/s encoded 1442 frames, 31.32 fps, 3961.54 kb/s encoded 1442 frames, 31.29 fps, 3961.41 kb/s System Details -------------- Name Intel Core i7 860 Codename Lynnfield Specification Intel(R) Core(TM) i7 CPU 860 @ 2.80GHz Core Stepping B1 Technology 45 nm manufacturer Gigabyte Technology Co., Ltd. vendor Gigabyte Technology Co., Ltd. manufacturer Gigabyte Technology Co., Ltd. Stock frequency 2800 MHz Core Speed 4000.0 MHz Northbridge Intel DMI Host Bridge rev. 11 Southbridge Intel P55 rev. 06 CAS# latency (CL) 8.0 RAS# to CAS# delay (tRCD) 8 RAS# Precharge (tRP) 8 Cycle Time (tRAS) 20 Command Rate (CR) 1T Memory Frequency 800.0 MHz (2:8) Memory Type DDR3 Memory Size 4096 MBytes Channels Dual Windows Version Microsoft Windows 7 (6.1) Ultimate Edition Service Pack 1 (Build 7601) Number of processors 1 Number of threads 4 Number of threads 4 (max 16) L2 cache 4 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x Package (platform ID) Socket 1156 LGA (0x1) Temperature 0 44°C (111°F) [0x2C] (TMPIN0) Temperature 1 25°C (76°F) [0x19] (TMPIN1) Temperature 2 47°C (116°F) [0x2F] (TMPIN2)
Thanks, guys!! Keep 'em coming! BTW, please remember to turn off Turbo Boost (for Intel) or Turbo Core (for AMD) when you test!
AMD Phenom II X4 965 BE - not OC'd Pass 1 looks 2 fps faster than 955 BE on the list, while Pass 2 is 1 fps faster.
Progress does not stand still evolving technology, increasing computing power of a PC. In this regard, I propose to replace the encoder used in the test x264_8bit, at the same x264_10bit, which is not only more resource demanding, but also better quality. You can download it here: x264.nl
EVGA SR-2 mobo + 1 x CPU (O.C.) with ECC RAM: Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 152.54 fps, 3913.50 kb/s encoded 1442 frames, 155.10 fps, 3913.50 kb/s encoded 1442 frames, 154.32 fps, 3913.50 kb/s encoded 1442 frames, 154.08 fps, 3913.50 kb/s Pass 2 ------ encoded 1442 frames, 47.79 fps, 3957.75 kb/s encoded 1442 frames, 47.69 fps, 3955.46 kb/s encoded 1442 frames, 47.72 fps, 3954.50 kb/s encoded 1442 frames, 47.67 fps, 3955.87 kb/s System Details -------------- Name Intel Xeon E5620 Codename Westmere-EP Specification Intel(R) Xeon(R) CPU E5645 @ 2.40GHz Core Stepping B1 Technology 32 nm Stock frequency 2400 MHz Core Speed 3420.5 MHz Northbridge Intel 5520 rev. 22 Southbridge Intel 82801JR (ICH10R) rev. 00 CAS# latency (CL) 9.0 RAS# to CAS# delay (tRCD) 9 RAS# Precharge (tRP) 9 Cycle Time (tRAS) 25 Command Rate (CR) 1T Memory Frequency 760.1 MHz (2:8) Memory Type DDR3 Memory Size 12288 MBytes Channels Triple Windows Version Microsoft Windows Server 2008 R2 Datacenter Edition (Full) Service Pack 1 (Build 7601) Number of processors 1 Number of threads 12 Number of threads 12 (max 32) L2 cache 6 x 256 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES Package (platform ID) Socket 1366 LGA (0x0) Temperature 0 39°C (102°F) [0x27] (CPU1 PWM) Temperature 1 39°C (102°F) [0x27] (System 2) Temperature 0 47°C (116°F) [0x2F] (CPU0 Socket) Temperature 1 41°C (105°F) [0x29] (CPU0 PWM) Temperature 2 25°C (76°F) [0x19] (System) Temperature 0 46°C (114°F) [0xC2E0] (core) Temperature 0 46°C (113°F) [0xC2D8] (core) Temperature 0 46°C (115°F) [0xC2E4] (core)
Intel Core 2 Duo E4300 Results for x264.exe r1913 ========================== Pass 1 ------ encoded 1442 frames, 32.40 fps, 3909.86 kb/s encoded 1442 frames, 32.50 fps, 3909.81 kb/s encoded 1442 frames, 32.40 fps, 3909.85 kb/s encoded 1442 frames, 32.42 fps, 3909.88 kb/s Pass 2 ------ encoded 1442 frames, 6.00 fps, 3962.29 kb/s encoded 1442 frames, 6.00 fps, 3962.76 kb/s encoded 1442 frames, 6.02 fps, 3962.12 kb/s encoded 1442 frames, 5.99 fps, 3962.73 kb/s System Details -------------- Name Intel Core 2 Duo E4300 Codename Conroe Specification Intel(R) Core(TM)2 CPU 4300 @ 1.80GHz Core Stepping L2 Technology 65 nm manufacturer Gigabyte Technology Co., Ltd. vendor Gigabyte Technology Co., Ltd. manufacturer Gigabyte Technology Co., Ltd. Stock frequency 1800 MHz Core Speed 1205.8 MHz FID range 6.0x - 9.0x Northbridge Intel i945G rev. A2 Southbridge Intel 82801GB (ICH7/R) rev. A1 CAS# latency (CL) 5.0 RAS# to CAS# delay (tRCD) 4 RAS# Precharge (tRP) 4 Cycle Time (tRAS) 12 Memory Frequency 268.0 MHz (3:4) Memory Type DDR2 Memory Size 2048 MBytes Channels Dual Windows Version Microsoft Windows XP Professional Service Pack 3 (Build 2600) Number of processors 1 Number of threads 2 Number of threads 2 (max 2) L2 cache 2048 KBytes, 8-way set associative, 64-byte line size Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T Package (platform ID) Socket 775 LGA (0x0) Temperature 2 46°C (114°F) [0x2E] (TMPIN2)
